cgma
BoundingBoxTool Class Reference
Class for bounding boxes (primarily for "tight" bounding boxes). More...
#include <BoundingBoxTool.hpp>
List of all members.
Static Public Member Functions
static CubitStatus get_tight_bounding_box (DLIList< RefEntity * > &ref_entity_list, CubitVector &center, CubitVector axes[3], CubitVector &extension, double ang_facet_tol, double abs_facet_tol)
static CubitStatus get_axis_bounding_box (DLIList< RefEntity * > &ref_entity_list, CubitVector &center, CubitVector axes[3], CubitVector &extension)
static CubitStatus get_corner_points (CubitVector &center, CubitVector axes[3], CubitVector &extension, CubitVector &p1, CubitVector &p2, CubitVector &p3, CubitVector &p4, CubitVector &p5, CubitVector &p6, CubitVector &p7, CubitVector &p8)
 Using the center, axes and extension, gets the 8 corners of the box.
static CubitBoolean get_use_triangles ()
static void set_use_triangles (CubitBoolean val)
static int get_use_triangles_setting ()
static void set_use_triangles_setting (int val)
static CubitBoolean get_use_curves ()
static void set_use_curves (CubitBoolean val)
static int get_use_curves_setting ()
static void set_use_curves_setting (int val)
static CubitBoolean get_use_vertices ()
static void set_use_vertices (CubitBoolean val)
static int get_use_vertices_setting ()
static void set_use_vertices_setting (int val)
static void initialize_settings ()
 Initialize all settings in this class.
Protected Member Functions
 ~BoundingBoxTool ()
 BoundingBoxTool ()
Static Private Member Functions
static CubitStatus append_ref_entity_points (DLIList< RefEntity * > &ref_entity_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol)
static CubitStatus append_body_points (DLIList< Body * > &body_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol)
static CubitStatus append_volume_points (DLIList< RefVolume * > &vol_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol)
static CubitStatus append_curve_points (DLIList< RefEdge * > &ref_edge_list, DLIList< CubitVector * > &vec_list)
static CubitStatus append_vertex_points (DLIList< RefVertex * > &ref_vertex_list, DLIList< CubitVector * > &vec_list)
static CubitStatus append_surface_points (DLIList< RefFace * > &ref_face_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol)
static CubitBoolean expand_groups_in_list (DLIList< RefEntity * > &ref_entity_list)
Static Private Attributes
static CubitBoolean useTriangles = CUBIT_TRUE
static CubitBoolean useCurves = CUBIT_FALSE
static CubitBoolean useVertices = CUBIT_FALSE
Detailed Description
Definition at line 25 of file BoundingBoxTool.hpp.
Definition at line 32 of file BoundingBoxTool.cpp.
Definition at line 28 of file BoundingBoxTool.cpp.
Member Function Documentation
CubitStatus BoundingBoxTool::append_body_points ( DLIList< Body * > &  body_list,
DLIList< CubitVector * > &  vec_list,
double  ang_tol,
double  abs_tol
) [static, private]
Definition at line 147 of file BoundingBoxTool.cpp.
   int i;
   Body *body_ptr;
   DLIList<RefFace*> ref_face_list;
   body_list.reset();
   for( i=0; i<body_list.size(); i++ )
      body_ptr = body_list.get_and_step();
      DLIList<RefFace*> ref_face_list_tmp;
      body_ptr->ref_faces( ref_face_list_tmp );
      ref_face_list.merge_unique( ref_face_list_tmp );
   append_surface_points( ref_face_list, vec_list, ang_tol, abs_tol);
   return CUBIT_SUCCESS;
CubitStatus BoundingBoxTool::append_curve_points ( DLIList< RefEdge * > &  ref_edge_list,
) [static, private]
Definition at line 261 of file BoundingBoxTool.cpp.
   // First grab all the vertices and append their coordinates to vec_list.
