cgma
CCubitFile.cpp
00001 /*******************************************************************************
00002     COPYRIGHT 2002 CATERPILLAR INC.  ALL RIGHTS RESERVED
00003
00004     This program is the property of Caterpillar Inc., includes Caterpillar's
00005     confidential and trade secret information, and is maintained as an
00006     unpublished copyrighted work.  It is not to be copied or used by others
00007     except under license from Caterpillar.  This program is also protected as an
00008     unpublished work in accordance with the copyright act of 1976.  In the event
00009     of either inadvertent or deliberate publication, Caterpillar Inc. intends to
00010     maintain copyright protection for this work under the relevant copyright
00011     laws pertaining to published works.  The inclusion of a copyright notice
00012     hereon is precautionary only, and does not imply publication or disclosure.
00013
00014
00015  Filename      : CCubitFile.cpp
00016
00017  Purpose       : Implements reading and writing data in the Cubit file format.
00018
00019  Special Notes :
00020
00021  Creator       : Will A. Helden
00022
00023  Creation Date : 02/15/02
00024
00025  Owner         : Will A. Helden
00026
00027 *******************************************************************************/
00028
00029 #include "CCubitFile.hpp"
00030 #include "CubitDefines.h"
00031 #include "CubitFileIOWrapper.hpp"
00032 #include "CubitFileMetaData.hpp"
00033 #include "CubitFileFEModel.hpp"
00034 #include "CubitFileSimModel.hpp"
00035 #include <cstring>
00036 #include "CubitFileUtil.hpp"
00037
00038 using namespace NCubitFile;
00039
00041 // Construction/Destruction
00043
00044 /* Note: some platforms define both BIG_ENDIAN and LITTLE_ENDIAN
00045    so don't do if defined(LITTLE_ENDIAN) here.  Compare to BYTE_ORDER instead. */
00046 #if defined(_WIN32) || defined(__LITTLE_ENDIAN__) || defined(CUBIT_LINUX) || (defined(LITTLE_ENDIAN) && (BYTE_ORDER==LITTLE_ENDIAN)) /* should be little endian platforms */
00047     const UnsignedInt32 CCubitFile::mintNativeEndian = 0;
00048 #else // big endian platforms
00049     const UnsignedInt32 CCubitFile::mintNativeEndian = 0xFFFFFFFF;
00050 #endif
00051     const UnsignedInt32 CCubitFile::mintSizeOfContents =
00052         sizeof(SCubitFileContentsHeader) / sizeof(UnsignedInt32);
00053     const UnsignedInt32 CCubitFile::mintSizeOfModel =
00054         sizeof(SCubitFileModelEntry) / sizeof(UnsignedInt32);
00055
00056 CCubitFile::CCubitFile()
00057 {
00058     meErrorState = eSuccess;
00059     mintNextModelID = 1;
00060
00061     mpaReadModels = mpaWriteModels = NULL;
00062     mpaReadModelStat = NULL;
00063     mpMetaData = NULL;
00064     mstrReadFileName = mstrWriteFileName = mstrBackupFileName = NULL;
00065     mpReadFEModel = mpWriteFEModel = NULL;
00066     mpReadSimModel = mpWriteSimModel = NULL;
00067
00068     mModelBuff.mintNumModels = 0;
00069     mModelBuff.mpaModelData = NULL;
00070 }
00071
00072 CCubitFile::~CCubitFile()
00073 {
00074     // auto-save?
00075     // delete incomplete temp files
00076     FreeAll();
00077
00078     // Assume if any FE models are still around now (i.e. EndRead/Write hasn't
00079     // been called) there was an error, so free their memory.
00080     if(mpReadFEModel)
00081         delete mpReadFEModel;
00082     if(mpWriteFEModel)
00083         delete mpWriteFEModel;
00084     if(mpReadSimModel)
00085         delete mpReadSimModel;
00086     if(mpWriteSimModel)
00087         delete mpWriteSimModel;
00088
00089     if(mModelBuff.mpaModelData)
00090         delete [] mModelBuff.mpaModelData;
00091 }
00092
00093 void CCubitFile::FreeAll()
00094 // Frees all allocated memory, closes open files, and resets class members to
00095 // their constructed state.
00096 {
00097     // Free all allocated memory.
00098     if(mstrReadFileName)
00099         delete [] mstrReadFileName;
00100     if(mstrWriteFileName)
00101         delete [] mstrWriteFileName;
00102     if(mstrBackupFileName)
00103         delete [] mstrBackupFileName;
00104     mstrReadFileName = mstrWriteFileName = mstrBackupFileName = NULL;
00105     if(mpaReadModels)
00106         delete [] mpaReadModels;
00107     if(mpaWriteModels)
00108         delete [] mpaWriteModels;
00109     mpaReadModels = mpaWriteModels = NULL;
00110     if(mpaReadModelStat)
00111         delete [] mpaReadModelStat;
00112     mpaReadModelStat = NULL;
00113     if(mpMetaData)
00114         delete mpMetaData;
00115     mpMetaData = NULL;
00116
00117     // Close any open files.
00118     try {
00119         if(mpReadFile)
00120             mpReadFile.close();
00121         if(mpWriteFile)
00122             mpWriteFile.close();
00123     }
00124     catch(...)  { }
00125 }
00126
00127 CCubitFile::EErrorCode CCubitFile::Open(const char* xstrReadFileName,
00128                                         const char* xstrWriteFileName,
00129                                         const char* xstrBackupFileName)
00130 // Open a file for reading or writing.
00131 // === NOTES ===
00132 // *  The read file is a file to be read only.  The file must exist and be
00133 //    accessable or this function will fail.
00134 // *  The write file is an output file.  The file must be creatable or this
00135 //    function will fail.  If the file already exists, it will be overwritten.
00136 //    If the write file name is the same as the read file name, a temporary
00137 //    write file name will be generated to be written to until the completion
00138 //    of the write operation at which time the read file will be deleted and
00139 //    the write file renamed to take its place.
00140 // *  The backup file name is used for preventing the loss of old read files.
00141 //    If the read file was to be deleted automatically by a write operation,
00142 //    specification of a backup name, will cause the read file to be renamed
00143 //    instead.
00144 // *  Any of these three filenames may be NULL, but at least one name, read or
00145 //    write, must be specified.
00146 {
00147     try {
00148         if(!xstrReadFileName && !xstrWriteFileName)
00149             throw ePassedNullPointer;
00150
00151         mpMetaData = new CMetaData;
00152
00153         // If a file has been designated for reading, copy its name and try to
00154         // open it.
00155         if(xstrReadFileName ) {
00156             UnsignedInt32 lintFileName = std::strlen(xstrReadFileName);
00157             mstrReadFileName = new char[lintFileName + 1];
00158             std::strcpy(mstrReadFileName, xstrReadFileName);
00159
00160             if( !xstrWriteFileName )
00161             {
00162               mpReadFile.open(mstrReadFileName, "rb");
00163               if(!mpReadFile)
00164                   throw eFileReadError;
00165
00166               // Test to see if the file is a cubit file... it should begin with
00167               // the string 'CUBE'.
00168               unsigned char lachrMagic[4];
00169               if(fread(lachrMagic, 1, 4, mpReadFile.file()) != 4)
00170                   throw eFileUnrecognizedFormat;
00171               if((lachrMagic[0] != 'C') || (lachrMagic[1] != 'U') ||
00172                   (lachrMagic[2] != 'B') || (lachrMagic[3] != 'E'))
00173                   throw eFileUnrecognizedFormat;
00174
00175               // Load the file's "table of contents".
00176               CIOWrapper lIO(mpReadFile.file(), 4, 0);
00177               lIO.BeginReadBlock(4);
00178               lIO.Read((UnsignedInt32*)&mReadContents, mintSizeOfContents);
00179               lIO.EndReadBlock();
00180
00181               if(mReadContents.mintHeaderSchema > 0)
00182                   throw eFileUnrecognizedFormat;
00183
00184               if(mReadContents.mintNumModels) {
00185                   mpaReadModels =
00186                       new SCubitFileModelEntry[mReadContents.mintNumModels];
00187                   mpaReadModelStat = new EModelStat[mReadContents.mintNumModels];
00188                   if(!mpaReadModels || !mpaReadModelStat)  throw eMemoryError;
00189
00190                   lIO.BeginReadBlock(mReadContents.mintModelTableOffset);
00191                   lIO.Read((UnsignedInt32*)mpaReadModels,
00192                       mReadContents.mintNumModels * mintSizeOfModel);
00193                   lIO.EndReadBlock();
00194
00195                   UnsignedInt32 lintMod;
00196                   for(lintMod = 0; lintMod < mReadContents.mintNumModels; lintMod++) {
00197                       mpaReadModelStat[lintMod] = eStatNotWritten;
00198                       if(mpaReadModels[lintMod].mintModelHandle >= mintNextModelID)
00199                           mintNextModelID = mpaReadModels[lintMod].mintModelHandle + 1;
00200                   }
00201               }
00202
00203               // Read the file-scoped (model) meta-data.
00204               mpMetaData->ReadMetaData(mpReadFile.file(),
00205                   mReadContents.mintModelMetaDataOffset, 0,
00206                   mReadContents.mintHeaderSourceEndian);
00207             }
00208             else
00209             {
00210                mReadContents.mintHeaderSourceEndian = mintNativeEndian;
00211                mReadContents.mintHeaderSchema = 0;
00212                mReadContents.mintNumModels = 0;
00213                mReadContents.mintModelTableOffset = 0;
00214                mReadContents.mintModelMetaDataOffset = 0;
00215                mReadContents.mintActiveFEModel = 0;
00216
00217               // Copy the backup file name, if specified.
