cgma
CubitOctreeCell Class Reference
#include <CubitOctreeCell.hpp>
List of all members.
Public Member Functions
 CubitOctreeCell ()
 CubitOctreeCell (CubitVector center, double dimension, int level, CubitOctreeCell *parent_cell)
virtual ~CubitOctreeCell ()
void display (CubitOctree *ptr_octree, int opt)
void display_color_wireframe (CubitOctree *ptr_octree)
void display_octreefacetpointdata (void)
void release_octreefacetpointdata (void)
void set_oct_grid_node (const int i, const int j, const int k, CubitOctreeNode *ptr_node)
int get_depth (void)
double get_dimension (void)
void set_child (int i, int j, int k, CubitOctreeCell *ptr_child_cell)
CubitVector get_center (void)
CubitOctreeNodeget_octree_grid_node (const int i, const int j, const int k)
int id (void)
CubitOctreeCellget_child (const int i, const int j, const int k)
void set_leaf (bool type)
CubitOctreeCellfind_leaf_octree_cell (const CubitVector &point)
void subdivide_octree_based_on_point (CubitPoint *ptr_point)
bool is_leaf (void)
void distribute_facet_points_among_children (void)
int num_of_facet_point_data (void)
CubitBoolean append_list_item (OctreeFacetPointData *ptr_facet_point_data)
DLIList< OctreeFacetPointData * > * get_facet_point_data_list ()
void set_mark (CubitBoolean type)
CubitBoolean get_mark (void)
void set_visit (CubitBoolean type)
CubitBoolean get_visit (void)
CubitBoolean add_adjacent_unmarked_cells (DLIList< CubitOctreeCell * > &queue)
CubitBoolean is_intersects_box (const CubitBox &box)
CubitBoolean does_facet_intersect_octreecell (CubitFacet *ptr_facet)
void set_color_and_intersection_datas (CubitFacet *ptr_facet, RefFace *ptr_Ref_face, CubitSense surf_sense=CUBIT_FORWARD)
CubitBoolean does_contain_positive_and_negative_nodes ()
CubitBoolean is_facet_point_data_present (const CubitVector &coord)
CubitBoolean is_facet_point_data_present (OctreeFacetPointData *new_facet_point_data)
CubitBoolean interpolate_grey_octreecell_node (void)
void coloring (DLIList< CubitOctreeCell * > &black_cell_list)
double trilinear_interpolation (const CubitVector &point)
double inverse_distance_interpolation (const CubitVector &point)
double min_size_interpolation (const CubitVector &point)
double min_distance_interpolation (const CubitVector &point)
CubitStatus find_indices_in_parent (int *index)
void write_octreecell_sizing_info_file (FILE *pof, DLIList< CubitOctreeCell * > &stack)
void mark_color (int type)
int get_color ()
Private Attributes
CubitVector mCenter
double dimension
int depth
CubitBoolean leaf
int num
int color
CubitBoolean mark
CubitBoolean visit
CubitOctreeNodecubitOctreeNode [2][2][2]
CubitOctreeCellparent
CubitOctreeCellchildren [2][2][2]
DLIList< OctreeFacetPointData * > octreeFacetPointDataList
DLIList
< OctreeIntersectionData * > *
myFacetList
Detailed Description
Definition at line 29 of file CubitOctreeCell.hpp.
Definition at line 33 of file CubitOctreeCell.hpp.
CubitOctreeCell::CubitOctreeCell ( CubitVector  center,
double  dimension,
int  level,
CubitOctreeCell parent_cell
Definition at line 24 of file CubitOctreeCell.cpp.
  static int counter = 0;
  int i, j, k;
  leaf = CUBIT_TRUE;
  dimension = dim;
  mCenter = cen;
  depth = level;
  num = counter;
  counter ++;
  parent = parent_cell;
  mark = CUBIT_FALSE;
  visit = CUBIT_FALSE;
  color = CUBIT_WHITE_INDEX;
//  CubitOctreeNode = new CubitOctreeNode* [2][2][2];
  myFacetList = NULL;
  for( i = 0; i < 2; i++ ){
    for( j = 0; j < 2; j++ ){
      for( k = 0; k < 2; k++ ){
        cubitOctreeNode[i][j][k] = NULL;
        children[i][j][k] = NULL;
    //CubitOctree = NULL;
Definition at line 63 of file CubitOctreeCell.cpp.
  int i, j, k;
        if( children[i][j][k] != NULL ){
          delete children[i][j][k];
  int num_elm = octreeFacetPointDataList.size();
  for( i = 0; i < num_elm; i++ ){
    delete octreeFacetPointDataList.pop();
    // delete_local_node_matrix();
    /*if (myFacetList)
      for (i=0; i < myFacetList->size(); ++i)
      delete myFacetList->get_and_step();
      delete myFacetList;
      }*/ //uncomment later
Member Function Documentation
Definition at line 404 of file CubitOctreeCell.cpp.
