cgma
CGMReadParallel Class Reference
#include <CGMReadParallel.hpp>
List of all members.
Public Types
enum  ParallelLoadOption { BCAST, BCAST_AND_DELETE, SCATTER }
enum  CGMParallelOpts {
  POPT_NONE = 0, POPT_READ, POPT_READ_DELETE, POPT_BCAST,
  POPT_BCAST_DELETE, PORT_SCATTER, PORT_SCATTER_DELETE, POPT_READ_PARALLEL,
  POPT_FORMAT, POPT_DEFAULT
Public Member Functions
 CGMReadParallel (GeometryQueryTool *gqt=NULL, CGMParallelComm *pc=NULL)
CubitStatus load_file (const char *file_names, const char *options, const char *set_tag_name=0, const int *set_tag_values=0, int num_set_tag_values=0)
CubitStatus load_file (const char *file_name, int parallel_mode, std::string &partition_tag_name, std::vector< int > &partition_tag_vals, std::vector< int > &pa_vec, const CGMFileOptions &opts, const char *set_tag_name, const int *set_tag_values, const int num_set_tag_values, const int reader_rank, const bool surf_partition)
void set_reader (unsigned int reader)
Static Public Attributes
static const char * CGMparallelOptsNames []
static const char * CGMpartitionOptsNames []
Private Member Functions
CubitStatus read_entities (const char *file_name)
CubitStatus balance_round_robin ()
CubitStatus delete_nonlocal_entities (int reader, std::string &ptag_name, std::vector< int > &ptag_vals)
CubitStatus check_partition_info ()
Private Attributes
GeometryQueryToolm_gqt
CGMParallelCommm_pcomm
bool m_scatter
bool m_reader
unsigned int m_rank
unsigned int m_proc_size
BALANCE_METHOD m_bal_method
DLIList< RefEntity * > m_surf_entity_list
Detailed Description
Definition at line 16 of file CGMReadParallel.hpp.
Member Enumeration Documentation
Enumerator:
POPT_NONE
POPT_READ
POPT_READ_DELETE
POPT_BCAST
POPT_BCAST_DELETE
PORT_SCATTER
PORT_SCATTER_DELETE
POPT_READ_PARALLEL
POPT_FORMAT
POPT_DEFAULT
Definition at line 47 of file CGMReadParallel.hpp.
Enumerator:
BCAST
BCAST_AND_DELETE
SCATTER
Definition at line 22 of file CGMReadParallel.hpp.
Member Function Documentation
Definition at line 384 of file CGMReadParallel.cpp.
  // get bodies
  int i, j, k;
  DLIList<RefEntity*>& body_entity_list = m_pcomm->partition_body_list();
  int n_proc = m_proc_size;
  double* loads = new double[n_proc]; // estimated loads for each processor
  double* ve_loads = new double[n_proc]; // estimated loads for each processor
  for (i = 0; i < n_proc; i++) {
    loads[i] = 0.0;
    ve_loads[i] = 0.0;
  if (m_bal_method == ROUND_ROBIN) { // round-robin case
    int n_entity = body_entity_list.size();
    int n_entity_proc = n_entity / n_proc; // # of entities per processor
    int i_entity_proc = n_entity_proc; // entity index limit for each processor
    int proc = 0;
    RefEntity* entity;
    // assign processors to bodies
    body_entity_list.reset();
    for (i = 0; i < n_entity; i++) {
      if (i == i_entity_proc) {
        proc++;
        if (proc < n_proc)
          i_entity_proc += n_entity_proc;
        else {
          proc %= n_proc;
          i_entity_proc++;
      // assign to bodies
      entity = body_entity_list.get_and_step();
      DLIList<int> shared_procs;
      shared_procs.append(proc);
      TDParallel *td_par = (TDParallel *) entity->get_TD(
          &TDParallel::is_parallel);
      if (td_par == NULL)
        td_par = new TDParallel(entity, NULL, &shared_procs);
      loads[proc] += entity->measure();
      // assign to volumes, it should be removed in future
      DLIList<RefVolume*> volumes;
      (dynamic_cast<TopologyEntity*>(entity))->ref_volumes(volumes);
      int n_vol = volumes.size();
