cgma
IntersectionTool.hpp
00001 // file: GeomIntersectionTool.hpp
00002 // author: Michael Stephenson
00003 //
00004
00005 #ifndef INTERSECTION_TOOL_HPP
00006 #define INTERSECTION_TOOL_HPP
00007
00008 #include "CubitDefines.h"
00009 #include "CGMUtilConfigure.h"
00010
00011 class CubitVector;
00012 template <class X> class DLIList;
00013
00014 class CUBIT_UTIL_EXPORT IntersectionTool
00015 {
00016 public:
00017   IntersectionTool(const double &tol = 0.0001);
00018   virtual ~IntersectionTool() {}
00019
00020   virtual CubitStatus closest_points_on_segments(CubitVector &p0,
00021                                                  CubitVector &p1,
00022                                                  CubitVector &p2,
00023                                                  CubitVector &p3,
00024                                                  CubitVector &point_1,
00025                                                  CubitVector &point_2,
00026                                                  double &sc, double &tc);
00027     //- Finds the two closest points on the line segments {p0,p1} and {p2,p3},
00028     //- and returns them in point_1 and point_2.  Will return failure
00029     //- if a divide by zero is attempted.
00030
00031   double distance_point_line(const double point[3], const double start[3],
00032                              const double end[3], double &t);
00033   int point_on_polyline(CubitVector& pt, DLIList<CubitVector*> &pt_list,
00034                          double *tol_in = NULL);
00035
00036   double parametric_position(const double node[3],
00037                            const double pt1[3],
00038                            const double pt2[3]);
00039
00050
00051   virtual CubitStatus initialize(){return CUBIT_SUCCESS;}
00052
00053   // The following copyright applies to the following two functions...
00054   //
00055   // Copyright 2001, softSurfer (www.softsurfer.com)
00056   //
00057   // This code may be freely used and modified for any purpose
00058   // providing that this copyright notice is included with it.
00059   // SoftSurfer makes no warranty for this code, and cannot be held
00060   // liable for any real or imagined damage resulting from its use.
00061   // Users of this code must verify correctness for their application.
00062
00063   static int intersect_triangle_with_ray( CubitVector &ray_origin, CubitVector &ray_direction,
00064       const CubitVector *p0, const CubitVector *p1, const CubitVector *p2,
00065       CubitVector* point, double &distance, int &edge_hit );
00066     //- Find intersection point of a ray and a triangle
00067     //    Return: -1 = triangle is degenerate (a segment or point)
00068     //             0 = disjoint (no intersect)
00069     //             1 = intersect at unique point
00070     //             2 = are in the same plane
00071
00072   static int intersect_segment_with_ray( CubitVector &ray_origin, CubitVector &ray_direction,
00073       const CubitVector *p0, const CubitVector *p1,
00074       CubitVector* point, double &distance, int &point_hit, double tol=0.0 );
00075     //- Find intersection point of a ray and a facet edge
00076     //    Return: -1 = edge is degenerate (a point)
00077     //             0 = disjoint (no intersect)
00078     //             1 = intersect at unique point
00079     //             2 = are the same line (infinite points)
00080
00081   static int intersect_point_with_ray( CubitVector &ray_origin, CubitVector &ray_direction,
00082       const CubitVector* point, double &distance, double tol=0.0);
00083     //- Find intersection of a ray and a point
00084     //    Return: 0 = no intersection
00085     //            1 = intersection
00086
00087
00088 protected:
00089   double mTolerance;
00090   double mToleranceSquared;
00091
00092   CubitBoolean ray_tri_test(const double start[3], const double dir[3],
00093                             const double tri1[3], const double tri2[3],
00094                             const double tri3[3],
00095                             double &t, double &alpha, double &beta);
00096
00097   CubitBoolean skew_line_test(const double start1[3], const double end1[3],
00098                               const double start2[3], const double end2[3],
00099                               double &t, double &u);
00100
00101   void tolerance(const double &tol);
00102   double tolerance(void) const;
00103
00104 private:
00105 };
00106
00107 inline IntersectionTool::IntersectionTool(const double &tol)
00108     : mTolerance(tol)
00109 {
00110   mToleranceSquared = tol * tol;
00111 }
00112
00113 #endif // INTERSECTION_TOOL_HPP
00114