//optimized
  static int i, j, k, l, m, n;
  static CubitOctreeNode *ptr_grid_node;
  static CubitOctreeCell *ptr_cell;
  static DLIList<CubitOctreeCell*> temp_list;
  for( i = 1; i >= 0; i-- ){
    for( j = 1; j >= 0; j-- ){
      for( k = 1; k >= 0; k-- ){
        ptr_grid_node = cubitOctreeNode[i][j][k];
        for( l = 0; l < 2; l++ ){
          for( m = 0; m < 2; m++ ){
            for( n = 0; n < 2; n++ ){
              ptr_cell = ptr_grid_node->get_adj_cell( l, m, n );
              if( ptr_cell != NULL )
                if( ptr_cell->mark == CUBIT_FALSE )
                    //queue.append( ptr_cell );
                  temp_list.append(ptr_cell);
                    // ptr_cell->set_mark( CUBIT_TRUE );
                  ptr_cell->mark = CUBIT_TRUE;
  queue += temp_list;
  temp_list.clean_out();
  return CUBIT_TRUE;
bool CubitOctreeCell::append_list_item ( OctreeFacetPointData ptr_facet_point_data)
Definition at line 398 of file CubitOctreeCell.cpp.
  octreeFacetPointDataList.push( ptr_facet_point_data );
  return CUBIT_TRUE;
void CubitOctreeCell::coloring ( DLIList< CubitOctreeCell * > &  black_cell_list)
Definition at line 598 of file CubitOctreeCell.cpp.
  int i,j,k;
  int grey, black;
  grey = FALSE;
  black = TRUE;
  if( leaf == CUBIT_TRUE ){
          if( cubitOctreeNode[i][j][k]->get_color() != CUBIT_BLACK_INDEX )
            black = FALSE;
          else
            grey = TRUE;
    if( black == TRUE )
      color = CUBIT_BLACK_INDEX;
      black_cell_list.append(this);
    else
      if( grey == TRUE ){
      color = CUBIT_GREY_INDEX;
      //grey_cell_list.push( this );
      else
        color = CUBIT_WHITE_INDEX; //constructor
      //return CUBIT_TRUE;
  else{
          children[i][j][k]->coloring( /*grey_cell_list,*/ black_cell_list);
  //return CUBIT_FALSE;
void CubitOctreeCell::display ( CubitOctree ptr_octree,
int  opt
Definition at line 186 of file CubitOctreeCell.cpp.
  int i, j, k;
  if( is_leaf() == CUBIT_FALSE ){
            //if( children[i][j][k] != NULL ){
          children[i][j][k]->display(ptr_octree, opt);
  else if (opt == 1)
      // draw all cells in black wireframe mode
    //double corners[3];
    //double half_edge_length = get_dimension()/2.0;
    //CubitVector center = get_center();
    //center.get_xyz(corners);
    //double box[6] = {corners[0]-half_edge_length, corners[1]-half_edge_length, corners[2]-half_edge_length,
                    //corners[0]+half_edge_length, corners[1]+half_edge_length, corners[2]+half_edge_length};
    //SVDrawTool::draw_cube(box, CUBIT_BLACK_INDEX, SVDrawTool::WIRE);
    return;
  else if (opt == 2)
      // draw grey and black cells in black wireframe mode
      //(color == CUBIT_GREY_INDEX || color == CUBIT_BLACK_INDEX)
    if (color == CUBIT_BLACK_INDEX)
    return;
  else if (opt == 3)
      // draw grey cells in white smoothshade mode
    if (color == CUBIT_GREY_INDEX)
      //SVDrawTool::draw_cube(box, CUBIT_WHITE_INDEX, SVDrawTool::SHADE);
    return;
  else if (opt == 4)
    if (color != CUBIT_WHITE_INDEX)
    return;
  else if (opt == 5)
      // draw grey and black cells in color wireframe mode
      if( color == CUBIT_GREY_INDEX || color == CUBIT_BLACK_INDEX )
          display_color_wireframe(ptr_octree);
      return;
  else
    if( /*color == CUBIT_GREY_INDEX ||*/ color == CUBIT_BLACK_INDEX )
    return;
Definition at line 95 of file CubitOctreeCell.cpp.
