cgma
CAEntitySense.cpp
00001 //- File:           CAEntitySense.cpp
00002 //- Owner:          Corey Ernst
00003 //- Description:    Cubit Attribute for entity colors.
00004 //- Checked By:
00005 //- Version:
00006
00007 #include "CAEntitySense.hpp"
00008 #include "RefEntity.hpp"
00009 #include "RefEdge.hpp"
00010 #include "RefFace.hpp"
00011 #include "BridgeManager.hpp"
00012 #include "BasicTopologyEntity.hpp"
00013 #include "CastTo.hpp"
00014 #include "CubitMessage.hpp"
00015
00016
00017 CubitAttrib* CAEntitySense_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa)
00018 {
00019   return new CAEntitySense(entity, p_csa);
00020 }
00021
00022 CAEntitySense::CAEntitySense(RefEntity* new_attrib_owner,
00023                        const CubitSimpleAttrib &csa_ptr)
00024         : CubitAttrib(new_attrib_owner)
00025 {
00026   std::vector<int, std::allocator<int> > i_list = csa_ptr.int_data_list();
00027
00028   if( i_list.size() > 0)
00029   {
00030     int i =  i_list[0];
00031     if( i == -1 )
00032       entitySense = CUBIT_UNKNOWN;
00033     else if( i == 0 )
00034       entitySense = CUBIT_FORWARD;
00035     else if( i == 1 )
00036       entitySense = CUBIT_REVERSED;
00037   }
00038   else
00039     entitySense = CUBIT_UNKNOWN;
00040 }
00041
00042 CAEntitySense::CAEntitySense(RefEntity* new_attrib_owner)
00043        : CubitAttrib(new_attrib_owner)
00044 {
00045  entitySense = CUBIT_FORWARD;
00046 }
00047
00048 CAEntitySense::~CAEntitySense()
00049 {
00050 }
00051
00052
00053 CubitStatus CAEntitySense::actuate()
00054 {
00055    if ( hasActuated)
00056       return CUBIT_SUCCESS;
00057
00058    if ( !attribOwnerEntity )
00059       return CUBIT_FAILURE;
00060
00061    deleteAttrib = CUBIT_FALSE;
00062
00063    int dimension = attribOwnerEntity->dimension();
00064    if( 1 == dimension || 2 == dimension )
00065    {
00066      BasicTopologyEntity* bte_ptr = CAST_TO(attribOwnerEntity, BasicTopologyEntity);
00067      CubitSense tmp_sense = CUBIT_UNKNOWN;
00068      if( bte_ptr )
00069      {
00070        tmp_sense = bte_ptr->bridge_manager()->topology_bridge()->bridge_sense();
00071        if( tmp_sense != entitySense )
00072        {
00073          if( 1==dimension )
00074          {
00075            RefEdge *ref_edge = dynamic_cast<RefEdge*>( bte_ptr );
00076            ref_edge->reverse_tangent();
00077          }
00078          else if( 2 == dimension )
00079          {
00080            RefFace *ref_face = dynamic_cast<RefFace*>( bte_ptr );
00081            ref_face->reverse_normal();
00082          }
00083        }
00084      }
00085    }
00086
00087    hasActuated = CUBIT_TRUE;
00088    return CUBIT_SUCCESS;
00089 }
00090
00091 CubitStatus CAEntitySense::update()
00092 {
00093   int dimension = attribOwnerEntity->dimension();
00094   if( 1 == dimension || 2 == dimension )
00095   {
00096     BasicTopologyEntity* bte_ptr = CAST_TO(attribOwnerEntity, BasicTopologyEntity);
00097     entitySense = CUBIT_UNKNOWN;
00098     if( bte_ptr )
00099       entitySense = bte_ptr->bridge_manager()->topology_bridge()->bridge_sense();
00100   }
00101
00102   if( entitySense == CUBIT_FORWARD || entitySense == CUBIT_UNKNOWN )
00103     delete_attrib(CUBIT_TRUE);
00104
00105   return CUBIT_SUCCESS;
00106 }
00107
00108 CubitSimpleAttrib CAEntitySense::cubit_simple_attrib()
00109 {
00110   std::vector<CubitString> cs_list;
00111   std::vector<int, std::allocator<int> >  i_list;
00112
00113   i_list.push_back( entitySense );
00114
00115   cs_list.push_back(att_internal_name());
00116
00117   CubitSimpleAttrib csattrib_ptr(&cs_list, NULL, &i_list);
00118
00119   return csattrib_ptr;
00120 }
00121
00122 void CAEntitySense::print()
00123 {
00124     // print info on this attribute
00125
00126   PRINT_INFO("CAEntitySense: owner = %s %d:   color ",
00127              attribOwnerEntity->class_name(), attribOwnerEntity->id());
00128   if( entitySense == CUBIT_UNKNOWN )
00129      PRINT_INFO("                             CUBIT_UNKNOWN\n");
00130   else if( entitySense == CUBIT_FORWARD )
00131     PRINT_INFO("                             CUBIT_FORWARD\n");
00132   else if( entitySense == CUBIT_REVERSED )
00133     PRINT_INFO("                             CUBIT_REVERSED\n");
00134 }
