cgma
CompositeAttrib Class Reference
#include <CompositeAttrib.hpp>
List of all members.
Public Member Functions
const CubitStringname () const
 CompositeAttrib (const CubitSimpleAttrib &attrib, CompositeAttrib *next_ptr)
 CompositeAttrib (const CompositeAttrib &copy)
 ~CompositeAttrib ()
void append_to_csa (CubitSimpleAttrib &attrib) const
bool equals (const CubitSimpleAttrib &attrib) const
CubitSimpleAttrib csa () const
Public Attributes
CompositeAttribnext
Private Member Functions
void append_to_lists (std::vector< CubitString > &strings, std::vector< int > &ints, std::vector< double > &reals) const
Private Attributes
std::vector< int > int_array
std::vector< double > real_array
std::vector< CubitStringstring_array
Detailed Description
Definition at line 21 of file CompositeAttrib.hpp.
Definition at line 27 of file CompositeAttrib.cpp.
Definition at line 44 of file CompositeAttrib.cpp.
Definition at line 114 of file CompositeAttrib.cpp.
Member Function Documentation
Definition at line 61 of file CompositeAttrib.cpp.
void CompositeAttrib::append_to_lists ( std::vector< CubitString > &  strings,
std::vector< int > &  ints,
std::vector< double > &  reals
) const [private]
Definition at line 77 of file CompositeAttrib.cpp.
  int_list.insert(int_list.end(), int_array.begin(), int_array.end());
  real_list.insert(real_list.end(), real_array.begin(), real_array.end());
  string_list.insert(string_list.end(), string_array.begin(), string_array.end());
Definition at line 95 of file CompositeAttrib.cpp.
  std::vector<CubitString> string_list;
  std::vector<int> int_list;
  std::vector<double> real_list;
  append_to_lists( string_list, int_list, real_list );
  return CubitSimpleAttrib(&string_list, &real_list, &int_list);
bool CompositeAttrib::equals ( const CubitSimpleAttrib attrib) const
Definition at line 127 of file CompositeAttrib.cpp.
  if (attrib.string_data_list().size() != string_array.size() ||
      attrib.int_data_list().size() != int_array.size() ||
      attrib.double_data_list().size() != real_array.size())
    return false;
  return std::equal(string_array.begin(), string_array.end(), attrib.string_data_list().begin()) &&
      std::equal(int_array.begin(), int_array.end(), attrib.int_data_list().begin()) &&
      std::equal(real_array.begin(), real_array.end(), attrib.double_data_list().begin());
const CubitString& CompositeAttrib::name ( ) const [inline]
Definition at line 35 of file CompositeAttrib.hpp.
{ return string_array[0]; }
Member Data Documentation
std::vector<int> CompositeAttrib::int_array [private]
Definition at line 25 of file CompositeAttrib.hpp.
std::vector<double> CompositeAttrib::real_array [private]
Definition at line 26 of file CompositeAttrib.hpp.
Definition at line 27 of file CompositeAttrib.hpp.
