cgma
CubitSimpleAttrib.cpp
00001 //- Filename:    CubitSimpleAttrib.cc
00002 //- Description: Implementation of class CubitSimpleAttrib
00003 //- Owner:       Greg Nielson
00004 //- Checked by:
00005 //- Version:
00006
00007 #include <string.h>
00008 #include "SettingHandler.hpp"
00009
00010 #include "CubitSimpleAttrib.hpp"
00011 #include "CubitString.hpp"
00012 #include "CubitMessage.hpp"
00013 #include "RefEntity.hpp"
00014 #include "RefEntityFactory.hpp"
00015 #include "CubitFileIOWrapper.hpp"
00016
00017 CubitBoolean CubitSimpleAttrib::pushAttribs = CUBIT_FALSE;
00018
00019 //SettingHolder SettingHandler::settingObject43 = SettingHolder("Push_Attribs", CubitSimpleAttrib::set_push_attribs, CubitSimpleAttrib::get_push_attribs, CUBIT_FALSE);
00020
00021 CubitSimpleAttrib::CubitSimpleAttrib()
00022 {
00023 }
00024
00025 CubitSimpleAttrib::~CubitSimpleAttrib()
00026 {
00027 }
00028
00029 CubitSimpleAttrib::CubitSimpleAttrib(const CubitString new_character_type,
00030                                      const CubitString new_string_data,
00031                                      const CubitString new_more_string_data,
00032                                      const int* new_integer_data,
00033                                      const double* new_double_data)
00034 {
00035   assert(new_character_type.length() > 0);
00036
00037   stringDataList.push_back(new_character_type);
00038
00039   if (new_string_data.length()) {
00040     stringDataList.push_back(new_string_data);
00041   }
00042
00043   if (new_more_string_data.length()) {
00044     stringDataList.push_back(new_more_string_data);
00045   }
00046
00047   if(new_double_data)
00048     doubleDataList.push_back( *new_double_data );
00049   if(new_integer_data)
00050     intDataList.push_back( *new_integer_data );
00051
00052   return;
00053 }
00054
00055 bool CubitSimpleAttrib::isEmpty() const
00056 {
00057   return stringDataList.empty() &&
00058       doubleDataList.empty() &&
00059       intDataList.empty();
00060 }
00061
00062 CubitSimpleAttrib::CubitSimpleAttrib(const CubitSimpleAttrib& csa_ptr)
00063 {
00064   this->stringDataList = csa_ptr.stringDataList;
00065   this->doubleDataList = csa_ptr.doubleDataList;
00066   this->intDataList = csa_ptr.intDataList;
00067 }
00068
00069 CubitSimpleAttrib::CubitSimpleAttrib(const std::vector<CubitString> *string_list,
00070                                      const std::vector<double> *double_list,
00071                                      const std::vector<int> *int_list)
00072 {
00073   if(string_list)
00074     this->stringDataList = *string_list;
00075   if(double_list)
00076     this->doubleDataList = *double_list;
00077   if(int_list)
00078     this->intDataList = *int_list;
00079 }
00080
00081
00082 CubitSimpleAttrib &CubitSimpleAttrib::operator=(const CubitSimpleAttrib &other)
00083 {
00084     this->stringDataList = other.stringDataList;
00085     this->intDataList = other.intDataList;
00086     this->doubleDataList = other.doubleDataList;
00087     return *this;
00088 }
00089
00090 CubitString CubitSimpleAttrib::character_type() const //- returns the type of attribute
00091 {
00092   if(stringDataList.size() >= 1 )
00093   {
00094     return stringDataList[0];
00095   }
00096   return CubitString();
00097 }
00098
00099 void CubitSimpleAttrib::string_data_list( const std::vector<CubitString>& new_list)
00100 {
00101   this->stringDataList = new_list;
00102 }
00103
00104 void CubitSimpleAttrib::double_data_list(const std::vector<double>& new_list)
00105 {
00106   doubleDataList = new_list;
00107 }
00108
00109 void CubitSimpleAttrib::int_data_list(const std::vector<int>& new_list)
00110 {
00111   intDataList = new_list;
00112 }
00113
00114 bool CubitSimpleAttrib::operator==(const CubitSimpleAttrib& other) const
00115 {
00116   return this->stringDataList == other.stringDataList &&
00117          this->doubleDataList == other.doubleDataList &&
00118          this->intDataList == other.intDataList;
00119 }
00120
00121
00122 //Initialize all settings in this class
00123 void CubitSimpleAttrib::initialize_settings()
00124 {
00125
00126   SettingHandler::instance()->add_setting("Push Attribs",
00127                                          CubitSimpleAttrib::set_push_attribs,
00128                      CubitSimpleAttrib::get_push_attribs);
00129 }
00130
00131 void CubitSimpleAttrib::print() const
00132 {
00133   PRINT_INFO("CSA: type = %s\n", stringDataList[0].c_str());
00134
00135   PRINT_INFO("String data: ");
00136   for ( size_t i=1; i<stringDataList.size(); i++)
00137     PRINT_INFO("%s;", stringDataList[i].c_str());
00138   if (stringDataList.size() == 0)
00139     PRINT_INFO("(none)");
00140   PRINT_INFO("\n");
00141
00142   PRINT_INFO("Int data: ");
00143   for (size_t i=0; i<intDataList.size(); i++)
00144     PRINT_INFO("%d;", intDataList[i]);
00145   if (intDataList.size() == 0)
00146     PRINT_INFO("(none)");
00147   PRINT_INFO("\n");
00148
00149   PRINT_INFO("Double data: ");
00150   for (size_t i=0; i<doubleDataList.size(); i++)
00151     PRINT_INFO("%f;", doubleDataList[i]);
00152   if (doubleDataList.size() == 0)
00153     PRINT_INFO("(none)");
00154   PRINT_INFO("\n");
00155 }
00156
