cgma
Surface.hpp
00001 //-------------------------------------------------------------------------
00002 // Copyright Notice
00003 //
00004 // Copyright (c) 1996
00005 // by Malcolm J. Panthaki, DBA, and the University of New Mexico.
00006 //-------------------------------------------------------------------------
00007 //
00008 //-------------------------------------------------------------------------
00009 // Filename      : Surface.hpp
00010 //
00011 // Purpose       :
00012 //
00013 // Special Notes :
00014 //
00015 // Creator       : Xuechen Liu
00016 //
00017 // Creation Date : 08/02/96
00018 //
00019 // Owner         : Malcolm J. Panthaki
00020 //-------------------------------------------------------------------------
00021
00022 #ifndef SURFACE_HPP
00023 #define SURFACE_HPP
00024
00025
00026 #include <assert.h>
00027
00028
00029 #include "CubitDefines.h"
00030 #include "GeometryEntity.hpp"
00031
00032
00033 class CubitVector;
00034 template <class X> class DLIList;
00035 class ShellSM;
00036
00037 class CUBIT_GEOM_EXPORT Surface : public GeometryEntity
00038 {
00039    public :
00040
00041       Surface() ;
00042       //- The default constructor
00043
00044       virtual ~Surface() ;
00045       //- The destructor
00046
00047       typedef Curve ChildType;
00048
00049       virtual CubitSense get_shell_sense( ShellSM* shell_ptr ) const = 0;
00050
00051       virtual void closest_point_trimmed(CubitVector from_point,
00052                                          CubitVector& point_on_surface) = 0;
00053       //R void
00054       //I CubitVector
00055       //I- point from which to find closest point on trimmed surface
00056       //O CubitVector
00057       //O- point on trimmed surface closest to passed-in point
00058       //- This function finds the closest point on a TRIMMED surface to the
00059       //- passed-in point.
00060
00061       virtual void closest_points_trimmed(std::vector<CubitVector> &from_points_list,
00062                                           std::vector<CubitVector> &points_on_surface_list);
00063
00064       virtual CubitStatus closest_point_along_vector(CubitVector& from_point,
00065                                          CubitVector& along_vector,
00066                                          CubitVector& point_on_surface) = 0;
00067
00068       virtual CubitStatus get_point_normal( CubitVector& point,
00069                                             CubitVector& normal ) = 0;
00070       //- Only valid for planar surfaces
00071       //- Finds the underlying plane's origin and normal (unit) vector
00072       //- Returns CubitFailure if not a plane.
00073
00074       virtual void param_dir(CubitVector &/*unit_dir_in_world_space*/,
00075         CubitVector &/*pos_on_surf*/, double &/*du*/, double &/*dv*/){}
00076
00077       virtual CubitStatus closest_point_uv_guess(
00078           CubitVector const& location,
00079           double& u_guess, double& v_guess,
00080           CubitVector* closest_location = NULL,
00081           CubitVector* unit_normal = NULL ) = 0;
00082         //R CubitStatus
00083         //I location
00084         //I- Position to evaluate from.
00085         //I u, v
00086         //I- As input, hint as to location of result.
00087         //I- As output, u and v of the result.
00088         //I closest_location
00089         //I- If not null, the closest point to 'location' on the surface.
00090         //I unit_normal
00091         //I- If not null, set to normal at result position.
00092         //- Find closest point on surface, passing a parameter pair
00093         //- near the result point as a hint to the surface evaluator
00094         //- and passing back the paramter pair of the resuling
00095         //- position on the surface.
00096
00097
00098       virtual CubitStatus closest_point(
00099           CubitVector const& location,
00100           CubitVector* closest_location = NULL,
00101           CubitVector* unit_normal = NULL,
00102           CubitVector* curvature1 = NULL,
00103           CubitVector* curvature2 = NULL) = 0;
00104       //R  CubitStatus
00105       //R- CUBIT_SUCCESS/FAILURE
00106       //I location
00107       //I- The point to which the closest point on the surface is desired.
