cgma
CoFace.cpp
00001 //-------------------------------------------------------------------------
00002 // Copyright Notice
00003 //
00004 // Copyright (c) 1996
00005 // by Malcolm J. Panthaki, DBA, and the University of New Mexico.
00006 //-------------------------------------------------------------------------
00007 //
00008 //-------------------------------------------------------------------------
00009 // Filename      : CoFace.cc
00010 //
00011 // Purpose       :
00012 //
00013 // Special Notes :
00014 //
00015 // Creator       : Xuechen Liu
00016 //
00017 // Creation Date : 08/02/96
00018 //
00019 // Owner         : Jihong Ma
00020 //-------------------------------------------------------------------------
00021
00022 // ********** BEGIN STANDARD INCLUDES      **********
00023 // ********** END STANDARD INCLUDES        **********
00024
00025 // ********** BEGIN MOTIF INCLUDES         **********
00026 // ********** END MOTIF INCLUDES           **********
00027
00028 // ********** BEGIN OPEN INVENTOR INCLUDES **********
00029 // ********** END OPEN INVENTOR INCLUDES   **********
00030
00031 // ********** BEGIN CUBIT INCLUDES         **********
00032
00033 #include "CoFace.hpp"
00034 #include "RefFace.hpp"
00035 #include "RefVolume.hpp"
00036 #include "GroupingEntity.hpp"
00037 #include "CastTo.hpp"
00038 #include "GeometryDefines.h"
00039 #include "Shell.hpp"
00040
00041 // ********** END CUBIT INCLUDES           **********
00042
00043 // ********** BEGIN STATIC DECLARATIONS    **********
00044 // ********** END STATIC DECLARATIONS      **********
00045
00046
00047 // ********** BEGIN PUBLIC FUNCTIONS       **********
00048 //-------------------------------------------------------------------------
00049 // Purpose       : The default constructor.
00050 //
00051 // Special Notes :
00052 //
00053 // Creator       : Xuechen Liu
00054 //
00055 // Creation Date : 08/02/96
00056 //-------------------------------------------------------------------------
00057 CoFace::CoFace()
00058 {
00059 }
00060
00061 //-------------------------------------------------------------------------
00062 // Purpose       : The destructor.
00063 //
00064 // Special Notes :
00065 //
00066 // Creator       : Raikanta Sahu
00067 //
00068 // Creation Date : 10/22/96
00069 //-------------------------------------------------------------------------
00070 CoFace::~CoFace()
00071 {
00072 }
00073
00074 //-------------------------------------------------------------------------
00075 // Purpose       : The constructor with a pointer to a face and the
00076 //                 sense of this CoFace.
00077 //
00078 // Special Notes :
00079 //
00080 // Creator       : Xuechen Liu
00081 //
00082 // Creation Date : 08/02/96
00083 //-------------------------------------------------------------------------
00084 CoFace::CoFace(RefFace* facePtr, CubitSense sense)
00085 {
00086    attach_basic_topology_entity(facePtr) ;
00087    set_sense(sense) ;
00088 }
00089
00090 //-------------------------------------------------------------------------
00091 // Purpose       : This function returns a pointer to the RefFace which
00092 //                 the current CoFace is associated with.
00093 //
00094 // Special Notes :
00095 //
00096 // Creator       : Malcolm J. Panthaki
00097 //
00098 // Creation Date : 08/02/96
00099 //-------------------------------------------------------------------------
00100 RefFace* CoFace::get_ref_face_ptr()
00101 {
00102    // Call the generic function defined in the SenseEntity class to
00103    // do the real work
00104    BasicTopologyEntity* BTEPtr = get_basic_topology_entity_ptr();
00105
00106    // Cast the returned pointer to RefFace and return it
00107    return CAST_TO( BTEPtr, RefFace );
00108 }
00109
00110 //-------------------------------------------------------------------------
00111 // Purpose       : Get the parent Shell.
