cgma
RefVertex.cpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : RefVertex.cpp
00003 //
00004 // Purpose       : This file contains the implementation of the class
00005 //                 RefVertex. A RefVertex is a TopologyEntity and represents
00006 //                 a point or vertex in the topology of the Model.
00007 //
00008 // Special Notes :
00009 //
00010 // Creator       : Xuechen Liu
00011 //
00012 // Creation Date : 07/11/96
00013 //
00014 // Owner         : Malcolm J. Panthaki
00015 //-------------------------------------------------------------------------
00016
00017
00018 #include <assert.h>
00019
00020 #include "CubitDefines.h"
00021 #include "GeometryDefines.h"
00022
00023 #include "RefEntityFactory.hpp"
00024 #include "GeometryQueryTool.hpp"
00025 #include "GeometryQueryEngine.hpp"
00026 #include "ModelQueryEngine.hpp"
00027
00028 #include "RefVolume.hpp"
00029 #include "RefFace.hpp"
00030 #include "RefEdge.hpp"
00031 #include "RefVertex.hpp"
00032 #include "Point.hpp"
00033 #include "DLIList.hpp"
00034 #include "CastTo.hpp"
00035 #include "ToolData.hpp"
00036 #include "CoVertex.hpp"
00037
00038 //-------------------------------------------------------------------------
00039 // Purpose       : Constructor with a pointer to a Point
00040 //
00041 // Special Notes :
00042 //
00043 // Creator       : Xuechen Liu
00044 //
00045 // Creation Date : 07/11/96
00046 //-------------------------------------------------------------------------
00047 RefVertex::RefVertex(TBPoint* pointPtr)
00048 {
00049    // Set the GeometryEntity pointer
00050    if (pointPtr != NULL)
00051    {
00052       set_geometry_entity_ptr(pointPtr) ;
00053    }
00054    else
00055    {
00056       PRINT_ERROR("In the RefVertex(TBPoint*) constructor\n");
00057       PRINT_ERROR("       Input TBPoint pointer is NULL\n");
00058       assert(CUBIT_FALSE);
00059    }
00060
00061    // Initialize the member data
00062    initialize();
00063 }
00064
00065 //-------------------------------------------------------------------------
00066 // Purpose       : The destructor.
00067 //
00068 // Special Notes :
00069 //
00070 // Creator       : Malcolm J. Panthaki
00071 //
00072 // Creation Date : 11/06/96
00073 //-------------------------------------------------------------------------
00074 RefVertex::~RefVertex()
00075 {
00076 }
00077
00078 //-------------------------------------------------------------------------
00079 // Purpose       : Return a pointer to the point associated with a vertex.
00080 //
00081 // Special Notes :
00082 //
00083 // Creator       : Xuechen Liu
00084 //
00085 // Creation Date : 08/02/96
00086 //-------------------------------------------------------------------------
00087 TBPoint* RefVertex::get_point_ptr()
00088 {
00089   return CAST_TO(get_geometry_entity_ptr(), TBPoint) ;
00090 }
00091
00092 const TBPoint* RefVertex::get_point_ptr() const
00093 {
00094   return CAST_TO(get_geometry_entity_ptr(), TBPoint) ;
00095 }
00096
00097
00098 //-------------------------------------------------------------------------
00099 // Purpose       : Returns the global coordinates of this RefVertex.
00100 //
00101 // Special Notes :
00102 //
00103 // Creator       : Malcolm J. Panthaki
00104 //
00105 // Creation Date : 09/25/96
00106 //-------------------------------------------------------------------------
00107 CubitVector RefVertex::coordinates() const
00108 {
00109   const TBPoint* point_ptr = get_point_ptr();
00110
00111   if (point_ptr != NULL)
00112   {
00113     return point_ptr->coordinates();
00114   }
00115   else
00116   {
00117     PRINT_ERROR("In RefVertex::coordinates\n"
00118                 "       RefVertex %d has no GeometryEntity attached to it.\n"
00119                 "       THIS IS A BUG - PLEASE REPORT IT.\n", id());
00120     assert( point_ptr != NULL );
00121     return CubitVector();
00122   }
00123 }
00124
00125 //-------------------------------------------------------------------------
00126 // Purpose       : Return the "center point" of the RefVertex -- its
00127 //                 coordinates.
00128 //
00129 // Special Notes :
00130 //
00131 // Creator       : Raikanta Sahu
00132 //
00133 // Creation Date : 10/30/96
00134 //-------------------------------------------------------------------------
00135 CubitVector RefVertex::center_point()
00136 {
00137    return this->coordinates();
00138 }
00139 void RefVertex::common_ref_edges(RefVertex *other_vertex,
00140                                 DLIList <RefEdge*> &common_ref_edges,
00141                                 RefFace *owning_face)
00142 {
00143     //- returns an edge sharing the other vertex and owned by owning_face
00144     //- (if non-NULL)
00145     //- The edge must have this vertex and other_vertex as its
00146     //- start and end vertices.
