cgma
CubitOctreeNode Class Reference
#include <CubitOctreeNode.hpp>
List of all members.
Public Member Functions
 CubitOctreeNode (const CubitVector &cen, CubitOctreeCell *parent_cell, const int i, const int j, const int k)
 CubitOctreeNode (const double &x, const double &y, const double &z)
void initialize_constructor (const double &x, const double &y, const double &z)
 in CubitOctree outside nodes are GREY, inside nodes are BLACK. And boundary nodes are WHITE.
 ~CubitOctreeNode ()
void display (OctreeNodeConstant type=NODE_SIZE, float draw_size=-1)
int get_color ()
void set_color (const int new_color)
int get_num ()
CubitVectorget_coord ()
double get_size (OctreeSourceEntityType type) const
int id ()
void set_size (double s, int type)
void set_adj_node (enum OctreePosition type, CubitOctreeNode *ptr_grid_node)
void set_adj_node_distance (enum OctreePosition type, int dist)
double manhattan_distance_adj_node (int index)
double manhattan_distance_adj_node (CubitOctreeNode *ptr_adj_node)
double get_distance ()
double x ()
double y ()
double z ()
void x (double value)
void y (double value)
void z (double value)
CubitOctreeNodeget_adj_node (int num)
int get_adj_node_distance (enum OctreePosition type)
void append_list_item (CubitVector facet_normal)
void calc_facet_patch_distance_normal (DLIList< OctreeIntersectionData * > &idatas, int num_use_idatas, double &patch_distance, CubitVector &patch_normal, CubitBoolean sort, CubitBoolean set_Refface)
void SAT_find_face_distance_average_normal ()
CubitOctreeCellget_min_depth_cell ()
int get_cell_depth_difference ()
int get_counter ()
void update_adj_cell (CubitOctreeCell *ptr_cell, int i, int j, int k)
int find_min_depth_cell_and_depth_difference (void)
void calculate_size_based_on_cell_dimension (double bbox_dimension)
CubitOctreeCellget_adj_cell (const int i, const int j, const int k)
void set_mark (CubitBoolean type)
CubitBoolean get_mark ()
void set_visit (CubitBoolean type)
CubitBoolean get_visit () const
CubitVector get_normal () const
int find_half_space (CubitFacet *ptr_facet)
CubitBoolean get_halfspace_direction ()
void set_halfspace_direction (const CubitBoolean type)
void find_intersection_with_facet (CubitOctreeType type, RefFace *ptr_face, CubitFacet *ptr_facet, DLIList< CubitOctreeNode * > &boundary_white_node_list)
CubitBoolean find_intersection_point (int axis, CubitVector grid_node0, CubitVector grid_node1, CubitVector &facet_normal, CubitVector facet_vert0, CubitVector facet_vert1, CubitVector facet_vert2, CubitVector &int_point, double &para)
void append_list_item (OctreeIntersectionData *ptr_int_data)
DLIList
< OctreeIntersectionData * > *
get_idata_list ()
CubitBoolean bfs_to_find_contained_nodes (int max_onode_per_src)
CubitBoolean dfs_to_find_contained_nodes (int max_onode_per_src)
void find_distance_at_adj_node (PriorityQueue< CubitOctreeNode * > *heap)
CubitBoolean find_size_using_adj_node ()
Static Public Member Functions
static void reset_counter ()
static CubitBoolean is_same_side (const CubitVector &p1, const CubitVector &p2, const CubitVector &a, const CubitVector &b)
static CubitBoolean is_intersection_point_contained_inside_facet (const CubitVector &int_point, const CubitVector &facet_vert0, const CubitVector &facet_vert1, const CubitVector &facet_vert2)
static CubitBoolean compare_function (CubitOctreeNode *&a, CubitOctreeNode *&b)
Private Attributes
int num
CubitBoolean visit
CubitBoolean mark
short color
CubitBoolean halfspaceDirection
double size
DLIList< OctreeIntersectionData * > octreeIntersectionDataList
int cellDepthDifference
CubitOctreeCellminDepthCell
double distance
CubitVector coord
CubitOctreeNodeadjGridNode [6]
int adjNodeDistance [6]
CubitOctreeCelladjCell [2][2][2]
RefFacerefFace
CubitVector mNormal
Static Private Attributes
static int mCounter = -1
Detailed Description
Definition at line 31 of file CubitOctreeNode.hpp.