00112 //
00113 // Special Notes :
00114 //
00115 // Creator       : Jason Kraftcheck
00116 //
00117 // Creation Date : 06/09/99
00118 //-------------------------------------------------------------------------
00119 Shell* CoFace::get_shell_ptr()
00120 {
00121    GroupingEntity* gpe_ptr = get_grouping_entity_ptr();
00122
00123    // Cast the returned pointer to RefFace and return it
00124    return CAST_TO( gpe_ptr, Shell );
00125 }
00126
00127 //-------------------------------------------------------------------------
00128 // Purpose       : This function returns a pointer to the RefVolume which
00129 //                 the current CoFace is associated with.
00130 //
00131 // Special Notes :
00132 //
00133 // Creator       : David White
00134 //
00135 // Creation Date : 03/14/97
00136 //-------------------------------------------------------------------------
00137 RefVolume* CoFace::get_ref_volume()
00138 {
00139    BasicTopologyEntity* bte_ptr = get_parent_basic_topology_entity_ptr();
00140
00141    // Cast the returned pointer to RefFace and return it
00142    return dynamic_cast<RefVolume*>(bte_ptr);
00143 }
00144
00145
00146 //-------------------------------------------------------------------------
00147 // Purpose       : This function is called after a child of a TopologyEntity
00148 //                 is switched. The sense of a CoFace may change if one
00149 //                 of its RefFace changes. This function takes care of
00150 //                 that. If the sense of the RefFaces that were switched
00151 //                 is same, nothing is done. If the RefFaces are of
00152 //                 opposite sense, the sense of this object is switched,
00153 //                 i.e. if it was FORWARD, it is made REVERSE, and vice
00154 //                 versa.
00155 //
00156 // Special Notes : This function assumes the RefFaces are equivalent...
00157 //
00158 // Creator       : David White
00159 //
00160 // Creation Date : 4/3/97
00161 //-------------------------------------------------------------------------
00162
00163 void CoFace::switch_child_notify(TopologyEntity const* newChild,
00164                                  TopologyEntity const* oldChild )
00165 {
00166    // Make sure the entities being switched are RefFaces. If not,
00167    // get out of this function.
00168   TopologyEntity* tmp_new_child = const_cast<TopologyEntity*>(newChild);
00169   TopologyEntity* tmp_old_child = const_cast<TopologyEntity*>(oldChild);
00170    RefFace* new_child_ref_face = CAST_TO(tmp_new_child, RefFace) ;
00171    RefFace* old_child_ref_face = CAST_TO(tmp_old_child, RefFace) ;
00172
00173    if ( ( new_child_ref_face == NULL ) || ( old_child_ref_face == NULL ) )
00174    {
00175       return ;
00176    }
00177
00178    CubitSense sense =
00179        old_child_ref_face->compare_alignment( new_child_ref_face );
00180
00181      // If the sense of the old RefFace relative to the new RefFace is
00182      // same, nothing needs to be done. However, if the relative sense
00183      // is reversed, switch the sense of the CoFace.
00184    if ( sense == CUBIT_REVERSED )
00185    {
00186      if ( get_sense() == CUBIT_FORWARD )
00187      {
00188        set_sense(CUBIT_REVERSED) ;
00189      }
00190      else
00191      {
00192        set_sense(CUBIT_FORWARD) ;
00193      }
00194    }
00195 }
00196
00197
00198 // ********** END PUBLIC FUNCTIONS         **********
00199
00200 // ********** BEGIN PROTECTED FUNCTIONS    **********
00201 // ********** END PROTECTED FUNCTIONS      **********
00202
00203 // ********** BEGIN PRIVATE FUNCTIONS      **********
00204 // ********** END PRIVATE FUNCTIONS        **********
00205
00206 // ********** BEGIN HELPER CLASSES         **********
00207 // ********** END HELPER CLASSES           **********
00208
00209 // ********** BEGIN EXTERN FUNCTIONS       **********
00210 // ********** END EXTERN FUNCTIONS         **********
00211
00212 // ********** BEGIN STATIC FUNCTIONS       **********
00213 // ********** END STATIC FUNCTIONS         **********
00214
