cgma
RandomMersenne.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : RandomMersenne.hpp
00003 //
00004 // Purpose       : Main include for random number generator
00005 //                 This random number generator came from the authors of the Mersenne
00006 //                 random number generator, Makoto Matsumoto and Takuji Nishimura.
00007 //                 See the definition file RandomMersenne.cpp for the full copyright
00008 //                 statement.
00009 //
00010 //                 I have made the following changes, starting from the (faster version
00011 //                 of the) source code provided by the authors.  I have made the following
00012 //                 changes:
00013 //                 - put the generator into a C++ class, to simplify use of inline functions
00014 //                   and member instead of global variables
00015 //                 - made the period parameters enum variables instead of #defines,
00016 //                   formerly static state variables member variables, and formerly
00017 //                   global functions member functions.
00018 //                 - removed check for initialization from next_state, since I require
00019 //                   initialization when the class object is created
00020 //
00021 //                 Other Notes:
00022 //                 - I made the no-argument constructor private, to force input of
00023 //                   a seed value.  The random sequence gets initialized upon construction.
00024 //                 - function names in this class don't follow our naming convention, because
00025 //                   I wanted to stay as close to the original source code as possible
00026 //                 - most of the public functions in this class are inlined, in the hopes that
00027 //                   at least some compilers will honor that; these functions all call a
00028 //                   non-inlined function next_state() though.
00029 //
00030 //
00031 // Creator       : Tim Tautges (mostly code from aforementioned site)
00032 //
00033 // Date          : 08/02
00034 //
00035 // Owner         : Tim Tautges
00036 //-------------------------------------------------------------------------
00037
00038 #ifndef RANDOM_MERSENNE_HPP
00039 #define RANDOM_MERSENNE_HPP
00040
00041 #include "CGMUtilConfigure.h"
00042
00043 class CUBIT_UTIL_EXPORT RandomMersenne {                  // encapsulate random number generator
00044
00045 public:
00046
00048   RandomMersenne(unsigned long seed);
00049
00051   RandomMersenne(unsigned long init_key[], unsigned long key_length);
00052
00056   void init_by_array(unsigned long init_key[], unsigned long key_length);
00057
00059   unsigned long genrand_int32();
00060
00062   long genrand_int31();
00063
00065   double genrand_real1();
00066
00068   double genrand_real2();
00069
00071   double genrand_real3();
00072
00074   double genrand_res53();
00075
00076 private:
00077
00079   RandomMersenne() {}
00080
00082   void init_genrand(unsigned long s);
00083
00084   enum {
00085     N = 624, M = 397,
00086     MATRIX_A = 0x9908b0dfU,
00087     UPPER_MASK = 0x80000000U, /* most significant w-r bits */
00088     LOWER_MASK = 0x7fffffffU /* least significant r bits */
00089   };
00090
00091   unsigned long mt[N];
00092   unsigned mti;
00093   int left;
00094   int initf;
00095   unsigned long *next;
00096
00097 };
00098
00099 inline RandomMersenne::RandomMersenne(unsigned long seed)
00100 {
00101   init_genrand(seed);
00102 }
00103
00104 inline RandomMersenne::RandomMersenne(unsigned long init_key[],
00105                                       unsigned long key_length)
00106 {
00107   init_by_array(init_key, key_length);
00108 }
00109
00110 /* generates a random number on [0,0x7fffffff]-interval */
00111 inline long RandomMersenne::genrand_int31()
00112 {
00113   return (long) (genrand_int32() >> 1);
00114 }
00115
00116 #endif
00117
