cgma
ChollaCurve.cpp
00001 //- Class:       ChollaCurve
00002 //- Description: Temporary class for constructing the facet-based geometry
00003 //-
00004 //- Owner:       Steven J. Owen
00005 //- Checked by:
00006 //- Version:
00007
00008 #include "CubitVector.hpp"
00009 #include "ChollaCurve.hpp"
00010 #include "ChollaSurface.hpp"
00011 #include "ChollaPoint.hpp"
00012 #include "TDGeomFacet.hpp"
00013 #include "CastTo.hpp"
00014 #include "CubitFacet.hpp"
00015 #include "CubitFacetData.hpp"
00016 #include "CubitFacetEdge.hpp"
00017 #include "CubitFacetEdgeData.hpp"
00018 #include "ChollaDebug.hpp"
00019 #include "GfxDebug.hpp"
00020 #include "CurveFacetEvalTool.hpp"
00021 #include "ChollaEngine.hpp"
00022 #include "ChollaVolume.hpp"
00023 #include "CubitMessage.hpp"
00024
00025
00026 //===============================================================================
00027 //Function:  ChollaCurve (PUBLIC) (constructor)
00028 //===============================================================================
00029 ChollaCurve::ChollaCurve( int block_id )
00030 {
00031   static int count = 1;
00032   id = count++;
00033   myCurve = NULL;
00034   myEvalTool = NULL;
00035   startPoint = NULL;
00036   endPoint = NULL;
00037   blockID = block_id;
00038   myLength = MYLENGTH_UNINITIALIZED;
00039   myMergePartner = NULL;
00040 }
00041
00042 //===============================================================================
00043 //Function:  ~ChollaCurve (PUBLIC) (destructor)
00044 //===============================================================================
00045 ChollaCurve::~ChollaCurve()
00046 {
00047 }
00048
00049 //===============================================================================
00050 //Function:  remove_td_associativity (PUBLIC)
00051 //===============================================================================
00052 void ChollaCurve::remove_td_associativity( ChollaSurface *fsm_ptr )
00053 {
00054   int i;
00055   TDGeomFacet *td;
00056   FacetEntity *edge_ptr;
00057   for(i=0; i<curveEdgeList.size(); i++)
00058   {
00059     edge_ptr = curveEdgeList.get_and_step();
00060     td = TDGeomFacet::get_geom_facet( edge_ptr );
00061     if (td)
00062     {
00063       td->remove_cholla_curve( this );
00064       td->remove_cholla_surf( fsm_ptr );
00065     }
00066   }
00067 }
00068
00069
00070 //=============================================================================
00071 //Function:  get_ends (PUBLIC)
00072 //Description: returns the end locations of the curve.  Determines their
00073 //             location if not yet defined
00074 //Author: sjowen
00075 //Date: 12/4/00
00076 //=============================================================================
00077 CubitStatus ChollaCurve::get_ends( CubitVector &start, CubitVector &end )
00078 {
00079   if (startPoint && endPoint)
00080   {
00081     start = startPoint->coordinates();
00082     end = endPoint->coordinates();
00083   }
00084   else
00085   {
00086     CubitStatus stat = determine_ends();
00087     if (stat == CUBIT_FAILURE)
00088       return stat;
00089     start = startPoint->coordinates();
00090     end = endPoint->coordinates();
00091   }
00092   return CUBIT_SUCCESS;
00093 }
00094
00095 //=============================================================================
00096 //Function:  get_ends (PUBLIC)
00097 //Description: returns the end nodes of the curve.  Determines the
00098 //             nodes if not yet defined
00099 //Author: sjowen
00100 //Date: 12/4/00
00101 //=============================================================================
00102 CubitStatus ChollaCurve::get_ends( CubitPoint *&start_ptr, CubitPoint *&end_ptr )
00103 {
00104   if (startPoint && endPoint )
00105   {
00106     start_ptr = startPoint;
00107     end_ptr = endPoint;
00108   }
00109   else
00110   {
00111     CubitStatus stat = determine_ends();
00112     if (stat == CUBIT_FAILURE)
00113       return stat;
00114     start_ptr = startPoint;
00115     end_ptr = endPoint;
00116   }
00117   return CUBIT_SUCCESS;
00118 }
00119
00120 //=============================================================================
00121 //Function:  split_curve (PRIVATE)
00122 //Description: split this curve into multiple ChollaCurve where there are
00123 //             discontinuous strings of edges.  Define start and end nodes
00124 //             for each curve while we are at it
00125 //Author: sjowen
00126 //Date: 12/4/00
00127 //=============================================================================
00128 CubitStatus ChollaCurve::split_curve(
00129   DLIList<ChollaCurve*> &facet_curve_list)
00130 {
00131   DLIList<ChollaCurve*> new_curve_list;
00132
