cgma
CubitPolygon.hpp
00001 //- Class: CubitPolygon
00002 //-
00003 //- Description: This file defines the CubitPolygon class which is basically
00004 //- an ordered list of 2D points and their 2D bounding box.
00005 //-
00006 //- Owner: Steve Storm
00007
00008 #ifndef CUBITPOLYGON_HPP
00009 #define CUBITPOLYGON_HPP
00010
00011 #include "CubitDefines.h"
00012 #include "Cubit2DPoint.hpp"
00013 #include "DLIList.hpp"
00014 #include "CGMGeomConfigure.h"
00015
00016 class CUBIT_GEOM_EXPORT CubitPolygon
00017 {
00018 public:
00019
00020   //- Heading: Constructors and Destructor
00021   CubitPolygon();  //- Default constructor.
00022
00023   CubitPolygon( DLIList<Cubit2DPoint*> &point_list );
00024   //- Constructor: create polygon from array of points.  Points are copied.
00025
00026   CubitPolygon( Cubit2DPoint &point );
00027   //- Constructor: create polygon with initial point.  Point is copied.
00028
00029   ~CubitPolygon();
00030   //- Destructor
00031
00032   void add_point( Cubit2DPoint &point );
00033   //- Add a point to the end of the point list.  Point is copied.
00034
00035   CubitPointContainment pnt_containment( Cubit2DPoint &point,
00036                                          double tol = 1e-10 );
00037   //- Determine if the input point is inside, outside or on the boundary
00038   //- of the polygon.
00039
00040   CubitStatus centroid_area( Cubit2DPoint &centroid, double &area );
00041   //- Get geometrical centroid and area of polygon
00042
00043 private:
00044
00045   DLIList<Cubit2DPoint*> pointList;
00046   Cubit2DPoint minCoord;  // Minimum coordinate of polygon
00047   Cubit2DPoint maxCoord;  // Maximum coordinate of polygon
00048
00049 };
00050
00051 #endif
00052
00053
