cgma
CompositeCoEdge.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CompositeCoEdge.hpp
00003 //
00004 // Purpose       : Combined set of CoEdgeSMs
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jason Kraftcheck
00009 //
00010 // Creation Date : 01/11/02
00011 //-------------------------------------------------------------------------
00012
00013 #ifndef COMPOSITE_COEDGE_HPP
00014 #define COMPOSITE_COEDGE_HPP
00015
00016 #include "VGDefines.h"
00017 #include "CoEdgeSM.hpp"
00018 #include "TBOwner.hpp"
00019 #include "VGArray.hpp"
00020
00021 class CompositeCurve;
00022 class CompositeLoop;
00023 class CompositePoint;
00024
00025 class CompositeCoEdge : public CoEdgeSM, public TBOwner
00026 {
00027 friend class CompositeLoop;
00028 friend class CompositeCurve;
00029
00030 public:
00031
00032   CompositeCoEdge( CoEdgeSM* coedge_ptr );
00033   CompositeCoEdge( CompositeCurve* point_curve );
00034
00035   ~CompositeCoEdge();
00036
00037   int num_coedges() const;
00038
00039   int index_of( CoEdgeSM* coedge_ptr ) const;
00040   int index_of( Curve* curve_ptr ) const;
00041
00042   CubitSense get_sense( int index ) const;
00043   CoEdgeSM* get_coedge( int index ) const;
00044
00045   CompositeCoEdge* next() const;
00046   CompositeCoEdge* prev() const;
00047     // Return next or previous coedge in a CompositeLoop.
00048     // If there is not a parent CompositeSurface, then
00049     // there is not a parent CompositeLoop and these will
00050     // return NULL.
00051
00052   CubitStatus combine( CompositeCoEdge* dead_coedge, bool prepend );
00053   CubitStatus insert_coedge( int index, CoEdgeSM* coedge );
00054   CubitStatus remove_coedge( int index );
00055   CompositeCoEdge* split( int index );
00056
00057   CompositePoint* start_point();
00058   CompositePoint* end_point();
00059 /*
00060   CoEdgeSM* remove_first();
00061   CoEdgeSM* remove_last();
00062 */
00063   virtual CubitSense sense();
00064
00065   void sense( CubitSense sense );
00066
00067   CompositeLoop* get_loop() const;
00068 //  void loop( CompositeLoop* );
00069
00070   CompositeCurve* get_curve() const;
00071 //  void curve( CompositeCurve* );
00072
00073   LoopSM* get_parent_loop();
00074     //- Get the parent loop at the composite level of
00075     //- the topo bridge graph.  I.E. Get parent CompositeLoop
00076     //- if there is one.  Otherwise get the SM-level loop.
00077
00078   void get_parents_virt( DLIList<TopologyBridge*>& parents );
00079   void get_children_virt( DLIList<TopologyBridge*>& children );
00080   GeometryQueryEngine* get_geometry_query_engine() const;
00081   int layer() const { return COMPOSITE_LAYER; }
00082
00083   void append_simple_attribute_virt( const CubitSimpleAttrib& simple_attrib_ptr );
00084   void remove_simple_attribute_virt( const CubitSimpleAttrib& simple_attrib_ptr );
00085   void remove_all_simple_attribute_virt();
00086   CubitStatus get_simple_attribute( DLIList<CubitSimpleAttrib>& attrib_list );
00087   CubitStatus get_simple_attribute( const CubitString& name,
00088                                     DLIList<CubitSimpleAttrib>& attrib_list );
00089
00090   CubitStatus remove_bridge( TopologyBridge* bridge );
00091   CubitStatus swap_bridge( TopologyBridge* old_tb,
00092                            TopologyBridge* new_tb,
00093                            bool reversed );
00094   CubitBoolean contains_bridge( TopologyBridge* bridge ) const;
00095   void notify_reversed( TopologyBridge* bridge );
00096
00097   void reverse();
00098
00099   void print_debug_info( const char* line_prefix = 0, bool brief = false );
00100
00101 private:
00102
00103   CompositeCoEdge();
00104
00105   VGArray<CoEdgeSM*> coedgeSet;
00106
00107   CubitSense mySense;
00108
00109   CompositeLoop*  myLoop;
00110   CompositeCoEdge* nextCoedge;
00111   CompositeCoEdge* prevCoedge;
00112
00113   CompositeCurve* myCurve;
00114   CompositeCoEdge* nextOnCurve;
00115 };
00116
00117 inline int CompositeCoEdge::num_coedges() const
00118   { return coedgeSet.size(); }
00119
00120 inline CoEdgeSM* CompositeCoEdge::get_coedge( int index ) const
00121   { return coedgeSet[index]; }
00122
00123 inline int CompositeCoEdge::index_of( CoEdgeSM* coedge ) const
00124   { return coedgeSet.find( coedge ); }
00125
00126 inline void CompositeCoEdge::sense( CubitSense sense )
00127   { assert( sense != CUBIT_UNKNOWN ); mySense = sense; }
00128
00129 inline CubitSense CompositeCoEdge::sense()
00130   { return mySense; }
00131
00132 inline CompositeCoEdge* CompositeCoEdge::next() const
00133   { return nextCoedge; }
00134
00135 inline CompositeLoop* CompositeCoEdge::get_loop() const
00136   { return myLoop; }
00137
00138 inline CompositeCurve* CompositeCoEdge::get_curve() const
00139   { return myCurve; }
00140 #endif