00133   // Go through the curveEdgeList and pull edges off one by one as we
00134   // determine which curve it belongs to.  Continue until we have depleted
00135   // the list
00136
00137   int periodic = 0;
00138   int start_size = curveEdgeList.size();
00139   int icount = 0;
00140
00141   curveEdgeList.reset();
00142   while( curveEdgeList.size() > 0)
00143   {
00144
00145     // First, find an edge that has a start point on it
00146
00147     CubitFacetEdge *start_edge_ptr = (CubitFacetEdge *)curveEdgeList.get_and_step();
00148     CubitPoint *point0_ptr = start_edge_ptr->point(0);
00149     CubitPoint *point1_ptr = start_edge_ptr->point(1);
00150     CubitPoint *start_point = NULL;
00151     if (periodic)
00152     {
00153       start_point = startPoint;
00154     }
00155     else
00156     {
00157       if (next_edge( point0_ptr, start_edge_ptr ) == NULL)
00158         start_point = point0_ptr;
00159       else if(next_edge( point1_ptr, start_edge_ptr ) == NULL)
00160         start_point = point1_ptr;
00161     }
00162     if (start_point != NULL || periodic)
00163     {
00164
00165       // create a new curve to hold the edge info
00166
00167       TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(start_edge_ptr);
00168       int block_id = (td_gm_edge == NULL) ? -1 : td_gm_edge->get_block_id();
00169       ChollaCurve *fcm_ptr = new ChollaCurve( block_id );
00170       new_curve_list.append( fcm_ptr );
00171
00172       // assign the edges to the new curve in the correct order and orientation
00173
00174       CubitStatus rv = fcm_ptr->build_curve_from_edges( start_point,  periodic, start_size, start_edge_ptr, this );
00175       if (rv != CUBIT_SUCCESS)
00176         return rv;
00177
00178       // remove the edges in the new curve from this curve
00179
00180       int ii;
00181       DLIList<FacetEntity *> flist = fcm_ptr->get_facet_list();
00182       DLIList<CubitFacetEdge *> elist;
00183       CubitFacetEdge *edge_ptr;
00184       CAST_LIST( flist, elist, CubitFacetEdge );
00185       for ( ii = elist.size(); ii > 0; ii-- )
00186       {
00187         edge_ptr = elist.get_and_step();
00188         curveEdgeList.remove( edge_ptr );
00189       }
00190       start_size = curveEdgeList.size();
00191       icount = 0;
00192       periodic = 0;
00193     }
00194
00195     // if we have gone through all of the edges without finding an end,
00196     // then we have a periodic curve.  Choose an arbirary node to act as
00197     // the beginning and end
00198
00199     if (curveEdgeList.size() > 0)
00200     {
00201       icount++;
00202       if (icount > start_size)
00203       {
00204         curveEdgeList.reset();
00205         CubitFacetEdge *edge = (CubitFacetEdge *)curveEdgeList.get();
00206         CubitPoint *point_ptr = edge->point(0);
00207         startPoint = point_ptr;
00208         endPoint = point_ptr;
00209         periodic = 1;
00210       }
00211     }
00212   }
00213
00214   // add the new curves to the global curve list
00215
00216   int ii, jj;
00217   for (ii=new_curve_list.size(); ii>0; ii--)
00218   {
00219     ChollaCurve *fcm_ptr = new_curve_list.get_and_step();
00220
00221     facet_curve_list.append( fcm_ptr );
00222
00223     // update the surface info
00224
00225     for (jj=surfaceList.size(); jj>0; jj--)
00226     {
00227       ChollaSurface *fsm_ptr = surfaceList.get_and_step();
00228       fcm_ptr->add_surface( fsm_ptr );
00229       fsm_ptr->remove_curve( this );
00230       fsm_ptr->add_curve( fcm_ptr );
00231     }
00232
00233     // update the geometric curve pointer
00234
00235     fcm_ptr->assign_geometric_curve( NULL );
00236
00237     // update the curve pointers in the edge tool data
00238
00239     DLIList<FacetEntity*> facet_list = fcm_ptr->get_facet_list();
00240     for (jj=facet_list.size(); jj > 0; jj--)
00241     {
00242       FacetEntity *edge_ptr = facet_list.get_and_step();
00243       TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr);
00244       td_gm_edge->remove_cholla_curve( this );
00245       td_gm_edge->add_cholla_curve( fcm_ptr );
00246     }
00247   }
00248
00249   return CUBIT_SUCCESS;
00250 }
00251
00252 //=============================================================================
00253 //Function: build_curve_from_edges
00254 //Description: insert the ordered and oriented edges into this cholla curve
00255 //Notes:  traverses starting at start_point and gathers facet edges until it
00256 //        runs into another curve.
00257 //        start_point is an existing CubitPoint at either end of the curve
00258 //        max_edges is the maximum number of edges on this curve.  should be
00259 //        known beforehand (used for error checking).
