cgma
FacetorTool.cpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : FacetorTool.cpp
00003 //
00004 // Purpose       : 2D Delaunay mesher, template that can use both mesh and geom entities, not yet tested with geometric
00005 //                 entities
00006 //
00007 // Creator       : Christopher Hynes
00008 //
00009 // Creation Date : 5/31/2002
00010 //
00011 // Owner         : Steve Owen
00012 //-------------------------------------------------------------------------
00013
00014 #ifdef INLINE_TEMPLATES
00015 #define MY_INLINE inline
00016 #else
00017 #define MY_INLINE
00018 #endif
00019
00020 #include "FacetorTool.hpp"
00021 #include "FacetorUtil.hpp"
00022 #include "TDDelaunay.hpp"
00023 #include "BoundaryConstrainTool.hpp"
00024 #include "CubitPoint.hpp"
00025 #include "CubitPointData.hpp"
00026 #include "CubitFacet.hpp"
00027 #include "CubitFacetData.hpp"
00028 #include "FacetEvalTool.hpp"
00029 #include "ParamTool.hpp"
00030 #include "CubitMessage.hpp"
00031
00032 #define DETERM(p1,q1,p2,q2,p3,q3)\
00033      ((q3)*((p2)-(p1)) + (q2)*((p1)-(p3)) + (q1)*((p3)-(p2)))
00034 #define SQR(x) ((x) * (x))
00035 #define FT_INSIDE_TOL 1.0e-6
00036 #define QUALITY_ANGLE 0.361283155162   /* 20.7 degrees */
00037 #define ALPHA 0.70228615
00038
00039 //-------------------------------------------------------------------------
00040 // Function:    FacetorTool
00041 // Description: constructor
00042 // Author:      chynes
00043 // Date:        6/5/2002
00044 //-------------------------------------------------------------------------
00045 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00046 FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::
00047 FacetorTool( SURF *ref_face_ptr,
00048             DLIList<NODE *> &bounding_nodes,
00049             NODE **boundary_edge_start_nodes,
00050             NODE **boundary_edge_end_nodes,
00051             int num_boundary_edges,
00052             SIZEFUNC *sizing_function,
00053             ParamTool *p_tool )
00054 {
00055   //update private variables
00056   pTool = p_tool;
00057   refFacePtr = ref_face_ptr;
00058   boundingNodes = &bounding_nodes;
00059   boundaryEdgeStartNodes = boundary_edge_start_nodes;
00060   boundaryEdgeEndNodes = boundary_edge_end_nodes;
00061   numBoundaryEdges = num_boundary_edges;
00062   sizingFunction = sizing_function;
00063
00064   curVisitFlag = INT_MIN+1;
00065   boxNodes[0] = boxNodes[1] = boxNodes[2] = boxNodes[3] = NULL;
00066 }
00067
00068
00069 //-------------------------------------------------------------------------
00070 // Function:    ~FacetorTool
00071 // Description: destructor
00072 // Author:      chynes
00073 // Date:        5/31/2002
00074 //-------------------------------------------------------------------------
00075 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00076 FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::~FacetorTool()
00077 {
00078   numBoundaryEdges = 0;
00079 }
00080
00081
00082 //-------------------------------------------------------------------------
00083 // Function:    mesh_surf
00084 // Description: mesh the surface
00085 // Author:      chynes
00086 // Date:        5/31/2002
00087 //-------------------------------------------------------------------------
00088 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00089 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::mesh_surf(DLIList<TRI *> &facet_list)
00090 {
00091   CubitStatus  ret_value  = CUBIT_SUCCESS;
00092
00093   // update private variables
00094   facetList = &facet_list;
00095
00096   // create two initial bounding triangles
00097
00098   if (ret_value == CUBIT_SUCCESS)
00099   {
00100     ret_value = init_box();
00101   }
00102
00103   // insert the boundary nodes
00104
00105   if (ret_value == CUBIT_SUCCESS)
00106   {
00107       //PRINT_INFO("Inserting boundary nodes \n");
00108     ret_value = insert_nodes( boundingNodes );
00109   }
00110
00111   // constrain the boundary
00112
00113   if (ret_value == CUBIT_SUCCESS)
00114   {