      volumes.reset();
      for (j = 0; j < n_vol; j++) {
        RefEntity *vol = volumes.get_and_step();
        td_par = (TDParallel *) vol->get_TD(&TDParallel::is_parallel);
        if (td_par == NULL)
          td_par = new TDParallel(vol, NULL, &shared_procs);
      // add local surface load
      DLIList<RefFace*> faces;
      (dynamic_cast<TopologyEntity*>(entity))->ref_faces(faces);
      int n_face = faces.size();
      faces.reset();
      for (j = 0; j < n_face; j++) {
        RefFace* face = faces.get_and_step();
        TopologyEntity *te = CAST_TO(face, TopologyEntity);
        if (te->bridge_manager()->number_of_bridges() < 2) {
          loads[proc] = loads[proc] + face->measure();
    // Get all child entities
    DLIList<RefEntity*> child_list;
    RefEntity::get_all_child_ref_entities(body_entity_list, child_list);
    int n_child = child_list.size();
    // assign processors to interface entities
    child_list.reset();
    for (i = 0; i < n_child; i++) {
      entity = child_list.get_and_step();
      TopologyEntity *te = CAST_TO(entity, TopologyEntity);
      if (te->bridge_manager()->number_of_bridges() > 1) {
        DLIList<Body*> parent_bodies;
        (dynamic_cast<TopologyEntity*>(entity))->bodies(parent_bodies);
        int n_parent = parent_bodies.size();
        for (j = 0; j < n_parent; j++) {
          RefEntity *parent_vol = CAST_TO(parent_bodies.get_and_step(),
              RefEntity);
          TDParallel *parent_td = (TDParallel *) parent_vol->get_TD(
          if (parent_td == NULL) {
            PRINT_ERROR("parent Volume has to be partitioned.");
            return CUBIT_FAILURE;
          shared_procs.append_unique(parent_td->get_charge_proc());
        if (shared_procs.size() > 1) { // if it is interface
          if (td_par == NULL) {
            int merge_id = TDUniqueId::get_unique_id(entity);
            if (entity->entity_type_info() == typeid(RefFace)) { // face
              if (shared_procs.size() != 2) {
                PRINT_ERROR(
                    "Error: # of shared processors of interface surface should be 2.");
              // balance interface surface loads
              if (loads[shared_procs[0]] > loads[shared_procs[1]]) {
                shared_procs.reverse();
              loads[shared_procs[0]] = loads[shared_procs[0]]
                  + entity->measure();
              td_par = new TDParallel(entity, NULL, &shared_procs, NULL,
                  merge_id, 1);
            } else if (entity->entity_type_info() == typeid(RefEdge)
                || entity->entity_type_info() == typeid(RefVertex)) {
              int min_p = shared_procs[0];
              int n_shared_proc = shared_procs.size();
              for (int i1 = 1; i1 < n_shared_proc; i1++) {
                if (ve_loads[shared_procs[i1]] < ve_loads[min_p]) {
                  min_p = shared_procs[i1];
              ve_loads[min_p] = ve_loads[min_p] + entity->measure();
              shared_procs.remove(min_p);
              shared_procs.insert_first(min_p);
              // add ghost geometries to shared processors for edge
              if (entity->entity_type_info() == typeid(RefEdge)) {
                parent_bodies.reset();
                      RefEntity);
                  for (k = 0; k < n_shared_proc; k++) {
                    parent_td->add_ghost_proc(shared_procs[k]);
                  merge_id, 1);
  } else if (m_bal_method == PARTITION_DYNAMIC) {
  return CUBIT_SUCCESS;
Definition at line 619 of file CGMReadParallel.cpp.