00260 //
00261 // ***this function used to be part of split_curve. ***
00262 //Author: sjowen
00263 //Return:
00264 //Date: 09/07/2009
00265 //=============================================================================
00266 CubitStatus ChollaCurve::build_curve_from_edges( CubitPoint *start_point,
00267                                                 int periodic,
00268                                                 int max_edges,
00269                                                 CubitFacetEdge *start_edge_ptr,
00270                                                 ChollaCurve *parent_curve )
00271 {
00272
00273   // find the first edge.  Match the chollacurve owner with this curve
00274   // do this only if the start_edge_ptr was not passed in
00275
00276   DLIList<CubitFacetEdge *> point_edge_list;
00277   start_point->edges(point_edge_list);
00278   CubitFacetEdge *edge_ptr;
00279   if (start_edge_ptr == NULL)
00280   {
00281     for (int ii=0; ii<point_edge_list.size() && !start_edge_ptr; ii++)
00282     {
00283       edge_ptr = point_edge_list.get_and_step();
00284       TDGeomFacet *td_geom = TDGeomFacet::get_geom_facet( edge_ptr );
00285
00286       // assumes that the TDGeomFacet info has already been set up for the edges
00287       assert(td_geom != NULL);
00288
00289       DLIList<ChollaCurve *> cholla_curves;
00290       td_geom->get_cholla_curves(cholla_curves);
00291
00292       // currently should be only one-to-one relationship
00293       // could also be edge on surface in which case no curves associated
00294       assert(cholla_curves.size() <= 1);
00295       if (cholla_curves.size())
00296       {
00297         if (cholla_curves.get() == this)
00298           start_edge_ptr = edge_ptr;
00299       }
00300     }
00301     assert(start_edge_ptr != NULL);  // didn't find an edge that marched this chollacurve
00302   }
00303
00304   // create a new curve to hold the edge info
00305
00306   this->set_start( start_point );
00307   start_point->set_as_feature();
00308
00309   this->add_facet( start_edge_ptr );
00310   int iedgecount = 0;
00311   edge_ptr = start_edge_ptr;
00312   CubitPoint *point0_ptr = start_point, *point1_ptr;
00313   CubitPoint *end_point = NULL;
00314   while(!end_point)
00315   {
00316     point1_ptr = edge_ptr->other_point( point0_ptr );
00317     if ((edge_ptr = parent_curve->next_edge( point1_ptr, edge_ptr )) == NULL)
00318     {
00319       end_point = point1_ptr;
00320     }
00321     else
00322     {
00323       iedgecount++;
00324       if (iedgecount > max_edges)
00325       {
00326         PRINT_ERROR("ChollaCurve has start, but no end\n");
00327         return CUBIT_FAILURE;
00328       }
00329
00330       this->add_facet( edge_ptr );
00331       if (periodic && point1_ptr == start_point)
00332         end_point = start_point;
00333       point0_ptr = point1_ptr;
00334     }
00335   }
00336   this->set_end( end_point );
00337   end_point->set_as_feature();
00338
00339   // make sure all the edges are oriented correctly
00340
00341   int i;
00342   DLIList<FacetEntity *> flist = this->get_facet_list();
00343   flist.reset();
00344   DLIList<CubitFacetEdge *> elist;
00345   CAST_LIST( flist, elist, CubitFacetEdge );
00346   elist.reset();
00347   CubitPoint *cur_pt = start_point, *tmp_pt;
00348   for ( i = elist.size(); i > 0; i-- )
00349   {
00350     edge_ptr = elist.get_and_step();
00351     point0_ptr = edge_ptr->point(0);
00352     point1_ptr = edge_ptr->point(1);
00353     if (point0_ptr != cur_pt)
00354     {
00355       assert( cur_pt == point1_ptr );
00356       edge_ptr->flip();
00357       tmp_pt = point0_ptr;
00358       point0_ptr = point1_ptr;
00359       point1_ptr = tmp_pt;
00360       assert( point0_ptr == edge_ptr->point(0) &&
00361              point1_ptr == edge_ptr->point(1) );
00362     }
00363     cur_pt = point1_ptr;
00364   }
00365
00366   int mydebug = 0;
00367   if (mydebug)
00368   {
00369     int i;
00370     DLIList<FacetEntity *> flist = this->get_facet_list();
00371     flist.reset();
00372     DLIList<CubitFacetEdge *> elist;
00373     CAST_LIST( flist, elist, CubitFacetEdge );
00374     elist.reset();
00375     for ( i = elist.size(); i > 0; i-- ) {
00376       CubitFacetEdge *edge = elist.get_and_step();
00377       CubitVector pt0_v = edge->point(0)->coordinates();
00378       CubitVector pt1_v = edge->point(1)->coordinates();
00379       GfxDebug::draw_point(pt0_v, CUBIT_GREEN_INDEX );
00380       GfxDebug::draw_point(pt1_v, CUBIT_RED_INDEX );
00381       GfxDebug::draw_line( pt0_v, pt1_v, CUBIT_YELLOW_INDEX );
00382       GfxDebug::flush();
00383       int view = 0;
00384       if (view)
00385         dview();
00386     }
00387   }
00388   return CUBIT_SUCCESS;
00389 }
00390
00391 CubitStatus ChollaCurve::order_edges()
00392 {
00393   int i;
00394   bool periodic = false;
00395   if (NULL == startPoint)
00396   {
00397     DLIList<ChollaPoint *>  cholla_points = get_points();
00398     periodic = (cholla_points.size() == 1);
00399
00400     ChollaPoint *chpt = cholla_points.get();
00401     CubitPoint *start_point = dynamic_cast<CubitPoint *> (chpt->get_facets());
00402
00403     this->set_start( start_point );
00404     if (NULL == start_point)
00405       return CUBIT_FAILURE;
00406     start_point->set_as_feature();
00407
00408     if (periodic)
00409     {
00410       this->set_end(start_point);
00411     }
00412     else