00115       //PRINT_INFO("Constraining the mesh to the boundary\n");
00116     ret_value = constrain_boundary();
00117   }
00118
00119   // delete the triangles on the outside of the boundary
00120
00121   if (ret_value == CUBIT_SUCCESS)
00122   {
00123       //PRINT_INFO("Deleting the exterior entities\n");
00124     ret_value = delete_exterior();
00125   }
00126
00127   // insert the hards
00128
00129   // insert interior points
00130
00131   if (ret_value == CUBIT_SUCCESS) {
00132       //PRINT_INFO("Refining the interior mesh\n");
00133     ret_value = refine_interior(*facetList);
00134   }
00135
00136     // clean up
00137     //PRINT_INFO("Cleaning up some data\n");
00138   clean_up_data();
00139
00140
00141   return ret_value;
00142 }
00143
00144 //-------------------------------------------------------------------------
00145 // Function:    mesh_surfwoIP
00146 // Description: mesh the surface w/o interior point refinement
00147 // Author:      chynes
00148 // Date:        6/20/2002
00149 //-------------------------------------------------------------------------
00150 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00151 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::mesh_surfwoIP(DLIList<TRI *> &facet_list)
00152 {
00153   CubitStatus  ret_value  = CUBIT_SUCCESS;
00154
00155   //update private variables
00156   facetList = &facet_list;
00157
00158   // create two initial bounding triangles
00159
00160   if (ret_value == CUBIT_SUCCESS)
00161   {
00162     ret_value = init_box();
00163   }
00164
00165   // insert the boundary nodes
00166
00167   if (ret_value == CUBIT_SUCCESS)
00168   {
00169     ret_value = insert_nodes( boundingNodes );
00170   }
00171
00172   // constrain the boundary
00173
00174   if (ret_value == CUBIT_SUCCESS)
00175   {
00176     ret_value = constrain_boundary();
00177   }
00178
00179   // delete the triangles on the outside of the boundary
00180
00181   if (ret_value == CUBIT_SUCCESS)
00182   {
00183     ret_value = delete_exterior();
00184   }
00185
00186   // insert the hard points
00187
00188   // clean up
00189
00190   clean_up_data();
00191
00192   return ret_value;
00193 }
00194
00195 //-------------------------------------------------------------------------
00196 // Function:    mesh_surfwoIPBC
00197 // Description: mesh the surface w/o interior point refinement
00198 // Author:      chynes
00199 // Date:        6/20/2002
00200 //-------------------------------------------------------------------------
00201 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00202 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::mesh_surfwoIPBC(DLIList<TRI *> &facet_list)
00203 {
00204   CubitStatus  ret_value  = CUBIT_SUCCESS;
00205
00206   // update private variables
00207
00208   facetList = &facet_list;
00209
00210   // create two initial bounding triangles
00211
00212   if (ret_value == CUBIT_SUCCESS)
00213   {
00214     ret_value = init_box();
00215   }
00216
00217   // insert the boundary nodes
00218
00219   if (ret_value == CUBIT_SUCCESS)
00220   {
00221     ret_value = insert_nodes( boundingNodes );
00222   }
00223
00224   // delete the triangles on the outside of the boundary
00225
00226   if (ret_value == CUBIT_SUCCESS){
00227     ret_value = delete_exterior();
00228   }
00229
00230   // insert the hard points
00231
00232   // clean up
00233
00234   clean_up_data();
00235
00236   return ret_value;
00237 }
00238
00239 //-------------------------------------------------------------------------
00240 // Function:    init_box
00241 // Description: create two initial bounding triangles
00242 // Author:      chynes
00243 // Date:        5/31/2002
00244 //-------------------------------------------------------------------------
00245 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00246 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::init_box(void)
00247 {
00248   // find the bounding box
00249
00250   int ii;
00251   CubitVector min_box, max_box;
00252   min_box.x( CUBIT_DBL_MAX );min_box.y( CUBIT_DBL_MAX );
