cgma
PartitionLoop.cpp
00001 #include "DLIList.hpp"
00002
00003 #include "PartitionCoEdge.hpp"
00004 #include "PartitionLoop.hpp"
00005 #include "PartitionSurface.hpp"
00006 #include "VirtualQueryEngine.hpp"
00007
00008 //-------------------------------------------------------------------------
00009 // Purpose       : Constructor
00010 //
00011 // Special Notes :
00012 //
00013 // Creator       : Jason Kraftcheck
00014 //
00015 // Creation Date : 01/11/02
00016 //-------------------------------------------------------------------------
00017 PartitionLoop::PartitionLoop(  )
00018   : mySurface(0), firstCoedge( 0 ), nextInSurface( 0 ), numCoedges( 0 )
00019 {
00020 }
00021
00022 //-------------------------------------------------------------------------
00023 // Purpose       : The purpose of this function is to see if a loop is an external
00024 //                  or internal loop of a surface.
00025 //
00026 // Special Notes :
00027 //
00028 // Creator       : Jonathan Bugman
00029 //
00030 // Creation Date : 9/9/2008
00031 //-------------------------------------------------------------------------
00032 CubitBoolean PartitionLoop::is_external()
00033 {
00034           PRINT_ERROR( "This command is not supported with this engine.\n");
00035           return CUBIT_FAILURE;
00036 }
00037
00038 LoopType PartitionLoop::loop_type()
00039 {
00040   return LOOP_TYPE_UNKNOWN;
00041 }
00042
00043 //-------------------------------------------------------------------------
00044 // Purpose       : Destructor
00045 //
00046 // Special Notes :
00047 //
00048 // Creator       : Jason Kraftcheck
00049 //
00050 // Creation Date : 01/11/02
00051 //-------------------------------------------------------------------------
00052 PartitionLoop::~PartitionLoop()
00053 {
00054   if( mySurface )
00055   {
00056     mySurface->remove( this );
00057     mySurface = 0;
00058   }
00059
00060   CubitStatus s = remove_all_coedges();
00061   assert( s );
00062   if (CUBIT_SUCCESS != s) {
00063     PRINT_ERROR("Failed to remove all coedges.\n");
00064   }
00065 }
00066
00067 //-------------------------------------------------------------------------
00068 // Purpose       : insert a child coedge
00069 //
00070 // Special Notes :
00071 //
00072 // Creator       : Jason Kraftcheck
00073 //
00074 // Creation Date : 03/23/02
00075 //-------------------------------------------------------------------------
00076 CubitStatus PartitionLoop::insert_after( PartitionCoEdge* insert,
00077                                          PartitionCoEdge* after )
00078 {
00079   if( insert->myLoop != 0 )
00080     return CUBIT_FAILURE;
00081
00082   if( numCoedges == 0 )
00083   {
00084     if( after )
00085       return CUBIT_FAILURE;
00086
00087     insert->loopNext = insert;
00088     insert->loopPrev = insert;
00089     firstCoedge = insert;
00090   }
00091   else
00092   {
00093     if( !after || after->myLoop != this )
00094       return CUBIT_FAILURE;
00095
00096     insert->loopPrev = after;
00097     insert->loopNext = after->loopNext;
00098     insert->loopNext->loopPrev = insert;
00099     insert->loopPrev->loopNext = insert;
00100   }
00101
00102   insert->myLoop = this;
00103   numCoedges++;
00104   return CUBIT_SUCCESS;
00105 }
00106 CubitStatus PartitionLoop::insert_before( PartitionCoEdge* insert,
00107                                           PartitionCoEdge* before )
00108 {
00109   if( insert->myLoop != 0 )
00110     return CUBIT_FAILURE;
00111
00112   if( numCoedges == 0 )
00113   {
00114     if( before )
00115       return CUBIT_FAILURE;
00116
00117     insert->loopNext = insert;
00118     insert->loopPrev = insert;
00119     firstCoedge = insert;
00120   }
00121   else
00122   {
00123     if( !before || before->myLoop != this )
00124       return CUBIT_FAILURE;
00125
00126     insert->loopNext = before;
00127     insert->loopPrev = before->loopPrev;
00128     insert->loopNext->loopPrev = insert;
00129     insert->loopPrev->loopNext = insert;
00130   }
00131
00132   insert->myLoop = this;
00133   numCoedges++;
00134   return CUBIT_SUCCESS;
00135 }
00136
00137 //-------------------------------------------------------------------------
00138 // Purpose       : remove a child coedge
00139 //
00140 // Special Notes :
00141 //
00142 // Creator       : Jason Kraftcheck
00143 //
00144 // Creation Date : 03/23/02
00145 //-------------------------------------------------------------------------
00146 CubitStatus PartitionLoop::remove( PartitionCoEdge* coedge )
00147 {
00148   if( coedge->myLoop != this )
00149     return CUBIT_FAILURE;
00150
00151   if( numCoedges == 1 )
00152   {
00153     assert( coedge->loopNext == coedge &&
00154             coedge->loopPrev == coedge );
00155     firstCoedge = 0;
00156   }
00157   else
00158   {
00159     coedge->loopNext->loopPrev = coedge->loopPrev;
00160     coedge->loopPrev->loopNext = coedge->loopNext;
00161     if( firstCoedge == coedge )
00162       firstCoedge = coedge->loopNext;
00163   }
00164
00165   numCoedges--;
00166   coedge->myLoop = 0;
00167   coedge->loopNext = 0;
00168   coedge->loopPrev = 0;
00169
00170   return CUBIT_SUCCESS;