00108       //O closest_location
00109       //O- The point on the Surface, closest to the
00110       //O- input location (which might not be on the Surface).  This is
00111       //O- input as a reference so that the function can modify its
00112       //O- contents.
00113 /*BWC
00114 It says that this is passed in as a reference but it isn't.  My guess is
00115 that it should be a reference and not a pointer.  I will leave it for
00116 now in case I am missing something, but, maybe it should be changed.
00117 BWC*/
00118       //I refvolume_ptr
00119       //I- The first underlying geometric entity is used to compute the
00120       //I- normal.
00121       //O unit_normal
00122       //O- The normal (represented as a unit vector) at the closest_location.
00123       //O- If this pointer is NULL, the normal is not returned.
00124       //O curvature1
00125       //O- The first principal curvature of the Surface at closest_location.
00126       //O- If this pointer is NULL, this curvature is not returned.
00127       //O curvature2
00128       //O- The second principal curvature of the Surface at closest_location.
00129       //O- If this pointer is NULL, this curvature is not returned.
00130       //- This function computes the point on the Surface closest to the input
00131       //- location -- i.e., closest_location.
00132       //-
00133       //- The first  FACE in the list
00134       //- is queried.
00135       //-
00136       //- If the input pointer values of unit_normal, curvature1 and curvature2
00137       //- are non-NULL, the normal and principal curvatures, too, are
00138       //- returned.  These are computed at closest_location, not at the
00139       //- input location.
00140       //-
00141       //- NOTE:
00142       //- It is assumed that if the calling code needs the normal or the
00143       //- principal curvatures, it will *allocate* space for the CubitVectors
00144       //- before sending in the pointers.
00145
00146       virtual CubitStatus closest_points(DLIList<CubitVector *> &location_list,
00147                                    DLIList<CubitVector *> *closest_location_list = NULL,
00148                                    DLIList<CubitVector *> *unit_normal_list = NULL,
00149                                    DLIList<CubitVector *> *curvature1_list = NULL,
00150                                    DLIList<CubitVector *> *curvature2_list = NULL);
00151
00152       virtual CubitStatus principal_curvatures(
00153           CubitVector const& location,
00154           double& curvature_1,
00155           double& curvature_2,
00156           CubitVector* closest_location = NULL ) = 0;
00157       //R CubitStatus
00158       //R- CUBIT_SUCCESS/FAILURE
00159       //I location
00160       //I- The point at which the curvatures are being requested -- it is also
00161       //I- the point to which the closest point on the surface is returned.
00162       //I refvolume_ptr
00163       //O closest_location
00164       //O- The point on the surface, closest to the input location (this
00165       //O- might not be on the surface).  This is input as a reference
00166       //O- so that the function can modify its contents.
00167       //O curvature_1/2
00168       //O- Returned principal curvature magnitudes.
00169       //- This functions computes the point on the surface that is closest
00170       //- to the input location and then calculates the magnitudes of the
00171       //- principal curvatures at this (possibly, new) point on the surface.
00172
00173
00174       virtual CubitStatus evaluate( double u, double v,
00175                             CubitVector *position,
00176                             CubitVector *normal,
00177                             CubitVector *curvature1,
00178                             CubitVector *curvature2 )=0;
00179
00180       // evaluate parameters on a surface
00181       // returns the position on the surface
00182       // returns the first order derivatives: du, dv
00183       // returns the second order derivatives: duu, duv, dvv
00184       virtual CubitStatus evaluate( double u, double v, CubitVector& pos, CubitVector deriv1[2], CubitVector deriv2[3]);
00185
00186      //R CubitStatus
00187       //R- CUBIT_SUCCESS/FAILURE
00188            //I u
00189       //I- The u coordinate value (local parametric space).
00190       //I v
00191       //I- The v coordinate value (local parametric space).
00192       //O- The coordinates of a point in global
00193       //- (world) space that correspond to the input {u,v} point in
00194       //- local parametric space. This is an optional output that is
00195       //- only calculated if the supplied CubitVector is not NULL;
00196       //O-The normal to the surface at the point with the given parametric position.
