cgma
CubitEvaluator.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CubitEvaluator.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Matthew Staten
00009 //
00010 // Creation Date : 09/14/04
00011 //
00012 // Owner         : Matthew Staten
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef CUBIT_EVALUATOR_HPP
00016 #define CUBIT_EVALUATOR_HPP
00017
00018 #include "CubitDefines.h"
00019 #include "GeometryDefines.h"
00020 #include "CubitTransformMatrix.hpp"
00021 #include "CGMGeomConfigure.h"
00022
00023 class CubitVector;
00024 class CubitBox;
00025 class CubitTransformMatrix;
00026
00027 class CUBIT_GEOM_EXPORT CubitEvaluatorData
00028 {
00029 public:
00030     virtual ~CubitEvaluatorData() {}
00031     virtual GeometryType ask_type() const { return UNDEFINED_SURFACE_TYPE; }
00032 };
00033
00034 class CUBIT_GEOM_EXPORT CubitEvaluator
00035 {
00036
00037 private:
00038
00039 protected:
00040
00041     CubitTransformMatrix mTmatrix;
00042
00043 public :
00044   virtual ~CubitEvaluator()
00045     {}
00046
00047     virtual GeometryType ask_type() { return UNDEFINED_SURFACE_TYPE; }
00048
00049     virtual const CubitEvaluatorData* evaluator_data() const = 0;
00050     virtual CubitBox bounding_box() const = 0;
00051     virtual CubitBoolean is_parametric() const = 0;
00052     virtual CubitBoolean is_periodic() const = 0;
00053     virtual CubitBoolean is_periodic_in_U( double &period ) const = 0;
00054     virtual CubitBoolean is_periodic_in_V( double &period ) const = 0;
00055     virtual CubitBoolean is_singular_in_U() const = 0;
00056     virtual CubitBoolean is_singular_in_V() const = 0;
00057     virtual CubitBoolean is_closed_in_U() const = 0;
00058     virtual CubitBoolean is_closed_in_V() const = 0;
00059     virtual CubitBoolean get_param_range_U( double& lower_bound,
00060                                             double& upper_bound ) const = 0;
00061     virtual CubitBoolean get_param_range_V( double& lower_bound,
00062                                             double& upper_bound ) const = 0;
00063
00064     virtual CubitVector position_from_u_v( double u, double v ) const = 0;
00065     virtual CubitStatus u_v_from_position( CubitVector const& location,
00066                                            double& u,
00067                                            double& v,
00068                                            CubitVector* closest_location ) const = 0;
00069
00070     virtual CubitStatus principal_curvatures( CubitVector const& location,
00071                                               double& curvature_1,
00072                                               double& curvature_2,
00073                                               CubitVector* closest_location = NULL ) = 0;
00074     //R CubitStatus
00075     //R- CUBIT_SUCCESS/FAILURE
00076     //I location
00077     //I- The point at which the curvatures are being requested -- it is also
00078     //I- the point to which the closest point on the surface is returned.
00079     //I- curvatures.
00080     //O closest_location
00081     //O- The point on the surface, closest to the input location (this
00082     //O- might not be on the surface).  This is input as a reference
00083     //O- so that the function can modify its contents.
00084     //O curvature_1/2
00085     //O- Returned principal curvature magnitudes.
00086     //- This functions computes the point on the surface that is closest
00087     //- to the input location and then calculates the magnitudes of the
00088     //- principal curvatures at this (possibly, new) point on the surface.
00089
00090     virtual CubitStatus closest_point( CubitVector const& location,
00091                                        CubitVector* closest_location = NULL,
00092                                        CubitVector* unit_normal_ptr = NULL,
00093                                        CubitVector* curvature1_ptr = NULL,
00094                                        CubitVector* curvature2_ptr = NULL ) const = 0;
00095     //R CubitStatus
00096     //R- CUBIT_SUCCESS/FAILURE
00097     //I location
00098     //I- The point to which the closest point on the surface is desired.
00099     //O closest_location
00100     //O- The point on the Surface, closest to the
00101     //O- input location (which might not be on the Surface).  This is
00102     //O- input as a reference so that the function can modify its
00103     //O- contents.
00104     //O unit_normal_ptr
00105     //O- The normal (represented as a unit vector) at the closest_location.
00106     //O- If this pointer is NULL, the normal is not returned.
00107     //O curvature1_ptr
00108     //O- The first principal curvature of the surface at closest_location.
00109     //O- If this pointer is NULL, this curvature is not returned.
00110     //O curvature2_ptr
00111     //O- The second principal curvature of the surface at closest_location.
00112     //O- If this pointer is NULL, this curvature is not returned.
00113     //- This function computes the point on the surface closest to the input
00114     //- location -- i.e., closest_location.
00115     //- The first Facet FACE in the list
00116     //- is queried.
00117     //-
00118     //- If the input pointer values of unit_normal, curvature1 and
00119     //- curvature2
00120     //- are non-NULL, the normal and principal curvatures, too, are
00121     //- returned.  These are computed at closest_location, not at the
00122     //- input location.
00123     //-
00124     //- NOTE:
00125     //- It is assumed that if the calling code needs the normal or the
00126     //- principal curvatures, it will *allocate* space for the CubitVectors
00127     //- before sending in the pointers.
00128
00129     void add_transformation( CubitTransformMatrix &tfmat )
00130     {
00131         mTmatrix = tfmat * mTmatrix;
00132     }
00133
00134 };
00135
00136
00137 // ********** BEGIN INLINE FUNCTIONS       **********
00138 // ********** END INLINE FUNCTIONS         **********
00139
00140 // ********** BEGIN FRIEND FUNCTIONS       **********
00141 // ********** END FRIEND FUNCTIONS         **********
00142
00143 // ********** BEGIN EXTERN FUNCTIONS       **********
00144 // ********** END EXTERN FUNCTIONS         **********
00145
00146 #endif
00147
