cgma
CubitFacetEdgeData.cpp
00001 //=======================================================================
00002 //
00003 //  File: CubitFacetEdgeData
00004 //  Description: used for edges of CubitFacets.  These are optional
00005 //               and used only if specific information must be stored at
00006 //               the edge common to tow facets
00007 //  Owner: sjowen
00008 //
00009 //=======================================================================
00010
00011 #include "CubitFacetEdge.hpp"
00012 #include "CubitFacetEdgeData.hpp"
00013 #include "CubitFacetData.hpp"
00014 #include "CubitPoint.hpp"
00015 #include "CubitVector.hpp"
00016 #include "GeometryDefines.h"
00017 #include "ToolData.hpp"
00018
00019 static int counter_id = 0;
00020
00021 //======================================================================
00022 // Function: CubitFacetEdgeData (PUBLIC)
00023 // Description: constructor.  Determines the adjacencies from existing
00024 //              CubitPoint adjacency information
00025 //              Note: can handle non-manifold topology
00026 // Author: sjowen
00027 // Date: 8/00
00028 //======================================================================
00029 CubitFacetEdgeData::CubitFacetEdgeData( CubitPoint *p1, CubitPoint *p2 )
00030 {
00031   assert( p1 && p2 );
00032   assert( p1 != p2 );
00033   pointArray[0] = p1;
00034   pointArray[1] = p2;
00035
00036   counter_id++;
00037   entityId = counter_id;
00038
00039   // determine adjacency (assumes facets are already defined)
00040   // set the edge and use on the adjacent facets
00041
00042   int sense;
00043   int eindex;
00044   CubitFacet *facet_ptr;
00045   DLIList<CubitFacet*> facet_list;
00046   p1->facets( facet_list );
00047   CubitBoolean found;
00048   for(int ii=0; ii<facet_list.size(); ii++) {
00049     found = CUBIT_FALSE;
00050     facet_ptr = facet_list.get_and_step();
00051     for(int jj=0; jj<3 && !found; jj++)
00052     {
00053       if (facet_ptr->point(jj) == p2)
00054       {
00055         found = CUBIT_TRUE;
00056         adjFacetList.append(facet_ptr);
00057         eindex = facet_ptr->edge_index( p1, p2, sense );
00058         facet_ptr->edge( this, eindex );
00059         facet_ptr->edge_use( sense, eindex );
00060       }
00061     }
00062   }
00063 }
00064
00065 //======================================================================
00066 // Function: CubitFacetEdgeData (PUBLIC)
00067 // Description: overloaded constructor:  Adjacency information is
00068 //              provided in the arguments -- assumes a 2D topology
00069 // Author: sjowen
00070 // Date: 8/00
00071 //======================================================================
00072 CubitFacetEdgeData::CubitFacetEdgeData( CubitPoint *p1, CubitPoint *p2,
00073                                 CubitFacet *facet1, CubitFacet *facet2,
00074                                 int edge_index1, int edge_index2)
00075 {
00076   assert( p1 && p2 );
00077   assert( p1 != p2 );
00078   pointArray[0] = p1;
00079   pointArray[1] = p2;
00080
00081   counter_id++;
00082   entityId = counter_id;
00083
00084   if (facet1) {
00085     adjFacetList.append(facet1);
00086     facet1->edge( this, edge_index1 );
00087     facet1->edge_use( 1, edge_index1 );
00088   }
00089   if (facet2) {
00090     adjFacetList.append(facet2);
00091     facet2->edge( this, edge_index2 );
00092     facet2->edge_use( -1, edge_index2 );
00093   }
00094 }
00095
00096 //======================================================================
00097 // Function: ~CubitFacetEdgeData (PUBLIC)
00098 // Description: destructor
00099 // Author: sjowen
00100 // Date: 8/00
00101 //======================================================================
00102 CubitFacetEdgeData::~CubitFacetEdgeData()
00103 {
00104   assert(adjFacetList.size() == 0);
00105 }
00106
00107 //======================================================================
00108 // Function: adj_facet (PUBLIC)
00109 // Description: get a specific adjacent facet (by index)
00110 // Author: sjowen
00111 // Date: 4/01