  int i;
  int nEntity = body_entity_list.size();
  for (i = 0; i < nEntity; i++) {
    RefEntity* entity = body_entity_list.get_and_step();
    if (td_par == NULL) { // if body is not partitioned
      DLIList<RefEntity*> volumes;
      entity->get_child_ref_entities(volumes);
      // check if the first Volume is partitioned here, should be removed in future
      volumes.reset();
      RefEntity *vol = volumes.get();
      if (vol == NULL || vol->entity_type_info() != typeid(RefVolume)) {
        PRINT_ERROR("Partitioned Body should have at least one Volume.");
        PRINT_ERROR("Partitioned Volume should have TDParallel data.");
      DLIList<int> s_procs;
      s_procs.append(td_par->get_charge_proc());
      td_par = new TDParallel(entity, NULL, &s_procs);
CubitStatus CGMReadParallel::delete_nonlocal_entities ( int  reader,
std::string &  ptag_name,
std::vector< int > &  ptag_vals
) [private]
Definition at line 542 of file CGMReadParallel.cpp.
  // find bodies deleted
  int i;
  DLIList<RefEntity*> partition_list, delete_body_list;
    if (td_par->get_charge_proc() != m_rank) { // candidate to be deleted
      // check child surfaces if surface partitioned
      DLIList<RefFace*> face_list;
      (dynamic_cast<TopologyEntity*>(entity))->ref_faces(face_list);
      bool b_partitioned_surf = false;
      int n_face = face_list.size();
      face_list.reset();
      for (int j = 0; j < n_face; j++) {
        RefEntity* face = face_list.get_and_step();
        TDParallel *td_par_face = (TDParallel *) face->get_TD(
        if (td_par_face != NULL) { // if surface is partitioned
          DLIList<int>* shared_procs = td_par_face->get_shared_proc_list();
          int n_shared = shared_procs->size();
          shared_procs->reset();
          for (int k = 0; k < n_shared; k++) {
            if (shared_procs->get_and_step() == (int) m_rank) {
              b_partitioned_surf = true;
              break;
      if (b_partitioned_surf)
        partition_list.append(entity);
      else
        delete_body_list.append(entity);
    } else
  // print info
  char pre_body[100];
  DLIList<CubitEntity*> tmp_body_list;
  if (CGM_read_parallel_debug) {
    if ((int) m_rank != reader) {
      CAST_LIST_TO_PARENT(delete_body_list, tmp_body_list);
      sprintf(pre_body, "Will delete %d Bodies: ", tmp_body_list.size());
      CubitUtil::list_entity_ids(pre_body, tmp_body_list);
    std::cout << "Partitioned Body list size after delete: "
        << partition_list.size() << std::endl;
  // delete bodies
  nEntity = delete_body_list.size();
  delete_body_list.reset();
    GeometryQueryTool::instance()->delete_RefEntity(
        delete_body_list.get_and_step());
  // update Body list in ParallelComm
  body_entity_list.clean_out();
  body_entity_list += partition_list;
CubitStatus CGMReadParallel::load_file ( const char *  file_names,
const char *  options,
const char *  set_tag_name = 0,
const int *  set_tag_values = 0,
int  num_set_tag_values = 0
Definition at line 66 of file CGMReadParallel.cpp.
