cgma
OCCGeometryCreator.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : OCCGeometryCreator.hpp
00003 //
00004 // Purpose       : For a list of facets, builds a topology of
00005 //                 surfaces, curves and vertices
00006 //
00007 // Special Notes :
00008 //
00009 // Creator       : Steven J. Owen
00010 //
00011 // Date          : 4/29/2001
00012 //
00013 // Owner         : Steven J. Owen
00014 //-------------------------------------------------------------------------
00015
00016 #ifndef MESHGEOMETRYCREATOR_HPP
00017 #define MESHGEOMETRYCREATOR_HPP
00018
00019 #include "DLIList.hpp"
00020
00021 class FacetEntity;
00022 class FacetCurveMesh;
00023 class FacetSurfaceMesh;
00024 class FacetVolumeMesh;
00025 class LoopSM;
00026 class Body;
00027 class Surface;
00028 class FacetPointMesh;
00029 class CubitPoint;
00030 class CubitFacetEdge;
00031 class CubitFacet;
00032
00033 class FacetGeometryCreator
00034 {
00035 public:
00036   FacetGeometryCreator( );
00037   FacetGeometryCreator(DLIList<FacetEntity*> &face_list,
00038                        DLIList<FacetEntity*> &edge_list,
00039                        DLIList<FacetEntity*> &point_list );
00040   //- Constructor
00041
00042   ~FacetGeometryCreator();
00043   //- Destructor
00044
00045 #ifdef BOYD14
00046   CubitStatus create_geometry(CubitBoolean use_feature_angle,
00047                               double angle,
00048                               int interp_order,
00049                               CubitBoolean smooth_non_manifold,
00050                               CubitBoolean split_surfaces,
00051                               DLIList<Surface *> &surface_list);
00052     //- Creates the geometry infrastructure based on
00053     //- the given mesh data.
00054 #endif
00055   void print_me();
00056
00057 private:
00058
00059   DLIList<FacetEntity*> faceList;
00060   DLIList<FacetEntity*> edgeList;
00061   DLIList<FacetEntity*> pointList;
00062   DLIList<FacetSurfaceMesh*> facetSurfaceList;
00063   DLIList<FacetCurveMesh*> facetCurveList;
00064   DLIList<FacetPointMesh*> facetPointList;
00065
00066   DLIList<FacetCurveMesh*> *hashCurveArray;
00067   int hashCurveSize;
00068   DLIList<FacetPointMesh*> *hashPointArray;
00069   int hashPointSize;
00070
00071   void set_up_tool_datas( );
00072   void delete_tool_datas( );
00073
00074 #ifdef BOYD14
00075   int facet_dimension(FacetEntity *facet_ptr);
00076     //- returns the dimension of the facet entity.
00077 #endif
00078
00079   CubitStatus create_volume_boundaries( DLIList<FacetSurfaceMesh*> &facet_surface_sheets,
00080                                         CubitBoolean use_feature_angle,
00081                                         double min_dot,
00082                                         CubitBoolean split_surfaces );
00083     //- creates the correct facetsurfaces for all the element blocks.
00084
00085   CubitStatus create_surface_boundaries( DLIList<FacetSurfaceMesh*> &facet_surface_list,
00086                                          DLIList<FacetCurveMesh*> &facet_curve_list,
00087                                          CubitBoolean use_feature_angle,
00088                                          double min_dot );
00089     //- creates the correct blockcurves for all the surfaces
00090
00091   CubitStatus create_curve_boundaries( DLIList<FacetCurveMesh*> &facet_curve_list,
00092                                        DLIList<FacetPointMesh*> &facet_point_list );
00093     //- creates the correct blockpoints for all the curves
00094
00095   CubitStatus classify_edge( FacetEntity *edge_ptr,
00096                              DLIList<FacetCurveMesh*> &facet_curve_list,
00097                              FacetSurfaceMesh *fsm_ptr );
00098     //- sorts a edge into its correct curve based on its associated
00099     //- blocks and sidesets.  Creates a new facet curve if necessary.
00100
00101   CubitStatus classify_point(CubitPoint *point_ptr,
00102                              DLIList<FacetPointMesh*> &facet_point_list,
00103                              FacetCurveMesh *fcm_ptr );
00104     //- sorts a node into correct point based on its associated
00105     //- curve.  Creates a new facet point if necessary
00106
00107   CubitStatus build_geometry( DLIList<FacetSurfaceMesh*> &facet_surface_list,
00108                               DLIList<FacetCurveMesh*> &facet_curve_list,
00109                               DLIList<FacetPointMesh*> &facet_point_list,
00110                               int interp_order,
00111                               CubitBoolean use_feature_angle,
00112                               double min_dot,
00113                               CubitBoolean smooth_non_manifold ,
00114                               CubitBoolean split_surfaces );
00115     //- build the CUBIT geometry based on the Facet entity class lists
00116
00117   CubitStatus build_point_geometry( DLIList<FacetPointMesh*> &facet_point_list );
00118     //- From the facet point list, create geometric points for each
00119
00120   CubitStatus build_curve_geometry( DLIList<FacetCurveMesh*> &facet_curve_list );
00121     //- From the facet curve list, create geometric curves for each
00122
00123   CubitStatus build_loop_geometry( DLIList<FacetCurveMesh*> &facet_curve_list,
00124                                    FacetSurfaceMesh *fsm_ptr,
00125                                    DLIList<LoopSM*> &loop_list,
00126                                    int &ncurves );
00127     //- From the facet curve list of a surface, create geometric loops
00128
00129   CubitStatus build_surface_geometry( DLIList<FacetSurfaceMesh*> &facet_surface_list,
00130                                       int interp_order, double min_dot );
00131     //- From the facet surface list, create geometric surface,
00132     //- loops and coedges for each surface in the list
00133
00134   CubitStatus init_hash_curves( );
00135   void delete_hash_curves( );
00136   int get_curve_hash_key( DLIList<FacetSurfaceMesh*> *bsm_list_ptr );
00137     // functions for hashing curves - to speed up edge classification
00138
00139   CubitStatus init_hash_points( );
00140   void delete_hash_points( );
00141   int get_point_hash_key( DLIList<FacetCurveMesh*> *bsm_list_ptr );
00142     // functions for hashing points - to speed up node classification
00143
00144   CubitStatus clean_geometry( CubitBoolean smooth_non_manifold,
00145                             CubitBoolean split_surfaces,
00146                             CubitBoolean use_feature_angle,
00147                             double min_dot,
00148                             DLIList <FacetCurveMesh *> &facet_curve_list );
00149
00150     //- fix the edge control points and the normals so they are conforming
00151     //- (or non-conforming) accross curves
00152
00153
00154 };
00155
00156 #endif
