cgma
CurveFacetEvalTool Class Reference
#include <CurveFacetEvalTool.hpp>
List of all members.
Public Member Functions
 CurveFacetEvalTool ()
 ~CurveFacetEvalTool ()
CubitStatus initialize (DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, FacetEvalTool *surf_eval=NULL)
CubitStatus initialize (FacetEvalTool *surf_eval_tool, CubitPoint *start_point, CubitPoint *end_point, CubitSense orientation)
CubitStatus initialize (FacetEvalTool *surf_eval_tool, CubitVector &start, CubitVector &end, CubitSense orientation)
CubitStatus initialize (FacetEvalTool *surf_eval_tool, CubitVector &start, std::vector< CubitVector > &positions)
CubitStatus save (FILE *fp)
CubitStatus restore (FILE *fp, unsigned int endian, int num_edges, int num_points, CubitFacetEdge **edges, CubitPoint **points, int num_fets, FacetEvalTool **fet_list)
int get_output_id ()
void set_output_id (int id)
CubitBox bounding_box ()
CubitStatus closest_point (CubitVector &this_point, CubitVector &closest_point_ptr, CubitVector *normal_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL)
CubitBoolean replace_point (CubitPoint *del_pnt, CubitPoint *keep_pnt)
CubitBoolean replace_facets (DLIList< CubitFacetEdge * > &curv_edges)
void remove_facets (DLIList< CubitFacetEdge * > &facet_edges)
CubitStatus position_from_fraction (double fraction, CubitVector &location_on_curve)
double u_from_arc_length (double root_param, double arc_length)
double length_from_u (double root_param, double end_param)
double length ()
CubitSense sense ()
void get_facets (DLIList< CubitFacetEdge * > &facet_list)
void get_points (DLIList< CubitPoint * > &point_list)
FacetEvalToolget_surf_eval_tool ()
void set_facet_eval_tool (FacetEvalTool *surf_eval_tool_ptr)
void set_length ()
CubitBoolean has_good_curve_data ()
void debug_draw_facet_edges (int color=-1)
Private Member Functions
void draw_edges (int color=-1)
void draw_edge (CubitFacetEdge *edge, int color)
void draw_line (CubitVector &begin, CubitVector &end, int color=-1)
void draw_location (CubitVector &loc, int color=-1)
void destroy_facets ()
CubitStatus get_segments_from_loops (DLIList< DLIList< CubitFacetEdge * > * > *facet_loop_list, CubitVector &start, CubitVector &end, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, CubitSense owrts)
CubitStatus get_segments_from_loops (DLIList< DLIList< CubitFacetEdge * > * > *facet_loop_list, CubitPoint *start_pt, CubitPoint *end_pt, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, CubitSense owrts)
CubitStatus get_segments_from_positions (std::vector< CubitVector > &positions, CubitVector &start_pt, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list)
CubitStatus evaluate_bezier_edge (CubitFacetEdge *edge, int index0, int index1, double fraction, CubitVector &location_on_curve, double *tangent)
CubitStatus project_to_bezier_edge (CubitFacetEdge *edge, CubitVector &point, CubitVector &projected_point, double *tangent, double *tval)
double u_on_facet_edge (CubitFacetEdge *edge_at_pt, CubitVector pt)
CubitStatus fix_point_edge_order ()
CubitSense find_curv_sense (CubitPoint *start_ptr)
CubitSense find_curv_sense (CubitVector &start)
Private Attributes
int toolID
int interpOrder
DLIList< CubitFacetEdge * > myEdgeList
DLIList< CubitPoint * > myPointList
CubitBoxmyBBox
FacetEvalToolsurfFacetEvalTool
double facetLength
CubitSense curvSense
CubitBoolean goodCurveData
int output_id
Detailed Description
Definition at line 26 of file CurveFacetEvalTool.hpp.
Definition at line 150 of file CurveFacetEvalTool.cpp.
  static int counter = 0;
  toolID = counter++;
  myBBox = NULL;
  goodCurveData = CUBIT_TRUE;
Definition at line 164 of file CurveFacetEvalTool.cpp.
  if ( myBBox ) delete myBBox;
  destroy_facets();
Member Function Documentation
Definition at line 578 of file CurveFacetEvalTool.cpp.
