cgma
SubCurve.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : SubCurve.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jason Kraftcheck
00009 //
00010 // Creation Date : 04/10/02
00011 //-------------------------------------------------------------------------
00012
00013 #ifndef SUB_CURVE_HPP
00014 #define SUB_CURVE_HPP
00015
00016 #include "PartitionCurve.hpp"
00017
00018 class SubCurve : public PartitionCurve
00019 {
00020
00021 public:
00022
00023   PartitionCurve* split( double param );
00024   CubitStatus combine( PartitionCurve* dead_curve );
00025
00026
00027   SubCurve( Curve* curve_ptr );
00028   SubCurve( SubCurve* curve_ptr, double start_param );
00029
00030   ~SubCurve();
00031
00032   Curve* real_curve() const;
00033
00034   int num_partitions() const;
00035   void get_all_partitions( DLIList<TopologyBridge*>& curves ) const;
00036
00037   CubitStatus get_graphics( GMem& result,
00038                             double angle_tolerance = 0,
00039                             double distance_tolernace = 0,
00040                             double max_edge_length = 0);
00041
00042   void reverse_sense();
00043
00044   virtual CubitStatus save(CubitSimpleAttrib&);
00045
00046     /*** Methods from GeometryEntity ***/
00047
00048   CubitBox bounding_box() const;
00049   double measure();
00050   GeometryType geometry_type();
00051
00052     /*** Methods from Curve ***/
00053
00054   CubitStatus closest_point( CubitVector const& from, CubitVector& closest,
00055                  CubitVector* tangent = 0,  CubitVector* curvature = 0,
00056                  double* param = 0 );
00057   CubitPointContainment point_containment( const CubitVector& point );
00058   CubitBoolean is_position_on( const CubitVector& position );
00059   CubitBoolean G1_discontinuous( double u, CubitVector* minus_tangent = 0,
00060                                            CubitVector* plus_tangent = 0 );
00061   CubitStatus get_interior_extrema( DLIList<CubitVector*>& points, CubitSense& sense );
00062   CubitStatus get_center_radius( CubitVector& center, double& radius );
00063
00064   CubitBoolean get_param_range( double& lower, double& upper );
00065   double start_param();
00066   double end_param();
00067   CubitBoolean is_periodic( double& period );
00068
00069   double length_from_u( double u1, double u2 );
00070   double u_from_position( const CubitVector& position );
00071   CubitStatus position_from_u( double u, CubitVector& result );
00072   double u_from_arc_length( double root, double length );
00073
00074   //R CubitStatus
00075   //O- true or false if spline is rational or not.
00076   //O- the degree of this spline
00077   //O- the control points
00078   //O- If rational, weight for each control point
00079   //O- whether underlying spline is reversed
00080   virtual CubitStatus get_spline_params( bool &rational,
00081                                          int &degree,
00082                                          DLIList<CubitVector> &cntrl_pts,
00083                                          DLIList<double> &cntrl_pt_weights,
00084                                          DLIList<double> &knots,
00085                                          bool &spline_is_reversed
00086                                        ) const;
00087   //R CubitStatus
00088   //O- center - ellipse center point
00089   //O- normal - normal of the plane of the ellipse
00090   //O- major_axis - major axis of the ellipse
00091   //O- radius_ratio - ratio of the length of the major to minor axis.
00092   virtual CubitStatus get_ellipse_params( CubitVector &center,
00093                                           CubitVector &normal,
00094                                           CubitVector &major_axis,
00095                                           double &radius_ratio ) const;
00096 private:
00097
00098   void fixup_periodic_param( double& param ) const;
00099   CubitBoolean get_ordered_param_range( double& lower, double& upper );
00100
00101   double startParam, endParam;
00102 };
00103
00104 inline Curve* SubCurve::real_curve() const
00105   { return dynamic_cast<Curve*>(partitioned_entity()); }
00106
00107
00108 #endif
