cgma
PartPTCurve.cpp
00001 #include "PartPTCurve.hpp"
00002 #include "PartitionSurface.hpp"
00003 #include "PartitionPoint.hpp"
00004 #include "GMem.hpp"
00005 #include "PartitionEngine.hpp"
00006 #include "CubitMessage.hpp"
00007
00008 PartPTCurve::PartPTCurve( PartitionSurface* owner )
00009 {
00010   owner->sub_entity_set().add_lower_order( this );
00011 }
00012
00013 PartPTCurve* PartPTCurve::construct( const CubitSimpleAttrib& attrib,
00014                                      PartitionSurface* owner )
00015 {
00016   DLIList<int> vertex_conn;
00017   PartPTCurve* result = new PartPTCurve( owner, attrib, vertex_conn );
00018
00019   if ( vertex_conn.size() != 4 )
00020   {
00021     delete result;
00022     return 0;
00023   }
00024
00025   PartitionPoint *start = 0, *end = 0;
00026   PartitionEntity* ent;
00027   vertex_conn.reset();
00028   int set_id = vertex_conn.get_and_step();
00029   int ent_id = vertex_conn.get_and_step();
00030   ent = PartitionEngine::instance().entity_from_id(set_id,ent_id,owner->sub_entity_set());
00031   start = dynamic_cast<PartitionPoint*>(ent);
00032   set_id = vertex_conn.get_and_step();
00033   ent_id = vertex_conn.get_and_step();
00034   ent = PartitionEngine::instance().entity_from_id(set_id,ent_id,owner->sub_entity_set());
00035   end = dynamic_cast<PartitionPoint*>(ent);
00036
00037   if ( !start || !end || start != end )
00038   {
00039     delete result;
00040     return 0;
00041   }
00042
00043   result->start_point( end );
00044   result->end_point( end );
00045   return result;
00046 }
00047
00048 PartPTCurve::PartPTCurve( PartitionSurface* surface,
00049                           const CubitSimpleAttrib& attrib,
00050                           DLIList<int>& vertex_conn )
00051 {
00052   DLIList<CubitVector*> points;
00053   DLIList<int> junk;
00054   surface->sub_entity_set().add_lower_order( this, attrib, 1, points, junk, vertex_conn, junk );
00055   assert( points.size() == 0 );
00056 }
00057
00058 PartPTCurve::~PartPTCurve()
00059   {}
00060
00061 PartitionCurve* PartPTCurve::split( double )
00062   { assert(0); return 0; }
00063
00064 CubitStatus PartPTCurve::combine( PartitionCurve* curve )
00065 {
00066   assert( dynamic_cast<PartPTCurve*>(curve) != NULL );
00067   assert( 0 );
00068   return CUBIT_FAILURE;
00069 }
00070
00071 CubitStatus PartPTCurve::get_graphics( GMem& result,
00072                                     double /*angle_tolerance*/,
00073                                     double /*distance_tolerance*/,
00074                                     double /*max_edge_length*/)
00075 {
00076   result.pointListCount = 0;
00077   return CUBIT_SUCCESS;
00078 }
00079
00080
00081 void PartPTCurve::append_simple_attribute_virt(const CubitSimpleAttrib& csa)
00082   { sub_entity_set().add_attribute( this, csa ); }
00083 void PartPTCurve::remove_simple_attribute_virt(const CubitSimpleAttrib& csa)
00084   { sub_entity_set().rem_attribute( this, csa ); }
00085 void PartPTCurve::remove_all_simple_attribute_virt()
00086   { sub_entity_set().rem_all_attrib( this ); }
00087 CubitStatus PartPTCurve::get_simple_attribute(DLIList<CubitSimpleAttrib>& list)
00088 {
00089   sub_entity_set().get_attributes( this, list );
00090   return CUBIT_SUCCESS;
00091 }
00092 CubitStatus PartPTCurve::get_simple_attribute(const CubitString& name,
00093                                        DLIList<CubitSimpleAttrib>& list)
00094 {
00095   sub_entity_set().get_attributes( this, name.c_str(), list );
00096   return CUBIT_SUCCESS;
00097 }
00098
00099 CubitBox PartPTCurve::bounding_box() const
00100   { return CubitBox( coordinates() ); }
00101 double PartPTCurve::measure()
00102   { return 0.0; }
00103 GeometryType PartPTCurve::geometry_type()
00104   { return POINT_CURVE_TYPE; }
00105
00106 CubitStatus PartPTCurve::closest_point( CubitVector const& ,
