cgma
CompositeGeom.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CompositeGeom.hpp
00003 //
00004 // Purpose       : Object used by CompositeSurface and CompositeCurve
00005 //                 to manage underlying entities.
00006 //
00007 // Special Notes :
00008 //
00009 // Creator       : Jason Kraftcheck
00010 //
00011 // Creation Date : 12/19/01
00012 //-------------------------------------------------------------------------
00013
00014 #ifndef COMPOSITE_GEOM_HPP
00015 #define COMPOSITE_GEOM_HPP
00016
00017 #include "DLIList.hpp"
00018 #include "VGArray.hpp"
00019 #include "CubitBox.hpp"
00020
00021 class GeometryEntity;
00022 class CubitSimpleAttrib;
00023 class CompositeAttrib;
00024 class TopologyBridge;
00025
00026 struct CompositeEntry
00027 {
00028   public:
00029
00030     GeometryEntity* entity; // underlying entity
00031     CubitSense sense;       // sense relative to composite
00032     double measure;         // cached value of entity->measure()
00033     CubitBox bbox;          // cached value of entity->bounding_box()
00034     double dist_sqr;        // temporary data used in closest_point() calc.
00035
00036     inline CompositeEntry()
00037       : entity(0), sense(CUBIT_UNKNOWN), measure(0.0), dist_sqr(0.0) {}
00038 };
00039
00040
00041 class CompositeGeom
00042 {
00043
00044   public:
00045
00046     CompositeGeom( int size = 0 );
00047
00048     ~CompositeGeom();
00049
00050     int num_entities() const
00051       { return entityList.size(); }
00052
00053     int index_of( TopologyBridge* geom_ptr ) const;
00054     inline GeometryEntity* entity( int index ) const;
00055
00056     inline CubitSense sense( int index ) const;
00057     inline double measure( int index );
00058     void reverse_sense( int index );
00059
00060     CubitStatus insert( int index, GeometryEntity* geom_ptr, CubitSense sense );
00061
00062     CubitStatus append( GeometryEntity* geom_ptr, CubitSense sense )
00063       { return insert( entityList.size(), geom_ptr, sense ); }
00064
00065     CubitStatus remove( int index, bool dead );
00066     CompositeGeom* split( int index );
00067     CompositeGeom* split( VGArray<int>& index_array );
00068     CubitStatus swap( int index, GeometryEntity* new_geom );
00069     CubitStatus reverse();
00070     CubitStatus reverse_order();
00071     CubitStatus reverse_rel_senses();
00072
00073     CubitStatus merge( CompositeGeom& dead, bool prepend = false );
00074
00075     CubitBox bounding_box();
00076     double measure();
00077
00078     int next_box_within_dist( double dist_squared );
00079     int closest_box( const CubitVector& position );
00080
00081     void update_cached_data()
00082       { needToUpdateBbox = true; needToUpdateMeasure = true; }
00083
00084     void add_attribute( const CubitSimpleAttrib& csa );
00085     void rem_attribute( const CubitSimpleAttrib& csa );
00086     void rem_all_attributes();
00087     void get_attributes( DLIList<CubitSimpleAttrib>& list );
00088     void get_attributes( const char* name,
00089                          DLIList<CubitSimpleAttrib>& list );
00090
00091     void print_debug_info( const char* line_prefix = 0 );
00092
00093     void read_attributes( GeometryEntity* entity = 0 );
00094     void write_attributes( GeometryEntity* entity = 0 );
00095
00096   private:
00097
00098     static void clean_up_attribs( GeometryEntity* ent );
00099
00100       // these have no implementation, just private delcarations
00101       // to prevent the compiler from generating default implementations
00102     CompositeGeom& operator=(const CompositeGeom&);
00103     CompositeGeom(const CompositeGeom&);
00104
00105     void update_data_bbox();
00106     void update_data_measure();
00107
00108     VGArray<CompositeEntry> entityList;
00109     int currentIndex;
00110     int firstIndex;
00111
00112     bool needToUpdateBbox;
00113     bool needToUpdateMeasure;
00114
00115     CompositeAttrib* listHead;
00116 };
00117
00118
00119 inline GeometryEntity* CompositeGeom::entity( int index ) const
00120 {
00121   return entityList[index].entity;
00122 }
00123
00124 inline CubitSense CompositeGeom::sense( int index ) const
00125 {
00126   return entityList[index].sense;
00127 }
00128
00129 inline double CompositeGeom::measure( int index )
00130 {
00131   if( needToUpdateMeasure )
00132     update_data_measure();
00133   return entityList[index].measure;
00134 }
00135
00136 #endif
00137
00138
00139
00140
00141