00218               if(xstrBackupFileName) {
00219                   UnsignedInt32 lintFileName = std::strlen(xstrBackupFileName);
00220                   mstrBackupFileName = new char[lintFileName + 1];
00221                   std::strcpy(mstrBackupFileName, xstrBackupFileName);
00222               }
00223             }
00224           }
00225           else {
00226               // If there wasn't a file to read, initialize the read contents to
00227               // nothing.
00228               mReadContents.mintHeaderSourceEndian = mintNativeEndian;
00229               mReadContents.mintHeaderSchema = 0;
00230               mReadContents.mintNumModels = 0;
00231               mReadContents.mintModelTableOffset = 0;
00232               mReadContents.mintModelMetaDataOffset = 0;
00233               mReadContents.mintActiveFEModel = 0;
00234         }
00235
00236         // If a file has been designated for writing
00237         if(xstrWriteFileName) {
00238             UnsignedInt32 lintFileName = std::strlen(xstrWriteFileName);
00239             mstrWriteFileName = new char[lintFileName + 10];
00240
00241             // If the read and write file names don't match, then the write
00242             // file can be opened by name.
00243             if(!mstrReadFileName || std::strcmp(mstrReadFileName, xstrWriteFileName)) {
00244                 mintWriteTempFile = 0;
00245                 std::strcpy(mstrWriteFileName, xstrWriteFileName);
00246                 mpWriteFile.open(mstrWriteFileName, "wb");
00247             }
00248             // Otherwise, generate a temporary file name to write to so that
00249             // the read file's contents will not be destroyed until it is
00250             // verifiable that any new writes are successful.
00251             else {
00252                 mintWriteTempFile = 1;
00253                 UnsignedInt32 lintTempFile = 0;
00254                 while(!mpWriteFile && (lintTempFile < 0xFF)) {
00255                     sprintf(mstrWriteFileName, "%s~%.2x.tmp",
00256                         mstrReadFileName, lintTempFile);
00257                     mpWriteFile.open(mstrWriteFileName, "wb");
00258                     lintTempFile++;
00259                 }
00260             }
00261             if(!mpWriteFile)
00262                 throw eFileWriteError;
00263
00264             // Initialize the write file contents - copy the model inventory
00265             // (but not actual contents yet) from the read file.
00266             mWriteContents.mintHeaderSourceEndian = mintNativeEndian;
00267             mWriteContents.mintHeaderSchema = 0;
00268             mWriteContents.mintNumModels = mReadContents.mintNumModels;
00269             mWriteContents.mintModelTableOffset = 0;
00270             mWriteContents.mintModelMetaDataOffset = 0;
00271             mWriteContents.mintActiveFEModel = mReadContents.mintActiveFEModel;
00272             mintWriteBuffNumModels = 0;
00273
00274             if(mWriteContents.mintNumModels) {
00275                 mpaWriteModels =
00276                     new SCubitFileModelEntry[mWriteContents.mintNumModels];
00277                 if(!mpaWriteModels)  throw eMemoryError;
00278
00279                 UnsignedInt32 lintMod;
00280                 for(lintMod = 0; lintMod < mWriteContents.mintNumModels; lintMod++) {
00281                     mpaWriteModels[lintMod].mintModelHandle =
00282                         mpaReadModels[lintMod].mintModelHandle;
00283                     mpaWriteModels[lintMod].mintModelOffset = 0;
00284                     mpaWriteModels[lintMod].mintModelLength = 0;
00285                     mpaWriteModels[lintMod].mintModelType =
00286                         mpaReadModels[lintMod].mintModelType;
00287                     mpaWriteModels[lintMod].mintModelOwner =
00288                         mpaReadModels[lintMod].mintModelOwner;
00289                 }
00290             }
00291
00292             // Initialize the write file by writing its identity and an initial
00293             // table of contents.
00294             CIOWrapper lIO(mpWriteFile.file());
00295             lIO.BeginWriteBlock(0);
00296             lIO.Write("CUBE", 4);
00297             lIO.Write((UnsignedInt32*)&mWriteContents, mintSizeOfContents);
00298             lIO.EndWriteBlock();
00299
00300             WriteModelTable();
00301         }
00302         else {
00303             // If there wasn't a file to written, initialize the write contents
00304             // to nothing.
00305             mWriteContents.mintHeaderSourceEndian = mintNativeEndian;
00306             mWriteContents.mintHeaderSchema = 0;
00307             mWriteContents.mintNumModels = 0;
00308             mWriteContents.mintModelTableOffset = 0;
00309             mWriteContents.mintModelMetaDataOffset = 0;
00310             mWriteContents.mintActiveFEModel = 0;
00311         }
00312
00313         return eSuccess;
00314     }
00315
00316     // Handle all open errors by reseting the file object.
00317     catch(EErrorCode xeErrorCode) {
00318         FreeAll();
00319         return xeErrorCode;
00320     }
00321     catch(...)  {
00322         FreeAll();
00323         return eUnknownError;
00324     }
00325 }
00326
00327 CCubitFile::EErrorCode CCubitFile::Close()
00328 // Close any open files, completing any pending write operations, and free any
00329 // allocated resources.  See Open() comments for more info.
00330 {
00331     try {
00332
00333         if(mpWriteFile) {
00334             // Write file scoped (model) metadata and update the file's table
00335             // of contents one last time.
00336             UnsignedInt32 lintMetaDataLength;
00337             mpMetaData->WriteMetaData(mpWriteFile.file(),
00338                 mWriteContents.mintModelMetaDataOffset, lintMetaDataLength);
00339             WriteModelTable();
00340
00341 // throw away erroneously written files?!?
00342
00343             // If the written file was a temporary file, delete the original
00344             // file and replace it with the temporary file.
00345             if(mintWriteTempFile) {
00346                 // Close any open files.
00347                 mpReadFile.close();
00348                 mpWriteFile.close();
00349
00350                 // If there was a backup name specified for the old read file
00351                 // rename it instead of deleting it.
00352                 if(mstrBackupFileName)
00353                     CubitFileUtil::rename_file(mstrReadFileName, mstrBackupFileName);
00354                 else
00355                     CubitFileUtil::remove_file(mstrReadFileName);
00356                 if(CUBIT_SUCCESS != CubitFileUtil::rename_file(mstrWriteFileName, mstrReadFileName))
00357                     throw eUnknownError;
00358             }
00359         }
00360
00361         // Close any open files and clean up allocated memory.
00362         FreeAll();
00363         return eSuccess;
00364     }
00365     catch(EErrorCode xeErrorCode) {
00366         FreeAll();
00367         return xeErrorCode;
00368     }
00369     catch(...)  {
00370         FreeAll();
00371         return eUnknownError;
00372     }
00373 }
00374
00375 /*UnsignedInt32 CCubitFile::GetModelList(UnsignedInt32& xintNumModels,
00376                                        const SModelData*& xpaModels)
00377 // Returns a list of all models contained in the file.
00378 {
00379     SCubitFileModelEntry* lpaModels = NULL;
00380     if(mpaWriteModels) {
00381         lpaModels = mpaWriteModels;
00382         xintNumModels = mWriteContents.mintNumModels;
00383     }
00384     else if(mpaReadModels) {
00385         lpaModels = mpaReadModels;
00386         xintNumModels = mReadContents.mintNumModels;
00387     }
00388
00389     if(!lpaModels || !xintNumModels) {
00390         xpaModels = NULL;
00391         return eNotFound;
00392     }
00393
00394     if(mModelBuff.mintNumModels < xintNumModels) {
00395         mModelBuff.mintNumModels = xintNumModels;
00396         if(mModelBuff.mpaModelData)
00397             delete [] mModelBuff.mpaModelData;
00398         mModelBuff.mpaModelData = new SModelData[xintNumModels];
00399     }
00400     xpaModels = mModelBuff.mpaModelData;
00401
00402     for(UnsignedInt32 lintModel = 0; lintModel < xintNumModels; lintModel++) {
00403         mModelBuff.mpaModelData[lintModel].mintModelHandle =
00404             lpaModels[lintModel].mintModelHandle;
00405         mModelBuff.mpaModelData[lintModel].mintModelType =
00406             lpaModels[lintModel].mintModelType;
00407         mModelBuff.mpaModelData[lintModel].mintModelOwner =
00408             lpaModels[lintModel].mintModelOwner;
00409     }
00410     return eSuccess;
00411 }*/
00412
00413 UnsignedInt32 CCubitFile::IsModel(HModel xintModel)
00414 {
00415     UnsignedInt32 lintIndex;
00416     if(mWriteContents.mintNumModels)
00417         return FindModel(xintModel, mpaWriteModels, mWriteContents.mintNumModels, lintIndex);
00418     else if(mReadContents.mintNumModels)
00419         return FindModel(xintModel, mpaReadModels, mReadContents.mintNumModels, lintIndex);
00420     return 0;  // failure
00421 }
00422
00423 UnsignedInt32 CCubitFile::GetReadModelLength(HModel xintModel,
00424                                              UnsignedInt32& xintLength)
00425 // Looks up the length of the data block in the cubit filr for the requested
00426 // model.  Returns success if the model is found, otherwise an error is returned.
00427 {
00428     UnsignedInt32 lintIndex;
00429     if(FindModel(xintModel, mpaReadModels, mReadContents.mintNumModels, lintIndex)) {
00430         xintLength = mpaReadModels[lintIndex].mintModelLength;
00431         return eSuccess;
00432     }
00433     else {
00434         xintLength = 0;
00435         return eNotFound;
00436     }
00437 }
00438
00439 UnsignedInt32 CCubitFile::CreateModel(EModelType xeModelType, HModel& xintModel)
00440 // Define a new model in the temp file.
