cgma
DagType.hpp
00001 #ifndef DAG_TYPE_HPP
00002 #define DAG_TYPE_HPP
00003
00004
00005
00006 class DagType
00007 {
00008
00009   public:
00010
00011     enum FunctionalType {
00012       BasicTopologyEntity_TYPE = 0,
00013       SenseEntity_TYPE = 1,
00014       GroupingEntity_TYPE = 2 };
00015
00016       // Constructor
00017       //
00018       // Construct invalid DagType
00019     inline DagType()
00020       : intType(-1)
00021       {}
00022
00023       // Constructor
00024       //
00025       // GroupingEntities and SenseEntities have the same
00026       // dimension as their child BasicTopologyEntity type.
00027       // Dimension may be outside the range [0,3], but
00028       // if so is_valid() will return false.  (i.e. it is
00029       // possible to construct invalid DagType objects.)
00030     inline DagType( int dimensionIn, FunctionalType func )
00031       : intType( 3 * dimensionIn + func )
00032       { }
00033
00034
00035       // Return the dimension of this type.
00036       //
00037       // GroupingEntities and SenseEntities have the same
00038       // dimension as their child BasicTopologyEntity type.
00039     inline int dimension() const
00040       { return intType / 3; }
00041
00042       // Return the base type of this subtype.
00043       //
00044       // Return values are one of GroupingEntity_TYPE,
00045       // SenseEntity_TYPE, or BasicTopologyEntity_TYPE.
00046     inline FunctionalType functional_type() const
00047       { return (FunctionalType)(intType % 3); }
00048
00049
00050       // Is this a valid DagType?
00051       //
00052       // An invalid type can be obtained by constructing
00053       // a DagType object with a dimension not in the
00054       // range [0,3], or using the operators below to
00055       // move above a Body or below a RefVertex in the DAG.
00056     inline bool is_valid() const
00057       {
00058         const unsigned bodyType = 11;
00059         return (unsigned)intType <= bodyType;
00060       }
00061
00062       // get parent of this type
00063     inline DagType parent() const
00064       { return DagType(intType + 1); }
00065
00066
00067       // Comparison Operators.
00068       //
00069       //   An entity higher in the DAG (closer to Body) is
00070       //   considered greater than an entity lower in the
00071       //   DAG (closer to RefVertex).
00072
00073     inline bool operator==( DagType other ) const
00074       { return intType == other.intType; }
00075
00076     inline bool operator!=( DagType other ) const
00077       { return intType != other.intType; }
00078
00079     inline bool operator<=( DagType other ) const
00080       { return intType <= other.intType; }
00081
00082     inline bool operator>=( DagType other ) const
00083       { return intType >= other.intType; }
00084
00085     inline bool operator< ( DagType other ) const
00086       { return intType < other.intType; }
00087
00088     inline bool operator> ( DagType other ) const
00089       { return intType > other.intType; }
00090
00091
00092       // Addition operators.
00093       //
00094       //  Increasing the value of the type moves the
00095       //  type up the DAG (closer to Body).  No bounds
00096       //  checking is done on the value.  Moving upwards
00097       //  from Body or downwards past RefVertex results
00098       //  in a DagType for which is_valid() returns false.
00099
00100     inline DagType operator++()
00101       { return DagType(++intType); }
00102
00103     inline DagType operator--()
00104       { return DagType(--intType); }
00105
00106     inline DagType operator++(int)
00107       { return DagType(intType++); }
00108
00109     inline DagType operator--(int)
00110       { return DagType(intType--); }
00111
00112     inline DagType operator+=( int i )
00113       { return DagType(intType += i); }
00114
00115     inline DagType operator-=( int i )
00116       { return DagType(intType -= i); }
00117
00118     inline DagType operator+( int i ) const
00119       { return DagType(intType + i); }
00120
00121     inline DagType operator-( int i ) const
00122       { return DagType(intType - i); }
00123
00124
00125       // Cast to bool.
00126       //
00127       // Same as is_valid().
00128     inline operator bool() const
00129       { return is_valid(); }
00130
00131
00132       // Get distance between types in DAG.
00133       //
00134       // Return value is negative if the passed type
00135       // is higher (closer to Body) in the DAG than
00136       // this type is.  The return value is 1 (one)
00137       // if the passed type is an immediate child of
00138       // this type.  The return value is 0 (zero) if
00139       // the types are the same.
00140     inline int operator-( DagType other ) const
00141       { return intType - other.intType; }
00142
00143       // Constants
00144 inline static DagType       body_type() {return DagType(3,GroupingEntity_TYPE);}
00145 inline static DagType  co_volume_type() {return DagType(3,SenseEntity_TYPE);}
00146 inline static DagType ref_volume_type() {return DagType(3,BasicTopologyEntity_TYPE);}
00147 inline static DagType      shell_type() {return DagType(2,GroupingEntity_TYPE);}
00148 inline static DagType    co_face_type() {return DagType(2,SenseEntity_TYPE);}
00149 inline static DagType   ref_face_type() {return DagType(2,BasicTopologyEntity_TYPE);}
00150 inline static DagType       loop_type() {return DagType(1,GroupingEntity_TYPE);}
00151 inline static DagType    co_edge_type() {return DagType(1,SenseEntity_TYPE);}
00152 inline static DagType   ref_edge_type() {return DagType(1,BasicTopologyEntity_TYPE);}
00153 inline static DagType      chain_type() {return DagType(0,GroupingEntity_TYPE);}
00154 inline static DagType  co_vertex_type() {return DagType(0,SenseEntity_TYPE);}
00155 inline static DagType ref_vertex_type() {return DagType(0,BasicTopologyEntity_TYPE);}
00156 inline static DagType    invalid_type() {return DagType(-1);}
00157   private:
00158
00159     inline explicit DagType( int value )
00160       : intType( value ) {}
00161
00162     int intType;
00163 };
00164
00165
00166 #endif
00167
