cgma
CubitAttribManager Class Reference
#include <CubitAttribManager.hpp>
List of all members.
Public Member Functions
 CubitAttribManager ()
virtual ~CubitAttribManager ()
CubitStatus register_attrib_type (const int att_type, const char *att_type_name, const char *att_internal_name, CACreateFunction p_create_function, CubitBoolean auto_actuate_flag, CubitBoolean auto_update_flag, CubitBoolean auto_write_flag, CubitBoolean auto_read_flag, CubitBoolean actuate_in_constructor, CubitBoolean actuate_after_geom_changes)
void get_registered_types (DLIList< int > &types)
CubitAttribcreate_cubit_attrib (const int attrib_type, RefEntity *attrib_user, const CubitSimpleAttrib &p_csa)
const char * att_internal_name (int attrib_type)
CubitBoolean auto_actuate_flag (int attrib_type)
CubitStatus set_auto_actuate_flag (int attrib_type, CubitBoolean value)
void set_all_auto_actuate_flags (CubitBoolean value)
CubitBoolean auto_update_flag (int attrib_type)
CubitStatus set_auto_update_flag (int attrib_type, CubitBoolean value)
void set_all_auto_update_flags (CubitBoolean value)
CubitBoolean auto_write_flag (int attrib_type)
CubitStatus set_auto_write_flag (int attrib_type, CubitBoolean value)
void set_all_auto_write_flags (CubitBoolean value)
CubitBoolean auto_read_flag (int attrib_type)
CubitStatus set_auto_read_flag (int attrib_type, CubitBoolean value)
void set_all_auto_read_flags (CubitBoolean value)
CubitBoolean actuate_in_constructor (int attrib_type)
CubitBoolean actuate_after_geom_changes (int attrib_type)
CubitStatus auto_update_attribs (RefEntity *cau)
int attrib_type (const CubitSimpleAttrib &csa_ptr)
int attrib_type (const char *name)
int attrib_type_from_internal_name (const char *name)
int auto_flag ()
void auto_flag (int flag)
bool silent_flag ()
void silent_flag (const bool flag)
const char * att_name (int attrib_type)
Private Attributes
DLIList< int > mTypes
DLIList< char * > mTypeNames
DLIList< char * > mInternalNames
DLIList< CACreateFunctionmCreatorFunctions
DLIList< CubitBooleanmAutoActuateFlags
DLIList< CubitBooleanmAutoUpdateFlags
DLIList< CubitBooleanmAutoWriteFlags
DLIList< CubitBooleanmAutoReadFlags
DLIList< CubitBooleanmActuateInConstructor
DLIList< CubitBooleanmActuateAfterGeomChanges
bool silentFlag
Detailed Description
Definition at line 23 of file CubitAttribManager.hpp.
Definition at line 11 of file CubitAttribManager.cpp.
    : silentFlag(false)
Definition at line 16 of file CubitAttribManager.cpp.
  std::map<int, CARegisterData*>::iterator iter = mTypeToCAData.begin();
  while (mTypeToCAData.end() != iter)
    delete iter->second;
    iter++;
  int i;
  assert(mTypeNames.size() == mInternalNames.size());
  for (i=mTypeNames.size(); i>0; i--)
    delete [] mTypeNames.get_and_step();
    delete [] mInternalNames.get_and_step();
Member Function Documentation
Definition at line 538 of file CubitAttribManager.cpp.
  int index = mTypes.where_is_item(attrib_type);
  if (-1 == index) {
    if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type);
    return false;
  mActuateAfterGeomChanges.reset();
  mActuateAfterGeomChanges.step(index);
  return mActuateAfterGeomChanges.get();
Definition at line 525 of file CubitAttribManager.cpp.
  if (-1 == index) {
    return false;
  mActuateInConstructor.reset();
  mActuateInConstructor.step(index);
  return mActuateInConstructor.get();
const char * CubitAttribManager::att_internal_name ( int  attrib_type)
Definition at line 498 of file CubitAttribManager.cpp.
  if (-1 == index) {
    return NULL;
  mInternalNames.reset();
  mInternalNames.step(index);
  return mInternalNames.get();
const char * CubitAttribManager::att_name ( int  attrib_type)
Definition at line 512 of file CubitAttribManager.cpp.
  if (-1 == index) {
    return NULL;
  mTypeNames.reset();
  mTypeNames.step(index);
  return mTypeNames.get();
Definition at line 421 of file CubitAttribManager.cpp.
