cgma
SubSurface.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : SubSurface.hpp
00003 //
00004 // Purpose       : Geoemtry for the split of a face.
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jason Kraftcheck
00009 //
00010 // Creation Date : 06/11/98
00011 //-------------------------------------------------------------------------
00012
00013 #ifndef SUB_SURFACE_HPP
00014 #define SUB_SURFACE_HPP
00015
00016 #include "PartitionSurface.hpp"
00017
00018 class SubSurface : public PartitionSurface
00019 {
00020 public:
00021
00022   SubSurface( Surface* real_surf );
00023     //- Constructor
00024
00025   CubitStatus combine( PartitionSurface* dead_surface );
00026
00027   virtual ~SubSurface();
00028     //- destructor.
00029
00030   inline Surface* partitioned_surface() const;
00031
00032   virtual CubitStatus save(CubitSimpleAttrib&);
00033
00034   //CubitBox bounding_box() const;
00035   //Use facet-based version inherited from PartitionSurface
00036
00037   double measure();
00038   GeometryType geometry_type();
00039
00040
00041   CubitStatus get_point_normal( CubitVector& point, CubitVector& normal );
00042
00043   virtual CubitStatus closest_point_uv_guess(
00044       CubitVector const& location,
00045       double& u, double& v,
00046       CubitVector* closest_location = NULL,
00047       CubitVector* unit_normal = NULL );
00048
00049   virtual CubitStatus evaluate( double u, double v,
00050                                 CubitVector *position,
00051                                 CubitVector *unit_normal,
00052                                 CubitVector *curvature1,
00053                                 CubitVector *curvature2 );
00054
00055   CubitStatus closest_point( CubitVector const& pos,
00056                              CubitVector* close = 0, CubitVector* norm = 0,
00057                              CubitVector* curv1 = 0, CubitVector* curv2 = 0);
00058   void closest_point_trimmed( CubitVector from, CubitVector& result );
00059
00060   CubitStatus closest_point_along_vector( CubitVector& from_point,
00061                                           CubitVector& along_vector,
00062                                           CubitVector& point_on_surface);
00063
00064   CubitStatus principal_curvatures( CubitVector const& loc,
00065                                     double& curv1, double& curv2,
00066                                     CubitVector* closest_location=0 );
00067
00068   CubitVector position_from_u_v( double u, double v );
00069   CubitStatus u_v_from_position( CubitVector const& location,
00070                                  double& u, double& v,
00071                                  CubitVector* closest_location = NULL );
00072
00073   CubitBoolean is_periodic();
00074   CubitBoolean is_periodic_in_U( double& period );
00075   CubitBoolean is_periodic_in_V( double& period );
00076   CubitBoolean is_singular_in_U( double u_param );
00077   CubitBoolean is_singular_in_V( double v_param );
00078   CubitBoolean is_closed_in_U();
00079   CubitBoolean is_closed_in_V();
00080
00081   CubitStatus uv_derivitives( double u, double v,
00082                               CubitVector &du, CubitVector &dv );
00083   CubitBoolean is_parametric();
00084   CubitBoolean get_param_range_U( double& lo, double& hi );
00085   CubitBoolean get_param_range_V( double& lo, double& hi );
00086
00087   CubitBoolean is_position_on( CubitVector &test_position );
00088
00089   CubitSense get_geometry_sense();
00090
00091   CubitStatus get_sphere_params( CubitVector &center,
00092                                  double &radius ) const;
00093     //- Only valid for spherical surfaces
00094     //O center
00095     //O- The center of the sphere
00096     //O radius
00097     //O- The radius of the sphere
00098
00099   CubitStatus get_cone_params( CubitVector &center,
00100                                CubitVector &normal,
00101                                CubitVector &major_axis,
00102                                double &radius_ratio,
00103                                double &sine_angle,
00104                                double &cos_angle ) const;
00105     //- Only valid for conical surfaces.  Cylinders are a special case of conicals.
00106     //O center
00107     //O-
00108     //O normal
00109     //O-
00110     //O major_axis
00111     //O-
00112     //O radius_ratio
00113     //O-
00114     //O sine_angle
00115     //O-
00116     //O cos_angle
00117     //O-
00118
00119   virtual CubitStatus get_torus_params( CubitVector &center,
00120                                         CubitVector &normal,
00121                                         double &major_radius,
00122                                         double &minor_radius ) const;
00123     //- Only valid for torus surfaces.
00124     //O center
00125     //O-
00126     //O normal
00127     //O-
00128     //O major_radius
00129     //O-
00130     //O minor_radius
00131     //O-
00132
00133   virtual CubitStatus get_nurb_params( bool &rational,
00134                                        int &degree_u,
00135                                        int &degree_v,
00136                                        int &num_cntrl_pts_u,
00137                                        int &num_cntrl_pts_v,
00138                                        DLIList<CubitVector> &cntrl_pts,
00139                                        DLIList<double> &weights,
00140                                        DLIList<double> &u_knots,
00141                                        DLIList<double> &v_knots ) const;
00142   //- Only valid for nurbs surfaces
00143   //O rational
00144   //O-   True if the nurb is rational
00145   //O degree_u
00146   //O-   The degree of the nurb in the u direction
00147   //O degree_v
00148   //O-   The degree of the nurb in the v direction
00149   //O num_cntrl_pts_u
00150   //O-   Number of control points in the u direction
00151   //O num_cntrl_pts_v
00152   //O-   Number of control points in the v direction
00153   //O cntrl_pts
00154   //O-   The control points stored as
00155   //O-           cntrl_pts[0                ] = pt[u=0][v=0]
00156   //O-           cntrl_pts[1                ] = pt[u=1][v=0]
00157   //O-               ...
00158   //O-           cntrl_pts[num_cntrl_pts_u-1] = pt[u=?][v=0]
00159   //O-           cntrl_pts[num_cntrl_pts_u  ] = pt[u=0][v=1]
00160   //O-               ...
00161   //O weights
00162   //O-   If rational, weights for each control point, stored in the same
00163   //O-   order as the control points.  No weights are returned if
00164   //O-   rational == false
00165   //O u_knots
00166   //O-   knot vector in the u direction
00167   //O v_knots
00168   //O-   knot vector in the v direction
00169
00170   void reverse_sense();
00171
00172 protected:
00173
00174   virtual PartitionSurface* copy();
00175
00176 private:
00177
00178   SubSurface( SubSurface* split_from );
00179 };
00180
00181 inline Surface* SubSurface::partitioned_surface() const
00182   { return dynamic_cast<Surface*>(partitioned_entity()); }
00183
00184
00185 #endif
00186