    //glColor3f( (cubitOctreeNode[0][0][0])->GetsizeColor(X), (cubitOctreeNode[0][0][0])->GetsizeColor(Y), (cubitOctreeNode[0][0][0])->GetsizeColor(Z) );
    //glColor3f( (cubitOctreeNode[1][0][0])->GetsizeColor(X), (cubitOctreeNode[1][0][0])->GetsizeColor(Y), (cubitOctreeNode[1][0][0])->GetsizeColor(Z) );
    // GfxDebug::draw_line( cubitOctreeNode[0][0][0]->x(), cubitOctreeNode[0][0][0]->y(), cubitOctreeNode[0][0][0]->z(), cubitOctreeNode[1][0][0]->x(), cubitOctreeNode[1][0][0]->y(), cubitOctreeNode[1][0][0]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[0][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][0][0]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[0][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node( cubitOctreeNode[0][0][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node( cubitOctreeNode[1][0][0]->get_size( OCTREE_SIZE_DEFAULT)) );
    //glColor3f( (cubitOctreeNode[0][1][0])->GetsizeColor(X), (cubitOctreeNode[0][1][0])->GetsizeColor(Y), (cubitOctreeNode[0][1][0])->GetsizeColor(Z) );
    //glColor3f( (cubitOctreeNode[1][1][0])->GetsizeColor(X), (cubitOctreeNode[1][1][0])->GetsizeColor(Y), (cubitOctreeNode[1][1][0])->GetsizeColor(Z) );
    //GfxDebug::draw_line( cubitOctreeNode[0][1][0]->x(), cubitOctreeNode[0][1][0]->y(), cubitOctreeNode[0][1][0]->z(),cubitOctreeNode[1][1][0]->x(), cubitOctreeNode[1][1][0]->y(), cubitOctreeNode[1][1][0]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[0][1][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][0]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[0][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][1][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][0]->get_size( OCTREE_SIZE_DEFAULT)) );
    //GfxDebug::draw_line( cubitOctreeNode[0][0][0]->x(), cubitOctreeNode[0][0][0]->y(), cubitOctreeNode[0][0][0]->z(), cubitOctreeNode[0][1][0]->x(), cubitOctreeNode[0][1][0]->y(), cubitOctreeNode[0][1][0]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[0][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[0][1][0]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[0][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[0][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][1][0]->get_size( OCTREE_SIZE_DEFAULT)) );
    //GfxDebug::draw_line( cubitOctreeNode[1][0][0]->x(), cubitOctreeNode[1][0][0]->y(), cubitOctreeNode[1][0][0]->z(), cubitOctreeNode[1][1][0]->x(), cubitOctreeNode[1][1][0]->y(), cubitOctreeNode[1][1][0]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[1][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][0]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[1][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][0][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][0]->get_size( OCTREE_SIZE_DEFAULT)) );
    //glColor3f( (cubitOctreeNode[0][0][1])->GetsizeColor(X), (cubitOctreeNode[0][0][1])->GetsizeColor(Y), (cubitOctreeNode[0][0][1])->GetsizeColor(Z) );
    //glColor3f( (cubitOctreeNode[1][0][1])->GetsizeColor(X), (cubitOctreeNode[1][0][1])->GetsizeColor(Y), (cubitOctreeNode[1][0][1])->GetsizeColor(Z) );
    //GfxDebug::draw_line( cubitOctreeNode[0][0][1]->x(), cubitOctreeNode[0][0][1]->y(), cubitOctreeNode[0][0][1]->z(), cubitOctreeNode[1][0][1]->x(), cubitOctreeNode[1][0][1]->y(), cubitOctreeNode[1][0][1]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[0][0][1]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][0][1]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[0][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][1]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][0][1]->get_size( OCTREE_SIZE_DEFAULT)) );
    //glColor3f( (cubitOctreeNode[0][1][1])->GetsizeColor(X), (cubitOctreeNode[0][1][1])->GetsizeColor(Y), (cubitOctreeNode[0][1][1])->GetsizeColor(Z) );
    //glColor3f( (cubitOctreeNode[1][1][1])->GetsizeColor(X), (cubitOctreeNode[1][1][1])->GetsizeColor(Y), (cubitOctreeNode[1][1][1])->GetsizeColor(Z) );
    //GfxDebug::draw_line( cubitOctreeNode[0][1][1]->x(), cubitOctreeNode[0][1][1]->y(), cubitOctreeNode[0][1][1]->z(), cubitOctreeNode[1][1][1]->x(), cubitOctreeNode[1][1][1]->y(), cubitOctreeNode[1][1][1]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[0][1][1]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][1]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[0][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][1][1]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][1]->get_size( OCTREE_SIZE_DEFAULT)) );
    //GfxDebug::draw_line( cubitOctreeNode[0][0][1]->x(), cubitOctreeNode[0][0][1]->y(), cubitOctreeNode[0][0][1]->z(), cubitOctreeNode[0][1][1]->x(), cubitOctreeNode[0][1][1]->y(), cubitOctreeNode[0][1][1]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[0][0][1]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[0][1][1]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[0][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][1]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[0][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][1][1]->get_size( OCTREE_SIZE_DEFAULT)) );
    //GfxDebug::draw_line( cubitOctreeNode[1][0][1]->x(), cubitOctreeNode[1][0][1]->y(), cubitOctreeNode[1][0][1]->z(), cubitOctreeNode[1][1][1]->x(), cubitOctreeNode[1][1][1]->y(), cubitOctreeNode[1][1][1]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[1][0][1]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][1]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[1][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][0][1]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][1]->get_size( OCTREE_SIZE_DEFAULT)) );