00253   max_box.x( -CUBIT_DBL_MAX );max_box.y( -CUBIT_DBL_MAX );
00254
00255   NODE *node_ptr;
00256   CubitVector node_loc;
00257   for (ii=0; ii<boundingNodes->size(); ii++)
00258   {
00259     node_ptr = boundingNodes->get_and_step();
00260     node_loc = node_ptr->coordinates();
00261     if (node_loc.x() < min_box.x()) min_box.x( node_loc.x() );
00262     if (node_loc.y() < min_box.y()) min_box.y( node_loc.y() );
00263     if (node_loc.x() > max_box.x()) max_box.x( node_loc.x() );
00264     if (node_loc.y() > max_box.y()) max_box.y( node_loc.y() );
00265   }
00266
00267   // expand the box by 10%
00268
00269   double dx = max_box.x() - min_box.x();
00270   double dy = max_box.y() - min_box.y();
00271   double expand;
00272   if (dx > dy)
00273     expand = 0.1 * dx;
00274   else
00275     expand = 0.1 * dy;
00276
00277   min_box.x( min_box.x() - expand );
00278   min_box.y( min_box.y() - expand );
00279   max_box.x( max_box.x() + expand );
00280   max_box.y( max_box.y() + expand );
00281
00282
00283    // create four new nodes
00284
00285   boxNodes[0] = (NODE *) new NODECHILD(min_box.x(), min_box.y(), 0.0, refFacePtr);
00286   boxNodes[1] = (NODE *) new NODECHILD(max_box.x(), min_box.y(), 0.0, refFacePtr);
00287   boxNodes[2] = (NODE *) new NODECHILD(max_box.x(), max_box.y(), 0.0, refFacePtr);
00288   boxNodes[3] = (NODE *) new NODECHILD(min_box.x(), max_box.y(), 0.0, refFacePtr);
00289
00290
00291   // create the two triangles
00292
00293   TRI *new_facet1 = (TRI *) new TRICHILD( boxNodes[0], boxNodes[1],
00294                                      boxNodes[3], refFacePtr );
00295   TRI *new_facet2 = (TRI *) new TRICHILD( boxNodes[1], boxNodes[2],
00296                                      boxNodes[3], refFacePtr );
00297
00298   facetList->append(new_facet1);
00299   facetList->append(new_facet2);
00300
00301   return CUBIT_SUCCESS;
00302 }
00303
00304
00305 //-------------------------------------------------------------------------
00306 // Function:    insert_nodes
00307 // Description: insert nodes into Delaunay mesh
00308 // Author:      chynes
00309 // Date:        6/3/2002
00310 //-------------------------------------------------------------------------
00311 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00312 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::
00313 insert_nodes(DLIList<NODE *> *&bounding_nodes)
00314 {
00315   CubitStatus rv = CUBIT_SUCCESS;
00316   int ii;
00317   NODE *point_ptr;
00318   TRI* start_tri = NULL;
00319   for (ii=0; ii<bounding_nodes->size() && rv == CUBIT_SUCCESS; ii++){
00320     point_ptr = bounding_nodes->get_and_step();
00321     rv = FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::insert_node(
00322        point_ptr, *facetList,
00323        refFacePtr, curVisitFlag,
00324        start_tri);
00325   }
00326
00327
00328   return rv;
00329 }
00330
00331
00332 //-------------------------------------------------------------------------
00333 // Function:    constrain_boundary
00334 // Description: recover the boundary edges from the mesh
00335 // Author:      chynes
00336 // Date:        6/3/2002
00337 //-------------------------------------------------------------------------
00338 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00339 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::constrain_boundary(void)
00340 {
00341   CubitStatus rv = CUBIT_SUCCESS;
00342
00343   BoundaryConstrainTool<SURF,TRI,EDGE,NODE,TRICHILD> bctool( refFacePtr );
00344   EDGE *edge_ptr = NULL;
00345   int ii;
00346   for (ii=0; ii<numBoundaryEdges && rv == CUBIT_SUCCESS; ii++)
00347   {
00348     rv = bctool.recover_edge( boundaryEdgeStartNodes[ii],
00349                   boundaryEdgeEndNodes[ii],
00350                   edge_ptr,
00351                   facetList);
00352     //assert(edge_ptr != NULL);
00353     if (edge_ptr == NULL)
00354     {
00355       PRINT_ERROR("Could not recover a boundary in Delaunay facetor.\n"
00356                   "Indicates potential problems with input loop geometry\n");