00413     {
00414       chpt = cholla_points.step_and_get();
00415       CubitPoint *end_point = dynamic_cast<CubitPoint *> (chpt->get_facets());
00416       if (NULL == end_point)
00417         return CUBIT_FAILURE;
00418       this->set_end(end_point);
00419       end_point->set_as_feature();
00420     }
00421   }
00422
00423   assert(startPoint);
00424   assert(endPoint);
00425
00426   if (curveEdgeList.size() > 1)
00427   {
00428     DLIList<CubitFacetEdge*> edges_ordered;
00429     CAST_LIST(curveEdgeList, edges_ordered, CubitFacetEdge);
00430
00431     CubitStatus stat = CubitFacetEdge::order_edge_list(edges_ordered, startPoint, endPoint);
00432
00433     if (CUBIT_FAILURE == stat)
00434       return CUBIT_FAILURE;
00435
00436     // store the edges in the correct order
00437     clean_out_edges();
00438
00439     edges_ordered.reset();
00440     for (i=0; i< edges_ordered.size(); i++)
00441     {
00442       this->add_facet(edges_ordered.get_and_step());
00443     }
00444   }
00445
00446
00447   // make sure all the edges are oriented correctly
00448   DLIList<FacetEntity *> flist = this->get_facet_list();
00449   flist.reset();
00450   DLIList<CubitFacetEdge *> elist;
00451   CAST_LIST( flist, elist, CubitFacetEdge );
00452   elist.reset();
00453   CubitPoint *cur_pt = startPoint, *tmp_pt;
00454   for ( i = elist.size(); i > 0; i-- )
00455   {
00456     CubitFacetEdge *edge_ptr = elist.get_and_step();
00457     CubitPoint *point0_ptr = edge_ptr->point(0);
00458     CubitPoint *point1_ptr = edge_ptr->point(1);
00459     if (point0_ptr != cur_pt)
00460     {
00461       assert( cur_pt == point1_ptr );
00462       edge_ptr->flip();
00463       tmp_pt = point0_ptr;
00464       point0_ptr = point1_ptr;
00465       point1_ptr = tmp_pt;
00466       assert( point0_ptr == edge_ptr->point(0) &&
00467              point1_ptr == edge_ptr->point(1) );
00468     }
00469     cur_pt = point1_ptr;
00470   }
00471
00472   int mydebug = 0;
00473   if (mydebug)
00474   {
00475     int i;
00476     DLIList<FacetEntity *> flist = this->get_facet_list();
00477     flist.reset();
00478     DLIList<CubitFacetEdge *> elist;
00479     CAST_LIST( flist, elist, CubitFacetEdge );
00480     elist.reset();
00481     for ( i = elist.size(); i > 0; i-- ) {
00482       CubitFacetEdge *edge = elist.get_and_step();
00483       CubitVector pt0_v = edge->point(0)->coordinates();
00484       CubitVector pt1_v = edge->point(1)->coordinates();
00485       GfxDebug::draw_point(pt0_v, CUBIT_GREEN_INDEX );
00486       GfxDebug::draw_point(pt1_v, CUBIT_RED_INDEX );
00487       GfxDebug::draw_line( pt0_v, pt1_v, CUBIT_YELLOW_INDEX );
00488       GfxDebug::flush();
00489       int view = 0;
00490       if (view)
00491         dview();
00492     }
00493   }
00494   return CUBIT_SUCCESS;
00495 }
00496
00497 //=============================================================================
00498 //Function: length
00499 //Description:
00500 //Author: sjowen
00501 //Date: 04/21/2009
00502 //============================================================================
00503 double ChollaCurve::length()
00504 {
00505   if (myLength > MYLENGTH_UNINITIALIZED)
00506     return myLength;
00507
00508   CubitFacetEdge *edge;
00509   FacetEntity *fent;
00510   myLength = 0.0;
00511   for (int iedge=0; iedge<curveEdgeList.size(); iedge++)
00512   {
00513     fent = curveEdgeList.get_and_step();
00514     edge = dynamic_cast<CubitFacetEdge *> (fent);
00515     myLength += edge->length();
00516   }
00517
00518   return myLength;
00519 }
00520
00521 //=============================================================================
00522 //Function: find adjacent edges at a point that lie on the curve
00523 //Description: determine the next edge from a given edge - return NULL if at the end
00524 //Author: william roshan quadros
00525 //Return: returns false if no adj_edges can be found
00526 //Date: 04/21/2009
00527 //=============================================================================
00528 bool ChollaCurve::adj_facet_edges( CubitPoint *node_ptr, CubitFacetEdge *&adj_edge1, CubitFacetEdge *&adj_edge2 )
00529 {
00530   // initialize adj_edge1 and adj_edge2
00531   adj_edge1 = adj_edge2 = NULL;
00532
00533   DLIList<CubitFacetEdge*> node_edge_list;
00534   node_ptr->edges( node_edge_list );
00535
00536   DLIList<CubitFacetEdge*> curve_edge_list;
00537   CAST_LIST(curveEdgeList, curve_edge_list, CubitFacetEdge);
00538
00539   curve_edge_list.intersect(node_edge_list);
00540   assert(curve_edge_list.size() < 3);
00541
00542   if (0 == curve_edge_list.size())
00543     return false;
00544
00545   curve_edge_list.reset();
00546   adj_edge1 = curve_edge_list.get();
00547
00548   if (curve_edge_list.size() > 1)
00549     adj_edge2 = curve_edge_list.next();
00550
00551   return true;
00552 }
00553
00554 //=============================================================================
00555 //Function:  next_edge (PRIVATE)
00556 //Description: determine the next edge from a given edge - return NULL if at
00557 //             the end
00558 //Author: sjowen
00559 //Date: 12/4/00
00560 //=============================================================================
00561 CubitFacetEdge *ChollaCurve::next_edge( CubitPoint *node_ptr,
00562                                         CubitFacetEdge *edge_ptr )
00563 {
00564   // check if this node has its hit flag set - we are at a feature break.
