cgma
CollapseAngleTool.hpp
00001 //---------------------------------------------------------------------------
00002 //- Filename:       CollapseAngleTool
00003 //- Purpose:  To collapse small angle for preparing for mesh
00004 //-
00005 //- Creator:       Jiangtao Hu
00006 //- Creation date: 02/09/2005
00007 //----------------------------------------------------------------------------
00008
00009 #ifndef COLLAPSEANGLETOOL_HPP
00010 #define COLLAPSEANGLETOOL_HPP
00011
00012 #include "DLIList.hpp"
00013 class RefVertex;
00014 class RefEdge;
00015 class RefFace;
00016 class CubitVector;
00017 template<class X> class DLIList;
00018
00019 class CollapseAngleTool
00020 {
00021 public:
00022   static CollapseAngleTool *instance();
00023     // return a static instance pointer
00024
00025   CubitStatus auto_collapse (double length,
00026                              double angle,
00027                              CubitBoolean preview,
00028                              CubitBoolean if_comp_vertex,
00029                              double max_angle);
00030
00031   void collapse_one_angle(RefVertex *vex_ptr,
00032                           RefEdge   *edge_to_remove,
00033                           RefEdge   *the_other_edge,
00034                           double     length1,
00035                           double     length2,
00036                           CubitBoolean get_position,
00037                           CubitVector  &position,
00038                           CubitBoolean preview,
00039                           CubitBoolean if_comp_vertex,
00040                           double       angle);
00041
00042 private:
00043   CollapseAngleTool();
00044     // Constructor
00045
00046   ~CollapseAngleTool();
00047     // Destructor
00048
00049   static CollapseAngleTool *instance_;
00050     // the static instance pointer
00051
00052   DLIList <RefEdge *> partly_drawn_curve;
00053   CubitStatus partition_curve(RefEdge *&edge,
00054                               RefVertex *root_vertex,
00055                               CubitVector  &position,
00056                               RefVertex *&new_vertex);
00057
00058   CubitBoolean if_partition_surf(RefVertex *vex_ptr,
00059                                  RefEdge  *edge_to_remove,
00060                                  RefFace  *common_face);
00061
00062   CubitStatus partition_curve(RefEdge *&edge,
00063                               RefVertex *root_vertex,
00064                               double  arc_length,
00065                               RefVertex *&new_vertex);
00066
00067   CubitStatus partition_surface(RefFace *common_face,
00068                                 RefEdge *& edge,
00069                                 RefVertex * root,
00070                                 RefVertex *vertex1,
00071                                 RefVertex *veretx2,
00072                                 RefFace  *&result_face);
00073
00074   CubitStatus collapse_angle(RefVertex *vex_ptr,
00075                              RefEdge   *edge_to_remove,
00076                              RefEdge   *the_other_edge,
00077                              double     length1,
00078                              double     length2,
00079                              CubitBoolean get_position,
00080                              CubitVector &position);
00081
00082   CubitStatus draw_preview(RefVertex *vex_ptr,
00083                            RefEdge   *edge_to_remove,
00084                            RefEdge   *the_other_edge,
00085                            double     length1,
00086                            double     length2,
00087                            CubitBoolean get_position,
00088                            CubitVector &position);
00089
00090   void  exchange_edges(RefEdge *&edge,
00091                        RefEdge *&the_other_edge);
00092
00093   double the_surface_angle(RefEdge *edge,
00094                            RefVertex *root_vertex,
00095                            double    length);
00096
00097   CubitStatus position_from_length(RefEdge *edge,
00098                                    RefVertex *root_vertex,
00099                                    double  arc_length,
00100                                    CubitVector& v_new);
00101 };
00102
00103 #endif
00104