00147   DLIList<RefEntity*> temp_list;
00148   join(other_vertex, temp_list);
00149
00150   int i;
00151   for (i = temp_list.size(); i > 0; i--)
00152   {
00153     RefEdge *common_edge = CAST_TO(temp_list.get(), RefEdge);
00154       //This extra 'if' block is needed in case other_vertex == this
00155     if (common_edge &&
00156         ((common_edge->start_vertex() == other_vertex &&
00157            common_edge->end_vertex() == this) ||
00158          ( common_edge->start_vertex() == this &&
00159            common_edge->end_vertex() == other_vertex )))
00160     {
00161       if (common_edge && (!owning_face || common_edge->is_child(owning_face)))
00162         common_ref_edges.append(common_edge);
00163     }
00164     temp_list.step();
00165   }
00166   return;
00167 }
00168
00169 RefEdge *RefVertex::common_ref_edge(RefVertex *other_vertex,
00170                                     RefFace *owning_face)
00171 {
00172     //- returns an edge sharing the other vertex and owned by owning_face
00173     //- (if non-NULL)
00174     //- The edge must have this vertex and other_vertex as its
00175     //- start and end vertices.
00176   DLIList<RefEntity*> temp_list;
00177   join(other_vertex, temp_list);
00178
00179   int i;
00180   for (i = temp_list.size(); i > 0; i--) {
00181     RefEdge *common_edge = CAST_TO(temp_list.get(), RefEdge);
00182
00183     if( NULL == common_edge )
00184       continue;
00185
00186       //This extra 'if' block is needed in case other_vertex == this
00187     if ( ( common_edge->start_vertex() == other_vertex &&
00188            common_edge->end_vertex() == this) ||
00189          ( common_edge->start_vertex() == this &&
00190            common_edge->end_vertex() == other_vertex ) )
00191     {
00192       if (common_edge && (!owning_face || common_edge->is_child(owning_face)))
00193         return common_edge;
00194       else
00195         temp_list.step();
00196     }
00197     else
00198       temp_list.step();
00199   }
00200
00201   return NULL;
00202 }
00203
00204 //-------------------------------------------------------------------------
00205 // Purpose       : Spatially compare two RefVertexes, notification is made if
00206 //                 the flag notify_ref_entity is set.
00207 //
00208 // Special Notes :
00209 //
00210 // Creator       : David White
00211 //
00212 // Creation Date : 04/08/97
00213 //-------------------------------------------------------------------------
00214 CubitBoolean RefVertex::about_spatially_equal(
00215                                 RefVertex* ref_vertex_ptr_2,
00216                                 double tolerance_factor,
00217                                 CubitBoolean notify_ref_entity )
00218 {
00219    if( this == ref_vertex_ptr_2 )
00220    {
00221       if (notify_ref_entity)
00222         remove_compare_data();
00223       return CUBIT_TRUE;
00224    }
00225
00226    const CubitVector vertex_1_position = this->coordinates();
00227    const CubitVector vertex_2_position = ref_vertex_ptr_2->coordinates();
00228    if (!GeometryQueryTool::instance()-> about_spatially_equal(
00229      vertex_1_position, vertex_2_position, tolerance_factor))
00230      return CUBIT_FALSE;
00231
00232    if ( notify_ref_entity == CUBIT_TRUE )
00233      this->comparison_found(ref_vertex_ptr_2);
00234
00235    return CUBIT_TRUE;
00236 }
00237
00238 // ********** END PUBLIC FUNCTIONS         **********
00239
00240 // ********** BEGIN PROTECTED FUNCTIONS    **********
00241 // ********** END PROTECTED FUNCTIONS      **********
00242
00243 // ********** BEGIN PRIVATE FUNCTIONS      **********
00244
00245 //-------------------------------------------------------------------------
00246 // Purpose       : Initializes member data
00247 //
00248 // Special Notes :
00249 //
00250 // Creator       : Malcolm J. Panthaki
00251 //
00252 // Creation Date : 10/07/96
00253 //-------------------------------------------------------------------------
00254 void RefVertex::initialize()
00255 {
00256    GeometryEntity* geom_ptr = get_geometry_entity_ptr();
00257    int saved_id = geom_ptr->get_saved_id();
00258    if ( !saved_id || RefEntityFactory::instance()->get_ref_vertex(saved_id) )
00259    {
00260      saved_id =  RefEntityFactory::instance()->next_ref_vertex_id();
00261      geom_ptr->set_saved_id(saved_id);
00262    }
00263    entityId = saved_id;
00264
00265    // Initialize some attributes
00266
00267      // read and initialize attributes
00268    auto_read_cubit_attrib();
00269    auto_actuate_cubit_attrib();
00270
00271    // Assign a default entity name
00272    assign_default_name();
00273
00274 }
00275
00276 void RefVertex::get_parent_ref_entities(DLIList<RefEntity*>& entity_list)
00277 {
00278
00279   // First get the type of RefEntity that is a child of "this" one
00280   DagType parent_type = get_parent_ref_entity_type();;
00281
00282   DLIList<TopologyEntity*> tempList ;
00283
00284   CubitStatus result = ModelQueryEngine::instance()->
00285       query_model( *this, parent_type, tempList );
00286   if (result == CUBIT_FAILURE)
00287   {
00288     PRINT_ERROR("In RefEntity::get_parent_ref_entities\n");
00289     PRINT_ERROR("       Query failed for unknown reason.\n");
00290     return;
00291   }
00292
00293   entity_list.clean_out();
00294   for(int i=0; i<tempList.size(); i++)
00295   {
00296     entity_list.append(static_cast<ParentType*>(tempList[i]));
00297   }
00298 }