00197       //- This is an optional output that is only calculated if the
00198       //- supplied CubitVector is not NULL;
00199       //O- The principle curvature directions at the point with the given parametric position.
00200       //- These are optional outputs that are only calculated if the
00201       //- supplied CubitVectors curvature1 and curvature2 are both not NULL;
00202
00203
00204       virtual CubitVector position_from_u_v (double u, double v) = 0;
00205       //R CubitVector
00206       //R- The returned position in global space
00207       //I u
00208       //I- The u coordinate value (local parametric space).
00209       //I v
00210       //I- The v coordinate value (local parametric space).
00211       //- This function returns the coordinates of a point in global
00212       //- (world) space that correspond to the input {u,v} point in
00213       //- local parametric space.
00214
00215       virtual CubitStatus u_v_from_position (
00216                                      CubitVector const& location,
00217                                      double& u,
00218                                      double& v,
00219                                      CubitVector* closest_location = NULL ) = 0;
00220       //R CubitStatus
00221       //R- CUBIT_SUCCESS/FAILURE
00222       //I location
00223       //I- The input point in global space
00224       //O closest_point
00225       //O- The point on the Surface closest to the input location
00226       //O u, v
00227       //O- The returned u, v coordinate values (in local parametric space)
00228       //O- of the closest_point
00229       //- This function returns the {u, v} coordinates of the point
00230       //- on the Surface closest to the input point (specified in global
00231       //- space). The closest_location is also returned.
00232
00233       virtual CubitBoolean is_periodic() = 0;
00234       //R CubitBoolean
00235       //R- CUBIT_TRUE/CUBIT_FALSE
00236       //- This function determines whether the underlying geometry of the
00237       //- Surface is periodic or not.  Returns CUBIT_TRUE if it is and
00238       //- CUBIT_FALSE if it is not.
00239
00240       virtual CubitBoolean is_periodic_in_U( double& period ) = 0;
00241       //R CubitBoolean
00242       //R- CUBIT_TRUE/CUBIT_FALSE
00243       //O period
00244       //O- The value of the period in the U direction.
00245       //- Determines whether the surface object is
00246       //- periodic in the U direction or not.  If it is, it
00247       //- returns CUBIT_TRUE and the value of the period. Otherwise,
00248       //- it returns CUBIT_FALSE and a value of 0.0 or the period.
00249
00250       virtual CubitBoolean is_periodic_in_V( double& period ) = 0;
00251       //R CubitBoolean
00252       //R- CUBIT_TRUE/CUBIT_FALSE
00253       //O period
00254       //O- The value of the period in the V direction.
00255       //- Determines whether the surface object is
00256       //- periodic in the V direction or not.  If it is, it
00257       //- returns CUBIT_TRUE and the value of the period. Otherwise,
00258       //- it returns CUBIT_FALSE and a value of 0.0 or the period.
00259
00260       virtual CubitBoolean is_singular_in_U( double u_param ) = 0;
00261       virtual CubitBoolean is_singular_in_V( double v_param ) = 0;
00262       //R CubitBoolean
00263       //R- CUBIT_TRUE/CUBIT_FALSE
00264       //I double u parameter value.
00265       //- Determines if the surface is singular in a given direction
00266       //- at a given parameter value.
00267
00268       virtual CubitBoolean is_closed_in_U(){return CUBIT_FALSE;}
00269       virtual CubitBoolean is_closed_in_V(){return CUBIT_FALSE;}
00270       //R CubitBoolean
00271       //R- CUBIT_TRUE/CUBIT_FALSE
00272       //- Determines if the surface is closed, smoothly or not in the
00273       //- given parameter direction.
00274       //- A periodic surface is always closed but a closed surface is
00275       //- is not always periodic.
00276       //- For modelars that do allow closed surfaces they will need
00277       //- to implement this functionality.  For instance, Pro does
00278       //- not allow such surfaces so it will always return false.
00279       //-  will so Surface implements its own function.