    //GfxDebug::draw_line( cubitOctreeNode[0][0][0]->x(), cubitOctreeNode[0][0][0]->y(), cubitOctreeNode[0][0][0]->z(), cubitOctreeNode[0][0][1]->x(), cubitOctreeNode[0][0][1]->y(), cubitOctreeNode[0][0][1]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[0][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[0][0][1]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[0][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[0][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][1]->get_size( OCTREE_SIZE_DEFAULT)) );
    //GfxDebug::draw_line( cubitOctreeNode[0][1][0]->x(), cubitOctreeNode[0][1][0]->y(), cubitOctreeNode[0][1][0]->z(), cubitOctreeNode[0][1][1]->x(), cubitOctreeNode[0][1][1]->y(), cubitOctreeNode[0][1][1]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[0][1][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[0][1][1]->get_color() != CUBIT_GREY_INDEX ){
    //GfxDebug::draw_line( cubitOctreeNode[1][0][0]->x(), cubitOctreeNode[1][0][0]->y(), cubitOctreeNode[1][0][0]->z(), cubitOctreeNode[1][0][1]->x(), cubitOctreeNode[1][0][1]->y(), cubitOctreeNode[1][0][1]->z(), CUBIT_BLUE_INDEX );
    //SkeletonDebug::draw_line( cubitOctreeNode[1][0][0]->get_coord(), cubitOctreeNode[1][0][0]->get_size( OCTREE_SIZE_DEFAULT), cubitOctreeNode[1][0][1]->get_coord(), cubitOctreeNode[1][0][1]->get_size( OCTREE_SIZE_DEFAULT) );
    if( cubitOctreeNode[1][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][0][1]->get_color() != CUBIT_GREY_INDEX ){
    //GfxDebug::draw_line( cubitOctreeNode[1][1][0]->x(), cubitOctreeNode[1][1][0]->y(), cubitOctreeNode[1][1][0]->z(), cubitOctreeNode[1][1][1]->x(), cubitOctreeNode[1][1][1]->y(), cubitOctreeNode[1][1][1]->z(), CUBIT_BLUE_INDEX );
    if( cubitOctreeNode[1][1][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][1]->get_color() != CUBIT_GREY_INDEX ){
        //SkeletonDebug::draw_line( cubitOctreeNode[1][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][1]->get_size( OCTREE_SIZE_DEFAULT)) );
Definition at line 296 of file CubitOctreeCell.cpp.
  int i, j, k;
          children[i][j][k]->display_octreefacetpointdata( );
  else{
    for( i = 0; i < octreeFacetPointDataList.size(); i++ ){
      octreeFacetPointDataList.get_and_step()->display();
Definition at line 360 of file CubitOctreeCell.cpp.
  int i;
  int l, m, n;
  OctreeFacetPointData *ptr_facet_point_data;
  octreeFacetPointDataList.reset();
    ptr_facet_point_data = octreeFacetPointDataList.get_and_step();
    l = m = n = 1;
    if( ptr_facet_point_data->x() < mCenter.x() )
      l = 0;
    if( ptr_facet_point_data->y() < mCenter.y() )
      m = 0;
    if( ptr_facet_point_data->z() < mCenter.z() )
      n = 0;
    children[l][m][n]->append_list_item( ptr_facet_point_data );
    // Clean the points and face list in the parent cell
  octreeFacetPointDataList.clean_out();
Definition at line 979 of file CubitOctreeCell.cpp.
  int i, j, k;
  CubitBoolean positive_space = CUBIT_FALSE;
  CubitBoolean negative_space = CUBIT_FALSE;
        if( cubitOctreeNode[i][j][k]->get_halfspace_direction() == OCTREE_POSITIVE )
          positive_space = CUBIT_TRUE;
        else
          negative_space = CUBIT_TRUE;
  if( positive_space == CUBIT_TRUE && negative_space == CUBIT_TRUE ){
    return CUBIT_TRUE;
  else{
    return CUBIT_FALSE;
Definition at line 825 of file CubitOctreeCell.cpp.
  int i;
  CubitVector v0 = ptr_facet->point(0)->coordinates() - get_center(), v1 = ptr_facet->point(1)->coordinates() - get_center(),
      v2 = ptr_facet->point(2)->coordinates() - get_center();
  static CubitVector sep_axes[13];
  sep_axes[0] = ptr_facet->normal();
  sep_axes[1] = CubitVector(1,0,0);// note to self: optimize following trivial cross products
  sep_axes[2] = CubitVector(0,1,0);
  sep_axes[3] = CubitVector(0,0,1);
  sep_axes[4] = sep_axes[1]*(v1-v0);
  sep_axes[5] = sep_axes[1]*(v2-v1);
  sep_axes[6] = sep_axes[1]*(v0-v2);
  sep_axes[7] = sep_axes[2]*(v1-v0);
  sep_axes[8] = sep_axes[2]*(v2-v1);
  sep_axes[9] = sep_axes[2]*(v0-v2);
  sep_axes[10] = sep_axes[3]*(v1-v0);
  sep_axes[11] = sep_axes[3]*(v2-v1);
  sep_axes[12] = sep_axes[3]*(v0-v2);
  sep_axes[4].normalize();
  sep_axes[5].normalize();
  sep_axes[6].normalize();
  sep_axes[7].normalize();
  sep_axes[8].normalize();
  sep_axes[9].normalize();
  sep_axes[10].normalize();
  sep_axes[11].normalize();
  sep_axes[12].normalize();
  double rad_b, dot1, dot2, dot3, min_t, max_t;
  for (i=0; i < 13; ++i)
      // rad_b is the "radius" of the projection of the cell onto the separating axis, centered about the projection of the cell's center
      // min_t and max_t are the extremes of the projection of the triangle onto the separating axis
    rad_b = (get_dimension() / 2.0) * (fabs(sep_axes[i].x()) + fabs(sep_axes[i].y()) + fabs(sep_axes[i].z()));
    dot1 = v0%sep_axes[i];
    dot2 = v1%sep_axes[i];
    dot3 = v2%sep_axes[i];
    min_t = CUBIT_MIN(CUBIT_MIN(dot1,dot2),dot3);
    max_t = CUBIT_MAX(CUBIT_MAX(dot1,dot2),dot3);
      // if the triangle's projection is on either side of the CubitOctree cell's projection, i.e. the projections don't overlap, then the two are disjoint
      //if ( min_t > rad_b || max_t < -rad_b)
    if ( (min_t - rad_b) > 1e-6 || (-rad_b -max_t) > 1e-6)
      // found a separating axis so facet and cell do not intersect
      return CUBIT_FALSE;
    // OctreeIntersectionData code was here
  return CUBIT_TRUE;
Definition at line 1165 of file CubitOctreeCell.cpp.