CubitOctreeNode::CubitOctreeNode ( const CubitVector cen,
CubitOctreeCell parent_cell,
const int  i,
const int  j,
const int  k
Definition at line 34 of file CubitOctreeNode.cpp.
  initialize_constructor( cen.x(), cen.y(), cen.z() );
  adjCell[x_index][y_index][z_index] = parent_cell;
CubitOctreeNode::CubitOctreeNode ( const double &  x,
const double &  y,
const double &  z
Definition at line 40 of file CubitOctreeNode.cpp.
Definition at line 45 of file CubitOctreeNode.cpp.
  int i;
  OctreeIntersectionData *idata;
  for (i=0; i < octreeIntersectionDataList.size(); ++i)
    idata = octreeIntersectionDataList.get_and_step();
    if (idata != NULL)
      delete idata;
  octreeIntersectionDataList.clean_out();
Member Function Documentation
void CubitOctreeNode::append_list_item ( OctreeIntersectionData ptr_int_data) [inline]
Definition at line 159 of file CubitOctreeNode.hpp.
        octreeIntersectionDataList.push( ptr_int_data );
void CubitOctreeNode::calc_facet_patch_distance_normal ( DLIList< OctreeIntersectionData * > &  idatas,
int  num_use_idatas,
double &  patch_distance,
CubitVector patch_normal,
CubitBoolean  sort,
Definition at line 395 of file CubitOctreeNode.cpp.
  int i, j;
  CubitBoolean duplicate = CUBIT_FALSE;
  for (i=0; i < idatas.size(); ++i)
    idatas.reset();
    idatas.step(i);
    OctreeIntersectionData *first = idatas.get();
    for (j=i+1; j < idatas.size(); ++j)
      idatas.reset();
      idatas.step(j);
      if (idatas.get() == first) {duplicate = CUBIT_TRUE;}
      break;
    if (duplicate == CUBIT_TRUE) {break;}
  if (duplicate) {PRINT_INFO("Duplicate idatas found for node %d\n", this->get_num());}
  if (sort) {idatas.sort(OctreeIntersectionData::compare_function);}
  idatas.reset();
  if (sort)
    patch_distance = /*(coord - idatas.get()->get_int_point())%idatas.get()->get_facet_normal();*/ idatas.get()->get_length();
//    CubitFacet *ptr_facet = idatas.get()->get_facet_ptr();
//    CubitVector closest_point_on_facet = idatas.get()->get_int_point(), facet_normal = idatas.get()->get_facet_normal();
/*    if (fabs((coord - closest_point_on_facet)%facet_normal) != (coord-closest_point_on_facet).length())
      SVDrawTool::clear_non_retained();
      SVDrawTool::draw_vector(coord, closest_point_on_facet, CUBIT_YELLOW_INDEX);
      PRINT_INFO("closest length is %lf\n", idatas.get()->get_length());
      DLIList<CubitFacet*> temp_facets;
      temp_facets.append(ptr_facet);
      SVDrawTool::draw_facets(temp_facets, CUBIT_YELLOW_INDEX);
      temp_facets.clean_out();
      CubitFacet *facet = idatas.get()->get_facet_ptr();
      if (facet != ptr_facet)
      SVDrawTool::draw_vector(coord, idatas.get()->get_int_point(), CUBIT_RED_INDEX);
      PRINT_INFO("Other length is %lf\n", idatas.get()->get_length());
      idatas.step();
      temp_facets.append(facet);
      temp_facets.remove(ptr_facet);
      SVDrawTool::draw_facets(temp_facets, CUBIT_RED_INDEX);
      int j,k;
      for (i=0; i < 2; ++i)
      for (j=0; j < 2; ++j)
      for (k=0; k < 2; ++k)
      CubitOctreeCell *CubitOctree_cell = adjCell[i][j][k];
      if (CubitOctree_cell == NULL) {continue;}
      double corners[3];
      double half_edge_length = CubitOctree_cell->get_dimension()/2.0;
      CubitVector center = CubitOctree_cell->get_center();
      center.get_xyz(corners);
      float box[6] = {corners[0]-half_edge_length, corners[1]-half_edge_length, corners[2]-half_edge_length,
      corners[0]+half_edge_length, corners[1]+half_edge_length, corners[2]+half_edge_length};
      SVDrawTool::draw_cube(box, CUBIT_GREEN_INDEX, SVDrawTool::WIRE);
      SVDrawTool::mouse_xforms();
  else {patch_distance = -1;}
  if (set_Refface) {refFace = idatas.get()->get_face();}
  if (num_use_idatas == -1) {num_use_idatas = idatas.size();}
  patch_normal = CubitVector(0,0,0);
    /*for (i=0; i < num_use_idatas; ++i)
      double len = idatas.get()->get_length();
      if (len < OCTREE_EPSILON) {len = OCTREE_EPSILON;}
      normal += idatas.get()->get_facet_normal() * 1/(len);
      idatas.step();
      normal.normalize(); */
  OctreeIntersectionData *ptr_data;
    //double denominator = 0.0;
  double length;
    //distance = 0.0;
  for( i=0; i < num_use_idatas; i++ )
    ptr_data = idatas.get_and_step();  // VED: important
    length = ptr_data->get_length();
    if( length < OCTREE_EPSILON ){
      patch_normal += ptr_data->get_normal() * (1/(OCTREE_EPSILON*OCTREE_EPSILON));
        //distance += ( ptr_data->get_normal()%( coord - ptr_data->get_int_point() ) ) * (1/OCTREE_EPSILON)/denominator;
    else{
      patch_normal += ptr_data->get_normal() * (1/(length*length));
        //distance += ( ptr_data->get_normal()%( coord - ptr_data->get_int_point() ) ) * (1/length)/denominator;
  patch_normal.normalize();
Definition at line 366 of file CubitOctreeNode.cpp.