00441 {
00442     if(!mpWriteFile)  return eFileWriteError;
00443
00444     // Allocate a new bigger model table, copy the existing table (if any)
00445     // into the new one and then replace the old one.
00446     SCubitFileModelEntry* lpaModels =
00447         new SCubitFileModelEntry[mWriteContents.mintNumModels + 1];
00448     if(!lpaModels)  return eMemoryError;
00449     if(mpaWriteModels) {
00450         memcpy(lpaModels, mpaWriteModels,
00451             sizeof(SCubitFileModelEntry) * mWriteContents.mintNumModels);
00452         delete [] mpaWriteModels;
00453     }
00454     mpaWriteModels = lpaModels;
00455
00456     // Initialize the new model's table entry.
00457     mpaWriteModels[mWriteContents.mintNumModels].mintModelHandle =
00458         xintModel;// = mintNextModelID++;
00459     mpaWriteModels[mWriteContents.mintNumModels].mintModelOffset = 0;
00460     mpaWriteModels[mWriteContents.mintNumModels].mintModelLength = 0;
00461     mpaWriteModels[mWriteContents.mintNumModels].mintModelType = xeModelType;
00462     mpaWriteModels[mWriteContents.mintNumModels].mintModelOwner = 0;
00463     mpaWriteModels[mWriteContents.mintNumModels].mintModel64bitOSPad = 0;
00464     mWriteContents.mintNumModels++;
00465
00466     return eSuccess;
00467 }
00468
00469 UnsignedInt32 CCubitFile::DeleteModel(HModel xintModel)
00470 // Flag an model that exists in the read file not to be copied into the write file.
00471 {
00472     if(!mpWriteFile)  return eFileWriteError;
00473
00474     // Flag the model in the old file as marked for deletion.
00475     UnsignedInt32 lintIndex;
00476     if(!FindModel(xintModel, mpaReadModels, mReadContents.mintNumModels, lintIndex))
00477         return eNotFound;
00478     if(mpaReadModelStat[lintIndex] == eStatWritten)
00479         return eOrderError;
00480     mpaReadModelStat[lintIndex] = eStatDelete;
00481
00482     // Remove the model from the write file's table and close up the position in
00483     // the model table (if applicable).
00484     if(FindModel(xintModel, mpaWriteModels, mWriteContents.mintNumModels, lintIndex)) {
00485         mWriteContents.mintNumModels--;
00486         if(mWriteContents.mintNumModels &&
00487             (lintIndex < mWriteContents.mintNumModels)) {
00488             for(UnsignedInt32 lintCopyTo = lintIndex; lintCopyTo <
00489                 mWriteContents.mintNumModels; lintCopyTo++) {
00490                 memcpy(&mpaWriteModels[lintCopyTo],
00491                     &mpaWriteModels[lintCopyTo + 1],
00492                     sizeof(SCubitFileModelEntry));
00493             }
00494         }
00495     }
00496
00497     // Find any models that have the deleted model as their owner and reset
00498     // the owner to no owner (0).
00499     if(mWriteContents.mintNumModels) {
00500         for(UnsignedInt32 lintModel = 0; lintModel <
00501             mWriteContents.mintNumModels; lintModel++) {
00502             if(mpaWriteModels[lintModel].mintModelOwner == xintModel)
00503                 mpaWriteModels[lintModel].mintModelOwner = 0;
00504         }
00505     }
00506
00507     // Delete any meta-data that belonged with the deleted model.
00508     mpMetaData->ClearMetaDataForID(xintModel);
00509
00510     return eSuccess;
00511 }
00512
00513 UnsignedInt32 CCubitFile::GetModelOwner(HModel xintModel, HModel& xintOwner)
00514 // Return the owning model of the passed model.
00515 {
00516     // Flag the model in the old file as marked for deletion.
00517     UnsignedInt32 lintIndex;
00518     if(!FindModel(xintModel, mpaWriteModels, mWriteContents.mintNumModels, lintIndex))
00519         return eNotFound;
00520     xintOwner = mpaWriteModels[lintIndex].mintModelOwner;
00521     return eSuccess;
00522 }
00523
00524 UnsignedInt32 CCubitFile::SetModelOwner(HModel xintModel, HModel xintOwner)
00525 // Set the owning model for the passed model.
00526 {
00527     // Flag the model in the old file as marked for deletion.
00528     UnsignedInt32 lintIndex;
00529     if(xintOwner &&  // don't allow the model to have a non-existant owner.
00530         !FindModel(xintOwner, mpaWriteModels, mWriteContents.mintNumModels, lintIndex))
00531         return eNotFound;
00532     if(!FindModel(xintModel, mpaWriteModels, mWriteContents.mintNumModels, lintIndex))
00533         return eNotFound;
00534     mpaWriteModels[lintIndex].mintModelOwner = xintOwner;
00535     return eSuccess;
00536 }
00537
00538 UnsignedInt32 CCubitFile::FindModel(HModel xintModel,
00539                                     SCubitFileModelEntry* xpaModels,
00540                                     UnsignedInt32 xintNumModels,
00541                                     UnsignedInt32& xintIndex)
00542 // Determine the index of the passed model handle in the passed model table.
00543 // Private function, return true/false, no exceptions thrown.
00544 {
00545     if(xintNumModels) {
00546         for(UnsignedInt32 lintMod = 0; lintMod < xintNumModels; lintMod++) {
00547             if(xpaModels[lintMod].mintModelHandle == xintModel) {
00548                 xintIndex = lintMod;
00549                 return 1; // success
00550             }
00551         }
00552     }
00553     return 0; // failure
00554 }
00555
00556 void CCubitFile::WriteModelTable()
00557 // Write (or rewrite) the model table to the write file.
00558 {
00559     if(!mpWriteFile)  throw eFileWriteError;
00560
00561     if(!mWriteContents.mintNumModels)  return;  // no models... nothing to do!
00562
00563     CIOWrapper lIO(mpWriteFile.file());
00564
00565     // Write the model table, if the number of models has increased, write the
00566     // table to a new location in the file, otherwise reuse the previous
00567     // table's file space.
00568     if(mWriteContents.mintNumModels > mintWriteBuffNumModels) {
00569         mintWriteBuffNumModels = mWriteContents.mintNumModels;
00570         mWriteContents.mintModelTableOffset = lIO.BeginWriteBlock();
00571     }
00572     else
00573         lIO.BeginRewriteBlock(mWriteContents.mintModelTableOffset, 0);
00574     lIO.Write((UnsignedInt32*)mpaWriteModels,
00575         mWriteContents.mintNumModels * mintSizeOfModel);
00576     lIO.EndWriteBlock();
00577
00578     // Rewrite the contents header to reflect any model table changes.
00579     lIO.BeginRewriteBlock(4, 0);
00580     lIO.Write((UnsignedInt32*)&mWriteContents, mintSizeOfContents);
00581     lIO.EndWriteBlock();
00582 }
00583
00584 void CCubitFile::CopyModel(UnsignedInt32 xintReadOffset,
00585                            UnsignedInt32& xintWriteOffset,
00586                            UnsignedInt32 xintLength,
00587                            FILE* xpReadFile, FILE* xpWriteFile)
00588 // Copy a model from one file to another.  The copied model is byte identical
00589 // to the original.
00590 {
00591     // Create a 16 kilobyte memory buffer to try to improve copy IO efficiency
00592     // over a byte-per-byte copy.
00593     char* lpachrCopyBuffer = new char[0x4000]; //16KB
00594     if(!lpachrCopyBuffer)
00595         throw eMemoryError;
00596
00597     // Position the files pointers for the copy.
00598     CIOWrapper lReadIO(xpReadFile);
00599     CIOWrapper lWriteIO(xpWriteFile);
00600     lReadIO.BeginReadBlock(xintReadOffset);
00601     xintWriteOffset = lWriteIO.BeginWriteBlock();
00602
00603     // Copy the models 16K at a time.
00604     UnsignedInt32 lintRemaining = xintLength;
00605     UnsignedInt32 lintCopyBytes = 0x4000;
00606     while(lintRemaining) {
00607         if(lintRemaining > 0x4000)  // More than 16K left, copy 16K.
00608             lintRemaining -= 0x4000;
00609         else {  // 16K or less left, copy all of what's left.
00610             lintCopyBytes = lintRemaining;
00611             lintRemaining = 0;
00612         }
00613         lReadIO.Read(lpachrCopyBuffer, lintCopyBytes);
00614         lWriteIO.Write(lpachrCopyBuffer, lintCopyBytes);
00615     }
00616
00617     // Make sure the copy was complete and free the buffer.
00618     lReadIO.EndReadBlock();
00619     if(lWriteIO.EndWriteBlock() != xintLength)
00620         throw eCorruptBlock;
00621     delete [] lpachrCopyBuffer;
00622 }
00623
00624
00626 // Geometry Model Read/Write
00628
00629 UnsignedInt32 CCubitFile::BeginWriteGeomModel(HModel xintGeomModel,
00630                                               const char* xstrGeomFile)
00631 // Copy an external geometry file into the cubit file as a geometry model.
00632 {
00633     if(!mpWriteFile)  return eFileWriteError;
00634
00635     // Try to open the geometry model file for reading.
00636     CubitFile lpGeomFile(xstrGeomFile, "rb");
00637     if(!lpGeomFile)
00638         return eFileReadError;
00639
00640     // Determine the size of the geometry file and then copy it into the
00641     // cubit file.
00642     EErrorCode leReturn = eSuccess;
00643     try {
00644         UnsignedInt32 lintReadIndex, lintWriteIndex;
00645         // Locate the model's index in the write contents and make sure it is
00646         // not an FEA model.
