cgma
CADeferredAttrib.hpp
00001 //- Class:          CADeferredAttrib
00002 //- Owner:          Tim Tautges
00003 //- Description:    Cubit attribute for storing attributes that will be used later,
00004 //-       i.e. for entities which don't yet exist in the model
00005 //- Checked by:
00006 //- Version:
00007 //-
00008 //- Deferred attributes are used to store data on one solid model entity
00009 //- which actually apply to a different entity, one which doesn't exist
00010 //- in the solid model as stored (usually something like virtual geometry)
00011 //-
00012 //- This attribute saves/updates something like this:
00013 //- 1) Normal attribute (mesh interval, scheme, etc.) updates
00014 //- 2) Normal attribute writes:
00015 //-    - creates simple attribute, csa_ptr, and passes to
00016 //-      GeometryEntity::append_simple_attrib
00017 //-    - For virtual entities, this is implemented in
00018 //-      VirtualEntity::append_simple_attrib_virt
00019 //- 3) Inside VE::append_simple_attrib_virt, the simple attribute is combined
00020 //-    with a uid for the owning ref entity and the two are used to make a
00021 //-    new *simple* deferred attribute
00022 //- 4) The simple deferred attribute is put onto the first underlying entity
00023 //-    using TopologyBridge::append_simple_attrib
00024 //-
00025 //- To restore:
00026 //- 1) Take dcsa, create CADeferredAttrib from it, and put it on owning entity:
00027 //-    - CADA stores uid from dcsa
00028 //-    - Then the dcsa is converted to a csa (CADA stuff removed) and stored
00029 //-      in CADA on owning entity
00030 //- 2) When virtual geometry is created from actuating an attribute, CADA is notified;
00031 //-    CADA goes through the list of CADA's, looking for any that apply to the
00032 //-    new entity (based on uid)
00033 //- 3) If any CADA's are found for the new entity, their csa data are converted to
00034 //-    a real CA, and that CA is put on the unactuatedCAs list in CADA.
00035 //- 4) At the end of CubitAttribUser::auto_actuate_cubit_attrib, CADA::cleanup_cadas
00036 //-    is called, which keeps going through the unactuatedCAs list until nothing
00037 //-    new happens (no new unactuated cas)
00038 //-
00039
00040 #ifndef CA_DEFERRED_ATTRIB_HPP
00041 #define CA_DEFERRED_ATTRIB_HPP
00042
00043 #include "CubitAttrib.hpp"
00044 #include <vector>
00045
00046 #include "CADefines.hpp"
00047
00048 class RefEntity;
00049 class CubitSimpleAttrib;
00050
00051 class CUBIT_GEOM_EXPORT CADeferredAttrib: public CubitAttrib
00052 {
00053 private:
00054
00055   int uniqueId;
00056     //- the deferred id tag for an entity
00057
00058   CubitSimpleAttrib thisCSA;
00059     //- the deferred attribute information
00060
00061   static std::vector<CADeferredAttrib*> allCADeferredAttribs;
00062     //- list of all CADA's; used in actuate_all function
00063
00064   static std::vector<CubitAttrib*> unactuatedCAs;
00065     //- list of new CubitAttrib's that haven't yet been actuated
00066
00067   static CubitStatus cleanup_cadas_private(const CubitBoolean from_constructor,
00068                                            const CubitBoolean after_geom_changes);
00069     //- moves between the global CADA list and the unactuated list:
00070     //-
00071     //- 1. tries to actuate all CADAs on unactuated list
00072     //- 2. tries to assign_to_owner all CADAs on global list
00073 public:
00074   virtual ~CADeferredAttrib();
00075
00076 //  CADeferredAttrib(RefEntity*);
00077
00078   CADeferredAttrib(RefEntity*, const CubitSimpleAttrib&);
00079     //- make a CADA from a simple attribute
00080
00081  CubitStatus actuate();
00082
00083   CubitStatus update();
00084
00085   CubitStatus reset();
00086
00087   CubitSimpleAttrib cubit_simple_attrib();
00088
00089   int unique_id() { return uniqueId;}
00090
00091   void unique_id (int id) {uniqueId = id;}
00092 private:
00093 //  CubitSimpleAttrib *this_csa() {return thisCSA;};
00094
00095   CubitStatus init_csa(const CubitSimpleAttrib &csa_ptr);
00096
00097   int int_attrib_type() {return CA_DEFERRED_ATTRIB;};
00098
00099   CubitStatus assign_to_owner(CubitAttribUser *owner = NULL);
00100     //- looks for an entity with the right uid, assigns itself to
00101     //- that entity if found
00102
00103   static CubitStatus get_deferred_attribs(const int uid,
00104                                           std::vector<CADeferredAttrib*> &cada_list);
00105     //- given a uid, return a list of CADAs with corresponding uid
00106
00107 public:
00108   static std::vector<CubitAttrib*> get_unactuated_deferred_attribs() { return unactuatedCAs; }
00109     //- get all unactuated deferred attribs
00110
00111   static CubitStatus cleanup_cadas(const CubitBoolean from_constructor,
00112                                    const CubitBoolean after_geom_changes);
00113     //- moves between the global CADA list and the unactuated list:
00114     //-
00115     //- 1. tries to actuate all CADAs on unactuated list
00116     //- 2. tries to assign_to_owner all CADAs on global list
00117
00118   static CubitStatus owner_created(RefEntity *new_owner, const int uid);
00119     //- for a newly created ref entity, assigns any CADA with the same uid to the
00120     //- new entity
00121 private:
00122 //  static CubitBoolean is_match(CubitSimpleAttrib *csa_ptr, const int uid);
00123     //- returns true if the simple attribute is deferred type and matches
00124     //- uid
00125
00126   static CubitSimpleAttrib csa_from_dcsa(const CubitSimpleAttrib &csa_ptr,
00127                                           const int uid = 0);
00128     //- given a deferred csa, convert it to a normal csa by removing
00129     //- first type string and first int; if first int doesn't match
00130     //- uid passed in, NULL is returned
00131
00132 public:
00133   static CubitBoolean add_unactuated_ca(CubitAttrib *ca_ptr);
00134     //- adds an unactuated ca (usually one that didn't actuate because it
00135     //- depends on some piece of geometry that doesn't exist yet)
00136
00137   static CubitBoolean remove_unactuated_ca(CubitAttrib* ca_ptr);
00138     //- If attribute gets destroted before it actuates, remove it
00139     //- from the list.
00140 };
00141
00142 CubitAttrib* CADeferredAttrib_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa);
00143
00144 #endif
00145
