cgma
FacetShell.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : FacetShell.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Xuechen Liu
00009 //
00010 // Creation Date : 08/06/96
00011 //
00012 // Owner         : Malcolm J. Panthaki
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef FACET_SHELL_HPP
00016 #define FACET_SHELL_HPP
00017
00018 // ********** BEGIN STANDARD INCLUDES      **********
00019 // ********** END STANDARD INCLUDES        **********
00020
00021 // ********** BEGIN CUBIT INCLUDES         **********
00022 #include "CubitDefines.h"
00023 #include "ShellSM.hpp"
00024
00025 class FacetBody;
00026 class FacetLump;
00027 class FacetSurface;
00028 class FacetLoop;
00029 class FacetCoEdge;
00030 class FacetCurve;
00031 class FacetPoint;
00032
00033 // ********** END CUBIT INCLUDES           **********
00034
00035 class FacetShell : public ShellSM
00036 {
00037 public:
00038
00039   FacetShell(Lump* my_lump,
00040              DLIList<Surface*> &my_surfs );
00041     //- Constructor with lists of attached lumps and surfaces.
00042
00043   FacetShell( DLIList<Surface*> &my_surfs );
00044     //- Constructor with lists of attached surfaces.
00045
00046   virtual ~FacetShell() ;
00047     //- Destructor.
00048   void add_lump(Lump* lump_ptr);
00049
00050
00051   virtual GeometryQueryEngine*
00052   get_geometry_query_engine() const;
00053     //R GeometryQueryEngine*
00054     //R- A pointer to the geometric modeling engine associated with
00055     //R- the object.
00056     //- This function returns a pointer to the geometric modeling engine
00057     //- associated with the object.
00058
00059   virtual void append_simple_attribute_virt(const CubitSimpleAttrib&);
00060     //R void
00061     //I
00062     //I-
00063     //I- that is to be appended to this OSME object.
00064     //- The purpose of this function is to append a
00065     //- attribute to the OSME. The  is attached to each of the
00066     //- underlying solid model entities this one points to.
00067
00068   virtual void remove_simple_attribute_virt(const CubitSimpleAttrib&);
00069     //R void
00070     //I CubitSimpleAttrib*
00071     //I- A reference to a CubitSimpleAttrib object which is the object
00072     //I- that is to be removed to this OSME object.
00073     //- The purpose of this function is to remove a simple
00074     //- attribute from the OSME. The attribute is attached to each of the
00075     //- underlying solid model entities this one points to.
00076
00077   virtual void remove_all_simple_attribute_virt();
00078     //R void
00079     //I-
00080     //- The purpose of this function is to remove all simple
00081     //- attributes from the OSME.
00082
00083   virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>&);
00084   virtual CubitStatus get_simple_attribute(const CubitString& name,
00085                                            DLIList<CubitSimpleAttrib>&);
00086     //R CubitSimpleAttrib*
00087     //R- the returned cubit simple attribute.
00088     //- The purpose of this function is to get the attributes
00089     //- of the geometry entity. The name is attached to the underlying solid
00090     //- model entity(ies) this one points to.
00091     //- MJP Note:
00092     //- This is the code that implements the requirement that names
00093     //- of VGI Entities propagate across solid model boolean
00094     //- operations.  The success of this relies, of course, on the underlying
00095     //- solid modeler being able to propagate attributes across
00096     //- such operations on its entities. If it cannot, then "names"
00097     //- of VGI entities will not propagate.
00098
00099   void get_lumps   ( DLIList<FacetLump   *>& lumps    );
00100   void get_surfaces( DLIList<FacetSurface*>& surfaces );
00101   void get_coedges ( DLIList<FacetCoEdge *>& coedges  );
00102   void get_curves  ( DLIList<FacetCurve  *>& curves   );
00103
00104   void get_parents_virt( DLIList<TopologyBridge*>& parents );
00105   void get_children_virt( DLIList<TopologyBridge*>& children );
00106
00107   inline Lump* get_lump() const { return myLump; }
00108
00109   inline void remove_lump() { myLump = 0; }
00110
00111   void disconnect_surfaces( DLIList<FacetSurface*> &surfs_to_disconnect );
00112   void disconnect_all_surfaces();
00113
00114   void reverse(); // invert sense of each surface as used in this shell.
00115   void reverse_surfaces(); //Actually flip the surface... do not change sense.
00116
00117   CubitPointContainment point_containment( const CubitVector &point, double tolerance = -1.0 );
00118
00119     //determine whether this is a sheet shell or not.
00120     // This function may have problems with certain non-manifold geometries
00121     // It is looking for facets that aren't attached to another facet for
00122     // one or more of its edges.
00123     // NOTE (mbrewer): this can probably be improved by going to the
00124     // curves and checking for the number of co-edges on each curve.
00125   CubitBoolean is_sheet();
00126
00127 protected:
00128
00129 private:
00130   Lump* myLump;
00131   DLIList<Surface*> mySurfs;
00132 };
00133
00134
00135
00136 #endif
00137