  int i, j, k;
        if( parent->get_child( i, j, k )->id() == num ){
          index[0] = i;
          index[1] = j;
          index[2] = k;
          return CUBIT_SUCCESS;
  return CUBIT_FAILURE;
Definition at line 333 of file CubitOctreeCell.cpp.
  int i, j, k;
  if( is_leaf() == CUBIT_TRUE ){
    return this;
  else{
    i = j = k = 1;
    if( point.x() < mCenter.x() )
      i = 0;
    if( point.y() < mCenter.y() )
      j = 0;
    if( point.z() < mCenter.z() )
      k = 0;
    if (children[i][j][k] == NULL) {return NULL;}
    return children[i][j][k]->find_leaf_octree_cell( point );
Definition at line 63 of file CubitOctreeCell.hpp.
{ return mCenter; }
CubitOctreeCell * CubitOctreeCell::get_child ( const int  i,
const int  j,
const int  k
Definition at line 327 of file CubitOctreeCell.cpp.
  return ( children[i][j][k] );
int CubitOctreeCell::get_color ( ) [inline]
Definition at line 168 of file CubitOctreeCell.hpp.
{return color;}
int CubitOctreeCell::get_depth ( void  ) [inline]
Definition at line 54 of file CubitOctreeCell.hpp.
{ return depth; }
double CubitOctreeCell::get_dimension ( void  ) [inline]
Definition at line 57 of file CubitOctreeCell.hpp.
{ return dimension; }
Definition at line 102 of file CubitOctreeCell.hpp.
{ return mark; }
CubitOctreeNode* CubitOctreeCell::get_octree_grid_node ( const int  i,
const int  j,
const int  k
) [inline]
Definition at line 66 of file CubitOctreeCell.hpp.
{ return cubitOctreeNode[i][j][k]; }
Definition at line 105 of file CubitOctreeCell.hpp.
{ return visit; }
int CubitOctreeCell::id ( void  ) [inline]
Definition at line 69 of file CubitOctreeCell.hpp.
{ return num; }
Definition at line 658 of file CubitOctreeCell.cpp.
  float avg_size;
  int counter;
  int i,j,k;
  avg_size = 0;
  counter = 0;
          //if( cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) != 0 && cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) != CUBIT_DBL_MAX  ){
          //if( cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) != 0.0 ){
        if (cubitOctreeNode[i][j][k]->get_color() == CUBIT_BLACK_INDEX)
          avg_size += cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT );
          counter++;
  if( counter == 0 ){
    return CUBIT_FALSE;
  avg_size /= counter;
          //if( cubitOctreeNode[i][j][k]->get_color() == CUBIT_WHITE_INDEX ){
        if( cubitOctreeNode[i][j][k]->get_color() != CUBIT_BLACK_INDEX ){
            //if( cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) == 0.0 ){
          cubitOctreeNode[i][j][k]->set_size( avg_size, OCTREE_SIZE_DEFAULT );
            //else{
            // cubitOctreeNode[i][j][k]->set_size( ( avg_size + cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) ) / 2.0, OCTREE_SIZE_DEFAULT );
  return CUBIT_TRUE;
Definition at line 1003 of file CubitOctreeCell.cpp.