00647         if(!FindModel(xintGeomModel, mpaWriteModels,
00648             mWriteContents.mintNumModels, lintWriteIndex))
00649             throw eNotFound;
00650         if(mpaWriteModels[lintWriteIndex].mintModelType == eFEModel)
00651             throw eNotFound;
00652         // Locate the model's index in the read contents, if possible, and
00653         // make sure the model has not already been written or deleted, and
00654         // then mark it written.
00655         if(FindModel(xintGeomModel, mpaReadModels,
00656             mReadContents.mintNumModels, lintReadIndex)) {
00657             if(mpaReadModelStat[lintReadIndex] != eStatNotWritten)
00658                 throw eOrderError;
00659             mpaReadModelStat[lintReadIndex] = eStatWritten;
00660         }
00661
00662         // Measure the length of the geometry model file and then copy it into
00663         // to cubit file.
00664         if(NCubitFile::SetLocation(lpGeomFile.file(), 0, SEEK_END))
00665             throw CCubitFile::eFileSeekError;
00666         UnsignedInt32 lintGeomLength = GetLocation(lpGeomFile.file());
00667         CopyModel(0, mpaWriteModels[lintWriteIndex].mintModelOffset,
00668             lintGeomLength, lpGeomFile.file(), mpWriteFile.file());
00669         mpaWriteModels[lintWriteIndex].mintModelLength = lintGeomLength;
00670     }
00671     catch(EErrorCode xeErrorCode)  {  leReturn = xeErrorCode;  }
00672     catch(...)  {  leReturn = eUnknownError;  }
00673
00674     return leReturn;
00675 }
00676
00677 UnsignedInt32 CCubitFile::EndWriteGeomModel()
00678 // The formal end to a geometry model write.
00679 {
00680     return eSuccess;
00681 }
00682
00683 UnsignedInt32 CCubitFile::BeginReadGeomModel(HModel xintGeomModel,
00684                                              FILE* xpGeomFile)
00685 // Copy an geometry model out of the cubit file into an external geometry file.
00686 {
00687     if(!mpReadFile)  return eFileReadError;
00688     if(!xpGeomFile)  return eFileWriteError;
00689
00690     UnsignedInt32 lintStartFilePos = GetLocation(xpGeomFile);
00691
00692     // Determine the size of the geometry file and then copy it into the
00693     // cubit file.
00694     EErrorCode leReturn = eSuccess;
00695     try {
00696         UnsignedInt32 lintReadIndex, lintWriteOffset;
00697         // Locate the model's index in the read contents and make sure it is
00698         // not an FEA model.
00699         if(!FindModel(xintGeomModel, mpaReadModels,
00700             mReadContents.mintNumModels, lintReadIndex))
00701             throw eNotFound;
00702         if(mpaReadModels[lintReadIndex].mintModelType == eFEModel)
00703             throw eNotFound;
00704
00705         // Copy the geometry model file out of the cubit file.
00706         CopyModel(mpaReadModels[lintReadIndex].mintModelOffset,
00707             lintWriteOffset, mpaReadModels[lintReadIndex].mintModelLength,
00708             mpReadFile.file(), xpGeomFile);
00709     }
00710     catch(EErrorCode xeErrorCode)  {  leReturn = xeErrorCode;  }
00711     catch(...)  {  leReturn = eUnknownError;  }
00712
00713     NCubitFile::SetLocation(xpGeomFile, lintStartFilePos, SEEK_SET);
00714     return leReturn;
00715 }
00716
00717 UnsignedInt32 CCubitFile::EndReadGeomModel()
00718 // The formal end to a geometry model read.
00719 {
00720     return eSuccess;
00721 }
00722
00723
00724 UnsignedInt32 CCubitFile::BeginWriteModel(HModel xintModelId, EModelType type,
00725                                                   FILE*& writeable_file)
00726 {
00727     // Let's not return a FILE* until we know it's going to be OK to write to.
00728   writeable_file = NULL;
00729
00730   if(!mpWriteFile)
00731     return eFileWriteError;
00732
00733   EErrorCode leReturn = eSuccess;
00734   try
00735   {
00736     UnsignedInt32 lintReadIndex, lintWriteIndex;
00737       // Locate the model's index in the write contents and make sure it is
00738       // the right kind of model.
00739     if(!FindModel(xintModelId,
00740                   mpaWriteModels,
00741                   mWriteContents.mintNumModels,
00742                   lintWriteIndex))
00743       throw eNotFound;
00744
00745     if(mpaWriteModels[lintWriteIndex].mintModelType != type)
00746       throw eNotFound;
00747
00748       // Locate the model's index in the read contents, if possible, and
00749       // make sure the model has not already been written or deleted, and
00750       // then mark it as being written.
00751     if(FindModel(xintModelId, mpaReadModels,
00752                  mReadContents.mintNumModels, lintReadIndex))
00753     {
00754       if(mpaReadModelStat[lintReadIndex] != eStatNotWritten)
00755         throw eOrderError;
00756       mpaReadModelStat[lintReadIndex] = eStatWriting;
00757     }
00758
00759       // Move the FILE* to the correct write position so the FILE*
00760       // can be written to directly.  From CopyFile, it looks like the
00761       // correct location is the end of the file.
00762     if (NCubitFile::SetLocation(mpWriteFile.file(), 0, SEEK_END))
00763       throw eFileSeekError;
00764
00765       // Save our current FILE* position so we can detect the size of
00766       // data written to the model.
00767     mpaWriteModels[lintWriteIndex].mintModelOffset = GetLocation(mpWriteFile.file());
00768
00769       // set the FILE*
00770     writeable_file = mpWriteFile.file();
00771   }
00772   catch(EErrorCode xeErrorCode)
00773   {  leReturn = xeErrorCode;  }
00774   catch(...)
00775   {  leReturn = eUnknownError;  }
00776
00777   return leReturn;
00778 }
00779
00780 UnsignedInt32 CCubitFile::EndWriteModel(HModel xintModelId)
00781 {
00782   if (!mpWriteFile)
00783     return eFileWriteError;
00784
00785     // Find the model's write record
00786   UnsignedInt32 lintWriteIndex;
00787   if(!FindModel(xintModelId,
00788                 mpaWriteModels,
00789                 mWriteContents.mintNumModels,
00790                 lintWriteIndex))
00791     return eNotFound;
00792
00793     // Make sure we saved the start position
00794   if (mpaWriteModels[lintWriteIndex].mintModelOffset == 0)
00795     return eOrderError;
00796
00797     // Get the end of the FILE.
00798   if (NCubitFile::SetLocation(mpWriteFile.file(), 0, SEEK_END))
00799     return eFileSeekError;
00800   UnsignedInt32 cur_pos = GetLocation(mpWriteFile.file());
00801
00802     // See how many bytes that is past our saved position.
00803   UnsignedInt32 size_in_bytes = cur_pos - mpaWriteModels[lintWriteIndex].mintModelOffset;
00804
00805     // Locate the model's index in the read contents, if possible, and
00806     // make sure the model has not already been written or deleted, and
00807     // then mark it as written.
00808   UnsignedInt32 lintReadIndex;
00809   if(FindModel(xintModelId, mpaReadModels,
00810                mReadContents.mintNumModels, lintReadIndex))
00811   {
00812     if(mpaReadModelStat[lintReadIndex] != eStatWriting)
00813       throw eOrderError;
00814     mpaReadModelStat[lintReadIndex] = eStatWritten;
00815   }
00816
00817     // Save the size to the model header.
00818   mpaWriteModels[lintWriteIndex].mintModelLength = size_in_bytes;
00819
00820   return eSuccess;
00821 }
00822
00823 // Returns a FILE* that can be read from.  The FILE* will NOT return EOF
00824 // at the end of the data...the reader should not go GetReadModelLength()
00825 // bytes beyond the current FILE* position.  You should copy the contents
00826 // to another FILE if this is an issue for the reader.
00827 UnsignedInt32 CCubitFile::BeginReadModel(HModel xintModelId, EModelType type,
00828                                                  FILE*& f)
00829 {
00830   f = NULL;
00831
00832   if(!mpReadFile)
00833     return eFileReadError;
00834
00835     // Determine the size of the geometry file and then copy it into the
00836     // cubit file.
00837   EErrorCode leReturn = eSuccess;
00838   try
00839   {
00840     UnsignedInt32 lintReadIndex;
00841       // Locate the model's index in the read contents and make sure it is
00842       // an assembly model.
00843     if(!FindModel(xintModelId, mpaReadModels,
00844                   mReadContents.mintNumModels, lintReadIndex))
00845       throw eNotFound;
00846     if(mpaReadModels[lintReadIndex].mintModelType != type)
00847       throw eNotFound;
00848
00849       // Set the read pointer to the correct location
00850     NCubitFile::SetLocation(mpReadFile.file(), mpaReadModels[lintReadIndex].mintModelOffset, SEEK_SET);
00851
00852       // Set the FILE*
00853     f = mpReadFile.file();
00854   }
00855   catch(EErrorCode xeErrorCode)
00856   { leReturn = xeErrorCode; }
00857   catch(...)
00858   { leReturn = eUnknownError; }
00859
00860   return leReturn;
00861 }
00862
00863 UnsignedInt32 CCubitFile::EndReadModel()
00864 {
00865   return eSuccess;
00866 }
00867
00868
00870 // FEA Model Read/Write
00872
00873 UnsignedInt32 CCubitFile::BeginWriteFEModel(HModel xintFEModel,
00874                                             UnsignedInt32 xintGeomCount,
00875                                             UnsignedInt32 xintGroupCount,
00876                                             UnsignedInt32 xintBlockCount,
00877                                             UnsignedInt32 xintNodeSetCount,
00878                                             UnsignedInt32 xintSideSetCount)
00879 // Prepares the file for the writing of a FEA model.  After this call there
00880 // should be no other write oprations on the file not associated with the
00881 // writing of the FEA model until a matching call is made to EndWriteFEModel.