  int i;
  int counter = 0;
  double sum = 0.0;
  for( i = 0; i < 6; i++ ){
    if( adjNodeDistance[i] >= 0  ){
      sum += 1.0 / pow( 2.0, adjNodeDistance[i] );
      counter++;
  size = sum / counter * bbox_dimension;
Definition at line 898 of file CubitOctreeNode.cpp.
  if( a->get_distance() < b->get_distance() )
    return CUBIT_TRUE;
  else
    return CUBIT_FALSE;
void CubitOctreeNode::display ( OctreeNodeConstant  type = NODE_SIZE,
float  draw_size = -1
Definition at line 114 of file CubitOctreeNode.cpp.
  switch( type ){
    case NODE_SIZE:
        if (draw_size < 0)
          draw_size = size;
        //SkeletonDebug::draw_point( coord, draw_size );
        break;
    case NODE_DISTANCE:
        if( color == CUBIT_BLACK_INDEX ){
          //SkeletonDebug::draw_point( coord,  (float)draw_size ) ;
        break;
    case NODE_FACE_NUM:
        if( refFace != NULL ){
          //SkeletonDebug::draw_point( coord, (float)(( refFace->id() % 18) * 0.5)   );
        else{
          PRINT_INFO("ERROR: Face Ptr Doesn't Exist in White Grid Node \n");
        break;
    case NODE_NORMAL:
        //SkeletonDebug::draw_line(coord, draw_size, coord+mNormal,draw_size);
      break;
    default:
        //SkeletonDebug::draw_point( coord, 1 );
        break;
Definition at line 907 of file CubitOctreeNode.cpp.
  int i;
  CubitVector mat_pnt_center;
  double new_node_distance;
  // PRINT_INFO("Testing: Face id = %d\n", mrefFace->id());
  visit = CUBIT_TRUE;
    // at the boundary of solid
    if( adjGridNode[i] == NULL )
      continue;
    //  *************** WARNING *********
    // if the adjGridNode is on boundary or outside don't do anything
    // Just testing white node is enough because we assume the facet and the grid
    // intersection done during octree generation is correct
    // At this point only at the boundary there is white and black nodes because of facet/octree intersection
    // and both at interior and outside we grey node
    //if( adjGridNode[i]->get_color() == CUBIT_WHITE_INDEX || adjGridNode[i]->get_color() == CUBIT_GREY_INDEX )
    if( adjGridNode[i]->get_color() == CUBIT_WHITE_INDEX || adjGridNode[i]->get_color() == CUBIT_YELLOW_INDEX)
      continue;
    // meeting of the front should be the major
    // criteria not the size value. check for null of
    // grid_node->face. then check for adjacency, black_white, and size...
    new_node_distance = distance + ( adjGridNode[i]->coord - coord )%mNormal;
    // WARNING: The below condition is very important.
    // Therefore I think the normal calculation is wrong
    // Front should always go forward.
    if(new_node_distance <= distance)
      // OPEN IT
      // this happens at the concave region containing many surfaces.