  CubitString char_type = csa_ptr.character_type();
  return attrib_type_from_internal_name(char_type.c_str());
int CubitAttribManager::attrib_type ( const char *  name)
Definition at line 403 of file CubitAttribManager.cpp.
  int i;
  mTypeNames.reset();
  assert (mTypes.size() == mTypeNames.size());
  for (i=0; i<mTypeNames.size(); i++)
    if (!strcmp(name, mTypeNames.get_and_step()))
      mTypes.reset();
      mTypes.step(i);
      return mTypes.get();
  return CA_UNDEFINED;
Definition at line 427 of file CubitAttribManager.cpp.
  int i;
  assert (mTypes.size() == mInternalNames.size());
  for (i=0; i<mInternalNames.size(); i++)
    if (!strcmp(name, mInternalNames.get_and_step()))
      mTypes.reset();
      mTypes.step(i);
Definition at line 445 of file CubitAttribManager.cpp.
  if (-1 == index) {
    return false;
  mAutoActuateFlags.reset();
  mAutoActuateFlags.step(index);
  return mAutoActuateFlags.get();
Definition at line 383 of file CubitAttribManager.cpp.
  int sum = 0;
  CubitBoolean b_temp;
  mAutoUpdateFlags.reset();
  assert (mAutoUpdateFlags.size() == mAutoActuateFlags.size());
  for (int i = mAutoUpdateFlags.size(); i>0; i--)
    b_temp = mAutoUpdateFlags.get_and_step();
    if (b_temp) sum++;
    b_temp = mAutoActuateFlags.get_and_step();
    if (b_temp) sum++;
  if (2*mAutoUpdateFlags.size() == sum) return 0;
  else if (sum == 0) return 1;
  else return -1;
void CubitAttribManager::auto_flag ( int  flag)
Definition at line 343 of file CubitAttribManager.cpp.
  if (flag == -1) {
    flag = auto_flag();
    if (flag == -1) {
      if (!silentFlag) PRINT_ERROR("Can't change attribute flag with toggle, "
                  "some are already set.\n");
      return;
  CubitBoolean set_flag = (flag == 1 ? CUBIT_TRUE : CUBIT_FALSE);
    mAutoUpdateFlags.change_to(set_flag);
    mAutoUpdateFlags.step();
    mAutoActuateFlags.change_to(set_flag);
    mAutoActuateFlags.step();
  if (!set_flag) {
      // make sure entity_name flag isn't set false here
    int index = mTypes.where_is_item(CA_ENTITY_NAME);
    assert(-1 != index);
    mAutoUpdateFlags.step(index);
    mAutoUpdateFlags.change_to(CUBIT_TRUE);
    mAutoActuateFlags.change_to(CUBIT_TRUE);
Definition at line 484 of file CubitAttribManager.cpp.
  if (-1 == index) {
    return false;
  mAutoReadFlags.reset();
  mAutoReadFlags.step(index);
  return mAutoReadFlags.get();
Definition at line 182 of file CubitAttribManager.cpp.
    //- create attribs whose auto update flag is set
  CubitStatus status = CUBIT_SUCCESS;
  DLIList<CubitAttrib*> attrib_list;
    CubitBoolean auto_update = ((iter->second)->flags) & CA_AUTOUPDATE;
    int attrib_type = iter->first;
    if (auto_update)
      attrib_list.clean_out();
      cau->find_cubit_attrib_type(attrib_type, attrib_list);
      if (attrib_list.size() == 0) {
        create_cubit_attrib(attrib_type, cau);
        if (status == CUBIT_FAILURE) break;
    iter++;
  mTypes.reset();
  assert(mTypes.size() == mAutoUpdateFlags.size());
  int index;
  for (index=mAutoUpdateFlags.size(); index>0; index--) {
      // check the auto update flag first, if not set we can go
    if (mAutoUpdateFlags.get() == CUBIT_TRUE)
        // else we must create a CA of type if there's not one already there
      cau->find_cubit_attrib_type(mTypes.get(), attrib_list);
        create_cubit_attrib(mTypes.get(), cau, CubitSimpleAttrib());
    mTypes.step();
  return status;
Definition at line 458 of file CubitAttribManager.cpp.
  if (-1 == index) {
    return false;
  return mAutoUpdateFlags.get();
Definition at line 471 of file CubitAttribManager.cpp.
  if (-1 == index) {
    return false;
  mAutoWriteFlags.reset();
  mAutoWriteFlags.step(index);
  return mAutoWriteFlags.get();
CubitAttrib * CubitAttribManager::create_cubit_attrib ( const int  attrib_type,
RefEntity attrib_user,
const CubitSimpleAttrib p_csa
Definition at line 123 of file CubitAttribManager.cpp.