00565
00566   TDGeomFacet *td_gm_node = TDGeomFacet::get_geom_facet(node_ptr);
00567   if (td_gm_node->get_hit_flag() == 1 || node_ptr->is_feature())
00568     return NULL;
00569
00570   int jj, kk;
00571
00572   // find the next edge
00573
00574   CubitFacetEdge *next_edge_on_curve = NULL;
00575   DLIList<CubitFacetEdge*> edge_list;
00576   node_ptr->edges( edge_list );
00577   int num_adj_curves = 1;  // keep track of the number of curves at this node
00578   for (jj=0; jj<edge_list.size(); jj++)
00579   {
00580     CubitFacetEdge *node_edge_ptr = edge_list.get_and_step();
00581     if (node_edge_ptr != edge_ptr)
00582     {
00583       TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(node_edge_ptr);
00584       if (td_gm_edge != NULL)
00585       {
00586         DLIList<ChollaCurve*> fcurve_list;
00587         td_gm_edge->get_cholla_curves( fcurve_list );
00588         if (fcurve_list.size() > 0)
00589         {
00590
00591           // if 3 or more curves meet at this node, then force the curve to terminate here
00592
00593           num_adj_curves++;
00594           if (num_adj_curves >= 3)
00595           {
00596             return NULL;
00597           }
00598
00599           // otherwise try to match the curve to the edge to find the next edge
00600
00601           for (kk=0; kk<fcurve_list.size(); kk++)
00602           {
00603             ChollaCurve *fcm_ptr = fcurve_list.get_and_step();
00604             if (fcm_ptr == this)
00605             {
00606               next_edge_on_curve = node_edge_ptr;
00607             }
00608           }
00609         }
00610       }
00611     }
00612   }
00613   return next_edge_on_curve;
00614 }
00615
00616
00617 //=============================================================================
00618 //Function:  determine_ends (PRIVATE)
00619 //Description: determine the end nodes of the curve
00620 //             Assumes that there is one continuous string of edges
00621 //             (may need to call split_curve first)
00622 //Author: sjowen
00623 //Date: 12/4/00
00624 //=============================================================================
00625 CubitStatus ChollaCurve::determine_ends( )
00626 {
00627   int ii, jj, kk, inode;
00628   CubitFacetEdge *edge_ptr;
00629   CubitPoint *node0_ptr, *node1_ptr, *node_ptr;
00630   startPoint = endPoint = NULL;
00631   int done = 0;
00632   for(ii=0; ii<curveEdgeList.size() && !done; ii++)
00633   {
00634     edge_ptr = (CubitFacetEdge *)curveEdgeList.get_and_step();
00635     node0_ptr = edge_ptr->point(0);
00636     node1_ptr = edge_ptr->point(1);
00637     for (inode=0; inode<2 && !done; inode++)
00638     {
00639       node_ptr = (inode==0) ? node0_ptr : node1_ptr;
00640       DLIList<CubitFacetEdge*> edge_list;
00641       node_ptr->edges( edge_list );
00642       for (jj=0; jj<edge_list.size() && !done; jj++)
00643       {
00644         CubitFacetEdge *node_edge_ptr = edge_list.get_and_step();
00645         if (node_edge_ptr != edge_ptr)
00646         {
00647           TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(node_edge_ptr);
00648           if (td_gm_edge != NULL)
00649           {
00650             int found = 0;
00651             DLIList<ChollaCurve*> fcurve_list;
00652             td_gm_edge->get_cholla_curves( fcurve_list );
00653             for (kk=0; kk<fcurve_list.size() && !found; kk++)
00654             {
00655               ChollaCurve *fcm_ptr = fcurve_list.get_and_step();
00656               if (fcm_ptr == this)
00657                 found = 1;
00658             }
00659             if (!found)
00660             {
00661               if (startPoint == NULL)
00662               {
00663                 startPoint = node_ptr;
00664               }
00665               else
00666               {
00667                 endPoint = node_ptr;
00668                 done = 1;
00669               }
00670             }
00671           }
00672         }
00673       }
00674     }
00675
00676   }
00677
00678   // check for periodic condition - just choose an arbitrary node to serve as
00679   // both start and end of the curve
00680
00681   if (startPoint == NULL && endPoint == NULL)
00682   {
00683     curveEdgeList.reset();
00684     edge_ptr = (CubitFacetEdge *)curveEdgeList.get();
00685     node_ptr = edge_ptr->point(0);
00686     startPoint = node_ptr;
00687     endPoint = node_ptr;
00688   }
00689   else if ( ( startPoint == NULL && endPoint != NULL ) ||
00690            ( startPoint != NULL && endPoint == NULL ) )
00691   {
00692     PRINT_ERROR("Could not determine start and end of curve in ChollaCurve\n");
00693     return CUBIT_FAILURE;
00694   }
00695   return CUBIT_SUCCESS;
00696 }
00697
00698
00699 CubitStatus ChollaCurve::build_curve_facet_eval_tool( void )
00700 {
00701   //debug this function as point list is not valid
00702
00703   if( this->get_eval_tool() )
00704   {
00705     assert(false); //WARNING: Curve facet eval tool already exist!