      //PRINT_DEBUG_157(" Distance Calculation is wrong (discresing)\n");
      if (adjGridNode[i]->refFace != NULL)
        //if (adjGridNode[i]->mrefFace != mrefFace)
        continue;
        adjGridNode[i]->color = CUBIT_BLACK_INDEX;
        //new_node_distance = distance;
        continue;
      //SVDrawTool::draw_vector(adjGridNode[i]->coord, closest, CUBIT_RED_INDEX);
    //if( adjGridNode[i]->mrefFace != mrefFace )
    if( adjGridNode[i]->refFace == NULL ){
      // internal black nodes
      // not near skeleton
      adjGridNode[i]->distance = new_node_distance;
      adjGridNode[i]->refFace = refFace;
      adjGridNode[i]->mNormal = mNormal;
      heap->push( adjGridNode[i] );
    else{
Definition at line 383 of file CubitOctreeNode.cpp.
  if( (coord - ptr_facet->point(0)->coordinates()) % (ptr_facet->normal()) >= 0 )
    halfspaceDirection = OCTREE_POSITIVE;
  return halfspaceDirection;
CubitBoolean CubitOctreeNode::find_intersection_point ( int  axis,
CubitVector facet_normal,
CubitVector int_point,
double &  para
Definition at line 735 of file CubitOctreeNode.cpp.
  double A, B, C, D;
  double nominator, denominator;
  D = - ( facet_normal%(facet_vert1 - grid_node0) );
  A = facet_normal.x();
  B = facet_normal.y();
  C = facet_normal.z();
  switch( axis ){
    case OCTREE_X:
        if( fabs(A) < OCTREE_EPSILON ){
            //line parallel to facet
            // both end points are intersection points
          return CUBIT_FALSE;
        else{
          nominator = D;
          denominator = A * ( grid_node0.x() - grid_node1.x() );
          para = nominator / denominator;
        break;
    case OCTREE_Y:
        if( fabs(B) < OCTREE_EPSILON ){
          return CUBIT_FALSE;
        else{
          nominator = D;
          denominator = B * ( grid_node0.y() - grid_node1.y() );
        break;
    case OCTREE_Z:
        if( fabs(C) < OCTREE_EPSILON ){
          return CUBIT_FALSE;
        else{
          nominator = D;
          denominator = C * ( grid_node0.z() - grid_node1.z() );
        break;
    default:
        break;
  int_point = grid_node0 + para * ( grid_node1 - grid_node0 );
  return( is_intersection_point_contained_inside_facet( int_point, facet_vert0, facet_vert1, facet_vert2 ) );
void CubitOctreeNode::find_intersection_with_facet ( CubitOctreeType  type,
RefFace ptr_face,
CubitFacet ptr_facet,
DLIList< CubitOctreeNode * > &  boundary_white_node_list
Definition at line 629 of file CubitOctreeNode.cpp.
  int i;
  CubitBoolean result;
  CubitVector int_point;
  CubitVector facet_normal;
  double para;
  facet_normal = ptr_facet->normal();
    result = CUBIT_FALSE;
    if( adjGridNode[i] != NULL ){
      if( adjGridNode[i]->halfspaceDirection == OCTREE_NEGATIVE && adjGridNode[i]->mark == CUBIT_TRUE ){
          //-  adj_node[0] = O_FRONT Node
          //-  adj_node[1] = O_BACK Node
          //-  adj_node[2] = O_RIGHT Node
          //-  adj_node[3]  = O_LEFT Node
          //-  adj_node[4] = O_TOP Node
          //-  adj_node[5] = O_BOTTOM Node
        switch( i ){
          case O_FRONT:
              result = find_intersection_point( OCTREE_X, coord, adjGridNode[i]->coord, facet_normal, ptr_facet->point(0)->coordinates(), ptr_facet->point(1)->coordinates(), ptr_facet->point(2)->coordinates(), int_point, para );
              break;
          case O_BACK:
              break;
          case O_RIGHT:
              result = find_intersection_point( OCTREE_Y, coord, adjGridNode[i]->coord, facet_normal, ptr_facet->point(0)->coordinates(), ptr_facet->point(1)->coordinates(), ptr_facet->point(2)->coordinates(), int_point, para );
              break;
          case O_LEFT:
              break;
          case O_TOP:
              result = find_intersection_point( OCTREE_Z, coord, adjGridNode[i]->coord, facet_normal, ptr_facet->point(0)->coordinates(), ptr_facet->point(1)->coordinates(), ptr_facet->point(2)->coordinates(), int_point, para );
              break;
          case O_BOTTOM:
              break;
          default:
              break;
    if( result == CUBIT_TRUE ){
      OctreeIntersectionData * ptr_data;
      switch( type ){
        case CUBIT_OCTREE_VOLUME:
              // update color of boundary node
            if( color != CUBIT_WHITE_INDEX ){
                  // Mark the common cells incident on both end points of the edge as GREY
                  // To resolve the intersection problems I added the SAT intersection code -ved
              boundary_white_node_list.push( this );
              refFace = ptr_face;
                //PRINT_DEBUG_157(" Testing:  Face Num = %d\n", RefFace->id() );
              color = CUBIT_WHITE_INDEX;
              distance = -1;
            // WARNING: devided by zero.