  CGMFileOptions opts(options);
  // Get parallel settings
  int parallel_mode;
  CGMFOErrorCode result = opts.match_option("PARALLEL", CGMparallelOptsNames,
      parallel_mode);
  if (FO_FAILURE == result) {
    PRINT_ERROR("Unexpected value for 'PARALLEL' option\n");
  } else if (FO_ENTITY_NOT_FOUND == result) {
    parallel_mode = 0;
  bool surf_partition = false;
  std::string partition_tag_name;
  std::vector<int> partition_tag_vals;
  // Get partition tag value(s), if any, and whether they're to be
  result = opts.get_ints_option("PARTITION_VAL", partition_tag_vals);
  // Get partition setting
  result = opts.get_option("PARTITION", partition_tag_name);
  if (FO_ENTITY_NOT_FOUND == result || partition_tag_name.empty()) {
    partition_tag_name = "GEOM_DIMENSION";
    m_bal_method = ROUND_ROBIN;
  } else {
    // use geom dimension for partition
    if (partition_tag_name == "GEOM_DIMENSION") {
      int geom_dim = 0;
      for (std::vector<int>::iterator pit = partition_tag_vals.begin();
          pit != partition_tag_vals.end(); pit++) {
        geom_dim = *pit;
        if (geom_dim == 2)
          surf_partition = true; // body & surface partition
        else if (geom_dim == 3)
          surf_partition = false; // body partition only
        else {
          PRINT_ERROR("Geometry dimension %d is not supported.\n", geom_dim);
    // static partition, use chaco
    else if (partition_tag_name == "PAR_PARTITION_STATIC") {
      m_bal_method = PARTITION_STATIC;
    // dynamic partition, use zoltan
    else if (partition_tag_name == "PAR_PARTITION_DYNAMIC") {
      m_bal_method = PARTITION_DYNAMIC;
    // round-robin
    result = opts.get_null_option("PARTITION_DISTRIBUTE");
    if (FO_SUCCESS == result)
  // get MPI IO processor rank
  int reader_rank;
  result = opts.get_int_option("MPI_IO_RANK", reader_rank);
    reader_rank = 0;
  else if (FO_SUCCESS != result) {
    PRINT_ERROR("Unexpected value for 'MPI_IO_RANK' option\n");
  m_pcomm->proc_config().set_master(reader_rank); // set master processor
  bool reader = (reader_rank == (int) m_rank);
  // now that we've parsed all the parallel options, make an instruction
  // queue
  std::vector<int> pa_vec;
  switch (parallel_mode) {
  case POPT_READ:
    pa_vec.push_back(PA_READ);
    pa_vec.push_back(PA_BALANCE);
    break;
  case POPT_DEFAULT:
  case POPT_READ_DELETE:
    pa_vec.push_back(PA_DELETE_NONLOCAL);
    break;
  case POPT_BCAST:
    if (reader) {
    pa_vec.push_back(PA_BROADCAST);
    break;
  case POPT_BCAST_DELETE:
    if (reader) {
    break;
  case PORT_SCATTER:
    if (reader) {
    pa_vec.push_back(PA_SCATTER);
    m_scatter = true;
    break;
  case POPT_FORMAT:
    PRINT_ERROR("Access to format-specific parallel read not implemented.\n");
  case POPT_READ_PARALLEL:
    PRINT_ERROR("Partitioning for PARALLEL=READ_PARALLEL not supported yet.\n");
  default:
  return load_file(file_name, parallel_mode, partition_tag_name,
      partition_tag_vals, pa_vec, opts, set_tag_name, set_tag_values,
      num_set_tag_values, reader_rank, surf_partition);
CubitStatus CGMReadParallel::load_file ( const char *  file_name,
int  parallel_mode,
std::string &  partition_tag_name,
std::vector< int > &  partition_tag_vals,
std::vector< int > &  pa_vec,
const CGMFileOptions opts,
const char *  set_tag_name,
const int *  set_tag_values,
Definition at line 199 of file CGMReadParallel.cpp.