00882 // RETURNS: 0 on success, other values indicate error code.
00883 {
00884     try {
00885         if(!mpWriteFile)  throw eFileWriteError;
00886         if(mpWriteFEModel)  throw eOrderError;
00887
00888         // Write the model table first to try to guarentee that it will be
00889         // at the beginning of the file.
00890         WriteModelTable();
00891
00892         // Lookup the requested model in the model table and make sure it is
00893         // an FEA model.
00894         if(!FindModel(xintFEModel, mpaWriteModels, mWriteContents.mintNumModels,
00895             mintFEModelIndex))
00896             throw eNotFound;
00897         if(mpaWriteModels[mintFEModelIndex].mintModelType != eFEModel)
00898             throw eNotFound;
00899
00900         // Create the object that manages FEA model file transactions and have
00901         // it begin its model write.
00902         mpWriteFEModel = new CFEModel();
00903         if(!mpWriteFEModel)
00904             throw eMemoryError;
00905
00906         mpaWriteModels[mintFEModelIndex].mintModelOffset =
00907             mpWriteFEModel->InitWrite(mpWriteFile.file(), xintGeomCount, xintGroupCount,
00908             xintBlockCount, xintNodeSetCount, xintSideSetCount);
00909         return eSuccess;
00910     }
00911     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
00912     catch(...)  {  return eUnknownError;  }
00913 }
00914
00915 // Try to write the nodes for the passed geometry index/ID to the writable file
00916 UnsignedInt32 CCubitFile::WriteNodes(UnsignedInt32 xintIndex,
00917                                      UnsignedInt32 xintGeomID,
00918                                      UnsignedInt32 xintNodeCount,
00919                                      UnsignedInt32 *xpaintNodeIDs,
00920                                      double *xpadblX,
00921                                      double *xpadblY,
00922                                      double *xpadblZ)
00923 {
00924   try
00925   {
00926     if(!mpWriteFEModel)
00927       throw eOrderError;
00928     mpWriteFEModel->WriteNodes(xintIndex, xintGeomID,
00929                                xintNodeCount, xpaintNodeIDs,
00930                                xpadblX, xpadblY, xpadblZ);
00931   }
00932   catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
00933   catch(...)  {  return eUnknownError;  }
00934   return eSuccess;
00935 }
00936
00937 UnsignedInt32 CCubitFile::WriteElems(UnsignedInt32 xintIndex,
00938                                      UnsignedInt32 xintNumTypes,
00939                                      SElemData* xpaElemData)
00940 // Try to write the element connectivity for the passed geometry index/ID
00941 // to the writable file.
00942 {
00943     try {
00944         if(!mpWriteFEModel)
00945             throw eOrderError;
00946         mpWriteFEModel->WriteElems(xintIndex, xintNumTypes, xpaElemData);
00947         return eSuccess;
00948     }
00949     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
00950     catch(...)  {  return eUnknownError;  }
00951 }
00952
00953 UnsignedInt32 CCubitFile::WriteGroup(UnsignedInt32 xintIndex,
00954                                      UnsignedInt32 xintGroupID,
00955                                      UnsignedInt32 xintGroupType,
00956                                      ConstCharPtr xpachrGroupName,
00957                                      UnsignedInt32 xintNumTypes,
00958                                      SGroupData* xpaGroupData)
00959 // Try to write the membership of the passed group index to the writable file.
00960 // RETURNS: 0 on success, other values indicate error code.
00961 {
00962     try {
00963         if(!mpWriteFEModel)
00964             throw eOrderError;
00965         mpWriteFEModel->WriteGroup(xintIndex, xintGroupID,
00966             xintGroupType, xpachrGroupName, xintNumTypes, xpaGroupData);
00967         return eSuccess;
00968     }
00969     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
00970     catch(...)  {  return eUnknownError;  }
00971 }
00972
00973 UnsignedInt32 CCubitFile::WriteBlock(UnsignedInt32 xintIndex,
00974                                      UnsignedInt32 xintBlockID,
00975                                      int unique_id,
00976                                      UnsignedInt32 xintBlockType,
00977                                      UnsignedInt32 xintBlockColor,
00978                                      UnsignedInt32 xintMixedElemType,
00979                                      UnsignedInt32 xintDefPyramidType,
00980                                      UnsignedInt32 xintMaterialID,
00981                                      UnsignedInt32 xintBlockDimension,
00982                                      UnsignedInt32 xintNumTypes,
00983                                      SBlockData* xpaBlockData,
00984                                      UnsignedInt32 xintAttributeOrder,
00985                                      double* xpadblAttributes)
00986 // Try to write the membership of the passed group index to the writable file.
00987 // RETURNS: 0 on success, other values indicate error code.
00988 {
00989     try {
00990         if(!mpWriteFEModel)
00991             throw eOrderError;
00992         mpWriteFEModel->WriteBlock(xintIndex, xintBlockID, unique_id, xintBlockType,
00993             xintBlockColor, xintMixedElemType, xintDefPyramidType,
00994             xintMaterialID, xintBlockDimension, xintNumTypes, xpaBlockData,
00995             xintAttributeOrder, xpadblAttributes);
00996         return eSuccess;
00997     }
00998     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
00999     catch(...)  {  return eUnknownError;  }
01000 }
01001
01002 UnsignedInt32 CCubitFile::WriteNodeSet(UnsignedInt32 xintIndex,
01003                                        UnsignedInt32 xintNodeSetID,
01004                                        int unique_id,
01005                                        UnsignedInt32 xintColor,
01006                                        UnsignedInt32 xintPointSymbol,
01007                                        UnsignedInt32 xintNumTypes,
01008                                        SNodeSetData* xpaNodeSetData,
01009                                        const std::vector<char>& bcdata)
01010 // Try to write the membership of the passed group index to the writable file.
01011 // RETURNS: 0 on success, other values indicate error code.
01012 {
01013     try {
01014         if(!mpWriteFEModel)
01015             throw eOrderError;
01016         mpWriteFEModel->WriteNodeSet(xintIndex, xintNodeSetID, unique_id, xintColor,
01017             xintPointSymbol, xintNumTypes, xpaNodeSetData, bcdata);
01018         return eSuccess;
01019     }
01020     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01021     catch(...)  {  return eUnknownError;  }
01022 }
01023
01024 UnsignedInt32 CCubitFile::WriteSideSet_11(UnsignedInt32 xintIndex,
01025                                        UnsignedInt32 xintSideSetID,
01026                                        int unique_id,
01027                                        UnsignedInt32 xintColor,
01028                                        UnsignedInt32 xintUseShells,
01029                                        UnsignedInt32 xintNumTypes,
01030                                        SSideSetData_11* xpaSideSetData,
01031                                        UnsignedInt32 xintNumDistFact,
01032                                        double* xpadblDistribution,
01033                                        const std::vector<char>& bcdata)
01034 // Try to write the membership of the passed group index to the writable file.
01035 // RETURNS: 0 on success, other values indicate error code.
01036 {
01037     try {
01038         if(!mpWriteFEModel)
01039             throw eOrderError;
01040         mpWriteFEModel->WriteSideSet_11(xintIndex, xintSideSetID, unique_id, xintColor,
01041             xintUseShells, xintNumTypes, xpaSideSetData, xintNumDistFact,
01042             xpadblDistribution, bcdata);
01043         return eSuccess;
01044     }
01045     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01046     catch(...)  {  return eUnknownError;  }
01047 }
01048
01049 UnsignedInt32 CCubitFile::EndWriteFEModel()
01050 // Designate the end of writing a FEA model and free any memory allocated for
01051 // the write operations and update the file contents header.
01052 // RETURNS: 0 on success, other values indicate error code.
01053 {
01054     try {
01055         if(!mpWriteFEModel)
01056             throw eOrderError;
01057         mpaWriteModels[mintFEModelIndex].mintModelLength =
01058             mpWriteFEModel->EndWrite();
01059         delete mpWriteFEModel;
01060         mpWriteFEModel = NULL;
01061
01062         UnsignedInt32 lintReadIndex;
01063         if(FindModel(mpaWriteModels[mintFEModelIndex].mintModelHandle,
01064             mpaReadModels, mReadContents.mintNumModels, lintReadIndex))
01065             mpaReadModelStat[lintReadIndex] = eStatWritten;
01066
01067         return eSuccess;
01068     }
01069     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01070     catch(...)  {  return eUnknownError;  }
01071 }
01072
01073 //-----------------------------------------------------------------------------
01074
01075 UnsignedInt32 CCubitFile::BeginReadFEModel(HModel xintFEModel,
01076                                            UnsignedInt32& xintGeomCount,
01077                                            UnsignedInt32& xintGroupCount,
01078                                            UnsignedInt32& xintBlockCount,
01079                                            UnsignedInt32& xintNodeSetCount,
01080                                            UnsignedInt32& xintSideSetCount)
01081 // Prepares the file for the reading of a FEA model.  After this call there
01082 // should be no other read oprations on the file not associated with the
01083 // reading of the FEA model until a matching call is made to EndReadFEModel.
01084 // RETURNS: 0 on success, other values indicate error code.
