cgma
ModelQueryEngine.hpp
00001 //-------------------------------------------------------------------------
00002 // Copyright Notice
00003 //
00004 // Copyright (c) 1996
00005 // by Malcolm J. Panthaki, DBA, and the University of New Mexico.
00006 //-------------------------------------------------------------------------
00007 //
00008 //-------------------------------------------------------------------------
00009 // Filename      : ModelQueryEngine.hpp
00010 //
00011 // Purpose       : This class provides the interface to query the model.
00012 //
00013 // Special Notes : This is a singleton class.
00014 //
00015 //                 The primary objects that this class deals with, at the
00016 //                 interface, are TopologyEntity's.  These are entities
00017 //                 that are represented as nodes in the DAG.  Each node of
00018 //         the DAG contains a pointer to a TopologyEntity.
00019 //
00020 //                 All of the query functions rely on the "type" of
00021 //                 objects. Some of them rely on the relationships
00022 //                 between different "type"s of objects. Currently all
00023 //                 such relationships, i.e. the entity relation diagram
00024 //                 (ERD) of the different TopologyEntity classes is maintained
00025 //                 by a class called ModelERD.
00026 //
00027 // Creator       : Xuechen Liu
00028 //
00029 // Creation Date : 06/08/96
00030 //
00031 // Owner         : Malcolm J. Panthaki
00032 //-------------------------------------------------------------------------
00033
00034 #ifndef MODEL_QUERY_ENGINE_HPP
00035 #define MODEL_QUERY_ENGINE_HPP
00036
00037
00038 // ********** BEGIN STANDARD INCLUDES      **********
00039 // ********** END STANDARD INCLUDES        **********
00040
00041 // ********** BEGIN MOTIF INCLUDES         **********
00042 // ********** END MOTIF INCLUDES           **********
00043
00044 // ********** BEGIN OPEN INVENTOR INCLUDES **********
00045 // ********** END OPEN INVENTOR INCLUDES   **********
00046
00047 // ********** BEGIN CUBIT INCLUDES         **********
00048
00049 #include "CubitDefines.h"
00050 #include "TopologyEntity.hpp"
00051 #include "DLIList.hpp"
00052
00053 // ********** END CUBIT INCLUDES           **********
00054
00055 // ********** BEGIN MACROS DEFINITIONS     **********
00056 // ********** END MACROS DEFINITIONS       **********
00057
00058 // ********** BEGIN FORWARD DECLARATIONS   **********
00059
00060 class TopologyEntity;
00061
00062 // ********** END FORWARD DECLARATIONS     **********
00063
00064 // ********** BEGIN ENUM DEFINITIONS       **********
00065
00066 enum CubitSearchDirection
00067 {
00068    CUBIT_SEARCH_NO_DIRECTION = -1,
00069    CUBIT_SEARCH_PARENT = 0,
00070    CUBIT_SEARCH_CHILD = 1
00071 };
00072 // ********** END ENUM DEFINITIONS         **********
00073
00074
00075 class CUBIT_GEOM_EXPORT ModelQueryEngine
00076 {
00077    public:
00078
00079       static ModelQueryEngine* instance();
00080       //R ModelQueryEngine*
00081       //R- A pointer to the only instance of this class.
00082       //- This function controls access and creation of the sole instance
00083       //- of this class. It ensures that only one instance can ever get
00084       //- created. It returns a pointer to the only instance of the class.
00085
00086       ~ModelQueryEngine() ;
00087       //- Destructor
00088
00089       static void delete_instance()
00090       {
00091         if(instance_)
00092           delete instance_;
00093         instance_ = NULL;
00094       }
00095
00096       //HEADER- Query functions on single source objects
00097
00098       CubitStatus query_model( TopologyEntity & source_object,
00099                                DagType target_type,
00100                                DLIList<TopologyEntity*>& result_set );
00101
00102       CubitStatus query_model_and_append( TopologyEntity& source_object,
00103                                           DagType target_type,
00104                                           DLIList<TopologyEntity*>& result_set );
00105       //R CubitStatus
00106       //R- CUBIT_SUCCESS/FAILURE
00107       //I sourceObject
00108       //I- A reference to the ModEnt on which query is to be done.
00109       //I targetType
00110       //I- The type of the ModEnts to query.