             ptr_data = new OctreeIntersectionData( this, facet_normal * -1, int_point, (adjGridNode[i]->coord - int_point).length(), ptr_face );
            adjGridNode[i]->append_list_item( ptr_data );
            break;
        case CUBIT_OCTREE_FACE:
            refFace = ptr_face;
            distance = -1;
            break;
        default:
            PRINT_INFO("This case not yet implemented \n");
            break;
Definition at line 332 of file CubitOctreeNode.cpp.
  int i, j, k;
  int depth_min_depth_cell = CUBIT_INT_MAX;
  int depth_max_detph_cell = -CUBIT_INT_MAX;
  int depth;
  for( i = 0; i < 2; i++ ){
    for( j = 0; j < 2; j++ ){
      for( k = 0; k < 2; k++ ){
        if( adjCell[i][j][k] != NULL ){
          depth = adjCell[i][j][k]->get_depth();
          if( depth < depth_min_depth_cell ){
            depth_min_depth_cell = depth;
            minDepthCell = adjCell[i][j][k];
          if( depth > depth_max_detph_cell ){
            depth_max_detph_cell = depth;
  if( depth_min_depth_cell != CUBIT_INT_MAX && depth_max_detph_cell != -CUBIT_INT_MAX ){
    cellDepthDifference = depth_max_detph_cell - depth_min_depth_cell;
  else{
    cellDepthDifference = 0;
  return cellDepthDifference;
Definition at line 871 of file CubitOctreeNode.cpp.
  int i;
  double sum = 0.0;
  int count = 0;
  for( i = 0; i < 6; i ++ ){
        // WARNING: Why we need to check for -1
        //if( adjGridNode[i]->size != -1 && adjGridNode[i]->size != CUBIT_DBL_MAX && adjGridNode[i]->size != 0){
        //if( adjGridNode[i]->size != CUBIT_DBL_MAX && adjGridNode[i]->size != 0.0 ){
      if( adjGridNode[i]->size != 0.0 ){
        sum += adjGridNode[i]->size;
        count++;
  if( sum != 0.0 ){
    size = sum / count;
    return CUBIT_TRUE;
  else
    return CUBIT_FALSE;
CubitOctreeCell* CubitOctreeNode::get_adj_cell ( const int  i,
const int  j,
const int  k
) [inline]
Definition at line 120 of file CubitOctreeNode.hpp.
{ return adjCell[i][j][k]; }
Definition at line 169 of file CubitOctreeNode.cpp.
  switch (select)
    case O_LEFT:
        return adjGridNode[O_LEFT];
    case O_RIGHT:
        return adjGridNode[O_RIGHT];
    case O_BOTTOM:
        return adjGridNode[O_BOTTOM];
    case O_TOP:
        return adjGridNode[O_TOP];
    case O_BACK:
        return adjGridNode[O_BACK];
    case O_FRONT:
        return adjGridNode[O_FRONT];
    default:
        PRINT_INFO("ERROR: AdjNode index exceeded\n");
        return NULL;
Definition at line 302 of file CubitOctreeNode.cpp.
  switch( select ){
    case O_LEFT:
        return adjNodeDistance[O_LEFT];
    case O_RIGHT:
        return adjNodeDistance[O_RIGHT];
    case O_BOTTOM:
        return adjNodeDistance[O_BOTTOM];
    case O_TOP:
        return adjNodeDistance[O_TOP];
    case O_BACK:
        return adjNodeDistance[O_BACK];
    case O_FRONT:
        return adjNodeDistance[O_FRONT];
    default:
        PRINT_INFO("ERROR: AdjNode index exceeded");
        return CUBIT_TRUE;
Definition at line 100 of file CubitOctreeNode.hpp.
{ return cellDepthDifference; }
int CubitOctreeNode::get_color ( ) [inline]
Definition at line 46 of file CubitOctreeNode.hpp.
{ return color; }
Definition at line 54 of file CubitOctreeNode.hpp.
{ return coord; }
Definition at line 107 of file CubitOctreeNode.cpp.
    //static int counter = -1;
  mCounter++;
  return(mCounter);
double CubitOctreeNode::get_distance ( ) [inline]
Definition at line 74 of file CubitOctreeNode.hpp.
