cgma
CAUniqueId.cpp
00001 //- Class:          CAUniqueId
00002 //- Owner:          Tim Tautges
00003 //- Description:    Cubit Attribute for unique ids
00004 //- Checked By:
00005 //- Version:
00006
00007 #include "CAUniqueId.hpp"
00008 #include "CubitSimpleAttrib.hpp"
00009 #include "RefEntity.hpp"
00010 #include "TDUniqueId.hpp"
00011 #include "GSaveOpen.hpp"
00012 #include "GeometryQueryTool.hpp"
00013
00014 DLIList<CAUniqueId *> CAUniqueId::allCAUniqueIds;
00015 bool CAUniqueId::autoUniqueId = false;
00016 UIDMap CAUniqueId::oldUIDToNewUID;
00017
00018 CubitAttrib* CAUniqueId_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa)
00019 {
00020   return new CAUniqueId(entity, p_csa);
00021 }
00022
00023 CAUniqueId::~CAUniqueId()
00024 {
00025   if (allCAUniqueIds.move_to(this))
00026     allCAUniqueIds.extract();
00027 }
00028
00029 CAUniqueId::CAUniqueId(RefEntity* new_attrib_owner,
00030                                const CubitSimpleAttrib &csa_ptr)
00031         : CubitAttrib(new_attrib_owner)
00032 {
00033   uniqueId = -1;
00034
00035   if(!csa_ptr.isEmpty())
00036   {
00037     uniqueId = csa_ptr.int_data_list()[0];
00038   }
00039   allCAUniqueIds.append(this);
00040 }
00041
00042 CubitStatus CAUniqueId::actuate()
00043 {
00044
00045   if (hasActuated == CUBIT_TRUE) return CUBIT_SUCCESS;
00046
00047     // create a TDUniqueId for the entity, if it doesn't already
00048     // exist
00049   TDUniqueId *uid = (TDUniqueId *) attrib_owner()->get_TD(&TDUniqueId::is_unique_id);
00050
00051   if (uid != NULL) {
00052       // check to make sure it's the same unique id
00053     if (uid->unique_id() != uniqueId) {
00054       PRINT_ERROR("Different unique id found for %s %d.\n",
00055                   attrib_owner()->class_name(), attrib_owner()->id());
00056       return CUBIT_FAILURE;
00057     }
00058   }
00059   else
00060   {
00061     if( !GSaveOpen::performingUndo &&
00062          GeometryQueryTool::importingSolidModel &&
00063         !GeometryQueryTool::mergeGloballyOnImport)
00064     {
00065       //Is there an entity that already has this id?
00066       ToolDataUser *tdu = TDUniqueId::find_td_unique_id(uniqueId);
00067       if( tdu )
00068       {
00069         //is it already in the map
00070         UIDMap::iterator iter;
00071         iter = oldUIDToNewUID.find( uniqueId );
00072
00073         if( iter != oldUIDToNewUID.end() )
00074           uniqueId = (*iter).second;
00075         else
00076         {
00077           int new_unique_id = TDUniqueId::generate_unique_id();
00078           UIDMap::value_type this_pair(uniqueId, new_unique_id);
00079           oldUIDToNewUID.insert(this_pair);
00080           uniqueId = new_unique_id;
00081         }
00082       }
00083     }
00084
00085       // else make a new one
00086     uid = new TDUniqueId(attrib_owner(), uniqueId);
00087   }
00088
00089   delete_attrib(CUBIT_TRUE);
00090   hasActuated = CUBIT_TRUE;
00091
00092   return CUBIT_SUCCESS;
00093 }
00094
00095 CubitStatus CAUniqueId::update()
00096 {
00097   if (hasUpdated) return CUBIT_SUCCESS;
00098
00099     // set the updated flag
00100   hasUpdated = CUBIT_TRUE;
00101
00102     // if the owner has a unique id, save it, otherwise delete this one
00103   TDUniqueId *td_uid = (TDUniqueId *) attrib_owner()->get_TD(&TDUniqueId::is_unique_id);
00104
00105   if (NULL == td_uid && autoUniqueId)
00106     td_uid = new TDUniqueId(attrib_owner());
00107
00108   if (td_uid == NULL) {
00109     delete_attrib(CUBIT_TRUE);
00110   }
00111
00112   else {
00113     uniqueId = td_uid->unique_id();
00114     if (delete_attrib() == CUBIT_TRUE) delete_attrib(CUBIT_FALSE);
00115   }
00116
00117   return CUBIT_SUCCESS;
00118 }
00119
00120 CubitSimpleAttrib CAUniqueId::cubit_simple_attrib()
00121 {
00122   return CubitSimpleAttrib(att_internal_name(), "", "",
00123                                &uniqueId);
00124 }
00125
00126 CubitStatus CAUniqueId::actuate_all()
00127 {
00128     //- actuate all the CAUI's on the list, then empty the list
00129   for (int i = allCAUniqueIds.size(); i > 0; i--) {
00130     CAUniqueId *cauid = allCAUniqueIds.get();
00131     if (cauid->actuate() == CUBIT_SUCCESS) allCAUniqueIds.extract();
00132     else allCAUniqueIds.step();
00133   }
00134
00135   return CUBIT_SUCCESS;
00136 }
00137
00138 void CAUniqueId::print()
00139 {
00140     // print info on this attribute
00141
00142   PRINT_INFO("CAUniqueId: owner = %s %d: uid=%d\n",
00143              attribOwnerEntity->class_name(), attribOwnerEntity->id(),
00144              uniqueId);
00145 }
00146
00147 void CAUniqueId::clear_out_old_to_new_map()
00148 {
00149   oldUIDToNewUID.clear();
00150 }
00151