01085 {
01086     try {
01087         if(!mpReadFile)  throw eFileReadError;
01088         if(mpReadFEModel)  throw eOrderError;
01089
01090         UnsignedInt32 lintIndex;
01091         if(!FindModel(xintFEModel, mpaReadModels, mReadContents.mintNumModels,
01092             lintIndex))
01093             throw eNotFound;
01094         if(mpaReadModels[lintIndex].mintModelType != eFEModel)
01095             throw eNotFound;
01096
01097         mpReadFEModel = new CFEModel();
01098         if(!mpReadFEModel)  throw eMemoryError;
01099
01100         mpReadFEModel->InitRead(mpReadFile.file(), mpaReadModels[lintIndex].mintModelOffset,
01101             xintGeomCount, xintGroupCount,
01102             xintBlockCount, xintNodeSetCount, xintSideSetCount);
01103         return eSuccess;
01104     }
01105     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01106     catch(...)  {  return eUnknownError;  }
01107 }
01108
01109 UnsignedInt32 CCubitFile::ReadNodes(UnsignedInt32 xintIndex,
01110                                     UnsignedInt32& xintGeomID,
01111                                     UnsignedInt32& xintNodeCount,
01112                                     UnsignedInt32*& xpaintNodeIDs,
01113                                     double*& xpadblX,
01114                                     double*& xpadblY,
01115                                     double*& xpadblZ)
01116 // Try to read the nodes for the passed geometry index/ID from the
01117 // read-only file.
01118 // RETURNS: 0 on success, other values indicate error code.
01119 {
01120     UnsignedInt32 lintErrorCode;
01121     try {
01122         if(!mpReadFEModel)
01123             throw eOrderError;
01124         mpReadFEModel->ReadNodes(xintIndex, xintGeomID,
01125             xintNodeCount, xpaintNodeIDs, xpadblX, xpadblY, xpadblZ);
01126         return eSuccess;
01127     }
01128     catch(EErrorCode xeErrorCode) {
01129         lintErrorCode = xeErrorCode;
01130     }
01131     catch(...) {
01132         lintErrorCode = eUnknownError;
01133     }
01134     xintNodeCount = 0;
01135     xpaintNodeIDs = NULL;
01136     xpadblX = xpadblY = xpadblZ = NULL;
01137     return lintErrorCode;
01138 }
01139
01140 UnsignedInt32 CCubitFile::ReadElems(HModel meshModelId,
01141                                     UnsignedInt32 xintIndex,
01142                                     UnsignedInt32& xintGeomID,
01143                                     UnsignedInt32& xintNumTypes,
01144                                     SElemData*& xpaElemData)
01145 // Try to read the element connectivity for the passed geometry index/ID
01146 // from the read-only file.
01147 // RETURNS: 0 on success, other values indicate error code.
01148 {
01149     UnsignedInt32 lintErrorCode;
01150     try {
01151
01152       CMetaData *mmd = NULL;
01153       this->GetReadMetaData(CCubitFile::eModelMetaData, mmd);
01154       if( !mmd )
01155       {
01156         throw eFileReadError;
01157       }
01158
01159       // get the data version from the file.
01160       // Version 1.0 has an old element type enum
01161       double data_version = 0.0;
01162       mmd->GetValue(meshModelId, "DataVersion", data_version);
01163
01164       if(!mpReadFEModel)
01165             throw eOrderError;
01166         mpReadFEModel->ReadElems(data_version, xintIndex, xintGeomID,
01167             xintNumTypes, xpaElemData);
01168         return eSuccess;
01169     }
01170     catch(EErrorCode xeErrorCode) {
01171         lintErrorCode = xeErrorCode;
01172     }
01173     catch(...) {
01174         lintErrorCode = eUnknownError;
01175     }
01176     xintNumTypes = 0;
01177     xpaElemData = NULL;
01178     return lintErrorCode;
01179 }
01180
01181 UnsignedInt32 CCubitFile::ReadGroupIdentity(UnsignedInt32 xintIndex,
01182                                             UnsignedInt32& xintGroupID,
01183                                             UnsignedInt32& xintGroupType,
01184                                             ConstCharPtr& xpachrGroupName)
01185 // Try to read the identity (ID, name, type) of the passed group index from the
01186 // read-only file.
01187 // RETURNS: 0 on success, other values indicate error code.
01188 {
01189     UnsignedInt32 lintErrorCode;
01190     try {
01191         if(!mpReadFEModel)
01192             throw eOrderError;
01193         mpReadFEModel->ReadGroupIdentity(xintIndex,
01194             xintGroupID, xintGroupType, xpachrGroupName);
01195         return eSuccess;
01196     }
01197     catch(EErrorCode xeErrorCode) {
01198         lintErrorCode = xeErrorCode;
01199     }
01200     catch(...) {
01201         lintErrorCode = eUnknownError;
01202     }
01203     xintGroupID = xintGroupType = 0;
01204     xpachrGroupName = NULL;
01205     return lintErrorCode;
01206 }
01207
01208 UnsignedInt32 CCubitFile::ReadGroupMembers(UnsignedInt32 xintIndex,
01209                                            UnsignedInt32& xintNumTypes,
01210                                            SGroupData*& xpaGroupData)
01211 // Try to read the membership of the passed group index from the read-only file.
01212 // Note: The
01213 // RETURNS: 0 on success, other values indicate error code.
01214 {
01215     UnsignedInt32 lintErrorCode;
01216     try {
01217         if(!mpReadFEModel)
01218             throw eOrderError;
01219         mpReadFEModel->ReadGroupMembers(xintIndex, xintNumTypes, xpaGroupData);
01220         return eSuccess;
01221     }
01222     catch(EErrorCode xeErrorCode) {
01223         lintErrorCode = xeErrorCode;
01224     }
01225     catch(...) {
01226         lintErrorCode = eUnknownError;
01227     }
01228     xintNumTypes = 0;
01229     xpaGroupData = NULL;
01230     return lintErrorCode;
01231 }
01232
01233 UnsignedInt32 CCubitFile::ReadBlock(UnsignedInt32 xintIndex,
01234                                     UnsignedInt32& xintBlockID,
01235                                     int& unique_id,
01236                                     UnsignedInt32& xintBlockType,
01237                                     UnsignedInt32& xintBlockColor,
01238                                     UnsignedInt32& xintMixedElemType,
01239                                     UnsignedInt32& xintDefPyramidType,
01240                                     UnsignedInt32& xintMaterialID,
01241                                     UnsignedInt32& xintBlockDimension,
01242                                     UnsignedInt32& xintNumTypes,
01243                                     SBlockData*& xpaBlockData,
01244                                     UnsignedInt32& xintAttributeOrder,
01245                                     double*& xpadblAttributes)
01246 // Try to read the membership of the passed block index from the read-only file.
01247 // Note: The
01248 // RETURNS: 0 on success, other values indicate error code.
01249 {
01250     UnsignedInt32 lintErrorCode;
01251     try {
01252         if(!mpReadFEModel)
01253             throw eOrderError;
01254         mpReadFEModel->ReadBlock(xintIndex, xintBlockID, unique_id,
01255             xintBlockType, xintBlockColor, xintMixedElemType,
01256             xintDefPyramidType, xintMaterialID, xintBlockDimension,
01257             xintNumTypes, xpaBlockData, xintAttributeOrder, xpadblAttributes);
01258         return eSuccess;
01259     }
01260     catch(EErrorCode xeErrorCode) {
01261         lintErrorCode = xeErrorCode;
01262     }
01263     catch(...) {
01264         lintErrorCode = eUnknownError;
01265     }
01266     xintBlockID = xintBlockType = xintBlockColor = xintMixedElemType =
01267         xintDefPyramidType = xintMaterialID = xintNumTypes =
01268         xintAttributeOrder = 0;
01269     xpaBlockData = NULL;
01270     xpadblAttributes = NULL;
01271     return lintErrorCode;
01272 }
01273
01274 UnsignedInt32 CCubitFile::ReadNodeSet(UnsignedInt32 xintIndex,
01275                                       UnsignedInt32& xintNodeSetID,
01276                                       int& unique_id,
01277                                       UnsignedInt32& xintColor,
01278                                       UnsignedInt32& xintPointSymbol,
01279                                       UnsignedInt32& xintNumTypes,
01280                                       SNodeSetData*& xpaNodeSetData,
01281                                       std::vector<char>& bcdata)
01282 // Try to read the membership of the passed node set index from the read-only file.
01283 // Note: The
01284 // RETURNS: 0 on success, other values indicate error code.
01285 {
01286     UnsignedInt32 lintErrorCode;
01287     try {
01288         if(!mpReadFEModel)
01289             throw eOrderError;
01290         mpReadFEModel->ReadNodeSet(xintIndex, xintNodeSetID, unique_id,
01291             xintColor, xintPointSymbol, xintNumTypes, xpaNodeSetData, bcdata);
01292         return eSuccess;
01293     }
01294     catch(EErrorCode xeErrorCode) {
01295         lintErrorCode = xeErrorCode;
01296     }
01297     catch(...) {
01298         lintErrorCode = eUnknownError;
01299     }
01300     xintNodeSetID = xintColor = xintPointSymbol = xintNumTypes = 0;
01301     xpaNodeSetData = NULL;
01302     return lintErrorCode;
01303 }
01304
01305 UnsignedInt32 CCubitFile::ReadSideSet_10(UnsignedInt32 xintIndex,
01306                                       UnsignedInt32& xintSideSetID,
01307                                       UnsignedInt32& xintColor,
01308                                       UnsignedInt32& xintUseShells,
01309                                       UnsignedInt32& xintNumTypes,
01310                                       SSideSetData_10*& xpaSideSetData,
01311                                       UnsignedInt32& xintNumDistFact,
01312                                       double*& xpadblDistribution)
01313 // Try to read the membership of the passed side set index from the read-only file.
01314 // Note: The
01315 // RETURNS: 0 on success, other values indicate error code.