00280
00281       virtual CubitStatus uv_derivitives( double u_param,
00282                                           double v_param,
00283                                           CubitVector &du,
00284                                           CubitVector &dv ) = 0;
00285       //R CubitStatus
00286       //R- CUBIT_SUCCESS/CUBIT_FAILURE
00287       //O- du, dv
00288       //- Determines the u and v derivitives from the given parameter
00289       //- values.
00290
00291       virtual CubitBoolean is_parametric() = 0;
00292       //R CubitBoolean
00293       //R- CUBIT_TRUE/CUBIT_FALSE
00294       //- This function determines whether the underlying geometry of the
00295       //- Surface is parametrically defined or not.  Returns CUBIT_TRUE if
00296       //- it is and CUBIT_FALSE if it is not.
00297
00298
00299
00300       virtual CubitBoolean get_param_range_U( double& lower_bound,
00301                                               double& upper_bound ) = 0;
00302       //R CubitBoolean
00303       //R- CUBIT_TRUE/CUBIT_FALSE
00304       //O lower_bound
00305       //O- The lower bound of the parametric range in the U direction.
00306       //O- This is set to 0.0 if the surface is not parametric.
00307       //O upper_bound
00308       //O- The upper bound of the parametric range in the U direction.
00309       //O- This is set to 0.0 if the surface is not parametric.
00310       //- Returns the lower and upper parametric bounds of the
00311       //- surface in U, if it is parametric.  Otherwise, it returns
00312       //- CUBIT_FALSE and zeroes for the upper and lower parametric
00313       //- bounds.
00314
00315       virtual CubitBoolean get_param_range_V( double& lower_bound,
00316                                               double& upper_bound ) = 0;
00317       //R CubitBoolean
00318       //R- CUBIT_TRUE/CUBIT_FALSE
00319       //O lower_bound
00320       //O- The lower bound of the parametric range in the V direction.
00321       //O- This is set to 0.0 if the surface is not parametric.
00322       //O upper_bound
00323       //O- The upper bound of the parametric range in the V direction.
00324       //O- This is set to 0.0 if the surface is not parametric.
00325       //- Returns the lower and upper parametric bounds of the
00326       //- surface in V, if it is parametric.  Otherwise, it returns
00327       //- CUBIT_FALSE and zeroes for the upper and lower parametric
00328       //- bounds.
00329
00330       virtual CubitBoolean is_position_on( CubitVector &test_position ) = 0;
00331       //R CubitBoolean
00332       //R- CUBIT_TRUE/CUBIT_FALSE
00333       //I CubitVector
00334       //I- position, point where we want to test, whether or not it
00335       //- is on the surface.
00336       virtual void are_positions_on( DLIList<CubitVector *> &test_position_list,
00337                                      DLIList<CubitBoolean *> &is_on_list );
00338
00339       virtual CubitPointContainment point_containment( const CubitVector &point ) = 0;
00340       virtual CubitPointContainment point_containment( double u, double v ) = 0;
00341       //R CubitPointContainment - is the point outside, inside or on the boundary?
00342       //R- CUBIT_PNT_OUTSIDE, CUBIT_PNT_INSIDE, CUBIT_PNT_BOUNDARY,
00343       //   CUBIT_PNT_UNKNOWN
00344       //I CubitVector
00345       //I- position to check, known to be on the Surface
00346       //I double
00347       //I- u coordinate, if known (significantly faster, if this is known - however
00348       //                           if not known let the function figure it out)
00349       //I double
00350       //I- v coordinate, if known (significantly faster, if this is known - however
00351       //                           if not known let the function figure it out)
00352
00353       virtual CubitSense get_geometry_sense() = 0;
00354       //- Returns the relative sense of the Surface with respect
00355       //- to the geometry underneath.  This is geometry engine dependent.
00356       //- Currently this is used for the tet mesher...