   // Then do the curves, but just put inside points in.  This avoids duplicate
   // points at the vertices.
   int i;
   RefEdge *ref_edge_ptr;
   DLIList<RefVertex*> ref_vertex_list;
   ref_edge_list.reset();
   for( i=0; i<ref_edge_list.size(); i++ )
      ref_edge_ptr = ref_edge_list.get_and_step();
      DLIList<RefVertex*> ref_vertex_list_temp;
      ref_edge_ptr->ref_vertices( ref_vertex_list_temp );
      ref_vertex_list.merge_unique( ref_vertex_list_temp );
   append_vertex_points( ref_vertex_list, vec_list );
   // Now add the *inside* curve points
   int j, num_pnts;
      GMem *g_mem = new GMem;
      ref_edge_ptr->get_graphics( *g_mem );
      num_pnts = g_mem->pointListCount;
      GPoint* point_list = g_mem->point_list();
      for( j=1; j<num_pnts-1; j++ )
         CubitVector* cubit_vector_ptr = new CubitVector(
            point_list[j].x, point_list[j].y, point_list[j].z );
         vec_list.append( cubit_vector_ptr );
      delete g_mem;
CubitStatus BoundingBoxTool::append_ref_entity_points ( DLIList< RefEntity * > &  ref_entity_list,
double  ang_tol,
double  abs_tol
) [static, private]
Definition at line 114 of file BoundingBoxTool.cpp.
   DLIList<Body*> body_list;
   CAST_LIST( ref_entity_list, body_list, Body );
   if( body_list.size() )
      append_body_points( body_list, vec_list, ang_facet_tol, abs_facet_tol );
   DLIList<RefVolume*> vol_list;
   CAST_LIST( ref_entity_list, vol_list, RefVolume );
   if( vol_list.size() )
      append_volume_points( vol_list, vec_list, ang_facet_tol, abs_facet_tol );
   DLIList<RefFace*> surface_list;
   CAST_LIST( ref_entity_list, surface_list, RefFace );
   if( surface_list.size() )
      append_surface_points( surface_list, vec_list, ang_facet_tol, abs_facet_tol );
   DLIList<RefEdge*> curve_list;
   CAST_LIST( ref_entity_list, curve_list, RefEdge );
   if( curve_list.size() )
      append_curve_points( curve_list, vec_list );
   DLIList<RefVertex*> vertex_list;
   CAST_LIST( ref_entity_list, vertex_list, RefVertex );
   if( vertex_list.size() )
      append_vertex_points( vertex_list, vec_list );
CubitStatus BoundingBoxTool::append_surface_points ( DLIList< RefFace * > &  ref_face_list,
double  ang_tol,
double  abs_tol
) [static, private]
Definition at line 197 of file BoundingBoxTool.cpp.
   int i;
   RefFace *ref_face_ptr;
   DLIList<RefEdge*> ref_edge_list;
   ref_face_list.reset();
   for( i=0; i<ref_face_list.size(); i++ )
      ref_face_ptr = ref_face_list.get_and_step();
      if( useTriangles == CUBIT_TRUE )
         int num_pnt;
         ref_face_ptr->get_graphics( *g_mem, (int)ang_tol, abs_tol );
         num_pnt = g_mem->pointListCount;
         //int num_pnts = g_mem->point_list_size();
         int y;
         for( y=0; y<num_pnt; y++ )
               point_list[y].x, point_list[y].y, point_list[y].z );
         delete g_mem;
      if( useCurves == CUBIT_TRUE )
         // Grab the curves from the surface
         DLIList<RefEdge*> ref_edge_list_tmp;
         ref_face_ptr->ref_edges( ref_edge_list_tmp );
         ref_edge_list.merge_unique( ref_edge_list_tmp );
      // Only need vertices if both surfaces and curves are false
      if( useTriangles == CUBIT_FALSE && useCurves == CUBIT_FALSE &&
         useVertices == CUBIT_TRUE )
         // Grab the vertices from the surface
         DLIList<RefVertex*> ref_vertex_list_tmp;
         ref_face_ptr->ref_vertices( ref_vertex_list_tmp );
         ref_vertex_list.merge_unique( ref_vertex_list_tmp );
      append_curve_points( ref_edge_list, vec_list );
CubitStatus BoundingBoxTool::append_vertex_points ( DLIList< RefVertex * > &  ref_vertex_list,
) [static, private]
Definition at line 308 of file BoundingBoxTool.cpp.
