cgma
PartPTCurve.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : PartPtCurve.hpp
00003 //
00004 // Purpose       : Point Curve for Partition Geometry
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jason Kraftcheck
00009 //
00010 // Creation Date : 04/27/02
00011 //-------------------------------------------------------------------------
00012
00013 #ifndef PART_PT_CURVE
00014 #define PART_PT_CURVE
00015
00016 #include "PartitionCurve.hpp"
00017
00018 class PartitionSurface;
00019
00020 class PartPTCurve : public PartitionCurve
00021 {
00022
00023 public:
00024
00025   PartPTCurve( PartitionSurface* owner );
00026
00027   static PartPTCurve* construct( const CubitSimpleAttrib& attrib,
00028                                  PartitionSurface* owner );
00029
00030   virtual ~PartPTCurve();
00031
00032   PartitionCurve* split( double );
00033
00034   CubitStatus combine( PartitionCurve* curve );
00035
00036   CubitStatus get_graphics( GMem& result,
00037                             double angle_tolerance=0,
00038                             double distance_tolerance=0,
00039                             double max_edge_length=0);
00040
00041   CubitVector coordinates() const;
00042
00043   virtual CubitStatus save( CubitSimpleAttrib& attrib );
00044
00045     /*** Methods from TopologyBridge ***/
00046
00047   void append_simple_attribute_virt( const CubitSimpleAttrib& );
00048   void remove_simple_attribute_virt( const CubitSimpleAttrib& );
00049   void remove_all_simple_attribute_virt();
00050   CubitStatus get_simple_attribute( DLIList<CubitSimpleAttrib>& );
00051   CubitStatus get_simple_attribute( const CubitString& name,
00052                                     DLIList<CubitSimpleAttrib>& );
00053
00054     /*** Methods from GeometryEntity ***/
00055
00056   CubitBox bounding_box() const;
00057   double measure();
00058   GeometryType geometry_type();
00059
00060     /*** Methods from Curve ***/
00061
00062   CubitStatus closest_point( CubitVector const& from, CubitVector& closest,
00063                  CubitVector* tangent = 0,  CubitVector* curvature = 0,
00064                  double* param = 0 );
00065   CubitPointContainment point_containment( const CubitVector& point );
00066   CubitBoolean is_position_on( const CubitVector& position );
00067   CubitBoolean G1_discontinuous( double u, CubitVector* minus_tangent = 0,
00068                                            CubitVector* plus_tangent = 0 );
00069   CubitStatus get_interior_extrema( DLIList<CubitVector*>& points, CubitSense& sense );
00070   CubitStatus get_center_radius( CubitVector& center, double& radius );
00071
00072   CubitBoolean get_param_range( double& lower, double& upper );
00073   double start_param();
00074   double end_param();
00075   CubitBoolean is_periodic( double& period );
00076
00077   double length_from_u( double u1, double u2 );
00078   double u_from_position( const CubitVector& position );
00079   CubitStatus position_from_u( double u, CubitVector& result );
00080   double u_from_arc_length( double root, double length );
00081
00082   void reverse_sense();
00083
00084   //R CubitStatus
00085   //O- true or false if spline is rational or not.
00086   //O- the degree of this spline
00087   //O- the control points
00088   //O- If rational, weight for each control point
00089   //O- whether underlying spline is reversed
00090   virtual CubitStatus get_spline_params( bool &rational,
00091                                          int &degree,
00092                                          DLIList<CubitVector> &cntrl_pts,
00093                                          DLIList<double> &cntrl_pt_weights,
00094                                          DLIList<double> &knots,
00095                                          bool &spline_is_reversed
00096                                        ) const;
00097   //R CubitStatus
00098   //O- center - ellipse center point
00099   //O- normal - normal of the plane of the ellipse
00100   //O- major_axis - major axis of the ellipse
00101   //O- radius_ratio - ratio of the length of the major to minor axis.
00102   virtual CubitStatus get_ellipse_params( CubitVector &center,
00103                                           CubitVector &normal,
00104                                           CubitVector &major_axis,
00105                                           double &radius_ratio ) const;
00106
00107   private:
00108
00109   PartPTCurve( PartitionSurface* owner,
00110                const CubitSimpleAttrib& attrib,
00111                DLIList<int>& vertex_connectivity );
00112
00113 };
00114
00115
00116 #endif
00117
00118
00119
