cgma
GeometryDefines.h File Reference
#include <stdio.h>
#include <stdlib.h>
#include <sys/types.h>
#include "CubitString.hpp"
Classes
struct  ModelExportOptions
Defines
#define CUBIT_RESABS   1.0E-12
#define GEOMETRY_RESABS   1.0E-6
#define DEFAULT_GEOM_FACTOR   500.0
Enumerations
enum  SolidModelerType {
  NOT_A_SOLID_MODELER, OCC, ACIS, PROE_GEOM,
  PROE_PART, PROE_ASSEMBLY, PROE_FEM_MESH_SOLID, PROE_FEM_MESH_SHELL,
  PROE_FEM_MESH_MIXED, PROE_FEM_MESH_BOUNDARY, PROE_FEM_MESH_QUILT
enum  GeometricRepresentationType {
  GEOMTYPE_NONE, SOLID_MODEL, FACETTED, MESH_BASED,
  COMPOSITE
enum  GeometryType {
  UNDEFINED_POINT_TYPE, ARC_CURVE_TYPE, ELLIPSE_CURVE_TYPE, PARABOLA_CURVE_TYPE,
  SEGMENTED_CURVE_TYPE, SPLINE_CURVE_TYPE, STRAIGHT_CURVE_TYPE, POINT_CURVE_TYPE,
  HELIX_CURVE_TYPE, HYPERBOLA_CURVE_TYPE, UNDEFINED_CURVE_TYPE, CONE_SURFACE_TYPE,
  PLANE_SURFACE_TYPE, SPHERE_SURFACE_TYPE, SPLINE_SURFACE_TYPE, TORUS_SURFACE_TYPE,
  BEST_FIT_SURFACE_TYPE, FACET_SURFACE_TYPE, CYLINDER_SURFACE_TYPE, REVOLUTION_SURFACE_TYPE,
  EXTRUSION_SURFACE_TYPE, OFFSET_SURFACE_TYPE, UNDEFINED_SURFACE_TYPE, UNDEFINED_LUMP_TYPE
enum  ImprintType {
  NO_IMPRINT = 0, ONLY_INVOLVED_BODIES, INCLUDE_NEIGHBORS, TOL_IMPRINT,
  TOL_IMPRINT_INCLUDE_NEIGHBORS
enum  LoopType {
  LOOP_TYPE_UNKNOWN, LOOP_TYPE_EXTERNAL, LOOP_TYPE_HOLE, LOOP_TYPE_U_PERIODIC,
  LOOP_TYPE_V_PERIODIC
Define Documentation
Definition at line 20 of file GeometryDefines.h.
Definition at line 30 of file GeometryDefines.h.
Definition at line 29 of file GeometryDefines.h.
Enumeration Type Documentation
Enumerator:
GEOMTYPE_NONE
SOLID_MODEL
FACETTED
MESH_BASED
COMPOSITE
Definition at line 50 of file GeometryDefines.h.
Enumerator:
ARC_CURVE_TYPE
ELLIPSE_CURVE_TYPE
PARABOLA_CURVE_TYPE
SPLINE_CURVE_TYPE
STRAIGHT_CURVE_TYPE
POINT_CURVE_TYPE
HELIX_CURVE_TYPE
CONE_SURFACE_TYPE
PLANE_SURFACE_TYPE
SPHERE_SURFACE_TYPE
SPLINE_SURFACE_TYPE
TORUS_SURFACE_TYPE
FACET_SURFACE_TYPE
OFFSET_SURFACE_TYPE
UNDEFINED_LUMP_TYPE
Definition at line 60 of file GeometryDefines.h.
Enumerator:
NO_IMPRINT
INCLUDE_NEIGHBORS
TOL_IMPRINT
Definition at line 95 of file GeometryDefines.h.
enum LoopType
Enumerator:
LOOP_TYPE_UNKNOWN
LOOP_TYPE_EXTERNAL
LOOP_TYPE_HOLE
Definition at line 105 of file GeometryDefines.h.
  /* Unknown loop type */
  LOOP_TYPE_UNKNOWN,
  /* The external loop of a surface */
  LOOP_TYPE_EXTERNAL,
  /* The loop is a hole */
  LOOP_TYPE_HOLE,
  /* The loop is a u or v periodic loop (only applies to periodic surfaces)
   * An example of this is a cylindrical surface with only 2 loops with each
   * loop defining a cap of the cylinder.
   * If its a u periodic loop, the face is periodic in u */
Enumerator:
NOT_A_SOLID_MODELER
OCC
ACIS
PROE_GEOM
PROE_PART
PROE_ASSEMBLY
PROE_FEM_MESH_SOLID
PROE_FEM_MESH_SHELL
PROE_FEM_MESH_MIXED
PROE_FEM_MESH_QUILT
Definition at line 34 of file GeometryDefines.h.
