cgma
CubitTransformMatrix Class Reference
#include <CubitTransformMatrix.hpp>
Inheritance diagram for CubitTransformMatrix:
CubitMatrix
List of all members.
Public Member Functions
 CubitTransformMatrix ()
 CubitTransformMatrix (const CubitTransformMatrix &from)
 ~CubitTransformMatrix ()
CubitTransformMatrixtranslate (const CubitVector &v)
CubitTransformMatrixtranslate (double x, double y, double z)
CubitTransformMatrixrotate (double degrees, const CubitVector &vector)
CubitTransformMatrixrotate (double degrees, char axis)
CubitTransformMatrixrotate (double degrees, const CubitVector &axis_from, const CubitVector &axis_to)
void get_rotation_axis_and_angle (CubitVector &rotation_axis, double &angle)
CubitTransformMatrixreflect (const CubitVector &vector)
CubitTransformMatrixscale_about_origin (const CubitVector &scale)
CubitTransformMatrixscale_about_origin (double x, double y, double z)
CubitTransformMatrixscale_about_origin (double scale)
CubitTransformMatrixinverse ()
CubitVector operator* (const CubitVector &point) const
CubitTransformMatrix operator* (const CubitTransformMatrix &matrix) const
CubitMatrix operator* (const CubitMatrix &matrix) const
CubitTransformMatrix operator* (double val) const
CubitVector origin () const
 return the origin of this system
CubitVector x_axis () const
 return the x-axis
CubitVector y_axis () const
 return the y-axis
CubitVector z_axis () const
 return the z-axis
void print_me () const
Static Public Member Functions
static CubitTransformMatrix construct_matrix (const CubitVector &origin, const CubitVector &x_axis, const CubitVector &y_axis)
Friends
CUBIT_UTIL_EXPORT CubitVector operator* (const CubitVector &point, const CubitTransformMatrix &matrix)
Detailed Description
Definition at line 20 of file CubitTransformMatrix.hpp.
Definition at line 16 of file CubitTransformMatrix.cpp.
    : CubitMatrix(4)
    // Just creates a 4x4 matrix set to identity
Definition at line 22 of file CubitTransformMatrix.cpp.
    : CubitMatrix(from)
    // Just copies it
Definition at line 29 of file CubitTransformMatrix.cpp.
    // Just deletes it
Member Function Documentation
CubitTransformMatrix CubitTransformMatrix::construct_matrix ( const CubitVector origin,
const CubitVector x_axis,
const CubitVector y_axis
) [static]
Definition at line 386 of file CubitTransformMatrix.cpp.
  CubitTransformMatrix mat;
  double angle = x_axis.interior_angle(CubitVector(1,0,0));
  CubitVector axis = angle == 180 ? CubitVector(0,1,0) : CubitVector(1,0,0) * x_axis;
  mat.rotate(angle, axis);
  CubitVector y = mat * CubitVector(0,1,0);
  angle = y_axis.interior_angle(y);
  axis = angle == 180 ? CubitVector(0,0,1) : y * y_axis;
  mat.translate(origin);
  return mat;
void CubitTransformMatrix::get_rotation_axis_and_angle ( CubitVector rotation_axis,
double &  angle
Definition at line 402 of file CubitTransformMatrix.cpp.
    double cos_theta = (this->get(0,0) + this->get(1,1) + this->get(2,2) - 1) / 2;
    double x = 0;
    double y = 0;
    double z = 0;
    if (fabs(cos_theta - 1) < .0001)
        // theta is 1 or almost 1
        angle = 0;
        x = 0;
        y = 0;
        z = 1;
    else if (fabs(cos_theta + 1) > .0001)
        // theta is NOT -1 or almost -1
        angle = acos(cos_theta);
        angle =  (angle * 180.0) / CUBIT_PI; // convert to degrees
        double sin_theta = sqrt(1 - cos_theta * cos_theta);
        x = ( (this->get(2,1) - this->get(1,2)) / 2 ) / sin_theta;
        y = ( (this->get(0,2) - this->get(2,0)) / 2 ) / sin_theta;
        z = ( (this->get(1,0) - this->get(0,1)) / 2 ) / sin_theta;
    else
        angle = 180;
        if (this->get(0,0) >= this->get(1,1))
            if (this->get(0,0) >= this->get(2,2))
                // 0,0 is maximal diagonal term
                x = sqrt(this->get(0,0) - this->get(1,1) - this->get(2,2) + 1) / 2;
                double half_inverse = 1 / (2 * x);
                y = half_inverse * this->get(0,1);
                z = half_inverse * this->get(0,2);
            else
                // 2,2 is maximal diagonal term
                z = sqrt(this->get(2,2) - this->get(0,0) - this->get(1,1) + 1) / 2;
                double half_inverse = 1 / (2 * z);
                x = half_inverse * this->get(0,2);
                y = half_inverse * this->get(1,2);
        else
            if (this->get(1,1) >= this->get(2,2))
                // 1,1 is maximal diagonal term
                y = sqrt(this->get(1,1) - this->get(0,0) - this->get(2,2) + 1) / 2;
                double half_inverse = 1 / (2 * y);
                x = half_inverse * this->get(0,1);
                z = half_inverse * this->get(1,2);
            else
    rotation_axis.x(x);
    rotation_axis.y(y);
    rotation_axis.z(z);
Reimplemented from CubitMatrix.