00357
00358       virtual CubitSense get_uv_sense()
00359       {
00360         return CUBIT_UNKNOWN;
00361       }
00362
00363       virtual CubitStatus get_projected_distance_on_surface( CubitVector *pos1,
00364                                                              CubitVector *pos2,
00365                                                              double &distance ) = 0;
00366
00367
00368       virtual GeometryType geometry_type()
00369       {return UNDEFINED_SURFACE_TYPE;};
00370       //R GeometryType (enum)
00371       //R- The enumerated type of the geometric representation
00372
00373       virtual GeometryType is_cylindrical()
00374       {return UNDEFINED_SURFACE_TYPE;};
00375       //R GeometryType (enum)
00376       //R- CYLINDRICAL_SURFACE_TYPE if true UNDEFINED_SURFACE_TYPE if false
00377
00378       // Now handled at RefFace level.  -- j.k. Oct, 2003
00379       //virtual void reverse_sense() = 0;
00380       //- Switch the sense of this Surface wrt the RefFace that owns it.
00381
00382       virtual CubitStatus get_nurb_params( bool &rational,
00383                                            int &degree_u,
00384                                            int &degree_v,
00385                                            int &num_cntrl_pts_u,
00386                                            int &num_cntrl_pts_v,
00387                                            DLIList<CubitVector> &cntrl_pts,
00388                                            DLIList<double> &weights,
00389                                            DLIList<double> &u_knots,
00390                                            DLIList<double> &v_knots ) const = 0;
00391       //- Only valid for nurbs surfaces
00392       //O rational
00393       //O-   True if the nurb is rational
00394       //O degree_u
00395       //O-   The degree of the nurb in the u direction
00396       //O degree_v
00397       //O-   The degree of the nurb in the v direction
00398       //O num_cntrl_pts_u
00399       //O-   Number of control points in the u direction
00400       //O num_cntrl_pts_v
00401       //O-   Number of control points in the v direction
00402       //O cntrl_pts
00403       //O-   The control points stored as
00404       //O-           cntrl_pts[0                ] = pt[u=0][v=0]
00405       //O-           cntrl_pts[1                ] = pt[u=1][v=0]
00406       //O-               ...
00407       //O-           cntrl_pts[num_cntrl_pts_u-1] = pt[u=?][v=0]
00408       //O-           cntrl_pts[num_cntrl_pts_u  ] = pt[u=0][v=1]
00409       //O-               ...
00410       //O weights
00411       //O-   If rational, weights for each control point, stored in the same
00412       //O-   order as the control points.  No weights are returned if
00413       //O-   rational == false
00414       //O u_knots
00415       //O-   knot vector in the u direction
00416       //O v_knots
00417       //O-   knot vector in the v direction
00418
00419       virtual CubitStatus get_sphere_params( CubitVector &center,
00420                                              double &radius ) const = 0;
00421       //- Only valid for spherical surfaces
00422       //O center
00423       //O- The center of the sphere
00424       //O radius
00425       //O- The radius of the sphere
00426
00427       virtual CubitStatus get_cone_params( CubitVector &center,
00428                                            CubitVector &normal,
00429                                            CubitVector &major_axis,
00430                                            double &radius_ratio,
00431                                            double &sine_angle,
00432                                            double &cos_angle ) const = 0;
00433       //- Only valid for conical surfaces.  Cylinders are a special case of conicals.
00434       //O center
00435       //O-
00436       //O normal
00437       //O-
00438       //O major_axis
00439       //O-
00440       //O radius_ratio
00441       //O-
00442       //O sine_angle
00443       //O-
00444       //O cos_angle
00445       //O-
00446
00447       virtual CubitStatus get_torus_params( CubitVector &center,
00448                                             CubitVector &normal,
00449                                             double &major_radius,
00450                                             double &minor_radius ) const = 0;
00451       //- Only valid for torus surfaces.
00452       //O center
00453       //O-
00454       //O normal
00455       //O-
00456       //O major_radius
00457       //O-
00458       //O minor_radius
00459       //O-
00460
00461    protected:
00462
00463    private:
00464
00465 } ;
00466
00467
00468 #endif
00469