01316 {
01317     UnsignedInt32 lintErrorCode;
01318     try {
01319         if(!mpReadFEModel)
01320             throw eOrderError;
01321         mpReadFEModel->ReadSideSet_10(xintIndex, xintSideSetID,
01322             xintColor, xintUseShells, xintNumTypes, xpaSideSetData,
01323             xintNumDistFact, xpadblDistribution);
01324         return eSuccess;
01325     }
01326     catch(EErrorCode xeErrorCode) {
01327         lintErrorCode = xeErrorCode;
01328     }
01329     catch(...) {
01330         lintErrorCode = eUnknownError;
01331     }
01332     xintSideSetID = xintColor = xintNumTypes = xintNumDistFact = 0;
01333     xpaSideSetData = NULL;
01334     xpadblDistribution = NULL;
01335     return lintErrorCode;
01336 }
01337
01338 UnsignedInt32 CCubitFile::ReadSideSet_11(UnsignedInt32 xintIndex,
01339                                       UnsignedInt32& xintSideSetID,
01340                                       int& unique_id,
01341                                       UnsignedInt32& xintColor,
01342                                       UnsignedInt32& xintUseShells,
01343                                       UnsignedInt32& xintNumTypes,
01344                                       SSideSetData_11*& xpaSideSetData,
01345                                       UnsignedInt32& xintNumDistFact,
01346                                       double*& xpadblDistribution,
01347                                       std::vector<char>& bcdata)
01348 // Try to read the membership of the passed side set index from the read-only file.
01349 // Note: The
01350 // RETURNS: 0 on success, other values indicate error code.
01351 {
01352     UnsignedInt32 lintErrorCode;
01353     try {
01354         if(!mpReadFEModel)
01355             throw eOrderError;
01356         mpReadFEModel->ReadSideSet_11(xintIndex, xintSideSetID, unique_id,
01357             xintColor, xintUseShells, xintNumTypes, xpaSideSetData,
01358             xintNumDistFact, xpadblDistribution, bcdata);
01359         return eSuccess;
01360     }
01361     catch(EErrorCode xeErrorCode) {
01362         lintErrorCode = xeErrorCode;
01363     }
01364     catch(...) {
01365         lintErrorCode = eUnknownError;
01366     }
01367     xintSideSetID = xintColor = xintNumTypes = xintNumDistFact = 0;
01368     xpaSideSetData = NULL;
01369     xpadblDistribution = NULL;
01370     return lintErrorCode;
01371 }
01372
01373 UnsignedInt32 CCubitFile::EndReadFEModel()
01374 // Designate the end of reading a FEA model and free any memory allocated for
01375 // the read operations.
01376 // RETURNS: 0 on success, other values indicate error code.
01377 {
01378     try {
01379         if(!mpReadFEModel)
01380             return eOrderError;
01381         mpReadFEModel->EndRead();
01382         delete mpReadFEModel;
01383         mpReadFEModel = NULL;
01384         return eSuccess;
01385     }
01386     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01387     catch(...)  {  return eUnknownError;  }
01388 }
01389
01390 UnsignedInt32 CCubitFile::BeginWriteSimModel(HModel xintSimModel,
01391                                              UnsignedInt32 xintBCCount,
01392                                              UnsignedInt32 xintICCount,
01393                                              UnsignedInt32 xintBCSetCount,
01394                                              UnsignedInt32 xintMaterialCount,
01395                                              UnsignedInt32 xintAmplitudeCount,
01396                                              UnsignedInt32 xintConstraintCount)
01397 {
01398     try {
01399         if(!mpWriteFile)  throw eFileWriteError;
01400         if(mpWriteSimModel)  throw eOrderError;
01401
01402         // Write the model table first to try to guarentee that it will be
01403         // at the beginning of the file.
01404         WriteModelTable();
01405
01406         // Lookup the requested model in the model table and make sure it is
01407         // an FEA model.
01408         if(!FindModel(xintSimModel, mpaWriteModels, mWriteContents.mintNumModels,
01409             mintSimModelIndex))
01410             throw eNotFound;
01411         if(mpaWriteModels[mintSimModelIndex].mintModelType != eSimModel)
01412             throw eNotFound;
01413
01414         // Create the object that manages FEA model file transactions and have
01415         // it begin its model write.
01416         mpWriteSimModel = new CSimModel();
01417         if(!mpWriteSimModel)
01418             throw eMemoryError;
01419
01420         mpaWriteModels[mintSimModelIndex].mintModelOffset =
01421             mpWriteSimModel->InitWrite(mpWriteFile.file(), xintBCCount,
01422                                        xintICCount, xintBCSetCount,
01423                                        xintMaterialCount, xintAmplitudeCount,
01424                                        xintConstraintCount);
01425         return eSuccess;
01426     }
01427     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01428     catch(...)  {  return eUnknownError;  }
01429 }
01430
01431 UnsignedInt32 CCubitFile::WriteBCSet(UnsignedInt32 xintIndex,
01432                                      UnsignedInt32 xintBCSetID,
01433                                      UnsignedInt32 xintBCSetUniqueID,
01434                                      UnsignedInt32 xintBCSetAnalysisType,
01435                                      UnsignedInt32 xintRestraintTypesCount,
01436                                      UnsignedInt32 xintLoadTypesCount,
01437                                      UnsignedInt32 xintContactPairTypesCount,
01438                                      SBCSetData* xpaBCSetRestraintData,
01439                                      SBCSetData* xpaBCSetLoadData,
01440                                      SBCSetData* xpaBCSetContactPairData)
01441 // Try to write the membership of the passed group index to the writable file.
01442 // RETURNS: 0 on success, other values indicate error code.
01443 {
01444     try {
01445         if(!mpWriteSimModel)
01446             throw eOrderError;
01447
01448         mpWriteSimModel->WriteBCSet(xintIndex,xintBCSetID,xintBCSetUniqueID,
01449             xintBCSetAnalysisType,xintRestraintTypesCount,xintLoadTypesCount,
01450             xintContactPairTypesCount,xpaBCSetRestraintData,
01451             xpaBCSetLoadData,xpaBCSetContactPairData);
01452
01453         return eSuccess;
01454     }
01455     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01456     catch(...)  {  return eUnknownError;  }
01457 }
01458
01459 UnsignedInt32 CCubitFile::WriteMaterial(UnsignedInt32 xintIndex,
01460                                         UnsignedInt32 xintMaterialID,
01461                                         UnsignedInt32 xintMaterialUniqueID,
01462                                         UnsignedInt32 xintPropertiesCount,
01463                                         SMaterialData* xpaMaterialData
01464                                         )
01465 {
01466     try {
01467         if(!mpWriteSimModel)
01468             throw eOrderError;
01469
01470         mpWriteSimModel->WriteMaterial(xintIndex,xintMaterialID,xintMaterialUniqueID,
01471             xintPropertiesCount,xpaMaterialData);
01472
01473         return eSuccess;
01474     }
01475     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01476     catch(...)  {  return eUnknownError;  }
01477 }
01478
01479 UnsignedInt32 CCubitFile::WriteConstraint(UnsignedInt32 xintIndex,
01480                                 UnsignedInt32 xintConstraintID,
01481                                 UnsignedInt32 xintConstraintUniqueID,
01482                                 UnsignedInt32 xintConstraintType,
01483                                 UnsignedInt32 xintIndependentTypeCount,
01484                                 SConstraintData* xpaIndependentData,
01485                                 UnsignedInt32 xintDependentTypeCount,
01486                                 SConstraintData* xpaDependentData
01487                                 )
01488 {
01489     try {
01490         if(!mpWriteSimModel)
01491             throw eOrderError;
01492
01493         mpWriteSimModel->WriteConstraint(xintIndex,xintConstraintID,xintConstraintUniqueID,
01494             xintConstraintType,xintIndependentTypeCount,xpaIndependentData,
01495             xintDependentTypeCount,xpaDependentData);
01496
01497         return eSuccess;
01498     }
01499     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01500     catch(...)  {  return eUnknownError;  }
01501 }
01502
01503 UnsignedInt32 CCubitFile::EndWriteSimModel()
01504 {
01505     try {
01506         if(!mpWriteSimModel)
01507             throw eOrderError;
01508         mpaWriteModels[mintSimModelIndex].mintModelLength =
01509             mpWriteSimModel->EndWrite();
01510         delete mpWriteSimModel;
01511         mpWriteSimModel = NULL;
01512
01513         UnsignedInt32 lintReadIndex;
01514         if(FindModel(mpaWriteModels[mintSimModelIndex].mintModelHandle,
01515             mpaReadModels, mReadContents.mintNumModels, lintReadIndex))
01516             mpaReadModelStat[lintReadIndex] = eStatWritten;
01517
01518         return eSuccess;
01519     }
01520     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01521     catch(...)  {  return eUnknownError;  }
01522 }
01523
01524 UnsignedInt32 CCubitFile::BeginReadSimModel(HModel xintSimModel,
01525                                             UnsignedInt32& xintBCCount,
01526                                             UnsignedInt32& xintICCount,
01527                                             UnsignedInt32& xintBCSetCount,
01528                                             UnsignedInt32& xintMaterialCount,
01529                                             UnsignedInt32& xintAmplitudeCount,
01530                                             UnsignedInt32& xintConstraintCount)
01531 {
01532     try {
01533         if(!mpReadFile)  throw eFileReadError;
01534         if(mpReadSimModel)  throw eOrderError;
01535
01536         UnsignedInt32 lintIndex;
01537         if(!FindModel(xintSimModel, mpaReadModels, mReadContents.mintNumModels,
01538             lintIndex))
01539             throw eNotFound;
01540         if(mpaReadModels[lintIndex].mintModelType != eSimModel)
01541             throw eNotFound;
01542
01543         mpReadSimModel = new CSimModel();
01544         if(!mpReadSimModel)  throw eMemoryError;
01545
01546         mpReadSimModel->InitRead(mpReadFile.file(), mpaReadModels[lintIndex].mintModelOffset,
01547                                  xintBCCount, xintICCount, xintBCSetCount,
01548                                  xintMaterialCount, xintAmplitudeCount,
01549                                  xintConstraintCount);
01550         return eSuccess;
01551     }
01552     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01553     catch(...)  {  return eUnknownError;  }
01554 }
01555
01556 UnsignedInt32 CCubitFile::ReadBCSet(UnsignedInt32 xintIndex,
01557                                     UnsignedInt32& xintBCSetID,
01558                                     UnsignedInt32& xintBCSetUniqueID,
01559                                     UnsignedInt32& xintBCSetAnalysisType,
01560                                     UnsignedInt32& xintRestraintTypesCount,
01561                                     UnsignedInt32& xintLoadTypesCount,
01562                                     UnsignedInt32& xintContactPairTypesCount,
01563                                     SBCSetData*& xpaBCSetRestraintData,
01564                                     SBCSetData*& xpaBCSetLoadData,
01565                                     SBCSetData*& xpaBCSetContactPairData)
01566 // Try to read the membership of the passed node set index from the read-only file.