  double size;
  long double denominator=0;
  long double nominator=0;
  double weight;
  long double dist_func;
  CubitVector node_coord;
  double dist;
  int i, j, k;
  int type = DEFAULT_INVERSE_DISTANCE_SCHEME_INSIDE_CELL;
        if(  get_octree_grid_node(i, j, k)->get_size(OCTREE_SIZE_DEFAULT) != 0.0 ){
          node_coord = get_octree_grid_node(i, j, k)->get_coord();
          dist = ( node_coord - point  ).length();
          if( dist < OCTREE_EPSILON )
            dist = OCTREE_EPSILON;
          switch( type ){
            case INVERSE_LINEAR:
                dist_func = dist;
                break;
            case INVERSE_QUADRATIC:
                dist_func = dist * dist;
                break;
            case INVERSE_CUBIC:
                dist_func = dist * dist * dist;
                break;
            default:
          denominator += 1.0 / ( dist_func );
  size = 0.0;
  for( i = 0; i < 2; i ++ ){
          node_coord = get_octree_grid_node(i,j,k)->get_coord();
          switch( type ){
                dist_func = dist;
                break;
                break;
            case INVERSE_CUBIC:
                break;
            default:
          nominator = 1.0 / ( dist_func );
          weight = nominator / denominator ;
          size +=  get_octree_grid_node(i,j,k)->get_size( OCTREE_SIZE_DEFAULT ) * weight;
            //PRINT_DEBUG_157(" size at grid node = %f\n",get_octree_grid_node(i,j,k)->get_size( OCTREE_SIZE_DEFAULT ));
  return size;
Definition at line 565 of file CubitOctreeCell.cpp.
  OctreeFacetPointData *facet_point_data;
  int i;
    if( (facet_point_data->coordinates() - coord ).length() < OCTREE_EPSILON ){
      return CUBIT_TRUE;
  return CUBIT_FALSE;
Definition at line 581 of file CubitOctreeCell.cpp.
  int i;
    if( facet_point_data->id() ==
        new_facet_point_data->id() ){
      return CUBIT_TRUE;
  return CUBIT_FALSE;
Definition at line 447 of file CubitOctreeCell.cpp.
  double x_min, x_max, y_min, y_max, z_min, z_max;
  CubitVector box_min, box_max;
  int I, II, III, IV;
    //GfxDebug::draw_point( center.x(), center.y(), center.z(), CUBIT_RED_INDEX, itoa( num, buffer, 10 ) );
    // DEBUG:
    // changed from dimension -> dimenstion_2
  double dimension_2 = dimension / 2.0;
  x_min = mCenter.x() - dimension_2;
  x_max = mCenter.x() + dimension_2;
  y_min = mCenter.y() - dimension_2;
  y_max = mCenter.y() + dimension_2;
  z_min = mCenter.z() - dimension_2;
  z_max = mCenter.z() + dimension_2;
  box_min = box.minimum();
  box_max = box.maximum();
    //PRINT_DEBUG_157("Testing: Bbox of facet MIN = [ %2.2lf %2.2lf %2.2lf ] MAX = [ %2.2lf %2.2lf %2.2lf ]\n",box_min.x(), box_min.y(), box_min.z(), box_max.x(), box_max.y(), box_max.z() );
    //PRINT_DEBUG_157("Testing:         Cell  MIN = [ %2.2lf %2.2lf %2.2lf ] MAX = [ %2.2lf %2.2lf %2.2lf ]\n",x_min, y_min, z_min, x_max, y_max, z_max );
    // A represent min of cell and B represent max of cell
    // C represent min of bbox and D represent max of bbox
    // A < C => I
    // B < C => II
    // A < D => III
    // B < D => IV
  I = II = III = IV = -1;
  if( x_max < box_min.x() ){
    II = 1;
    I = 1;
  else{
    if( x_min < box_min.x() ){
      I = 1;
  if( x_max <= box_max.x() ){
    III = 1;
    IV = 1;
  else{
    if( x_min <= box_max.x() ){
      III = 1;
  if( I * II == 1 && III * IV == 1 && I * III == 1 ){
      //PRINT_DEBUG_157(" X No Intersection \n");
    return CUBIT_FALSE;
  if( y_max < box_min.y() ){
    II = 1;
    I = 1;
  else{
    if( y_min < box_min.y() ){
      I = 1;
  if( y_max <= box_max.y() ){
    III = 1;
    IV = 1;
  else{
    if( y_min <= box_max.y() ){
      III = 1;
      //PRINT_DEBUG_157(" Y No Intersection \n");
    return CUBIT_FALSE;
  if( z_max < box_min.z() ){
    II = 1;
    I = 1;
  else{
    if( z_min < box_min.z() ){
      I = 1;
  if( z_max <= box_max.z() ){
    III = 1;
    IV = 1;
  else{
    if( z_min <= box_max.z() ){
      III = 1;
      //PRINT_DEBUG_157(" Z No Intersection \n");
    return CUBIT_FALSE;
    //PRINT_DEBUG_157(" *********************** Intersection ************************* \n");
  return CUBIT_TRUE;
bool CubitOctreeCell::is_leaf ( void  ) [inline]
Definition at line 83 of file CubitOctreeCell.hpp.
{ return leaf; }
void CubitOctreeCell::mark_color ( int  type) [inline]
Definition at line 162 of file CubitOctreeCell.hpp.
{ color = type; }
Definition at line 1095 of file CubitOctreeCell.cpp.
  double size;
  double dist;
  int i, j, k;
  double min_dist = CUBIT_DBL_MAX;
  size = 0.0;
          if( dist < min_dist )
            min_dist = dist;
            size = get_octree_grid_node(i,j,k)->get_size( OCTREE_SIZE_DEFAULT );
  return size;
Definition at line 1133 of file CubitOctreeCell.cpp.
  int i, j, k;
  double min_size = CUBIT_DBL_MAX;
  double size;
          if( size < OCTREE_EPSILON )
            size = OCTREE_EPSILON;
          if( size < min_size )
            min_size = size;
  return min_size;
Definition at line 89 of file CubitOctreeCell.hpp.