00107                                         CubitVector& closest,
00108                                         CubitVector* tangent,
00109                                         CubitVector* curvature,
00110                                         double* param )
00111 {
00112   closest = coordinates();
00113   if( tangent ) tangent->set(0.,0.,0.);
00114   if( curvature) curvature->set(0.,0.,0.);
00115   if( param ) *param = 0.0;
00116   return CUBIT_SUCCESS;
00117 }
00118
00119 CubitPointContainment PartPTCurve::point_containment( const CubitVector& position )
00120   { return is_position_on(position) ? CUBIT_PNT_BOUNDARY : CUBIT_PNT_OFF; }
00121
00122 CubitBoolean  PartPTCurve::is_position_on( const CubitVector& position )
00123 {
00124   const double tolsqr = GEOMETRY_RESABS * GEOMETRY_RESABS;
00125   return (position - coordinates()).length_squared() < tolsqr;
00126 }
00127
00128 CubitBoolean PartPTCurve::G1_discontinuous( double, CubitVector* min, CubitVector* plu )
00129 {
00130   if( min ) min->set( 0., 0., 0. );
00131   if( plu ) plu->set( 0., 0., 0. );
00132   return CUBIT_TRUE;
00133 }
00134
00135 CubitStatus PartPTCurve::get_interior_extrema( DLIList<CubitVector*>&, CubitSense& )
00136   { return CUBIT_SUCCESS; }
00137
00138 CubitStatus PartPTCurve::get_center_radius( CubitVector&, double& )
00139   { return CUBIT_FAILURE; }
00140
00141 CubitBoolean PartPTCurve::get_param_range( double& lower, double& upper )
00142   { lower = upper = 0.0; return CUBIT_TRUE; }
00143
00144 double PartPTCurve::start_param()
00145   { return 0.0; }
00146 double PartPTCurve::end_param()
00147   { return 0.0; }
00148
00149 CubitBoolean PartPTCurve::is_periodic( double& period )
00150   { period = 0.0; return CUBIT_TRUE; }
00151
00152 double PartPTCurve::length_from_u( double, double )
00153   { return  0.0; }
00154
00155 double PartPTCurve::u_from_position( const CubitVector& )
00156   { return 0.0; }
00157
00158 CubitStatus PartPTCurve::position_from_u( double, CubitVector& result )
00159   { result = coordinates(); return CUBIT_SUCCESS; }
00160
00161 double PartPTCurve::u_from_arc_length( double, double )
00162   { return 0.0; }
00163
00164 CubitVector PartPTCurve::coordinates() const
00165 {
00166   if( start_point() )
00167     return start_point()->coordinates();
00168
00169   if( end_point() )
00170     return end_point()->coordinates();
00171
00172   return CubitVector(0.,0.,0.);
00173 }
00174
00175 void PartPTCurve::reverse_sense()
00176   { }
00177
00178 CubitStatus PartPTCurve::save( CubitSimpleAttrib& attrib )
00179 {
00180   int id = sub_entity_set().get_id(this);
00181   if( id <= 0 ) return CUBIT_FAILURE;
00182
00183   DLIList<int> end_points(4);
00184   get_save_topology(end_points);
00185
00186   return sub_entity_set().save_geometry( id, 1, 0, 0, &end_points, 0, attrib );
00187 }
00188
00189 CubitStatus PartPTCurve::get_spline_params
00190 (
00191   bool &rational,    // return true/false
00192   int &degree,       // the degree of this spline
00193   DLIList<CubitVector> &cntrl_pts,  // xyz position of controlpoints
00194   DLIList<double> &cntrl_pt_weights, // if rational, a weight for each cntrl point.
00195   DLIList<double> &knots,   // There should be order+cntrl_pts.size()-2 knots
00196   bool &spline_is_reversed
00197 ) const
00198 {
00199   PRINT_ERROR("Currently, Cubit is unable to determine spline parameters for PartPTCurves.\n");
00200   return CUBIT_FAILURE;
00201 }
00202
00203 CubitStatus PartPTCurve::get_ellipse_params
00204 (
00205   CubitVector &center_vec,
00206   CubitVector &normal,
00207   CubitVector &major_axis,
00208   double &radius_ratio
00209 ) const
00210 {
00211   PRINT_ERROR("Currently, Cubit is unable to determine ellipse parameters for PartPTCurves.\n");
00212   return CUBIT_FAILURE;
00213 }