  CubitAttrib* new_attrib = NULL;
  CARegisterData *p_entry = NULL;
  CACreateFunction p_creator;
  std::map<int, CARegisterData*>::iterator iter;
  iter = mTypeToCAData.find(attrib_type);
  if (mTypeToCAData.end() == iter)
    assert(false);
    return NULL;
  p_entry = iter->second;
  p_creator = p_entry->mCreateFunction;
  new_attrib = (*p_creator)(attrib_user);
  return new_attrib;
  if (-1 == index) // type not registered
    if (!silentFlag) PRINT_ERROR("Attribute type %d can't be created because it hasn't been registered.\n",
                attrib_type);
    return NULL;
  mCreatorFunctions.reset();
  p_creator = mCreatorFunctions.next(index);
  new_attrib = (*p_creator)(attrib_user, p_csa);
  return new_attrib;
Definition at line 551 of file CubitAttribManager.cpp.
  types = mTypes;
  types.reset();
CubitStatus CubitAttribManager::register_attrib_type ( const int  att_type,
const char *  att_type_name,
const char *  att_internal_name,
Definition at line 40 of file CubitAttribManager.cpp.
  assert(CA_UNDEFINED != att_type);
  assert(CA_ALL_ATTRIBUTES != att_type);
  unsigned int flags = 0;
  if (auto_actuate_flag) flags |= CA_AUTOACTUATE;
  if (auto_update_flag) flags |= CA_AUTOUPDATE;
  if (auto_write_flag) flags |= CA_AUTOWRITE;
  if (auto_read_flag) flags |= CA_AUTOREAD;
  if (actuate_in_constructor) flags |= CA_ACTUATEINCONSTRUCTOR;
  if (actuate_after_geom_changes) flags |= CA_ACTUATEAFTERGEOMCHANGES;
  CARegisterData *p_entry = new CARegisterData(att_type_name, att_internal_name,
                                               p_create_function, flags);
  std::pair<std::map<int, CARegisterData*>::iterator, bool> result_pair;
  result_pair = mTypeToCAData.insert( std::pair<int, CARegisterData*>(att_type, p_entry) );
  if (!result_pair.second) // failed to insert because the type was already registered
    assert(false);
    delete p_entry;
    return CUBIT_FAILURE;
  int index = mTypes.where_is_item(att_type);
  if (-1 != index) // type already registered
    if (!silentFlag) PRINT_ERROR("Attribute type %d already registered\n.", att_type);
#ifndef NDEBUG
  int size = mTypes.size();
  assert (mTypeNames.size() == size);
  assert (mCreatorFunctions.size() == size);
  assert (mInternalNames.size() == size);
  assert (mAutoActuateFlags.size() == size);
  assert (mAutoUpdateFlags.size() == size);
  assert (mAutoWriteFlags.size() == size);
  assert (mAutoReadFlags.size() == size);
  assert (mActuateInConstructor.size() == size);
  assert (mActuateAfterGeomChanges.size() == size);
//  assert (mAttribImported.size() == size);
#endif
  mTypes.append(att_type);
  int namesize = strlen(att_type_name);
  char *stemp = new char[namesize+1];
  strcpy(stemp, att_type_name);
  mTypeNames.append(stemp);
  namesize = strlen(att_internal_name);
  strcpy(stemp, att_internal_name);
  mInternalNames.append(stemp);
  mCreatorFunctions.append(p_create_function);
  mAutoActuateFlags.append(auto_actuate_flag);
  mAutoUpdateFlags.append(auto_update_flag);
  mAutoWriteFlags.append(auto_write_flag);
  mAutoReadFlags.append(auto_read_flag);
  mActuateInConstructor.append(actuate_in_constructor);
  mActuateAfterGeomChanges.append(actuate_after_geom_changes);
//  mAttribImported.append(CUBIT_FALSE); // TODO - get rid of mAttribImported
  return CUBIT_SUCCESS;
Definition at line 233 of file CubitAttribManager.cpp.
//  std::map<int, CARegisterData*>::iterator iter = mTypeToCAData.begin();
//  while (mTypeToCAData.end() != iter)
  for (int i = mAutoActuateFlags.size(); i>0; i--)
    mAutoActuateFlags.change_to(value);
Definition at line 327 of file CubitAttribManager.cpp.
Definition at line 275 of file CubitAttribManager.cpp.
Definition at line 301 of file CubitAttribManager.cpp.
Definition at line 95 of file CubitAttribManager.hpp.
{return silentFlag;}
void CubitAttribManager::silent_flag ( const bool  flag) [inline]
Definition at line 96 of file CubitAttribManager.hpp.
{silentFlag = flag;}
Member Data Documentation
Definition at line 143 of file CubitAttribManager.hpp.
Definition at line 142 of file CubitAttribManager.hpp.
Definition at line 141 of file CubitAttribManager.hpp.
Definition at line 155 of file CubitAttribManager.hpp.