01567 // Note: The
01568 // RETURNS: 0 on success, other values indicate error code.
01569 {
01570     UnsignedInt32 lintErrorCode;
01571     try {
01572         if(!mpReadSimModel)
01573             throw eOrderError;
01574
01575         mpReadSimModel->ReadBCSet(xintIndex,xintBCSetID,xintBCSetUniqueID,
01576             xintBCSetAnalysisType,xintRestraintTypesCount,
01577             xintLoadTypesCount,xintContactPairTypesCount,xpaBCSetRestraintData,
01578             xpaBCSetLoadData,xpaBCSetContactPairData);
01579
01580         return eSuccess;
01581     }
01582     catch(EErrorCode xeErrorCode) {
01583         lintErrorCode = xeErrorCode;
01584     }
01585     catch(...) {
01586         lintErrorCode = eUnknownError;
01587     }
01588     xintBCSetID = xintBCSetUniqueID = xintBCSetAnalysisType = 0;
01589     xintRestraintTypesCount = xintLoadTypesCount = xintContactPairTypesCount = 0;
01590     xpaBCSetRestraintData = NULL;
01591     xpaBCSetLoadData = NULL;
01592     xpaBCSetContactPairData = NULL;
01593     return lintErrorCode;
01594 }
01595
01596 UnsignedInt32 CCubitFile::ReadMaterial(UnsignedInt32 xintIndex,
01597                                        UnsignedInt32& xintMaterialID,
01598                                        UnsignedInt32& xintMaterialUniqueID,
01599                                        UnsignedInt32& xintPropertiesCount,
01600                                        SMaterialData*& xpaMaterialData
01601                                        )
01602 {
01603     UnsignedInt32 lintErrorCode;
01604     try {
01605         if(!mpReadSimModel)
01606             throw eOrderError;
01607
01608         mpReadSimModel->ReadMaterial(xintIndex,xintMaterialID,xintMaterialUniqueID,
01609             xintPropertiesCount,xpaMaterialData);
01610
01611         return eSuccess;
01612     }
01613     catch(EErrorCode xeErrorCode) {
01614         lintErrorCode = xeErrorCode;
01615     }
01616     catch(...) {
01617         lintErrorCode = eUnknownError;
01618     }
01619     xintMaterialID = xintMaterialUniqueID = xintPropertiesCount = 0;
01620     xpaMaterialData = NULL;
01621     return lintErrorCode;
01622 }
01623
01624 UnsignedInt32 CCubitFile::ReadConstraint(UnsignedInt32 xintIndex,
01625                                UnsignedInt32& xintConstraintID,
01626                                UnsignedInt32& xintConstraintUniqueID,
01627                                UnsignedInt32& xintConstraintType,
01628                                UnsignedInt32& xintIndependentTypeCount,
01629                                SConstraintData*& xpaIndependentData,
01630                                UnsignedInt32& xintDependentTypeCount,
01631                                SConstraintData*& xpaDependentData
01632                                )
01633 {
01634     UnsignedInt32 lintErrorCode;
01635     try {
01636         if(!mpReadSimModel)
01637             throw eOrderError;
01638
01639         mpReadSimModel->ReadConstraint(xintIndex,xintConstraintID,xintConstraintUniqueID,
01640             xintConstraintType,xintIndependentTypeCount,xpaIndependentData,
01641             xintDependentTypeCount,xpaDependentData);
01642
01643         return eSuccess;
01644     }
01645     catch(EErrorCode xeErrorCode) {
01646         lintErrorCode = xeErrorCode;
01647     }
01648     catch(...) {
01649         lintErrorCode = eUnknownError;
01650     }
01651     xintConstraintID = xintConstraintUniqueID = xintConstraintType = 0;
01652     xpaIndependentData = xpaDependentData = NULL;
01653     return lintErrorCode;
01654 }
01655
01656 UnsignedInt32 CCubitFile::EndReadSimModel()
01657 {
01658     try {
01659         if(!mpReadSimModel)
01660             return eOrderError;
01661         mpReadSimModel->EndRead();
01662         delete mpReadSimModel;
01663         mpReadSimModel = NULL;
01664         return eSuccess;
01665     }
01666     catch(EErrorCode xeErrorCode)  {  return xeErrorCode;  }
01667     catch(...)  {  return eUnknownError;  }
01668 }
01669
01671 // Meta-data accessors
01673
01674 UnsignedInt32 CCubitFile::GetReadMetaData(EMetaDataOwnerType xeType,
01675                                           CMetaData*& xpMetaData)
01676 // Return the requested meta-data object for the read file if possible.
01677 {
01678     xpMetaData = NULL;
01679     if(xeType == eModelMetaData)
01680         xpMetaData = mpMetaData;
01681     else if(mpReadFEModel) {
01682         switch(xeType) {
01683         case eGeomMetaData:
01684             xpMetaData = &mpReadFEModel->GetGeomMetaData();
01685             break;
01686         case eNodeMetaData:
01687             xpMetaData = &mpReadFEModel->GetNodeMetaData();
01688             break;
01689         case eElemMetaData:
01690             xpMetaData = &mpReadFEModel->GetElemMetaData();
01691             break;
01692         case eGroupMetaData:
01693             xpMetaData = &mpReadFEModel->GetGroupMetaData();
01694             break;
01695         case eBlockMetaData:
01696             xpMetaData = &mpReadFEModel->GetBlockMetaData();
01697             break;
01698         case eNodeSetMetaData:
01699             xpMetaData = &mpReadFEModel->GetNodeSetMetaData();
01700             break;
01701         case eSideSetMetaData:
01702             xpMetaData = &mpReadFEModel->GetSideSetMetaData();
01703             break;
01704           default:
01705             break;
01706         }
01707     }
01708     else if (mpReadSimModel) {
01709         switch (xeType) {
01710             case eBCSetMetaData:
01711                 xpMetaData = &mpReadSimModel->GetBCSetMetaData();
01712                 break;
01713             case eMaterialMetaData:
01714                 xpMetaData = &mpReadSimModel->GetMaterialMetaData();
01715                 break;
01716             case eConstraintMetaData:
01717                 xpMetaData = &mpReadSimModel->GetConstraintMetaData();
01718                 break;
01719             default:
01720                 break;
01721         }
01722     }
01723     else
01724         return eOrderError;
01725     return xpMetaData ? eSuccess : eNotFound;
01726 }
01727
01728 UnsignedInt32 CCubitFile::GetWriteMetaData(EMetaDataOwnerType xeType,
01729                                            CMetaData*& xpMetaData)
01730 // Return the requested meta-data object for the write file if possible.
01731 {
01732     xpMetaData = NULL;
01733     if(xeType == eModelMetaData)
01734         xpMetaData = mpMetaData;
01735     else if(mpWriteFEModel) {
01736         switch(xeType) {
01737         case eGeomMetaData:
01738             xpMetaData = &mpWriteFEModel->GetGeomMetaData();
01739             break;
01740         case eNodeMetaData:
01741             xpMetaData = &mpWriteFEModel->GetNodeMetaData();
01742             break;
01743         case eElemMetaData:
01744             xpMetaData = &mpWriteFEModel->GetElemMetaData();
01745             break;
01746         case eGroupMetaData:
01747             xpMetaData = &mpWriteFEModel->GetGroupMetaData();
01748             break;
01749         case eBlockMetaData:
01750             xpMetaData = &mpWriteFEModel->GetBlockMetaData();
01751             break;
01752         case eNodeSetMetaData:
01753             xpMetaData = &mpWriteFEModel->GetNodeSetMetaData();
01754             break;
01755         case eSideSetMetaData:
01756             xpMetaData = &mpWriteFEModel->GetSideSetMetaData();
01757             break;
01758           default:
01759               break;
01760         }
01761     }
01762     else if (mpWriteSimModel) {
01763         switch (xeType) {
01764             case eBCSetMetaData:
01765                 xpMetaData = &mpWriteSimModel->GetBCSetMetaData();
01766                 break;
01767             case eMaterialMetaData:
01768                 xpMetaData = &mpWriteSimModel->GetMaterialMetaData();
01769                 break;
01770             case eConstraintMetaData:
01771                 xpMetaData = &mpWriteSimModel->GetConstraintMetaData();
01772                 break;
01773             default:
01774                 break;
01775         }
01776     }
01777     else
01778         return eOrderError;
01779     return xpMetaData ? eSuccess : eNotFound;
01780 }