00357       rv = CUBIT_FAILURE;
00358     }
00359   }
00360   return rv;
00361 }
00362
00363
00364 //-------------------------------------------------------------------------
00365 // Function:    delete_exterior
00366 // Description: delete the triangles on the outside of the boundary and on
00367 //              the interior of holes
00368 // Author:      chynes
00369 // Date:        6/3/2002
00370 //-------------------------------------------------------------------------
00371 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00372 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::delete_exterior(void)
00373 {
00374   CubitStatus rv = CUBIT_SUCCESS;
00375
00376   // mark edges at the boundary
00377
00378   EDGE *edge_ptr;
00379   int ii;
00380   for (ii=0; ii<numBoundaryEdges; ii++)
00381   {
00382     edge_ptr = boundaryEdgeStartNodes[ii]->shared_edge( boundaryEdgeEndNodes[ii] );
00383     if(!edge_ptr){
00384       PRINT_ERROR("Boundary edges were not successfully recovered.\n");
00385       return CUBIT_FAILURE;
00386     }
00387     edge_ptr->marked( CUBIT_TRUE );
00388   }
00389
00390   // get a tri adjacent to a bounding box node
00391
00392   DLIList<TRI*> adjtris;
00393   boxNodes[0]->tris( adjtris );
00394   TRI *tri_ptr = adjtris.get();
00395
00396   // mark the tris on the outside starting from this triangle
00397
00398   int num_edges_found=0;
00399   rv = mark_tris( tri_ptr, num_edges_found );
00400   if (rv != CUBIT_SUCCESS)
00401     return rv;
00402
00403   // delete the exterior triangles
00404
00405   int marked_flag = 1;
00406   rv = delete_tris( *facetList, marked_flag );
00407
00408   // check to see if we've found all the edges
00409   //PRINT_INFO("num_edges_found = %i, numBoundaryEdges = %i\n",num_edges_found,numBoundaryEdges);
00410
00411   if (num_edges_found != numBoundaryEdges)
00412   {
00413
00414     // if not, then there are interior loops(holes) that need to have their
00415     // triangles removed
00416
00417     // find a triangle at the boundary
00418
00419     TRI *adjtri;
00420     int jj;
00421     CubitBoolean found = CUBIT_FALSE;
00422     if(!facetList->size()){
00423       PRINT_ERROR("Problem marking exterior facets.\n");
00424       return CUBIT_FAILURE;
00425     }
00426
00427     for (ii=0; ii<facetList->size() && !found; ii++)
00428     {
00429       tri_ptr = facetList->get_and_step();
00430       for (jj=0; jj<3 && !found; jj++)
00431       {
00432     int kk = jj;
00433     adjtri = tri_ptr->adjacent( kk, refFacePtr );
00434         if (adjtri == NULL)
00435       {
00436           found = CUBIT_TRUE;
00437         }
00438       }
00439     }
00440
00441     // mark all the tris we want to keep
00442     if(!found){
00443       PRINT_WARNING("Possible problem.  No boundary edge found.\n");
00444     }
00445
00446     rv = mark_tris( tri_ptr, num_edges_found );
00447
00448     // delete all the rest
00449
00450     marked_flag = 0;
00451     rv = delete_tris( *facetList, marked_flag );
00452   }
00453
00454   return rv;
00455 }
00456
00457
00458 //-------------------------------------------------------------------------
00459 // Function:    delete_tris
00460 // Description: delete triangles in the list with the specified marked flag
00461 // Author:      chynes
00462 // Date:        6/3/2002
00463 //-------------------------------------------------------------------------
00464 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00465 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::delete_tris(DLIList<TRI *> &tri_list, int marked_flag)
00466 {
00467   CubitStatus rv = CUBIT_SUCCESS;
00468
00469   int ii, jj;
00470   EDGE *edge_ptr;
00471   TRI *tri_ptr;
00472   DLIList<EDGE *> edge_list;
00473   DLIList<TRI *> new_list;
00474   int ntri = tri_list.size();
00475   for(ii=0; ii<ntri; ii++)
00476   {
00477     tri_ptr = tri_list.pop();
00478     if (tri_ptr->marked() == marked_flag)
00479     {
00480       edge_list.clean_out();
00481       tri_ptr->edges( edge_list );
00482       delete tri_ptr;