00706   }
00707
00708   CurveFacetEvalTool *curv_eval_tool_ptr = new CurveFacetEvalTool();
00709
00710   // Step 1: Initialize facet_edge_list and point_list
00711   CubitStatus stat;
00712   DLIList<CubitPoint *> point_list;
00713   int i;
00714   // insert start point of every facet_edge
00715   curveEdgeList.reset();
00716   for( i = 0; i < curveEdgeList.size(); i++ )
00717   {
00718     point_list.append( CAST_TO( curveEdgeList.get_and_step(), CubitFacetEdge )->point(0) );
00719   }
00720   // insert end point of last facet_edge
00721   curveEdgeList.step( curveEdgeList.size() - 1 );
00722   point_list.append( CAST_TO( curveEdgeList.get(), CubitFacetEdge )->point(1) );
00723
00724   DLIList<CubitFacetEdge *> edge_list;
00725   CAST_LIST( curveEdgeList, edge_list, CubitFacetEdge );
00726   stat = curv_eval_tool_ptr->initialize( edge_list, point_list );
00727   if( stat != CUBIT_SUCCESS )
00728   {
00729     return stat;
00730   }
00731
00732  /*
00733  // Step 2: find sense of curve_facet_eval_tool  /// this is done internally in next Step in initialize()
00734   if( this->startPoint )
00735   {
00736     stat = curv_eval_tool_ptr->find_curv_sense( this->startPoint );
00737     if( stat != CUBIT_SUCCESS )
00738     {
00739       return stat;
00740     }
00741   }
00742 */
00743   // Step 2: Initialize adj_surface_facet_eval_tool with orientation_wrt_surface
00744   if( surfaceList.size() )
00745   {
00746     CubitSense orientation_wrt_surface;
00747     if( CUBIT_SUCCESS == ChollaEngine::determine_curve_orientation( surfaceList.get(), this, orientation_wrt_surface ) )
00748     {
00749       if( this->startPoint && this->endPoint )
00750       {
00751         stat = curv_eval_tool_ptr->initialize( surfaceList.get()->get_eval_tool(),
00752                       this->startPoint,
00753                       this->endPoint,
00754                       orientation_wrt_surface);
00755       }
00756     }
00757     else
00758     {
00759       assert(false);
00760     }
00761
00762     if( stat != CUBIT_SUCCESS )
00763     {
00764       assert( false );
00765       return stat;
00766     }
00767   }
00768   else
00769   {
00770     assert(false); //WARNING: No adjacent cholla surface available
00771   }
00772
00773   // Step 4: assign the new curv_eval_tool to cholla_curve
00774  assign_eval_tool( curv_eval_tool_ptr );
00775
00776   return stat;
00777 }
00778
00779 //=============================================================================
00780 //Function:  feature_angle (PRIVATE)
00781 //Description: compute angles at nodes on the curve to see if we need to split
00782 //             the curve.  Mark the node tooldata hitflag if the node will
00783 //             break the curve (this is refernced in next_edge)
00784 //Author: sjowen
00785 //Date: 12/4/00
00786 //=============================================================================
00787 CubitStatus ChollaCurve::feature_angle(
00788   double min_dot )
00789 {
00790   // first compute all of the edge vector and store with the edge tooldata
00791
00792   int ii, jj;
00793   FacetEntity *facet_ptr;
00794   CubitFacetEdge *edge_ptr;
00795   CubitPoint *start_node;
00796   CubitPoint *end_node;
00797   CubitVector tangent;
00798   TDGeomFacet *td_gm;
00799   for (ii=0; ii<curveEdgeList.size(); ii++)
00800   {
00801
00802     // compute the tangent vector of the edge and store it with its tooldata
00803
00804     facet_ptr = curveEdgeList.get_and_step();
00805     edge_ptr = CAST_TO( facet_ptr, CubitFacetEdge );
00806     start_node = edge_ptr->point(0);
00807     end_node = edge_ptr->point(1);
00808     tangent = end_node->coordinates() - start_node->coordinates();
00809     tangent.normalize();
00810     td_gm = TDGeomFacet::get_geom_facet( edge_ptr );
00811     td_gm->set_normal( tangent );
00812
00813     // initialize the nodes tooldata hit flags - set them all to -1
00814
00815     td_gm = TDGeomFacet::get_geom_facet(start_node);
00816     td_gm->set_hit_flag(-1);
00817     td_gm = TDGeomFacet::get_geom_facet(end_node);
00818     td_gm->set_hit_flag(-1);
00819   }
00820
00821   // now go through them again and compute the dot product between edges
00822
00823   CubitVector tang0;
00824   CubitVector tang1;
00825   double dot;
00826   CubitPoint *node_ptr;
00827   CubitFacetEdge *next_edge_ptr;
00828   TDGeomFacet *td_gm_node;
00829
00830   for (ii=0; ii<curveEdgeList.size(); ii++)
00831   {
00832     facet_ptr = curveEdgeList.get_and_step();
00833     edge_ptr = CAST_TO( facet_ptr, CubitFacetEdge );
00834     start_node = edge_ptr->point(0);
