cgma
FacetPoint.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : FacetPoint.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Steven J. Owen
00009 //
00010 // Creation Date : 08/02/96
00011 //
00012 // Owner         : Steven J. Owen
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef POINT_FACET_HPP
00016 #define POINT_FACET_HPP
00017
00018 // ********** BEGIN STANDARD INCLUDES      **********
00019 // ********** END STANDARD INCLUDES        **********
00020
00021 // ********** BEGIN CUBIT INCLUDES         **********
00022 #include "CubitDefines.h"
00023 #include "Point.hpp"
00024 #include "FacetAttribSet.hpp"
00025 // ********** END CUBIT INCLUDES           **********
00026
00027 // ********** BEGIN FORWARD DECLARATIONS   **********
00028 class TopologyEntity;
00029 class CubitSimpleAttrib;
00030 class RefVertex;
00031 class RefVolume;
00032 class RefVolume;
00033 class CubitPoint;
00034 class FacetAttrib;
00035
00036 class FacetBody;
00037 class FacetLump;
00038 class FacetShell;
00039 class FacetSurface;
00040 class FacetLoop;
00041 class FacetCoEdge;
00042 class FacetCurve;
00043
00044 // ********** END FORWARD DECLARATIONS     **********
00045
00046 class FacetPoint : public TBPoint
00047 {
00048 private:
00049
00050   DLIList<Curve*> myCurves;
00051   CubitPoint *myPoint;
00052   CubitBoolean iCreated;
00053
00054   FacetAttribSet attribSet;
00055     //List of FacetAttrib*'s instead of CubitSimpleAttribs
00056
00057 public :
00058
00059   FacetPoint(const CubitVector &location, DLIList<Curve*> &curves );
00060     //I- CubitVector &location
00061     //I- location of point (creates a CubiPoint).
00062     //I- DLIList<Curve*> curves
00063     //I- curves attaced to point
00064
00065   FacetPoint(CubitPoint *thePoint, DLIList<Curve*> &curves );
00066     //I- CubitPoint *thePoint
00067     //I- pointer to the CubitPoint associated with FacetPoint
00068     //I- DLIList<Curve*> curves
00069     //I- curves attaced to point
00070
00071   FacetPoint(CubitPoint *thePoint );
00072     //I- CubitPoint *thePoint
00073     //I- pointer to the CubitPoint associated with FacetPoint
00074
00075   virtual ~FacetPoint();
00076     //- The destructor
00077
00078   virtual void append_simple_attribute_virt(const CubitSimpleAttrib&);
00079     //R void
00080     //I
00081     //I-
00082     //I- that is to be appended to this OSME object.
00083     //- The purpose of this function is to append a
00084     //- attribute to the OSME. The  is attached to each of the
00085     //- underlying solid model entities this one points to.
00086
00087   virtual void remove_simple_attribute_virt(const CubitSimpleAttrib&);
00088     //R void
00089     //I CubitSimpleAttrib*
00090     //I- A reference to a CubitSimpleAttrib object which is the object
00091     //I- that is to be removed to this OSME object.
00092     //- The purpose of this function is to remove a simple
00093     //- attribute from the OSME. The attribute is attached to each of the
00094     //- underlying solid model entities this one points to.
00095
00096   virtual void remove_all_simple_attribute_virt();
00097     //R void
00098     //I-
00099     //- The purpose of this function is to remove all simple
00100     //- attributes from the OSME.
00101
00102   virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>&);
00103   virtual CubitStatus get_simple_attribute(const CubitString& name,
00104                                            DLIList<CubitSimpleAttrib>&);
00105     //R CubitSimpleAttrib*
00106     //R- the returned cubit simple attribute.
00107     //- The purpose of this function is to get the attributes
00108     //- of the geometry entity. The name is attached to the underlying solid
00109     //- model entity(ies) this one points to.
00110     //- MJP Note:
00111     //- This is the code that implements the requirement that names
00112     //- of VGI Entities propagate across solid model boolean
00113     //- operations.  The success of this relies, of course, on the underlying
00114     //- solid modeler being able to propagate attributes across
00115     //- such operations on its entities. If it cannot, then "names"
00116     //- of VGI entities will not propagate.
00117
00118   virtual CubitVector coordinates() const;
00119     //R CubitVector
00120     //R- Contains the coordinate values {x y z} of this Point
00121     //- Returns the spatial coordinates of this Point.
00122
00123   virtual CubitBox bounding_box() const ;
00124     // see comments in GeometryEntity.hpp
00125
00126   virtual GeometryQueryEngine*
00127   get_geometry_query_engine() const;
00128     //R GeometryQueryEngine*
00129     //R- A pointer to the geometric modeling engine associated with
00130     //R- the object.
00131     //- This function returns a pointer to the geometric modeling engine
00132     //- associated with the object.
00133
00134   void add_curve( Curve* curv_ptr )
00135     { myCurves.append_unique( curv_ptr ); }
00136     // associate this point with a curve
00137
00138   CubitPoint *get_cubit_point() const
00139     { return myPoint; }
00140     // return the CubitPoint associated with this facet point
00141
00142   CubitStatus save_attribs( FILE* file_ptr );
00143     // Write FactAttribs out to file
00144
00145   CubitStatus restore_attribs( FILE* file_ptr, unsigned int endian );
00146     // Read FactAttribs from file
00147
00148   void get_parents_virt( DLIList<TopologyBridge*>& parents );
00149   void get_children_virt( DLIList<TopologyBridge*>& children );
00150
00151   void get_lumps   ( DLIList<FacetLump   *>& lumps    );
00152   void get_shells  ( DLIList<FacetShell  *>& shells   );
00153   void get_surfaces( DLIList<FacetSurface*>& surfaces );
00154   void get_loops   ( DLIList<FacetLoop   *>& loops    );
00155   void get_coedges ( DLIList<FacetCoEdge *>& coedges  );
00156   void get_curves  ( DLIList<FacetCurve  *>& curves   );
00157
00158   CubitStatus disconnect_curve( FacetCurve* curve );
00159
00160   inline bool has_parent_curve() const { return myCurves.size() > 0; }
00161 };
00162
00163
00164 // ********** BEGIN INLINE FUNCTIONS       **********
00165 // ********** END INLINE FUNCTIONS         **********
00166
00167 // ********** BEGIN FRIEND FUNCTIONS       **********
00168 // ********** END FRIEND FUNCTIONS         **********
00169
00170 // ********** BEGIN EXTERN FUNCTIONS       **********
00171 // ********** END EXTERN FUNCTIONS         **********
00172
00173 #endif