  if ( !myBBox )
    int ii;
    CubitPoint *point_ptr;
    double x, y, z;
    double x_min = CUBIT_DBL_MAX, x_max = -CUBIT_DBL_MAX;
    double y_min = CUBIT_DBL_MAX, y_max = -CUBIT_DBL_MAX;
    double z_min = CUBIT_DBL_MAX, z_max = -CUBIT_DBL_MAX;
    for ( ii = myPointList.size(); ii > 0; ii-- )
      point_ptr = myPointList.get_and_step();
      x = point_ptr->x();
      y = point_ptr->y();
      z = point_ptr->z();
      if ( x < x_min )
        x_min = x;
      if ( y < y_min )
        y_min = y;
      if ( z < z_min )
        z_min = z;
      if ( x > x_max )
        x_max = x;
      if ( y > y_max )
        y_max = y;
      if ( z > z_max )
        z_max = z;
    CubitVector min_v(x_min, y_min, z_min );
    CubitVector max_v(x_max, y_max, z_max );
    myBBox = new CubitBox( min_v, max_v );
  return *(myBBox);
CubitStatus CurveFacetEvalTool::closest_point ( CubitVector this_point,
CubitVector closest_point_ptr,
CubitVector normal_ptr = NULL,
CubitVector curvature_ptr = NULL,
double *  param = NULL
Definition at line 805 of file CurveFacetEvalTool.cpp.
  CubitStatus stat = CUBIT_SUCCESS;
//  int outside;
  int mydebug = 0;
  if (mydebug)
    draw_location(this_point, CUBIT_RED_INDEX);
  if (surfFacetEvalTool == NULL)
    stat = project_to_linear_facet_edge( this_point, closest_point,
                                         tangent_ptr, curvature_ptr,
                                         param, &outside );
  else
    stat = project_to_facet_edge( this_point, closest_point,
                                  tangent_ptr, curvature_ptr, param, &outside );
  int i;
  CubitVector test_pt_v, closest_pt_v, pt0_v, pt1_v;
  double distance2, closest_distance2; //  distance squared
  CubitFacetEdge *edge, *best_edge = NULL;
  myEdgeList.reset();
  closest_distance2 = CUBIT_DBL_MAX;
  for ( i = myEdgeList.size(); i > 0; i-- ) {
    edge = myEdgeList.get_and_step();
    pt0_v = edge->point(0)->coordinates();
    pt1_v = edge->point(1)->coordinates();
    test_pt_v = FacetDataUtil::squared_distance_to_segment(this_point,
                     pt0_v,pt1_v,distance2);
    if ( distance2 < closest_distance2 ) {
      closest_distance2 = distance2;
      closest_pt_v = test_pt_v;
      best_edge = edge;
      if ( distance2 < GEOMETRY_RESABS*GEOMETRY_RESABS ) break;
  if (mydebug)
    myEdgeList.reset();
      GfxDebug::draw_point(pt0_v, CUBIT_GREEN_INDEX );
      GfxDebug::draw_point(pt1_v, CUBIT_RED_INDEX );
      GfxDebug::flush();
  if ( interpOrder == 0 ) {
    closest_point = closest_pt_v;
    if (tangent_ptr) {
      CubitVector tangent;
      if (best_edge->edge_tangent( closest_point, tangent ) != CUBIT_SUCCESS) {
        return CUBIT_FAILURE;
      if (curvSense == CUBIT_REVERSED)
        tangent = -tangent;
      *tangent_ptr = tangent;
    // evaluate the curvature if required
    if (curvature_ptr)
      if( myEdgeList.size() == 1 )
        (*curvature_ptr).set( 0, 0, 0);
      else
        CubitVector curvature;
        myEdgeList.move_to( best_edge );
        int index = myEdgeList.get_index();
        //"best_edge" could be last or first on curve
        CubitFacetEdge* prev_edge = NULL;
        myEdgeList.back();
        if( (index - 1) == myEdgeList.get_index() )
          prev_edge = myEdgeList.get();
        CubitFacetEdge* next_edge = NULL;
        myEdgeList.step(2);
        if( (index + 1) == myEdgeList.get_index() )
          next_edge = myEdgeList.get();
        CubitFacetEdge *closest_edge;
        //determine which adjacent edge is closest to "best_point"
        if( prev_edge && next_edge )
          CubitVector tmp_vec;
          double prev_dist, next_dist;
          tmp_vec = (prev_edge->point(0)->coordinates() +
                     prev_edge->point(1)->coordinates() ) / 2;
          prev_dist = closest_point.distance_between( tmp_vec );
          tmp_vec = (next_edge->point(0)->coordinates() +
                     next_edge->point(1)->coordinates() ) / 2;
          next_dist = closest_point.distance_between( tmp_vec );
          if( prev_dist < next_dist )
            closest_edge = prev_edge;
          else
            closest_edge = next_edge;
        else if( prev_edge )
        else
        if (best_edge->edge_curvature( closest_point, curvature, closest_edge ) != CUBIT_SUCCESS) {
          curvature = -curvature;
        *curvature_ptr = curvature;
  } else if ( interpOrder == 4 ) {
    double t_value;
    double tangent[3];
    stat = project_to_bezier_edge(best_edge,this_point,
                                  closest_point,tangent,&t_value);
    if(curvSense == CUBIT_REVERSED){
      tangent[0]= -tangent[0];
      tangent[1]= -tangent[1];
      tangent[2]= -tangent[2];
    if ( tangent_ptr ) {
      tangent_ptr->x(tangent[0]);
      tangent_ptr->y(tangent[1]);
      tangent_ptr->z(tangent[2]);
    if ( curvature_ptr ) {
    //  The idea here is to get the planes normal to two points on the curve
    //  on either side of the closest_point, and also to get the plane through
    //  these three points.  The point of intersection of these three planes
    //  should be a good approximation of the center of curvature, from which
    //  the curvature vector is readily found.