00835     end_node = edge_ptr->point(1);
00836     for (jj=0; jj<2; jj++)
00837     {
00838       node_ptr = (jj==0) ? start_node : end_node;
00839       td_gm_node = TDGeomFacet::get_geom_facet( node_ptr );
00840       if (td_gm_node->get_hit_flag() == -1)
00841       {
00842         next_edge_ptr = next_edge( node_ptr, edge_ptr );
00843         if (next_edge_ptr == NULL)
00844         {
00845           td_gm_node->set_hit_flag( 1 );
00846           node_ptr->set_as_feature();
00847         }
00848         else
00849         {
00850           td_gm = TDGeomFacet::get_geom_facet( edge_ptr );
00851           tang0 = td_gm->get_normal();
00852           td_gm = TDGeomFacet::get_geom_facet( next_edge_ptr );
00853           tang1 = td_gm->get_normal();
00854
00855           // change the sign of the tangent vectors if the
00856           // sense of the edges are not the same
00857
00858           if (node_ptr == start_node)
00859           {
00860             if (node_ptr != next_edge_ptr->point(1))
00861               tang0 = -tang0;
00862           }
00863           else
00864           {
00865             if (node_ptr != next_edge_ptr->point(0))
00866               tang0 = -tang0;
00867           }
00868
00869           // compute the dot product between tangemt vectors
00870
00871           dot = tang0 % tang1;
00872
00873           // set the hit flag if there needs to be a feature break here
00874
00875           if (dot <= min_dot)
00876           {
00877             td_gm_node->set_hit_flag( 1 );
00878             node_ptr->set_as_feature();
00879           }
00880           else
00881           {
00882             td_gm_node->set_hit_flag( 0 );
00883           }
00884         }
00885       }
00886     }
00887   }
00888   return CUBIT_SUCCESS;
00889 }
00890
00891 static int icolor = 0;
00892 void ChollaCurve::debug_draw()
00893 {
00894   icolor++;
00895   icolor = icolor%15;
00896   dcolor(icolor);
00897   dldraw(curveEdgeList);
00898 }
00899
00900 void ChollaCurve::print()
00901 {
00902   FILE *fp = fopen("debug.curve", "a");
00903   fprintf(fp,"*** Curve %d ***\n", id);
00904   for (int ii=0; ii<curveEdgeList.size(); ii++)
00905   {
00906     FacetEntity *fe_ptr = curveEdgeList.get_and_step();
00907     CubitFacetEdge *cfe_ptr = CAST_TO(fe_ptr, CubitFacetEdge );
00908     CubitPoint *cp0_ptr = cfe_ptr->point(0);
00909     CubitPoint *cp1_ptr = cfe_ptr->point(1);
00910     fprintf(fp,"  Edge (%d)\n", cfe_ptr->id() );
00911     fprintf(fp,"     Point (%d)  %8.4f  %8.4f  %8.4f\n",
00912       cp0_ptr->id(), cp0_ptr->x(), cp0_ptr->y(), cp0_ptr->z());
00913     fprintf(fp,"     Point (%d)  %8.4f  %8.4f  %8.4f\n",
00914       cp1_ptr->id(), cp1_ptr->x(), cp1_ptr->y(), cp1_ptr->z());
00915   }
00916   fclose(fp);
00917 }
00918
00919
00920   //  disassociate from cholla points
00921 CubitStatus ChollaCurve::disassociate_from_points( void )
00922 {
00923
00924   /*
00925   if( startPoint )
00926   {
00927     startPoint->remove_curve( this );
00928     startPoint = NULL;
00929   }
00930   if( endPoint )
00931   {
00932     endPoint->remove_curve( this );
00933     endPoint = NULL;
00934   }
00935   */
00936
00937   int i;
00938   for( i = 0; i < pointList.size(); i++ )
00939   {
00940     pointList.get_and_step()->remove_curve( this );
00941   }
00942   pointList.clean_out();
00943
00944   return CUBIT_SUCCESS;
00945 }
00946
00947   // disassociate from cholla surface
00948 CubitStatus ChollaCurve::disassociate_from_surfaces( void)
00949 {
00950   int i;
00951   for( i = 0; i < surfaceList.size(); i++ )
00952   {
00953     surfaceList.get_and_step()->remove_curve( this );
00954   }
00955   surfaceList.clean_out();
00956   return CUBIT_SUCCESS;
00957 }
00958
00959
00960 CubitStatus ChollaCurve::replace_facet( FacetEntity *remove_edge, FacetEntity *replace_edge )
00961 {
00962   curveEdgeList.move_to( remove_edge );
00963   curveEdgeList.insert( replace_edge );
00964   curveEdgeList.remove( remove_edge );
00965   myLength = MYLENGTH_UNINITIALIZED;
00966   return CUBIT_SUCCESS;
00967 }
00968
00969 CubitStatus ChollaCurve::insert_facet( FacetEntity *old_edge, FacetEntity *new_edge )
00970 {
00971   curveEdgeList.move_to( old_edge );
00972   curveEdgeList.insert( new_edge );
00973
00974   return CUBIT_SUCCESS;
00975 }
00976
00977 CubitStatus ChollaCurve::is_contain( FacetEntity *edge )
00978 {
00979   if( curveEdgeList.is_in_list( edge ) )
00980     return CUBIT_SUCCESS;
00981   else
00982     return CUBIT_FAILURE;
00983 }
00984
00985
00986 //=============================================================================