00112 //======================================================================
00113 CubitFacet *CubitFacetEdgeData::adj_facet( int index )
00114 {
00115   if (index < 0 || index > adjFacetList.size() - 1)
00116     return (CubitFacet *)NULL;
00117   adjFacetList.reset();
00118   return adjFacetList.next(index);
00119 }
00120
00121 //======================================================================
00122 // Function: facets (PUBLIC)
00123 // Description: get the atached facets
00124 // Author: sjowen
00125 // Date: 4/01
00126 //======================================================================
00127 void CubitFacetEdgeData::facets(DLIList<CubitFacet*> &facet_list)
00128 {
00129   facet_list += adjFacetList;
00130 }
00131
00132 //======================================================================
00133 // Function: edges (PUBLIC)
00134 // Description: get the atached edges
00135 // Author: sjowen
00136 // Date: 4/01
00137 //======================================================================
00138 void CubitFacetEdgeData::edges(DLIList<CubitFacetEdge*> &edge_list )
00139 {
00140   edge_list.append( this );
00141 }
00142
00143 //======================================================================
00144 // Function: points (PUBLIC)
00145 // Description: get the attached points
00146 // Author: sjowen
00147 // Date: 4/01
00148 //======================================================================
00149 void CubitFacetEdgeData::points(DLIList<CubitPoint*> &point_list )
00150 {
00151   point_list.append( pointArray[0] );
00152   point_list.append( pointArray[1] );
00153 }
00154
00155 //======================================================================
00156 // Function: remove_facet (PUBLIC)
00157 // Description: remove the facet from the edge adjacency list
00158 // Author: sjowen
00159 // Date: 4/01
00160 //======================================================================
00161 CubitStatus CubitFacetEdgeData::remove_facet( CubitFacet *facet_ptr )
00162 {
00163   CubitStatus stat = CUBIT_SUCCESS;
00164   bool removed = adjFacetList.remove( facet_ptr );
00165   if (removed)
00166     stat = CUBIT_SUCCESS;
00167   else
00168     stat = CUBIT_FAILURE;
00169   return stat;
00170 }
00171
00172 //-------------------------------------------------------------------------
00173 // Purpose       : Merge edges
00174 //
00175 // Special Notes : points must already be merged.
00176 //
00177 // Creator       : Jason Kraftcheck
00178 //
00179 // Creation Date : 02/24/03
00180 //-------------------------------------------------------------------------
00181 CubitStatus CubitFacetEdgeData::merge_edges( CubitFacetEdgeData* other_edge )
00182 {
00183   if( other_edge == this )
00184     return CUBIT_SUCCESS;
00185
00186   int reversed = false;
00187   if ( point(0) == other_edge->point(1) && point(1) == other_edge->point(0) )
00188     reversed = true;
00189   else if( point(0) != other_edge->point(0) || point(1) != other_edge->point(1) )
00190     return CUBIT_FAILURE;
00191
00192   CubitFacetData* facet;
00193   adjFacetList.reset();
00194   while( other_edge->adjFacetList.size() )
00195   {
00196     facet = dynamic_cast<CubitFacetData*>(other_edge->adjFacetList.pop());
00197     for ( int i = 0; i < 3; i++ )
00198     {
00199       if( facet->edge(i) == other_edge )
00200       {
00201         facet->edge( this, i );
00202         add_facet(facet);
00203         if( reversed )
00204           facet->edge_use( -facet->edge_use(i), i );
00205       }
00206     }
00207   }
00208
00209   delete other_edge;
00210   return CUBIT_SUCCESS;
00211 }
00212
00213 void CubitFacetEdgeData::flip()
00214 {
00215   CubitPoint* tmp = pointArray[0];
00216   pointArray[0] = pointArray[1];
00217   pointArray[1] = tmp;
00218   for ( int i = adjFacetList.size(); i--; )
00219   {
00220     CubitFacet* facet = adjFacetList.get_and_step();
00221     int index = facet->edge_index(this);
00222     assert(index >= 0);
00223     facet->edge_use( -facet->edge_use(index), index );
00224   }
00225   toggle_is_flipped();
00226 }
00227