{ return distance; }
Definition at line 124 of file CubitOctreeNode.hpp.
{ return mark; }
Definition at line 97 of file CubitOctreeNode.hpp.
{ return minDepthCell; }
Definition at line 132 of file CubitOctreeNode.hpp.
{return mNormal;}
int CubitOctreeNode::get_num ( ) [inline]
Definition at line 51 of file CubitOctreeNode.hpp.
{ return num; }
Definition at line 157 of file CubitOctreeNode.cpp.
    return size;
Definition at line 129 of file CubitOctreeNode.hpp.
{return visit;}
int CubitOctreeNode::id ( void  ) [inline]
Definition at line 60 of file CubitOctreeNode.hpp.
{ return num; }
void CubitOctreeNode::initialize_constructor ( const double &  x,
const double &  y,
const double &  z
Definition at line 63 of file CubitOctreeNode.cpp.
  int i, j, k;
  color = CUBIT_GREY_INDEX;  // boundary nodes are colored white and inside nodes black
                       // during facet intersection the white nodes dominates black
  visit = CUBIT_FALSE; // mat generation
  mark = CUBIT_FALSE;
  halfspaceDirection = OCTREE_NEGATIVE;
  num = get_counter();
  size = 0.0;
   distance = CUBIT_DBL_MAX;
  minDepthCell = NULL;
  mNormal.x(0.0);
  mNormal.y(0.0);
  mNormal.z(0.0);
  coord.x(x);
  coord.y(y);
  coord.z(z);
        adjCell[i][j][k] = NULL;
    // LRBTFN
    adjGridNode[i] = NULL;
    adjNodeDistance[i] = -1; // ?
 refFace = NULL;
CubitBoolean CubitOctreeNode::is_intersection_point_contained_inside_facet ( const CubitVector int_point,
const CubitVector facet_vert0,
const CubitVector facet_vert1,
const CubitVector facet_vert2
) [static]
Definition at line 815 of file CubitOctreeNode.cpp.
  if ( fabs((int_point-facet_vert0)%( (facet_vert1-facet_vert0) * (facet_vert2-facet_vert0) )) > OCTREE_EPSILON)
    return CUBIT_FALSE;
  if (is_same_side(int_point,facet_vert0, facet_vert1,facet_vert2) && is_same_side(int_point,facet_vert1, facet_vert0,facet_vert2) && is_same_side(int_point,facet_vert2, facet_vert0,facet_vert1)) {return CUBIT_TRUE;}
  return CUBIT_FALSE;
    /*CubitVector line0, line1, line2;
      double ang0, ang1, ang2;
      line0 = facet_vert0 - int_point ;
      line0 = line0 / line0.length();
      line1 = facet_vert1 - int_point ;
      line1 = line1 / line1.length();
      line2 = facet_vert2 - int_point ;
      line2 = line2 / line2.length();
        //Added (M. Brewer) to check for an invalid number passed to acos
          //compute ang0
          double temp_double = line0 % line1;
          if(temp_double>1.0)
          temp_double=1.0;
          else if (temp_double<-1.0)
          temp_double=-1.0;
          ang0 = acos( temp_double  );
            //compute ang1
            temp_double = line1 % line2;
            if(temp_double>1.0)
            temp_double=1.0;
            temp_double=-1.0;
            ang1 = acos( temp_double  );
              //compute ang2
              temp_double = line2 % line0;
              if(temp_double>1.0)
              temp_double=1.0;
              temp_double=-1.0;
              ang2 = acos( temp_double  );
              if( fabs ( ( ang0 + ang1 + ang2 ) - CUBIT_PI * 2 ) < OCTREE_EPSILON ){
              return CUBIT_TRUE;
              else{
              return CUBIT_FALSE;
CubitBoolean CubitOctreeNode::is_same_side ( const CubitVector p1,
const CubitVector p2,
const CubitVector a,
const CubitVector b
) [static]
Definition at line 802 of file CubitOctreeNode.cpp.
  static CubitVector edge;
  edge = b-a;
    //cp1 = edge*(p1-a);
    //cp2 = edge*(p2-a);
  if ( (edge*(p1-a)) % (edge*(p2-a))  >= 0) {return CUBIT_TRUE;}
  return CUBIT_FALSE;
Definition at line 269 of file CubitOctreeNode.cpp.