00987 //Function:  is_in_volume (PUBLIC)
00988 //Description:  return whether this curve is contained within the specified volume
00989 //Author: sjowen
00990 //Date: 9/11/2009
00991 //=============================================================================
00992 CubitBoolean ChollaCurve::is_in_volume( ChollaVolume *chvol_ptr )
00993 {
00994   for (int ii=0; ii<surfaceList.size(); ii++)
00995   {
00996     ChollaSurface *chsurf_ptr = surfaceList.get_and_step();
00997     DLIList<ChollaVolume *> chvol_list;
00998     chsurf_ptr->get_volumes(chvol_list);
00999     for (int jj=0; jj<chvol_list.size(); jj++)
01000     {
01001       ChollaVolume *mychvol_ptr = chvol_list.get_and_step();
01002       if (mychvol_ptr == chvol_ptr)
01003         return CUBIT_TRUE;
01004     }
01005   }
01006   return CUBIT_FALSE;
01007 }
01008
01009 //=============================================================================
01010 //Function:  is_in_surface (PUBLIC)
01011 //Description:  return whether this curve is contained within the specified surface
01012 //Author: sjowen
01013 //Date: 9/18/2009
01014 //=============================================================================
01015 CubitBoolean ChollaCurve::is_in_surface( ChollaSurface *chsurf_ptr )
01016 {
01017   for (int ii=0; ii<surfaceList.size(); ii++)
01018   {
01019     ChollaSurface *mysurf_ptr = surfaceList.get_and_step();
01020     if (mysurf_ptr == chsurf_ptr)
01021     {
01022       return CUBIT_TRUE;
01023     }
01024   }
01025   return CUBIT_FALSE;
01026 }
01027
01028
01029 //=============================================================================
01030 //Function:  get_facet_points (PUBLIC)
01031 //Description:  return the list of facet points on this chollacurve
01032 //Notes: inclusive = true will return end points as well, otherwise only
01033 //       interior points will be returned
01034 //Author: sjowen
01035 //Date: 9/11/2009
01036 //=============================================================================
01037 void ChollaCurve::get_facet_points( DLIList<CubitPoint *> &point_list, CubitBoolean inclusive)
01038 {
01039   FacetEntity *fe_ptr;
01040   CubitFacetEdge *edge_ptr;
01041   CubitPoint *pts[2];
01042   for (int ii=0; ii<curveEdgeList.size(); ii++)
01043   {
01044     fe_ptr = curveEdgeList.get_and_step();
01045     edge_ptr = dynamic_cast<CubitFacetEdge *> (fe_ptr);
01046     assert(edge_ptr != NULL);
01047     for (int jj=0; jj<2; jj++)
01048     {
01049       pts[jj] = edge_ptr->point(jj);
01050       if (inclusive)
01051       {
01052         point_list.append(pts[jj]);
01053       }
01054       else
01055       {
01056         if (pts[jj] != startPoint && pts[jj] != endPoint)
01057         {
01058           point_list.append(pts[jj]);
01059         }
01060       }
01061     }
01062   }
01063   point_list.uniquify_ordered();
01064 }
01065
01066 //=============================================================================
01067 //Function:  has_point (PUBLIC)
01068 //Description:  return whether the curve contains the gicen point
01069 //Notes:
01070 //=============================================================================
01071 CubitBoolean ChollaCurve::has_point( ChollaPoint *chpt )
01072 {
01073   for(int ii=0; ii<pointList.size(); ii++)
01074   {
01075     ChollaPoint *pt = pointList.get_and_step();
01076     if (pt == chpt)
01077       return CUBIT_TRUE;
01078   }
01079   return CUBIT_FALSE;
01080 }
01081
01082 //=============================================================================
01083 //Function:  verify_points (PUBLIC)
01084 //Description:  verify that all points on this curve have this curve as an adjacency
01085 //Notes:
01086 //=============================================================================
01087 CubitStatus ChollaCurve::verify_points()
01088 {
01089   for(int ii=0; ii<pointList.size(); ii++)
01090   {
01091     ChollaPoint *pt = pointList.get_and_step();
01092     if (!pt->is_in_curve(this))
01093       return CUBIT_FAILURE;
01094   }
01095   return CUBIT_SUCCESS;
01096 }
01097
01098 int ChollaCurve::num_volumes()
01099 {
01100
01101   DLIList<ChollaVolume *> chvol_list;
01102   for (int i=0; i<surfaceList.size(); i++)
01103   {
01104     ChollaSurface *chsurf_ptr = surfaceList.get_and_step();
01105     DLIList<ChollaVolume*> tmp_vols;
01106     chsurf_ptr->get_volumes(tmp_vols);
01107     chvol_list += tmp_vols;
01108   }
01109
01110   chvol_list.uniquify_unordered();
01111   return chvol_list.size();
01112 }
01113
01114 //EOF
01115