00483       for(jj=0; jj<3; jj++)
00484       {
00485         edge_ptr = edge_list.get_and_step();
00486         if(edge_ptr->number_tris() == 0 && edge_ptr->number_faces() == 0)
00487           delete edge_ptr;
00488       }
00489     }
00490     else
00491       new_list.append(tri_ptr);
00492   }
00493   tri_list+=new_list;
00494   return rv;
00495 }
00496
00497
00498 //-------------------------------------------------------------------------
00499 // Function:    mark_tris
00500 // Description: recursive function to mark all the triangles we want to keep
00501 // Author:      chynes
00502 // Date:        6/3/2002
00503 //-------------------------------------------------------------------------
00504 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00505 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::mark_tris(TRI *tri_ptr,
00506                                        int &num_edges_found)
00507 {
00508   CubitStatus rv = CUBIT_SUCCESS;
00509   tri_ptr->marked( CUBIT_TRUE );
00510   int ii;
00511   EDGE *edge_ptr;
00512   TRI *adjtri;
00513   for (ii=0; ii<3 && rv == CUBIT_SUCCESS; ii++)
00514   {
00515     int jj = ii;
00516     adjtri = tri_ptr->adjacent( jj, refFacePtr );
00517     edge_ptr = tri_ptr->edge( jj );
00518     if(edge_ptr->marked()) {
00519       num_edges_found++;
00520     }
00521     else {
00522       if (adjtri != NULL && !adjtri->marked())
00523         rv = mark_tris( adjtri, num_edges_found );
00524     }
00525   }
00526   return rv;
00527 }
00528
00529
00530 //-------------------------------------------------------------------------
00531 // Function:    refine_interior
00532 // Description: generate nodes on the interior of the tiangulation to
00533 //              improve quality
00534 // Notes:       this inserts nodes at the circumcenters of triangles roughly
00535 //              based on the algorithm by Jonathon Shewchuk
00536 // Author:      chynes
00537 // Date:        6/3/2002
00538 //-------------------------------------------------------------------------
00539 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00540 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::refine_interior(DLIList<TRI *> &tri_list)
00541 {
00542   CubitStatus rv = CUBIT_SUCCESS;
00543
00544   // classify the triangles based on their minimum angle
00545
00546   //rv =
00547   const int num_lists = 64;
00548   const double interval = QUALITY_ANGLE / double( num_lists - 1 );
00549   DLIList<TRI*>* tri_sort_array = new DLIList<TRI *> [num_lists];
00550   classify_triangles(tri_list, tri_sort_array, num_lists, interval );
00551
00552   // process each of the triangles until done
00553
00554   TRI *tri_ptr;
00555   TRI* start_tri = NULL;
00556   while ((tri_ptr = next_triangle(tri_sort_array, num_lists)) != NULL && rv == CUBIT_SUCCESS)
00557   {
00558     rv = FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::insert_at_circumcenter(tri_ptr,
00559        *facetList,
00560        start_tri,
00561        curVisitFlag,
00562        refFacePtr,
00563        tri_sort_array,
00564        num_lists,
00565        interval,
00566        QUALITY_ANGLE,
00567        sizingFunction,
00568        pTool);
00569   }
00570
00571   delete [] tri_sort_array;
00572   tri_sort_array = NULL;
00573
00574   return rv;
00575 }
00576
00577 //-------------------------------------------------------------------------
00578 // Function:    classify_triangles
00579 // Description: order the triangles in the current mesh by their worst angle
00580 // Author:      chynes
00581 // Date:        6/3/2002
00582 //-------------------------------------------------------------------------
00583 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00584 CubitStatus FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::classify_triangles(DLIList<TRI *> &tri_list,
00585        DLIList<TRI*>* sorted_lists,
00586        const int num_lists,
00587        const double interval)
00588 {
00589   CubitStatus rv = CUBIT_SUCCESS;
00590
00591   // Create an array of lists that will hold triangles as they are
