cgma
ChollaDebug.cpp
00001
00002 #include "FacetEntity.hpp"
00003 #include "CubitFacet.hpp"
00004 #include "CubitPoint.hpp"
00005 #include "CubitFacetEdge.hpp"
00006 #include "GfxDebug.hpp"
00007 #include "CubitBox.hpp"
00008 #include "ChollaSurface.hpp"
00009 #include "CubitMessage.hpp"
00010
00011 #include "ChollaDebug.hpp"
00012 static int fg_color = CUBIT_MAGENTA_INDEX;
00013 void dcolor(int icol)
00014 {
00015   fg_color = icol;
00016 }
00017
00018 void ddraw( FacetEntity *facet_ptr )
00019 {
00020   facet_ptr->debug_draw( fg_color );
00021 }
00022
00023 void dfdraw( CubitFacet *facet_ptr  )
00024 {
00025   facet_ptr->debug_draw( fg_color );
00026 }
00027
00028 void dedraw( CubitFacetEdge *facet_ptr )
00029 {
00030   facet_ptr->debug_draw( fg_color );
00031 }
00032
00033 void dpdraw( CubitPoint *facet_ptr )
00034 {
00035   facet_ptr->debug_draw( fg_color );
00036 }
00037
00038
00039 void dview()
00040 {
00041   GfxDebug::flush();
00042   GfxDebug::mouse_xforms();
00043 }
00044
00045 void dzoom(CubitBox &box)
00046 {
00047   GfxDebug::zoom(box);
00048 }
00049
00050
00051 void dsurfdraw( ChollaSurface *surf)
00052 {
00053   DLIList<FacetEntity*> surface_facets;
00054   surf->get_facets(surface_facets);
00055   dldraw(surface_facets);
00056 }
00057
00058
00059 void dldraw( DLIList<FacetEntity *> &facet_list )
00060 {
00061   FacetEntity *facet_ptr;
00062   for (int ii=0; ii<facet_list.size(); ii++)
00063   {
00064     facet_ptr = facet_list.get_and_step();
00065     facet_ptr->debug_draw( fg_color, 0 );
00066   }
00067   GfxDebug::flush();
00068 }
00069
00070 void dfldraw( DLIList<CubitFacet *> &facet_list )
00071 {
00072   CubitFacet *facet_ptr;
00073   for (int ii=0; ii<facet_list.size(); ii++)
00074   {
00075     facet_ptr = facet_list.get_and_step();
00076     facet_ptr->debug_draw( fg_color, 0 );
00077   }
00078   GfxDebug::flush();
00079 }
00080
00081 void deldraw( DLIList<CubitFacetEdge *> &edge_list )
00082 {
00083   CubitFacetEdge *edge_ptr;
00084   for (int ii=0; ii<edge_list.size(); ii++)
00085   {
00086     edge_ptr = edge_list.get_and_step();
00087     edge_ptr->debug_draw( fg_color, 0 );
00088   }
00089   GfxDebug::flush();
00090 }
00091
00092 void dpldraw( DLIList<CubitPoint *> &point_list )
00093 {
00094   CubitPoint *point_ptr;
00095   for (int ii=0; ii<point_list.size(); ii++)
00096   {
00097     point_ptr = point_list.get_and_step();
00098     point_ptr->debug_draw( fg_color, 0 );
00099   }
00100   GfxDebug::flush();
00101 }
00102
00103 int dflcheck( DLIList<CubitFacet *> &facet_list )
00104 {
00105   int ii;
00106   int ier = 0;
00107   for (ii=0; ii<facet_list.size(); ii++)
00108   {
00109     CubitFacet *facet_ptr = facet_list.get_and_step();
00110     ier += dfcheck( facet_ptr );
00111   }
00112   return ier;
00113 }
00114
00115 int dcheck( DLIList<FacetEntity *> &facet_list )
00116 {
00117   int ii;
00118   int ier = 0;
00119   for (ii=0; ii<facet_list.size(); ii++)
00120   {
00121     CubitFacet *facet_ptr = (CubitFacet *)facet_list.get_and_step();
00122     ier += dfcheck( facet_ptr );
00123   }
00124   return ier;
00125 }
00126
00127 int dfcheck( CubitFacet *facet_ptr )
00128 {
00129   int ier = 0;
00130
00131   // check edges
00132
00133   int ii, jj;
00134   for (ii=0; ii<3; ii++)
00135   {
00136     CubitFacetEdge *edge_ptr = facet_ptr->edge( ii );
00137     DLIList <CubitFacet *> facet_list;
00138     edge_ptr->facets( facet_list );
00139     int found = 0;
00140     for (jj=0; jj<facet_list.size() && !found; jj++)
00141     {
00142       CubitFacet *f = facet_list.get_and_step();
00143       if (f == facet_ptr)
00144       {
00145         found = 1;
00146       }
00147     }
00148     if (!found)
00149     {
00150       PRINT_ERROR( "Facet %d is not in Edge %d adjacency list\n",
00151                     facet_ptr->id(), edge_ptr->id() );
00152       ier++;
00153     }
00154
00155     // check the edge's orientation on the facet
00156
00157     CubitPoint *ep0, *ep1;
00158     int use = facet_ptr->edge_use( ii );
00159     if (use > 0)
00160     {
00161       ep0 = edge_ptr->point( 0 );
00162       ep1 = edge_ptr->point( 1 );
00163     }
00164     else
00165     {
00166       ep1 = edge_ptr->point( 0 );
00167       ep0 = edge_ptr->point( 1 );
00168     }
00169
00170     CubitPoint *fp0 = facet_ptr->point( (ii+1)%3 );
00171     CubitPoint *fp1 = facet_ptr->point( (ii+2)%3 );
00172     if (fp0 != ep0 || fp1 != ep1)
00173     {
00174       PRINT_ERROR( "Edge %d on Facet %d is not oriented with points %d and %d correctly\n",
00175         edge_ptr->id(), facet_ptr->id(), fp0->id(), fp1->id() );
00176       ier++;
00177     }
00178   }
00179
00180   // check nodes
00181
00182   for (ii=0; ii<3; ii++)
00183   {
00184     CubitPoint *point_ptr = facet_ptr->point( ii );
00185     DLIList <CubitFacet *> facet_list;
00186     point_ptr->facets( facet_list );
00187     int found = 0;
00188     for (jj=0; jj<facet_list.size() && !found; jj++)
00189     {
00190       CubitFacet *f = facet_list.get_and_step();
00191       if (f == facet_ptr)
00192       {
00193         found = 1;
00194       }
00195     }
00196     if (!found)
00197     {
00198       PRINT_ERROR( "Facet %d is not in Point %d adjacency list\n",
00199                     facet_ptr->id(), point_ptr->id() );
00200       ier++;
00201     }
00202   }
00203   return ier;
00204 }
00205
00206 // draw a vector
00207 void dray( const CubitVector &start, const CubitVector &vec, double length )
00208 {
00209   CubitVector end = start+length*vec;
00210   GfxDebug::draw_vector(end, start, fg_color );
00211   GfxDebug::flush();
00212 }
00213
00214 // draw a point
00215 void dpoint( const CubitVector &pt )
00216 {
00217   GfxDebug::draw_point(pt, fg_color);
00218   GfxDebug::flush();
00219
00220 }
00221
00222 int get_color()
00223 {
00224   return fg_color;
00225 }
00226
00227 //EOF
00228