00111       //I- It can be any kind of data type: root base type, intermediate
00112       //I- base type, or leaf type.
00113       //O resultModEntSet
00114       //O- Reference to a set of ModEnts where output of the query will be
00115       //O- put/appended.
00116       //- This function queries the given object, "sourceObject", for all
00117       //- the ModEnts of the given type, "targetType" that it is related to and
00118       //- puts/apppends the result of the query in "resultModEntSet".
00119       //- The return value is CUBIT_SUCCESS if the source object has either
00120       //- a parent-child or child-parent relationship with objects of the
00121       //- given type, CUBIT_FAILURE otherwise.
00122
00123
00124
00125
00126       //HEADER- Query functions on sets of source objects
00127
00128       CubitStatus query_model( DLIList<TopologyEntity*>& source_set,
00129                                DagType target_type,
00130                                DLIList<TopologyEntity*>& result_set );
00131
00132       CubitStatus query_model_and_append( DLIList<TopologyEntity*>& source_set,
00133                                           DagType target_type,
00134                                           DLIList<TopologyEntity*>& result_set );
00135       //R CubitStatus
00136       //R- CUBIT_SUCCESS/FAILURE
00137       //I sourceObjectSet
00138       //I- A reference to a set of ModEnts on which query is to be done.
00139       //I targetType
00140       //I- The type of the ModEnts to query.
00141       //I- It can be any kind of data type: root base type, intermediate
00142       //I- base type, or leaf type.
00143       //O resultModEntSet
00144       //O- Reference to a set of ModEnts where output of the query will be
00145       //O- put/appended.
00146       //- This function queries the given objects, "sourceObjectSet", for all
00147       //- the ModEnts of the given type, "targetType" that they are related to and
00148       //- puts/apppends the result of the query in "resultModEntSet".
00149       //- The return value is CUBIT_SUCCESS if each of the source objects
00150       //- has either a parent-child or child-parent relationship with
00151       //- objects of the given type, CUBIT_FAILURE otherwise.
00152
00153
00154       bool encountered( TopologyEntity* );
00155         //- Mark node as encountered if it was not already encountered.
00156         //- Return the previous value of the encountered flag.
00157
00158       class BeginQuery {
00159         public:
00160           inline BeginQuery()
00161             { ModelQueryEngine::instance()->inc_query_call_stack(); }
00162           inline ~BeginQuery()
00163             { ModelQueryEngine::instance()->dec_query_call_stack(); }
00164           inline void* operator new(size_t /*size*/) throw()
00165             { assert(0); return (void*)0; }
00166       };
00167
00168    protected:
00169
00170       CubitStatus query_append_children ( TopologyEntity& source_object,
00171                                           DagType child_type,
00172                                           DLIList<TopologyEntity*>& result_set );
00173       CubitStatus query_append_parents ( TopologyEntity& source_object,
00174                                          DagType parent_type,
00175                                          DLIList<TopologyEntity*>& result_set );
00176
00177
00178
00179       friend class ModelQueryEngine::BeginQuery;
00180
00181       void inc_query_call_stack();
00182       void dec_query_call_stack();
00183
00184       int queryCallStackDepth;
00185
00186       DLIList<TopologyEntity*> encounteredSet;
00187      // A set of marked ModelEntities.
00188
00189       DLIList<TopologyEntity*> intermediateNodeSets[2];
00190
00191    private:
00192
00193       ModelQueryEngine() ;
00194       //- Constructor. (Not callable by user code. Class is constructed
00195       //- by the "instance()" member function.
00196
00197       static ModelQueryEngine* instance_;
00198       //- The static pointer to unique instance of this class.
00199 };
00200
00201 // ********** BEGIN HELPER CLASSES         **********
00202 // ********** END   HELPER CLASSES         **********
00203
00204 // ********** BEGIN INLINE FUNCTIONS       **********
00205
00206 // ********** END INLINE FUNCTIONS         **********
00207
00208 // ********** BEGIN FRIEND FUNCTIONS       **********
00209 // ********** END FRIEND FUNCTIONS         **********
00210
00211 // ********** BEGIN EXTERN FUNCTIONS       **********
00212 // ********** END EXTERN FUNCTIONS         **********
00213
00214 #endif
00215