00592   // created (and deleted).  Each list will hold triangles whose angles
00593   // fall within a specified interval.  Triangles will be processed
00594   // from smallest angle to best angle
00595
00596   // classify each trriangle and place into sort lists
00597
00598   TRI *tri_ptr;
00599   int ii;
00600   for(ii=0; ii<tri_list.size() && rv == CUBIT_SUCCESS; ii++)
00601   {
00602     tri_ptr = tri_list.get_and_step();
00603     //rv =
00604     FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::classify_tri_by_angle(
00605                                     tri_ptr, sorted_lists,  num_lists, interval, QUALITY_ANGLE);
00606   }
00607
00608   return rv;
00609 }
00610
00611
00612 //-------------------------------------------------------------------------
00613 // Function:    next_triangle
00614 // Description: get the next triangle to process
00615 // Author:      chynes
00616 // Date:        6/3/2002
00617 //-------------------------------------------------------------------------
00618 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00619 TRI *FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::next_triangle(DLIList<TRI*>* sorted_lists,
00620        const int num_lists)
00621 {
00622   TRI *tri_ptr = NULL;
00623   int ii;
00624   for( ii = 1; ii < num_lists && tri_ptr == NULL; ii++)
00625   {
00626     if (sorted_lists[ii].size() > 0)
00627       tri_ptr = sorted_lists[ii].remove();
00628   }
00629   if (tri_ptr == NULL)
00630   {
00631     if (sorted_lists[0].size() > 0)
00632       tri_ptr = sorted_lists[0].remove();
00633   }
00634   return tri_ptr;
00635 }
00636
00637 //-------------------------------------------------------------------------
00638 // Function:    clean_up_data
00639 // Description: clean up any data we've allocated
00640 // Author:      chynes
00641 // Date:        6/3/2002
00642 //-------------------------------------------------------------------------
00643 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE
00644 void FacetorTool<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::clean_up_data(void)
00645 {
00646
00647   EDGE *del_edge_ptr;
00648   DLIList<EDGE *> del_edge_list;
00649   TRI *tri_ptr;
00650   DLIList<TRI *> tri_list;
00651
00652
00653   int ii, jj, kk;
00654
00655     //loop over facets and remove marks
00656   for(ii=0; ii<facetList->size(); ii++)
00657   {
00658     tri_ptr = facetList->get_and_step();
00659     tri_ptr->marked(CUBIT_FALSE);
00660     ToolData *td = tri_ptr->remove_TD( TDDelaunay< TRI, NODE >::is_delaunay );
00661     if (td != NULL)
00662     {
00663       TDDelaunay< TRI, NODE > *td_del = dynamic_cast<TDDelaunay< TRI, NODE >*> (td);
00664       delete td_del;
00665     }
00666   }
00667
00668     //loop over the box ndes
00669     //if meshing was successful, some of the below is unnecessary
00670   for(ii=0; ii<4; ii++)
00671   {
00672     if (boxNodes[ii] != NULL){
00673       tri_list.clean_out();
00674         //if there are tris attached, delete them.
00675       boxNodes[ii]->tris(tri_list);
00676       for (jj=0; jj<tri_list.size(); jj++)
00677       {
00678         tri_ptr = tri_list.get_and_step();
00679         del_edge_list.clean_out();
00680         tri_ptr->edges( del_edge_list );
00681         delete tri_ptr;
00682
00683           // also deltet the attached, unused edges
00684         for (kk=0; kk<del_edge_list.size(); kk++)
00685         {
00686           del_edge_ptr = del_edge_list.get_and_step();
00687           if (del_edge_ptr->number_tris() == 0)
00688             delete del_edge_ptr;
00689         }
00690       }
00691     }
00692       //finally delete the nodes
00693     delete boxNodes[ii];
00694   }
00695
00696   // clean off the edge marks
00697
00698   EDGE *edge_ptr;
00699   for (ii=0; ii<numBoundaryEdges; ii++)
00700   {
00701     edge_ptr = boundaryEdgeStartNodes[ii]->shared_edge( boundaryEdgeEndNodes[ii] );
00702     if (edge_ptr)
00703       edge_ptr->marked( CUBIT_FALSE );
00704   }
00705 }
00706
00707 // EOF
00708