Definition at line 273 of file CubitOctreeCell.cpp.
  int i, j, k;
          children[i][j][k]->release_octreefacetpointdata( );
  else{
void CubitOctreeCell::set_child ( int  i,
int  j,
int  k,
CubitOctreeCell ptr_child_cell
Definition at line 321 of file CubitOctreeCell.cpp.
  children[i][j][k] = ptr_child_cell;
void CubitOctreeCell::set_color_and_intersection_datas ( CubitFacet ptr_facet,
RefFace ptr_Ref_face,
CubitSense  surf_sense = CUBIT_FORWARD
Definition at line 885 of file CubitOctreeCell.cpp.
  int i, j, k;
  CubitVector facet_normal = ptr_facet->normal();
    //SVDrawTool::draw_vector(ptr_facet->center(),ptr_facet->center()+ptr_facet->normal(), CUBIT_MAGENTA_INDEX);
/*  if( ptr_facet->is_backwards() ) // Ved: note to self - check this
    facet_normal = facet_normal * -1;
    // if (!myFacetList) {myFacetList = new DLIList</*CubitFacet*/OctreeIntersectionData*>;} uncomment later
//    OctreeIntersectionData(CubitVector normal, int half_space, double len, RefFace *ptr_face, CubitVector closest_point_on_facet, CubitFacet *lp_facet);
/*  CubitVector dummy;
    OctreeIntersectionData *new_idata = new OctreeIntersectionData(dummy, 1, 0.0, ptr_Ref_face, dummy, ptr_facet);
    myFacetList->append(new_idata);*/ // uncomment later
    /* if (!myFaceList) {myFaceList = new DLIList<RefFace*>;}
       if (!myFaceList->where_is_item(ptr_Ref_face))
       myFaceList->append(ptr_Ref_face);
    // bool merged = (CAST_TO(ptr_Ref_face, RefFace)->num_parent_ref_entities() == 2);
  for (i=0; i < 2; ++i)
    for (j=0; j < 2; ++j)
      for (k=0; k < 2; ++k)
        CubitVector closest_point_on_facet;
        double dist_to_facet;
        if (defaultDistanceMetric == CAPSULE_DIST) {dist_to_facet = CubitOctree::capsule_distance_to_facet(cubitOctreeNode[i][j][k]->get_coord(), ptr_facet, closest_point_on_facet);}
        else if (defaultDistanceMetric == PROJECTED_DIST) {dist_to_facet = CubitOctree::capsule_distance_to_facet(cubitOctreeNode[i][j][k]->get_coord(), ptr_facet, closest_point_on_facet, CUBIT_TRUE);}
          /*if (dist_to_facet < 0)
              //PRINT_INFO("Invalid distance: %lf !!!!\n", dist_to_facet);
                //SVDrawTool::draw_point(cubitOctreeNode[i][j][k]->get_coord(), CUBIT_MAGENTA_INDEX);
                  //double test_dist = CubitOctree::capsule_distance_to_facet(cubitOctreeNode[i][j][k]->get_coord(), ptr_facet, closest_point_on_facet);
        OctreeIntersectionData *idata;
        if (/*merged == CUBIT_TRUE*/ surf_sense == CUBIT_UNKNOWN)
          CubitVector temp_facet_normal = facet_normal;
          if (cubitOctreeNode[i][j][k]->get_halfspace_direction() == OCTREE_NEGATIVE)
            temp_facet_normal *= -1.0;
//          SVDrawTool::draw_point(cubitOctreeNode[i][j][k]->get_coord(), CUBIT_MAGENTA_INDEX);
          idata = new OctreeIntersectionData(temp_facet_normal, OCTREE_NEGATIVE, dist_to_facet, ptr_Ref_face, closest_point_on_facet, ptr_facet);
          idata->set_merged(1);
        else
          CubitBoolean temp_half_space = cubitOctreeNode[i][j][k]->get_halfspace_direction();
          if (surf_sense == CUBIT_FORWARD) {temp_facet_normal *= -1.0;}
          else if (surf_sense == CUBIT_REVERSED) {temp_half_space = !temp_half_space;}
          idata = new OctreeIntersectionData(temp_facet_normal, temp_half_space, dist_to_facet, ptr_Ref_face, closest_point_on_facet, ptr_facet);
//        idata->set_facet_ptr(ptr_facet);
//        idata->set_int_point(closest_point_on_facet);
        cubitOctreeNode[i][j][k]->append_list_item(idata);
#ifdef USE_octree_BGMESH
  if (!visit)
    greyCellList->append(this); // for background mesh generation
    visit = CUBIT_TRUE;
#endif
void CubitOctreeCell::set_leaf ( bool  type) [inline]
Definition at line 75 of file CubitOctreeCell.hpp.