00171 }
00172
00173
00174
00175
00176 //-------------------------------------------------------------------------
00177 // Purpose       : remove (and return) all coedges
00178 //
00179 // Special Notes :
00180 //
00181 // Creator       : Jason Kraftcheck
00182 //
00183 // Creation Date : 03/24/02
00184 //-------------------------------------------------------------------------
00185 CubitStatus PartitionLoop::remove_all_coedges( DLIList<PartitionCoEdge*>* list )
00186 {
00187   while( firstCoedge )
00188   {
00189     if( list )
00190       list->append( firstCoedge );
00191     remove( firstCoedge );
00192   }
00193
00194   return CUBIT_SUCCESS;
00195 }
00196
00197 //-------------------------------------------------------------------------
00198 // Purpose       : get parent bridges
00199 //
00200 // Special Notes : pure virtual in TopologyBridge
00201 //
00202 // Creator       : Jason Kraftcheck
00203 //
00204 // Creation Date : 01/11/02
00205 //-------------------------------------------------------------------------
00206 void PartitionLoop::get_parents_virt( DLIList<TopologyBridge*>& parents )
00207   { if( mySurface ) parents.append( mySurface ); }
00208
00209
00210 //-------------------------------------------------------------------------
00211 // Purpose       : get child bridges
00212 //
00213 // Special Notes : pure virtual in TopologyBridge
00214 //
00215 // Creator       : Jason Kraftcheck
00216 //
00217 // Creation Date : 01/11/02
00218 //-------------------------------------------------------------------------
00219 void PartitionLoop::get_children_virt( DLIList<TopologyBridge*>& children )
00220 {
00221   PartitionCoEdge* coedge = firstCoedge;
00222
00223   if( coedge ) do
00224   {
00225     children.append( coedge );
00226     coedge = next_coedge( coedge );
00227   } while( coedge != firstCoedge );
00228 }
00229
00230
00231 //-------------------------------------------------------------------------
00232 // Purpose       : get tb layer number
00233 //
00234 // Special Notes :
00235 //
00236 // Creator       : Jason Kraftcheck
00237 //
00238 // Creation Date : 01/03/03
00239 //-------------------------------------------------------------------------
00240 int PartitionLoop::layer() const
00241   { return get_surface()->layer(); }
00242
00243 //-------------------------------------------------------------------------
00244 // Purpose       : Get PartitionEngine
00245 //
00246 // Special Notes :
00247 //
00248 // Creator       : Jason Kraftcheck
00249 //
00250 // Creation Date : 01/11/02
00251 //-------------------------------------------------------------------------
00252 GeometryQueryEngine* PartitionLoop::get_geometry_query_engine() const
00253   { return VirtualQueryEngine::instance(); }
00254
00255 //-------------------------------------------------------------------------
00256 // Purpose       : Attribute functions
00257 //
00258 // Special Notes :
00259 //
00260 // Creator       : Jason Kraftcheck
00261 //
00262 // Creation Date : 01/11/02
00263 //-------------------------------------------------------------------------
00264 void PartitionLoop::append_simple_attribute_virt( const CubitSimpleAttrib& )
00265 { }
00266 void PartitionLoop::remove_simple_attribute_virt( const CubitSimpleAttrib& )
00267 { }
00268 void PartitionLoop::remove_all_simple_attribute_virt()
00269 { }
00270 CubitStatus PartitionLoop::get_simple_attribute( DLIList<CubitSimpleAttrib>& )
00271 { return CUBIT_FAILURE; }
00272 CubitStatus PartitionLoop::get_simple_attribute( const CubitString&,
00273                                                  DLIList<CubitSimpleAttrib>& )
00274 { return CUBIT_FAILURE; }
00275
00276
00277
00278 //-------------------------------------------------------------------------
00279 // Purpose       : Reverse order and sense of coedges
00280 //
00281 // Special Notes :
00282 //
00283 // Creator       : Jason Kraftcheck
00284 //
00285 // Creation Date : 03/17/02
00286 //-------------------------------------------------------------------------
00287 void PartitionLoop::reverse()
00288 {
00289   PartitionCoEdge* coedge = firstCoedge;
00290   if( coedge ) do
00291   {
00292     PartitionCoEdge* temp = coedge->loopNext;
00293     coedge->loopNext = coedge->loopPrev;
00294     coedge->loopPrev = temp;
00295     coedge->reverse_sense();
00296     coedge = temp;
00297   } while( coedge != firstCoedge );
00298 }
00299
00300
00301 void PartitionLoop::print_debug_info( const char* /*line_prefix*/ )
00302 {
00303 /*
00304   if( line_prefix == 0 )
00305     line_prefix = "";
00306
00307   char* new_prefix = new char[strlen(line_prefix)+3];
00308   strcpy( new_prefix, line_prefix );
00309   strcat( new_prefix, "  " );
00310
00311   PRINT_INFO("%sPartitionLoop @ %p : \n", line_prefix, this );
00312   PartitionCoEdge* coedge = first_coedge();
00313   if( !coedge )
00314     PRINT_INFO("%s  No CoEdges!!\n");
00315   else do
00316   {
00317     coedge->print_debug_info( new_prefix );
00318     coedge = next_coedge( coedge );
00319   } while( coedge != first_coedge() );
00320
00321   delete [] new_prefix;
00322 */
00323 }
00324