  switch( index ){
    case O_FRONT:
        return fabs( coord.x() - adjGridNode[index]->coord.x() );
    case O_BACK:
    case O_RIGHT:
        return fabs( coord.y() - adjGridNode[index]->coord.y() );
    case O_LEFT:
    case O_TOP:
        return fabs( coord.z() - adjGridNode[index]->coord.z() );
    case O_BOTTOM:
    default:
        PRINT_INFO("WARNING: Adjacent grid node index doesn't exist");
        return 1.0;
Definition at line 298 of file CubitOctreeNode.cpp.
  return fabs( coord.x() - ptr_adj_node->coord.x() ) + fabs(coord.y() - ptr_adj_node->coord.y()) + fabs(coord.z() - ptr_adj_node->coord.z());
static void CubitOctreeNode::reset_counter ( ) [inline, static]
Definition at line 106 of file CubitOctreeNode.hpp.
{mCounter = -1;}
Definition at line 518 of file CubitOctreeNode.cpp.
    // three cases:
    // 1) One facet (one RefFace) => use facet's normal and distance to facet, RefFace is set to facet's owning face
    // 2) Multiple facets, one refFace => use distance to closest facet and its owning RefFace, IDW normal from N closest facets
    // 3) Multiple facets, multiple RefFaces => use distance to closest facet and its owning RefFace, IDW normal from N closest facets
    //int i, j, k;
    // case: no intersection datas, this should not happen. I should prolly put an cassertere.
  if (octreeIntersectionDataList.size() == 0)
    PRINT_ERROR("No OctreeIntersectionDatas attached to black grid node in queue for MAT generation!\n");
    return;
    // case: one facet, just get distance, normal, and face from facet
  if (octreeIntersectionDataList.size() == 1)
    distance = octreeIntersectionDataList.get()->get_length();
    mNormal = octreeIntersectionDataList.get()->get_facet_normal();
    refFace = octreeIntersectionDataList.get()->get_face();
      // remember to delete the idata - check if this is ok
    delete octreeIntersectionDataList.get();
    return;
    // case: multiple facets, one face
    // just initialize normal, distance, and Refface
    // case: two faces
    // determine if disconnected and if normals diverge => EWC case 1
    // else check angle
    // now find N closest facets (keep list of idatas though)
    // choose closest one, use distance to it and use its RefFace
    // then use all and IDW to get normal
  int num_facets_to_use;
  if (N_CLOSEST_FACETS_FACTOR_FOR_FRONT_NORMALS == 0.00) {num_facets_to_use = 1;}
  else if (N_CLOSEST_FACETS_FACTOR_FOR_FRONT_NORMALS == 1.00) {num_facets_to_use = octreeIntersectionDataList.size();}
  else {num_facets_to_use = (int)(N_CLOSEST_FACETS_FACTOR_FOR_FRONT_NORMALS * octreeIntersectionDataList.size());}
  if (num_facets_to_use == 0) {num_facets_to_use = 1;}
  else if (num_facets_to_use > octreeIntersectionDataList.size()) {num_facets_to_use = octreeIntersectionDataList.size();}
    /*DLIList<OctreeIntersectionData*> n_closest_idatas;
    RTree<OctreeIntersectionData*> *rtree = new RTree<OctreeIntersectionData*>;
    double closest = CUBIT_DBL_MAX;
    rtree->add(octreeIntersectionDataList.get_and_step());
    rtree->k_nearest_neighbor(coord, num_facets_to_use, closest, n_closest_idatas, OctreeIntersectionData::dist_sqr_to_vec);
    delete rtree;
//  calc_facet_patch_distance_normal(octreeIntersectionDataList, num_facets_to_use, distance, normal, CUBIT_TRUE, CUBIT_TRUE);
refFace = n_closest_idatas.get()->get_face();
distance = n_closest_idatas.get()->get_length();
for (i=0; i < num_facets_to_use; ++i)
double len = n_closest_idatas.get()->get_length();
normal += n_closest_idatas.get_and_step()->get_facet_normal() * 1/(len);
normal.normalize();*/
    mNormal = CubitVector(0,0,0);
    calc_facet_patch_distance_normal(octreeIntersectionDataList, num_facets_to_use, distance, mNormal, CUBIT_TRUE, CUBIT_TRUE);
        octreeIntersectionDataList.sort(OctreeIntersectionData::compare_function);
        octreeIntersectionDataList.reset();
        double len = octreeIntersectionDataList.get()->get_length();
        normal += octreeIntersectionDataList.get_and_step()->get_facet_normal() * 1/(len);
        normal.normalize();
      // now normal, distance to boundary, and Refface have been set
void CubitOctreeNode::set_adj_node ( enum OctreePosition  type,
CubitOctreeNode ptr_grid_node
Definition at line 197 of file CubitOctreeNode.cpp.