Definition at line 255 of file CubitTransformMatrix.cpp.
  CubitMatrix matrix = *this;
  matrix = matrix.inverse();
  for( int ii = 0; ii < 4; ii++ )
    for( int jj = 0; jj < 4; jj++ )
      set( ii, jj, matrix.get(ii,jj) );
  return *this;
CubitVector CubitTransformMatrix::operator* ( const CubitVector point) const
Definition at line 271 of file CubitTransformMatrix.cpp.
    // Make a sub-matrix, multiply the point by it.
  CubitVector vec = (this->sub_matrix(3, 3))*point;
    // Handle the fourth column here
  vec.x(vec.x() + get(0, 3));
  vec.y(vec.y() + get(1, 3));
  vec.z(vec.z() + get(2, 3));
  return vec;
CubitTransformMatrix CubitTransformMatrix::operator* ( const CubitTransformMatrix matrix) const
Definition at line 305 of file CubitTransformMatrix.cpp.
  CubitTransformMatrix rv;
  CubitMatrix temp(4);
  temp = CubitMatrix::operator*(matrix);
  for (int i = 0; i < 4; i++)
    for (int j = 0; j < 4; j++)
      rv.set(i, j, temp.get(i,j));
  return rv;
CubitMatrix CubitTransformMatrix::operator* ( const CubitMatrix matrix) const
Definition at line 317 of file CubitTransformMatrix.cpp.
  return CubitMatrix::operator*(matrix);
CubitTransformMatrix CubitTransformMatrix::operator* ( double  val) const
Definition at line 322 of file CubitTransformMatrix.cpp.
      rv.set(i, j, this->get(i,j)*val);
  return rv;
Definition at line 344 of file CubitTransformMatrix.cpp.
  return CubitVector(this->get(0,3), this->get(1,3), this->get(2,3));
Definition at line 331 of file CubitTransformMatrix.cpp.
  PRINT_INFO("%8.4f  %8.4f  %8.4f  %8.4f\n",
    get(0,0), get(0,1), get(0,2), get(0,3));
    get(1,0), get(1,1), get(1,2), get(1,3));
    get(2,0), get(2,1), get(2,2), get(2,3));
    get(3,0), get(3,1), get(3,2), get(3,3));
Definition at line 142 of file CubitTransformMatrix.cpp.
  double a, b, c, d;
  CubitVector axis = vector;
  axis.normalize();
  a = axis.x();
  b = axis.y();
  c = axis.z();
  d = sqrt(b*b + c*c);
    // Make an Identity matrix
  if(d)
      // Place values in appropriate places for negative rotate about x
    mat.set(1, 1, c/d);
    mat.set(1, 2, -b/d);
    mat.set(2, 1, b/d);
    mat.set(2, 2, c/d);
      // Perform Pre-Multiplication
    *this = mat * *this;
    mat.set_to_identity();
    // Place values in appropriate places for negative rotate about y
  mat.set(0, 0, d);
  mat.set(0, 2, -a);
  mat.set(2, 0, a);
  mat.set(2, 2, d);
    // Place values in appropriate places for reflect across z
  mat.set(2, 2, -1);
    // Place values in appropriate places for rotate about y
  mat.set(0, 0, d);
  mat.set(0, 2, a);
  mat.set(2, 0, -a);
  mat.set(2, 2, d);
  if(d)
      // Place values in appropriate places for rotate about x
    mat.set(1, 1, c/d);
    mat.set(1, 2, b/d);
    mat.set(2, 1, -b/d);
    mat.set(2, 2, c/d);
  return *this;
CubitTransformMatrix & CubitTransformMatrix::rotate ( double  degrees,
const CubitVector vector
Definition at line 51 of file CubitTransformMatrix.cpp.