   int i;
   RefVertex *ref_vertex_ptr;
   ref_vertex_list.reset();
   for( i=0; i<ref_vertex_list.size(); i++ )
      ref_vertex_ptr = ref_vertex_list.get_and_step();
      CubitVector coords = ref_vertex_ptr->coordinates();
      CubitVector* cubit_vector_ptr = new CubitVector( coords );
CubitStatus BoundingBoxTool::append_volume_points ( DLIList< RefVolume * > &  vol_list,
double  ang_tol,
double  abs_tol
) [static, private]
Definition at line 172 of file BoundingBoxTool.cpp.
   int i;
   RefVolume *vol_ptr;
   vol_list.reset();
   for( i=0; i<vol_list.size(); i++ )
      vol_ptr = vol_list.get_and_step();
      vol_ptr->ref_faces( ref_face_list_tmp );
CubitBoolean BoundingBoxTool::expand_groups_in_list ( DLIList< RefEntity * > &  ref_entity_list) [static, private]
Definition at line 394 of file BoundingBoxTool.cpp.
   CubitBoolean group_found = CUBIT_FALSE;
   // just have to step through original entity_list, not the expanded list
   for (int i = ref_entity_list.size(); i>0; i--)
      RefEntity *entity = ref_entity_list.get();
      RefGroup *group = CAST_TO( entity, RefGroup );
      if ( group )
         ref_entity_list.remove();
         group->expand_group( ref_entity_list );
         group_found = CUBIT_TRUE;
      else
         ref_entity_list.step();
   return group_found;
CubitStatus BoundingBoxTool::get_axis_bounding_box ( DLIList< RefEntity * > &  ref_entity_list,
CubitVector center,
CubitVector extension
) [static]
Convenience function to get an axis box in the same output format as a tight box.
Definition at line 68 of file BoundingBoxTool.cpp.
   CubitBoolean bounding_box_found = CUBIT_FALSE;
   CubitBox bounding_box;
   // Expand out groups in the list
   DLIList<RefEntity*> ref_entity_list_expanded = ref_entity_list;
   expand_groups_in_list( ref_entity_list_expanded );
   ref_entity_list_expanded.reset();
   for( int i = ref_entity_list_expanded.size(); i>0; i-- )
      RefEntity* ref_entity_ptr = ref_entity_list_expanded.get_and_step();
      if( bounding_box_found == CUBIT_FALSE )
         bounding_box = ref_entity_ptr->bounding_box();
         bounding_box_found = CUBIT_TRUE;
      else {
         bounding_box |= ref_entity_ptr->bounding_box();
   axes[0].set( 1.0, 0.0, 0.0 );
   axes[1].set( 0.0, 1.0, 0.0 );
   axes[2].set( 0.0, 0.0, 1.0 );
   if( bounding_box_found )
      extension.set( bounding_box.x_range()/2.0, bounding_box.y_range()/2.0,
         bounding_box.z_range()/2.0 );
      center = bounding_box.center();
   else
      extension.set( 0.0, 0.0, 0.0 );
      center.set( 0.0, 0.0, 0.0 );
CubitStatus BoundingBoxTool::get_corner_points ( CubitVector center,
CubitVector extension,
CubitVector p1,
CubitVector p2,
CubitVector p3,
CubitVector p4,
CubitVector p5,
CubitVector p6,
CubitVector p7,
CubitVector p8
) [static]
Definition at line 326 of file BoundingBoxTool.cpp.
