cgma
ChordalAxis.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : ChordalAxis.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jit Ken Tan
00009 //
00010 // Creation Date : 09/02/02
00011 //-------------------------------------------------------------------------
00012
00013 #ifndef CHORDALAXIS_HPP
00014 #define CHORDALAXIS_HPP
00015
00016 #include "CubitDefines.h"
00017 #include "DLIList.hpp"
00018 #include "CubitMessage.hpp"
00019 #include "CubitFacet.hpp"
00020 #include "CubitFacetEdge.hpp"
00021 #include "CubitPoint.hpp"
00022 #include "GfxDebug.hpp"
00023
00024 class TDChordal;
00025 class CubitVector;
00026 class ChordalAxis
00027 {
00028
00029   public:
00030
00031   ChordalAxis();
00032
00033   ~ChordalAxis();
00034
00035   //- Perform the entire chordal axis extraction
00036   CubitStatus chordal_axis_transform(DLIList <CubitPoint*> boundary_loop_list,DLIList <CubitFacet *> &facet_list, DLIList <CubitFacetEdge *> &axis);
00037
00038   private:
00039
00040   //- create a delaunay constrained triangulation
00041   CubitStatus create_triangulation(DLIList <CubitPoint*> boundary_loop_list);
00042
00043   //- extract the chordal axis for a junction triangle
00044   CubitStatus junction_triangle(CubitFacet *current_facet, TDChordal * td_chordal, DLIList <CubitFacetEdge *> &axis);
00045
00046   //-Get circumcenter given 3 points of the circle
00047   CubitVector get_center(CubitVector v1, CubitVector v2, CubitVector v3);
00048
00049   //- Flag the boundary edges
00050   CubitStatus flagging_boundary();
00051
00052   //- Flag a boundary edge
00053   CubitStatus flag_boundary( CubitFacet *curr_facet, CubitPoint *start_node, CubitPoint *end_node );
00054
00055   //- Classified each triangle based on its boundary edges
00056   CubitStatus process_triangles();
00057
00058   //- perform extraction
00059   CubitStatus axis_extraction( DLIList <CubitFacetEdge *> &axis );
00060
00061   //- Obtain TDChordal Tool data
00062   TDChordal *get_tool_data(CubitFacet* curr_facet);
00063
00064   //- Perform chordal axis extraction given a sleeve triangle
00065   CubitStatus sleeve_triangle(CubitFacet* curr_facet,TDChordal* td_chordal, DLIList <CubitFacetEdge *> &axis);
00066
00067   //- Perform pruning of the chordal axis
00068   CubitStatus pruning();
00069
00070   //- Searching for triangles to prune
00071   CubitStatus search_triangles_to_prune(CubitFacet *adj_triangle, CubitFacetEdge *curr_edge, CubitPoint *start_node, CubitVector unit_edge_vector, double pruning_distance, DLIList <CubitFacet *> &pruned_triangles, CubitStatus &prune );
00072
00073   //- Pruning commences with the junction triangle
00074   CubitStatus junction_triangle_pruning(CubitFacet *curr_facet, int edge_index, bool &pruning_performed);
00075
00076   //- Mark Triangle as discarded
00077   CubitStatus mark_tri_discarded(CubitFacet *curr_facet);
00078
00079   //- Mark Triangle as visited
00080   CubitStatus mark_visited(CubitFacet *curr_facet);
00081
00082   //- Mark Triangle as unvisited
00083   CubitStatus unmark_visited(CubitFacet *curr_facet);
00084
00085   //- Check if the triangle is visited
00086   CubitStatus get_visited(CubitFacet *curr_facet, bool &visited);
00087
00088   //- Determine the triangle type based on the number of boundary edges
00089   CubitStatus determine_tritype(CubitFacet *curr_facet);
00090
00091   //- Consolidate the junction triangles in our mesh
00092   CubitStatus junction_tris_collection();
00093
00094   //- for debugging purposes
00095   void debug_draw_facet(CubitFacet *curr_facet, int color){
00096     DLIList<CubitFacetEdge *> edge_list;
00097     curr_facet->edges(edge_list);
00098     int ii;
00099
00100     for(ii =0; ii<edge_list.size(); ii++){
00101       GfxDebug::draw_facet_edge(edge_list.get_and_step(), color);
00102     }
00103
00104   };
00105
00106   //- for debugging purposes
00107   void print_point(CubitPoint *curr_point){
00108     PRINT_INFO("Point  = (%f, %f) \n", curr_point->x(), curr_point->y());
00109   }
00110
00111   int numBoundaryEdges;
00112   CubitPoint **startNodes;
00113   CubitPoint **endNodes;
00114   DLIList <CubitFacet*> triangulation;
00115   DLIList <CubitFacet*> junctionTris;
00116   double pruningAlpha;
00117 };
00118
00119 #endif
00120