{ leaf = type; }
void CubitOctreeCell::set_mark ( CubitBoolean  type) [inline]
Definition at line 101 of file CubitOctreeCell.hpp.
{ mark = type; }
void CubitOctreeCell::set_oct_grid_node ( const int  i,
const int  j,
const int  k,
CubitOctreeNode ptr_node
Definition at line 316 of file CubitOctreeCell.cpp.
  cubitOctreeNode[i][j][k] = ptr_node;
void CubitOctreeCell::set_visit ( CubitBoolean  type) [inline]
Definition at line 104 of file CubitOctreeCell.hpp.
{ visit = type; }
Definition at line 713 of file CubitOctreeCell.cpp.
  double size;
  int i, j, k;
  CubitVector center, min_corner, max_corner;
  double dim, dim_2;
  double Nx[2], Ny[2], Nz[2];
  double size_at_node;
  CubitOctreeNode *ptr_node;
    // Find Shape functions at eight grid nodes of a cell
  dim = get_dimension();
  dim_2  =  dimension / 2.0;
  min_corner.x( center.x() - dim_2 );
  min_corner.y( center.y() - dim_2 );
  min_corner.z( center.z() - dim_2 );
  max_corner.x( center.x() + dim_2 );
  max_corner.y( center.y() + dim_2 );
  max_corner.z( center.z() + dim_2 );
  Nx[0] = ( max_corner.x() - point.x() ) / dim;
  Ny[0] = ( max_corner.y() - point.y() ) / dim;
  Nz[0] = ( max_corner.z() - point.z() ) / dim;
  Nx[1] = ( point.x() - min_corner.x() ) / dim;
  Ny[1] = ( point.y() - min_corner.y() ) / dim;
  Nz[1] = ( point.z() - min_corner.z() ) / dim;
    // Trilinear interpolation
    // if number of nodes with zero size exceeds  MAX_NUM_ZERO_SIZE_NODES
    // then average size is used instead of zero
    // Interpolate using non-zero nodes
  size = 0.0;
  int zero_node_counter = 0;
        ptr_node = get_octree_grid_node(i, j, k);
        size_at_node = ptr_node->get_size(OCTREE_SIZE_DEFAULT);
        if( size_at_node != 0.0 ){
          size +=  size_at_node * Nx[i] * Ny[j] * Nz[k];
        else{
          if( ptr_node->find_size_using_adj_node() == CUBIT_TRUE ){
            size += ptr_node->get_size( OCTREE_SIZE_DEFAULT ) * Nx[i] * Ny[j] * Nz[k];
          else{
            zero_node_counter ++;
    // For interior of volume avg_size will not be calculated
    // as no zero size node exist
  if( zero_node_counter > MAX_NUM_ZERO_SIZE_NODES ){
      // Find Average size
    double avg_size = 0.0;
    int counter = 0;
          size_at_node = get_octree_grid_node(i, j, k)->get_size(OCTREE_SIZE_DEFAULT);
            avg_size +=  size_at_node;
            counter ++;
    if( counter > 0 ){
        // use avg_size instead of zero during tri-linear interpolation
        // only at nodes with zero size
            if( size_at_node == 0.0 ){
              size +=  avg_size * Nx[i] * Ny[j] * Nz[k];
    else{
      PRINT_DEBUG_157(" WARNING: Size of all nodes is zero \n" );
        //In size at a point default auto size will be used
        // autosize could be based on either average medial radius or
        // steve's autosize function
  return size;
Definition at line 1187 of file CubitOctreeCell.cpp.
  int index[3];
  int i, j, k;
  if( parent == NULL ){
    fprintf( pof, "C %d -1 0 0 0 %d\n", num, !leaf );
  else{
    find_indices_in_parent( index );
    fprintf( pof, "C %d %d %d %d %d %d \n", num, parent->id(), index[0], index[1], index[2], !leaf );
  fprintf( pof, "V");
        fprintf( pof," %d ", cubitOctreeNode[i][j][k]->get_num() );
  fprintf( pof, "\n");
  if( leaf == 0 ){
    fprintf( pof, "H");
          fprintf( pof," %d ", children[i][j][k]->id() );
          stack.append( children[i][j][k] );
  fprintf( pof, "E\n");
Member Data Documentation
Definition at line 205 of file CubitOctreeCell.hpp.
int CubitOctreeCell::color [private]
Definition at line 188 of file CubitOctreeCell.hpp.
Definition at line 197 of file CubitOctreeCell.hpp.
int CubitOctreeCell::depth [private]
Definition at line 179 of file CubitOctreeCell.hpp.
double CubitOctreeCell::dimension [private]
Definition at line 176 of file CubitOctreeCell.hpp.
Definition at line 182 of file CubitOctreeCell.hpp.
Definition at line 191 of file CubitOctreeCell.hpp.
Definition at line 173 of file CubitOctreeCell.hpp.
int CubitOctreeCell::num [private]
Definition at line 185 of file CubitOctreeCell.hpp.
Definition at line 204 of file CubitOctreeCell.hpp.
Definition at line 194 of file CubitOctreeCell.hpp.