  switch( select )
    case O_LEFT:
        adjGridNode[O_LEFT] = ptr_node;
        break;
    case O_RIGHT:
        adjGridNode[O_RIGHT] = ptr_node;
        break;
    case O_BOTTOM:
        adjGridNode[O_BOTTOM] = ptr_node;
        break;
    case O_TOP:
        adjGridNode[O_TOP] = ptr_node;
        break;
    case O_BACK:
        adjGridNode[O_BACK] = ptr_node;
        break;
    case O_FRONT:
        adjGridNode[O_FRONT] = ptr_node;
        break;
    default:
void CubitOctreeNode::set_adj_node_distance ( enum OctreePosition  type,
int  dist
Definition at line 233 of file CubitOctreeNode.cpp.
  switch( select ){
    case O_LEFT:
        adjNodeDistance[O_LEFT] = dist;
        break;
    case O_RIGHT:
        adjNodeDistance[O_RIGHT] = dist;
        break;
    case O_BOTTOM:
        adjNodeDistance[O_BOTTOM] = dist;
        break;
    case O_TOP:
        adjNodeDistance[O_TOP] = dist;
        break;
    case O_BACK:
        adjNodeDistance[O_BACK] = dist;
        break;
    case O_FRONT:
        adjNodeDistance[O_FRONT] = dist;
        break;
    default:
        PRINT_INFO(" ERROR: AdjNode index exceeded");
void CubitOctreeNode::set_color ( const int  new_color) [inline]
Definition at line 49 of file CubitOctreeNode.hpp.
{color = new_color;}
Definition at line 141 of file CubitOctreeNode.hpp.
{ halfspaceDirection = type ; }
void CubitOctreeNode::set_mark ( CubitBoolean  type) [inline]
Definition at line 123 of file CubitOctreeNode.hpp.
{ mark = type; }
void CubitOctreeNode::set_size ( double  s,
int  type
Definition at line 163 of file CubitOctreeNode.cpp.
        size = s;
void CubitOctreeNode::set_visit ( CubitBoolean  type) [inline]
Definition at line 126 of file CubitOctreeNode.hpp.
{ visit = type; }
void CubitOctreeNode::update_adj_cell ( CubitOctreeCell ptr_cell,
int  i,
int  j,
int  k
) [inline]
Definition at line 108 of file CubitOctreeNode.hpp.
        adjCell[i][j][k] = ptr_cell;
double CubitOctreeNode::x ( ) [inline]
Definition at line 76 of file CubitOctreeNode.hpp.
{ return coord.x(); }
void CubitOctreeNode::x ( double  value) [inline]
Definition at line 81 of file CubitOctreeNode.hpp.
{ coord.x( value ); }
double CubitOctreeNode::y ( ) [inline]
Definition at line 77 of file CubitOctreeNode.hpp.
{ return coord.y(); }
void CubitOctreeNode::y ( double  value) [inline]
Definition at line 82 of file CubitOctreeNode.hpp.
{ coord.y( value ); }
double CubitOctreeNode::z ( ) [inline]
Definition at line 78 of file CubitOctreeNode.hpp.
{ return coord.z(); }
void CubitOctreeNode::z ( double  value) [inline]
Definition at line 83 of file CubitOctreeNode.hpp.
{ coord.z( value ); }
Member Data Documentation
Definition at line 239 of file CubitOctreeNode.hpp.
Definition at line 233 of file CubitOctreeNode.hpp.
Definition at line 236 of file CubitOctreeNode.hpp.
Definition at line 221 of file CubitOctreeNode.hpp.
short CubitOctreeNode::color [private]
Definition at line 205 of file CubitOctreeNode.hpp.
Definition at line 230 of file CubitOctreeNode.hpp.
double CubitOctreeNode::distance [private]
Definition at line 228 of file CubitOctreeNode.hpp.
Definition at line 203 of file CubitOctreeNode.hpp.
int CubitOctreeNode::mCounter = -1 [static, private]
Definition at line 200 of file CubitOctreeNode.hpp.
Definition at line 225 of file CubitOctreeNode.hpp.
Definition at line 245 of file CubitOctreeNode.hpp.
int CubitOctreeNode::num [private]
Definition at line 197 of file CubitOctreeNode.hpp.
Definition at line 242 of file CubitOctreeNode.hpp.
double CubitOctreeNode::size [private]
Definition at line 212 of file CubitOctreeNode.hpp.
Definition at line 202 of file CubitOctreeNode.hpp.