  double angle, ct, st;
    // Make a copy of vector so we don't have to change it
    // Convert degrees to radians
  angle = -degrees * CUBIT_PI/180.0;
    // Take sin and cos
  ct = cos(angle);
  st = sin(angle);
    // Normalize the axis vector
  axis.normalize();
    // Make an identity matrix
    // Setup some calculations that occur repeatedly
  double one_minus_cos = 1.0 - ct;
  double dx_ct = axis.x() * one_minus_cos;
  double dy_ct = axis.y() * one_minus_cos;
  double dz_ct = axis.z() * one_minus_cos;
  double dx_st = axis.x() * st;
  double dy_st = axis.y() * st;
  double dz_st = axis.z() * st;
    // Set the values in the matrix
  mat.set(0, 0,     ct + axis.x() * dx_ct);
  mat.set(1, 0, -dz_st + axis.x() * dy_ct);
  mat.set(2, 0,  dy_st + axis.x() * dz_ct);
  mat.set(0, 1,  dz_st + axis.y() * dx_ct);
  mat.set(1, 1,     ct + axis.y() * dy_ct);
  mat.set(2, 1, -dx_st + axis.y() * dz_ct);
  mat.set(0, 2, -dy_st + axis.z() * dx_ct);
  mat.set(1, 2,  dx_st + axis.z() * dy_ct);
  mat.set(2, 2,     ct + axis.z() * dz_ct);
    // Premultiply the matrix
    // Return
  return *this;
char  axis
Definition at line 99 of file CubitTransformMatrix.cpp.
  if(axis != 'x' && axis != 'y' && axis != 'z')
    throw std::invalid_argument("Invalid Axis: must be X, Y, or Z");
  //assert (axis == 'x' || axis == 'y' || axis == 'z');
    // Convert to Radians, Get the sine and cosine
  double angle = degrees * CUBIT_PI/180.;
  double s, c;
  s = sin(angle);
  c = cos(angle);
  switch (axis)
    case 'x':
      mat.set(1, 1, c);
      mat.set(2, 2, c);
      mat.set(1, 2, -s);
      mat.set(2, 1, s);
      break;
    case 'y':
      mat.set(0, 0, c);
      mat.set(0, 2, s);
      mat.set(2, 0, -s);
      mat.set(2, 2, c);
      break;
    case 'z':
      mat.set(0, 0, c);
      mat.set(1, 0, s);
      mat.set(0, 1, -s);
      mat.set(1, 1, c);
      break;
  return *this;
const CubitVector axis_from,
const CubitVector axis_to
Definition at line 216 of file CubitTransformMatrix.cpp.
    // Translate so that axis_from is at origin
  translate (-axis_from);
    // Rotate about specified axis
  rotate (degrees, axis_to - axis_from);
    // Translate back
  translate (axis_from);
  return *this;
Definition at line 232 of file CubitTransformMatrix.cpp.
  return scale_about_origin(scale.x(), scale.y(), scale.z());
CubitTransformMatrix & CubitTransformMatrix::scale_about_origin ( double  x,
double  y,
double  z
Definition at line 237 of file CubitTransformMatrix.cpp.
  mat.set(0, 0, x);
  mat.set(1, 1, y);
  mat.set(2, 2, z);
  return *this;
Definition at line 250 of file CubitTransformMatrix.cpp.
  return scale_about_origin(scale, scale, scale);
Definition at line 36 of file CubitTransformMatrix.cpp.
  return translate(v.x(), v.y(), v.z());
CubitTransformMatrix & CubitTransformMatrix::translate ( double  x,
double  y,
double  z
Definition at line 42 of file CubitTransformMatrix.cpp.
  set (0, 3, get(0, 3) + x);
  set (1, 3, get(1, 3) + y);
  set (2, 3, get(2, 3) + z);
  return *this;
return the x-axis
Definition at line 350 of file CubitTransformMatrix.cpp.
  CubitMatrix tmp1(4,1);
  tmp1.set(0,0,1);
  tmp1.set(1,0,0);
  tmp1.set(2,0,0);
  tmp1.set(3,0,0);
  CubitMatrix tmp2 = (*this) * tmp1;
  return CubitVector(tmp2.get(0,0), tmp2.get(1,0), tmp2.get(2,0));
return the y-axis
Definition at line 362 of file CubitTransformMatrix.cpp.
  tmp1.set(0,0,0);
  tmp1.set(1,0,1);
  tmp1.set(2,0,0);
  tmp1.set(3,0,0);
return the z-axis
Definition at line 374 of file CubitTransformMatrix.cpp.
  tmp1.set(0,0,0);
  tmp1.set(1,0,0);
  tmp1.set(2,0,1);
  tmp1.set(3,0,0);
Friends And Related Function Documentation
CUBIT_UTIL_EXPORT CubitVector operator* ( const CubitVector point,
) [friend]
Definition at line 286 of file CubitTransformMatrix.cpp.
    // Make a 1x4 matrix, multiply matrix by it.
  CubitMatrix m1(1,4);
  m1.set(0, 0, point.x());
  m1.set(0, 1, point.y());
  m1.set(0, 2, point.z());
  m1.set(0, 3, 1);
    // Perform the multiplication
  m1 = m1 * matrix;
    // The result is a 1x4
    // Put the results into a vector (dividing by w), and return
  double w = m1.get(0,3);
  return CubitVector(m1.get(0,0)/w, m1.get(0,1)/w, m1.get(0,2)/w);