   double x = extension.x(); double y = extension.y(); double z = extension.z();
   // Front, Bottom, Left
   center.next_point( -axes[0], x, p1 ); p1.next_point( -axes[1], y, p1 );
   p1.next_point( axes[2], z, p1 );
   // Front, Top, Left
   center.next_point( -axes[0], x, p2 ); p2.next_point( axes[1], y, p2 );
   p2.next_point( axes[2], z, p2 );
   // Front, Top, Right
   center.next_point( axes[0], x, p3 ); p3.next_point( axes[1], y, p3 );
   p3.next_point( axes[2], z, p3 );
   // Front, Bottom, Right
   center.next_point( axes[0], x, p4 ); p4.next_point( -axes[1], y, p4 );
   p4.next_point( axes[2], z, p4 );
   // Back, Bottom, Left
   center.next_point( -axes[0], x, p5 ); p5.next_point( -axes[1], y, p5 );
   p5.next_point( -axes[2], z, p5 );
   // Back, Top, Left
   center.next_point( -axes[0], x, p6 ); p6.next_point( axes[1], y, p6 );
   p6.next_point( -axes[2], z, p6 );
   // Back, Top, Right
   center.next_point( axes[0], x, p7 ); p7.next_point( axes[1], y, p7 );
   p7.next_point( -axes[2], z, p7 );
   // Back, Bottom, Right
   center.next_point( axes[0], x, p8 ); p8.next_point( -axes[1], y, p8 );
   p8.next_point( -axes[2], z, p8 );
CubitStatus BoundingBoxTool::get_tight_bounding_box ( DLIList< RefEntity * > &  ref_entity_list,
CubitVector center,
) [static]
Gets tightest box around the given entity list, using facets. Box is defined as center point, vector axes (unit vectors), and extension in each axis (x extension is 1/2 width of box, for example).
Definition at line 36 of file BoundingBoxTool.cpp.
   DLIList<CubitVector*> vec_list;
   // Get the facet points from all the objects in the list
   append_ref_entity_points( ref_entity_list_expanded, vec_list, ang_facet_tol, abs_facet_tol );
   // Get the smallest box that fits around the points making up the facetted geometry
   AnalyticGeometryTool::instance()->get_tight_bounding_box( vec_list, center,
                                                             axes, extension );
   // Free memory
   for( int i=0; i<vec_list.size(); i++ )
         vec_list.get_and_step();
      delete cubit_vector_ptr;
If curves are used, curve tesselation points will be included in the point list used to calculate the tight bounding box. This includes the vertices on the ends of the curves. One use for this is to find a more accurate tight bounding box, since curve tessellations are typically more fine than surface tessellations. However, in practice, I would generally recommend just using surface tessellations. One special case is if the user sends in a list of curves as the criteria for the tight bounding box, the curve
Definition at line 440 of file BoundingBoxTool.cpp.
{return useCurves;}
Definition at line 421 of file BoundingBoxTool.cpp.
{return useCurves;}
If triangles are used, surface facet points will be included in the point list used to calculate the tight bounding box. This will include vertices and points on the curves. This is the default implementation.
Definition at line 434 of file BoundingBoxTool.cpp.
{return useTriangles;}
Definition at line 415 of file BoundingBoxTool.cpp.
If vertices are used, vertex points will be included in the point list used to calculate the tight bounding box. In extremely large models, it could be advantageous to just use vertices. So the user would turn off both the surface and curve flags. One special case is if the user sends in a list of curves as the criteria for the tight bounding box, the curve tessellations are always used, even if the curve parameter is false and this parameter is true.
Definition at line 446 of file BoundingBoxTool.cpp.
{return useVertices;}
Definition at line 427 of file BoundingBoxTool.cpp.
Definition at line 443 of file BoundingBoxTool.cpp.
{useCurves=val;}
void BoundingBoxTool::set_use_curves_setting ( int  val) [static]
Definition at line 424 of file BoundingBoxTool.cpp.
Definition at line 437 of file BoundingBoxTool.cpp.
{useTriangles=val;}
void BoundingBoxTool::set_use_triangles_setting ( int  val) [static]
Definition at line 418 of file BoundingBoxTool.cpp.
Definition at line 449 of file BoundingBoxTool.cpp.
{useVertices=val;}
void BoundingBoxTool::set_use_vertices_setting ( int  val) [static]
Definition at line 430 of file BoundingBoxTool.cpp.
Member Data Documentation
Definition at line 131 of file BoundingBoxTool.hpp.
Definition at line 130 of file BoundingBoxTool.hpp.
Definition at line 132 of file BoundingBoxTool.hpp.
