cgma
CASourceFeature.cpp
00001 #include "CASourceFeature.hpp"
00002 #include "BasicTopologyEntity.hpp"
00003 #include "Body.hpp"
00004 #include "RefEntityName.hpp"
00005 #include "CastTo.hpp"
00006 #include "CubitMessage.hpp"
00007 #include "TDSourceFeature.hpp"
00008
00009 CubitAttrib* CASourceFeature_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa)
00010 {
00011   return new CASourceFeature(entity, p_csa);
00012 }
00013
00014 CASourceFeature::CASourceFeature(RefEntity* new_attrib_owner,
00015                                  const CubitSimpleAttrib& csa_ptr)
00016                                  : CubitAttrib(new_attrib_owner)
00017 {
00018     sourceFeature = GeometryFeatureEngine::FEATURE_UNDEFINED;
00019
00020     if(!csa_ptr.isEmpty())
00021     {
00022
00023       const std::vector<CubitString>& cs_list = csa_ptr.string_data_list();
00024
00025       // step over the attribute type
00026       // now read name / option pairs
00027       if(cs_list.size()==2)
00028       {
00029         CubitString cs = cs_list[1];
00030           if (cs.length() == 0)
00031               PRINT_WARNING("Empty feature attribute for %s %d.\n",
00032               attribOwnerEntity->class_name(),
00033               attribOwnerEntity->id());
00034           else
00035               sourceFeature = string_to_feature_type(cs);
00036       }
00037       else
00038           deleteAttrib = CUBIT_TRUE;
00039     }
00040 }
00041
00042 CASourceFeature::~CASourceFeature()
00043 {
00044 }
00045
00046 CubitStatus CASourceFeature::actuate()
00047 {
00048     if (hasActuated == CUBIT_TRUE)
00049         return CUBIT_SUCCESS;
00050
00051     // create a TDSourceFeature for the entity, if it doesn't already
00052     // exist
00053     TDSourceFeature *source_feature_data =
00054         (TDSourceFeature *) attrib_owner()->get_TD(&TDSourceFeature::is_source_feature);
00055
00056     if (!source_feature_data)
00057     {
00058         // else make a new one
00059         TDSourceFeature* new_tool_data = new TDSourceFeature(sourceFeature);
00060         attrib_owner()->add_TD(new_tool_data);
00061     }
00062
00063     delete_attrib(CUBIT_TRUE);
00064     hasActuated = CUBIT_TRUE;
00065
00066     return CUBIT_SUCCESS;
00067 }
00068
00069 CubitStatus CASourceFeature::update()
00070 {
00071     if(hasUpdated)
00072         return CUBIT_SUCCESS;
00073
00074     // set the updated flag
00075     hasUpdated = CUBIT_TRUE;
00076
00077     // if the owner has a unique id, save it, otherwise delete this one
00078     TDSourceFeature *source_feature_data =
00079         (TDSourceFeature *) attrib_owner()->get_TD(&TDSourceFeature::is_source_feature);
00080
00081     if (!source_feature_data)
00082         delete_attrib(CUBIT_TRUE);
00083     else
00084     {
00085         if (delete_attrib() == CUBIT_TRUE)
00086             delete_attrib(CUBIT_FALSE);
00087
00088         sourceFeature = source_feature_data->source_feature();
00089     }
00090
00091     return CUBIT_SUCCESS;
00092 }
00093
00094 CubitStatus CASourceFeature::reset()
00095 {
00096     sourceFeature = GeometryFeatureEngine::FEATURE_UNDEFINED;
00097
00098     hasUpdated = CUBIT_FALSE;
00099     return CUBIT_SUCCESS;
00100 }
00101
00102 CubitSimpleAttrib CASourceFeature::cubit_simple_attrib()
00103 {
00104     std::vector<CubitString> cs_list;
00105
00106     // pack the string list:
00107     // character type of this CA
00108     cs_list.push_back(att_internal_name());
00109
00110     // name, option pairs
00111     cs_list.push_back(feature_type_to_string(sourceFeature));
00112
00113     return CubitSimpleAttrib(&cs_list, NULL, NULL);
00114 }
00115
00116
00117 void CASourceFeature::print()
00118 {
00119     // print info on this attribute
00120     PRINT_INFO("CASourceFeature: owner = %s %d; feature: ",
00121         attribOwnerEntity->class_name(), attribOwnerEntity->id());
00122     PRINT_INFO("%s ", feature_type_to_string(sourceFeature).c_str());
00123
00124     PRINT_INFO("\n");
00125 }
00126
00127 GeometryFeatureEngine::FeatureType
00128 CASourceFeature::string_to_feature_type(CubitString value_in)
00129 {
00130     /*
00131     FEATURE_UNDEFINED,
00132     FEATURE_HOLE,
00133     FEATURE_ROUND,
00134     FEATURE_CHAMFER,
00135     FEATURE_SLOT ,
00136     FEATURE_CUT,
00137     FEATURE_IMPRINT
00138     */
00139     if(value_in == "IMPRINT")
00140         return GeometryFeatureEngine::FEATURE_IMPRINT;
00141     else if(value_in == "HOLE")
00142         return GeometryFeatureEngine::FEATURE_HOLE;
00143     else if(value_in == "ROUND")
00144         return GeometryFeatureEngine::FEATURE_ROUND;
00145     else if(value_in == "CHAMFER")
00146         return GeometryFeatureEngine::FEATURE_CHAMFER;
00147     else if(value_in == "SLOT")
00148         return GeometryFeatureEngine::FEATURE_SLOT;
00149     else if(value_in == "CUT")
00150         return GeometryFeatureEngine::FEATURE_CUT;
00151     else
00152         return GeometryFeatureEngine::FEATURE_UNDEFINED;
00153 }
00154
00155 // returning a cubit simple attribute string for the input feature type
00156 CubitString
00157 CASourceFeature::feature_type_to_string(GeometryFeatureEngine::FeatureType type_in)
00158 {
00159     switch(type_in)
00160     {
00161     case GeometryFeatureEngine::FEATURE_IMPRINT:
00162         return "IMPRINT";
00163     case GeometryFeatureEngine::FEATURE_HOLE:
00164         return "HOLE";
00165     case GeometryFeatureEngine::FEATURE_ROUND:
00166         return "ROUND";
00167     case GeometryFeatureEngine::FEATURE_CHAMFER:
00168         return "CHAMFER";
00169     case GeometryFeatureEngine::FEATURE_SLOT:
00170         return "SLOT";
00171     case GeometryFeatureEngine::FEATURE_CUT:
00172         return "CUT";
00173     default:
00174         return "";
00175     }
00176 }