  // actuate CA_BODIES and turn on auto flag for other attributes
  CGMApp::instance()->attrib_manager()->register_attrib_type(CA_BODIES,
      "bodies", "BODIES", &CABodies_creator, CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE,
      CUBIT_TRUE, CUBIT_TRUE, CUBIT_FALSE);
  CGMApp::instance()->attrib_manager()->auto_flag(CUBIT_TRUE);
    DEBUG_FLAG(90, CUBIT_TRUE);
    DEBUG_FLAG(138, CUBIT_TRUE);
  // do the work by options
  std::vector<int>::iterator vit;
  int i;
  for (i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); vit++, i++) {
    CubitStatus result = CUBIT_SUCCESS;
    switch (*vit) {
    case PA_READ:
      double tStart, tEnd;
        std::cout << "Reading file " << file_name << std::endl;
        tStart = MPI_Wtime();
      result = read_entities(file_name);
      if (CUBIT_SUCCESS != result) {
        PRINT_ERROR("Reading file %s failed.\n", file_name);
      } else if (CGM_read_parallel_debug) {
        tEnd = MPI_Wtime();
        PRINT_INFO("Read time in proc %d is %f.\n", m_rank, tEnd - tStart);
        PRINT_INFO("Read done.\n");
      break;
    case PA_BALANCE:
        std::cout << "Balancing entities." << std::endl;
        result = balance_round_robin();
        return result;
        PRINT_INFO("Balancing entities done.\n");
      break;
    case PA_DELETE_NONLOCAL:
        PRINT_INFO("Deleting nonlocal entities.\n");
      result = delete_nonlocal_entities(reader_rank, partition_tag_name,
        PRINT_ERROR("Delete failed.\n");
        tEnd = MPI_Wtime();
        PRINT_INFO("Delete done.\n");
        PRINT_INFO("Delete time in proc %d is %f.\n", m_rank, tEnd - tStart);
      break;
    case PA_BROADCAST:
      // do the actual broadcast; if single-processor, ignore error
      if (m_proc_size > 1) {
          PRINT_INFO("Broadcasting Body entities.\n");
        result = m_pcomm->broadcast_entities(reader_rank,
            m_pcomm->partition_body_list());
          PRINT_ERROR("Broadcasting Body entities failed.\n");
          tEnd = MPI_Wtime();
          PRINT_INFO("Bcast bodies done.\n");
          PRINT_INFO("Broadcast bodies time in proc %d is %f.\n", m_proc_size,
              tEnd - tStart);
        if (!check_partition_info()) {
          PRINT_ERROR("Check partition info failed.\n");
      break;
    case PA_SCATTER:
      // do the actual scatter
          PRINT_INFO("Scattering body entities.\n");
        result = m_pcomm->scatter_entities(reader_rank,
          PRINT_ERROR("Scattering body entities failed.\n");
          tEnd = MPI_Wtime();
          PRINT_INFO("Scatter bodies done.\n");
          PRINT_INFO("Scatter bodies time in proc %d is %f.\n", m_proc_size,
              tEnd - tStart);
        PRINT_INFO("Scatter done.\n");
      break;
    default:
CubitStatus CGMReadParallel::read_entities ( const char *  file_name) [private]
Definition at line 349 of file CGMReadParallel.cpp.
  // check file type
  CubitString file_type;
  if (strstr(file_name, ".stp"))
    file_type = "STEP";
  else if (strstr(file_name, ".igs"))
    file_type = "IGES";
  else if (strstr(file_name, ".occ") || strstr(file_name, ".OCC")
      || strstr(file_name, ".brep") || strstr(file_name, ".BREP"))
    file_type = "OCC";
  else {
    PRINT_ERROR("File type not known for file %s; skipping.\n", file_name);
  // import solid model
  CubitStatus result = CubitCompat_import_solid_model(file_name,
      file_type.c_str());
  // get body entities
  result = m_gqt->ref_entity_list("body", body_entity_list, CUBIT_FALSE);
    PRINT_ERROR("Getting Body entities failed.\n");
    return result;
  return result;
void CGMReadParallel::set_reader ( unsigned int  reader)
Member Data Documentation
Initial value:
 { "NONE", "READ",
    "READ_DELETE", "BCAST", "BCAST_DELETE", "SCATTER", "SCATTER_DELETE",
    "READ_PARALLEL", "FORMAT", "", 0 }
Definition at line 43 of file CGMReadParallel.hpp.
Initial value:
 { "NONE",
    "GEOM_DIMENSION", "PARARELL_PARTITION", "", 0 }
Definition at line 45 of file CGMReadParallel.hpp.
Definition at line 64 of file CGMReadParallel.hpp.
Definition at line 56 of file CGMReadParallel.hpp.
Definition at line 58 of file CGMReadParallel.hpp.
unsigned int CGMReadParallel::m_proc_size [private]
Definition at line 62 of file CGMReadParallel.hpp.
unsigned int CGMReadParallel::m_rank [private]
bool CGMReadParallel::m_reader [private]
Definition at line 60 of file CGMReadParallel.hpp.
