cgma
ImprintPointData.hpp
00001 //-----------------------------------------------------------------------------
00002 //
00003 //  File: ImprintPointData.hpp
00004 //
00005 //  Purpose:  Child class of CubitPoint.  It is the Cubit-specific version of
00006 //            of the CubitPoint.
00007 //
00008 //  Notes:    Note that this class contains data which is accessed
00009 //            virtually from CubitPoint.  In most cases, you can create
00010 //            a ImprintPointData and treat it as if it is a CubitPoint.
00011 //            For example:
00012 //               CubitPoint *cp = (CubitPoint *) new ImprintPointData(...);
00013 //            There should be no reason to reference the CubitFacetPoint
00014 //            directly.  This is done to allow different data representations
00015 //            of a point in addition to that used by Cubit.
00016 //
00017 //-----------------------------------------------------------------------------
00018
00019
00020 #ifndef IMPRINTPOINTDATA_HPP
00021 #define IMPRINTPOINTDATA_HPP
00022
00023 // Include for CubitBoolean
00024 #include "CubitDefines.h"
00025 #include "CubitVector.hpp"
00026 #include "DLIList.hpp"
00027 #include "CubitPoint.hpp"
00028 #include "CastTo.hpp"
00029 #include "RefEntity.hpp"
00030 #include "RefVertex.hpp"
00031 #include "MemoryManager.hpp"
00032 #include "ImprintMatchData.hpp"
00033 #include "ImprintLineSegment.hpp"
00034
00035 enum PointType { UNSET_POINT = -1,
00036                  VERTEX_ON_BOUNDARY_1,
00037                  VERTEX_ON_BOUNDARY_2,
00038                  CREATE_NEW_VERTEX,
00039                  VERTEX_ON_BOTH_BOUNDARIES,
00040                  ON_BOUNDARY_1,
00041                  ON_BOUNDARY_2,
00042                  ON_BOTH_BOUNDARIES,
00043                  ON_SURFACE_1,
00044                  ON_SURFACE_2};
00045
00046
00047
00048 class ImprintPointData : public CubitPoint
00049 {
00050 private:
00051
00052   CubitVector coords;
00053   DLIList<CubitFacet*> *attachedFacets;
00054   RefEntity *myOwner;
00055   PointType myPointType;
00056   CubitBoolean ownerRefVertex;
00057   ImprintPointData *matchingPoint;
00058   CubitBoolean startPartition;
00059   CubitBoolean endPartition;
00060   DLIList<ImprintMatchData*> *pointMatches;
00061   CubitBoolean isMatched;
00062   ImprintLineSegment *prevSeg;
00063   ImprintLineSegment *nextSeg;
00064
00065   int listLoopPos;
00066   int loopPos;
00067   int loopSize;
00068
00069   int entityId;
00070   void initialize_imprint_data();
00071     //- Initialize just the data for this class.
00072
00073   static MemoryManager memoryManager;
00074     //- memory management object
00075
00076 public:
00077
00078   ImprintPointData(double x_val, double y_val, double z_val );
00079   ImprintPointData( const CubitVector &new_point );
00080   ImprintPointData( ImprintPointData *copy, CubitVector &new_coords );
00081
00082   ~ImprintPointData();
00083
00084   SetDynamicMemoryAllocation(memoryManager)
00085       //- class specific new and delete operators
00086
00087   int id(){ return entityId;}
00088
00089   double x(){return coords.x();}
00090   double y(){return coords.y();}
00091   double z(){return coords.z();}
00092   void set( const CubitVector &pos ) { coords = pos; }
00093
00094   void marked(int marked){ markedFlag = marked;}
00095   int marked(){return markedFlag;}
00096     //- generic marker for efficient sorting.
00097
00098   CubitVector coordinates() const { return coords; }
00099   void coordinates(double point_array[3]);
00100   void add_facet( CubitFacet *facet);
00101   void remove_facet( CubitFacet *facet );
00102   int num_adj_facets();
00103
00104   void facets( DLIList<CubitFacet*> &facet_list)
00105     { if (attachedFacets) facet_list += *attachedFacets; }
00106   void edges( DLIList<CubitFacetEdge*> &edge_list);
00107   void points( DLIList<CubitPoint*> &point_list)
00108     { point_list.append( this ); }
00109
00110   void compute_avg_normal();
00111
00112     //-Functions just for imprint point data.
00113   void owner(RefEntity* my_owner)
00114     {
00115       myOwner = my_owner;
00116     }
00117   RefEntity* owner()
00118     {return myOwner;}
00119   CubitBoolean is_owner_vertex()
00120     {if (myPointType == CREATE_NEW_VERTEX ||
00121          myPointType == VERTEX_ON_BOUNDARY_1 ||
00122          myPointType == VERTEX_ON_BOUNDARY_2 ||
00123          myPointType == VERTEX_ON_BOTH_BOUNDARIES )
00124       return CUBIT_TRUE;
00125     else
00126       return CUBIT_FALSE;
00127     }
00128   void set_point_type(PointType type)
00129     {myPointType = type;}
00130   PointType get_point_type()
00131     {return myPointType;}
00132   CubitStatus set_matching_point(ImprintPointData *other);
00133   ImprintPointData* get_matching_point()
00134     {return matchingPoint;}
00135   void set_start_partition()
00136     {startPartition = CUBIT_TRUE;}
00137   void set_end_partition()
00138     {endPartition = CUBIT_TRUE;}
00139   CubitBoolean get_start_partition()
00140     {return startPartition;}
00141   CubitBoolean get_end_partition()
00142     {return endPartition;}
00143   void set_loop_pos( int ii, int jj, int loop_size )
00144   {
00145     listLoopPos = ii;
00146     loopPos = jj;
00147     loopSize = loop_size;
00148   }
00149   int get_list_loop_pos()
00150     {return listLoopPos;}
00151   int get_loop_pos()
00152     {return loopPos;}
00153   int get_loop_size()
00154     {return loopSize;}
00155   void add_match_data(ImprintMatchData *match_data);
00156   void get_match_list(DLIList <ImprintMatchData*> &match_data_list);
00157   void set_matched(ImprintMatchData *match_data);
00158   void set_unmatched();
00159
00160   CubitBoolean is_matched()
00161     {return isMatched;}
00162   ImprintLineSegment* get_prev_seg()
00163     {return prevSeg;}
00164   void set_prev_seg(ImprintLineSegment *prev_seg)
00165     {prevSeg = prev_seg;}
00166
00167   ImprintLineSegment* get_next_seg()
00168     {return nextSeg;}
00169   void set_next_seg(ImprintLineSegment *next_seg)
00170     {nextSeg = next_seg;}
00171
00172
00173 };
00174
00175 #endif