    //  tan1 and tan2 are the normals to the two planes for the endpoints;
    //  norm3 is the normal for the plane through the three points.
      CubitVector tan1, tan2, point_1,  point_2;
      CubitVector *tan1_ptr = &tan1;
      CubitVector *tan2_ptr = &tan2;
//       CubitVector *point_1_ptr = &point_1;
      CubitVector *point_2_ptr = &point_2;
      t_value -= 0.01;
      best_edge->evaluate_single_tangent(t_value,tan1_ptr);
      t_value += 0.02;
      best_edge->evaluate_single(t_value,tan2_ptr);
      best_edge->evaluate_single_tangent(t_value,point_2_ptr);
      tan1.normalize();
      tan2.normalize();
      //  Get the plane through the point and normal to the tangent for the two
      //  points at the end.
      //  Get the plane for the three points.
      CubitVector arm1 = point_1 - closest_point;
      CubitVector arm2 = point_2 - closest_point;
      CubitVector norm3 = arm1*arm2;
      norm3.normalize();
      double denominator;
      denominator = tan1 % ( tan2 * norm3 );
      if ( fabs(denominator) < GEOMETRY_RESABS ) { // planes are parallel;
                                                    // curvature is infinite
        curvature_ptr->x(CUBIT_DBL_MAX);
        curvature_ptr->y(CUBIT_DBL_MAX);
        curvature_ptr->z(CUBIT_DBL_MAX);
      } else {
        CubitVector IntersectionPoint;
        IntersectionPoint = ( (point_1%tan1)*(norm3*tan2) +
                              (closest_point%norm3)*(tan2*tan1) +
                              (point_2%tan2)*(tan1*norm3) )/denominator;
        curvature_ptr->x(closest_point.x() - IntersectionPoint.x());
        curvature_ptr->y(closest_point.y() - IntersectionPoint.y());
        curvature_ptr->z(closest_point.z() - IntersectionPoint.z());
  } else {
    PRINT_ERROR("Error:  Only curves or order 0 or 4 are supported.\n");
  if (param)
    *param = u_on_facet_edge( best_edge, closest_point );
  if (mydebug)
    draw_location(closest_point, CUBIT_GREEN_INDEX);
  return stat;
Definition at line 2115 of file CurveFacetEvalTool.cpp.
  draw_edges(color);
Definition at line 1783 of file CurveFacetEvalTool.cpp.
void CurveFacetEvalTool::draw_edge ( CubitFacetEdge edge,
int  color
) [private]
Definition at line 1822 of file CurveFacetEvalTool.cpp.
  CubitPoint *begin_point = edge->point(0);
  CubitPoint *end_point = edge->point(1);
  GfxDebug::draw_line(begin_point->x(),
                      begin_point->y(),
                      begin_point->z(),
                      end_point->x(),
                      end_point->y(),
                      end_point->z(),
                      color);
  GfxDebug::flush();
void CurveFacetEvalTool::draw_edges ( int  color = -1) [private]
Definition at line 1795 of file CurveFacetEvalTool.cpp.
  int ii;
  if ( color == -1 )
    color = CUBIT_BLUE_INDEX;
  for ( ii = myEdgeList.size(); ii > 0; ii-- )
    CubitFacetEdge *edge = myEdgeList.get_and_step();
                        begin_point->y(),
                        begin_point->z(),
                        end_point->x(),
                        end_point->y(),
                        end_point->z(),
                        color);
  GfxDebug::flush();
void CurveFacetEvalTool::draw_line ( CubitVector begin,
CubitVector end,
int  color = -1
) [private]
Definition at line 1843 of file CurveFacetEvalTool.cpp.
  GfxDebug::draw_line(begin.x(), begin.y(), begin.z(),
                      end.x(), end.y(), end.z(), color);
  GfxDebug::flush();
void CurveFacetEvalTool::draw_location ( CubitVector loc,
int  color = -1
) [private]
Definition at line 1855 of file CurveFacetEvalTool.cpp.
  if ( color == -1 )
    color = CUBIT_YELLOW_INDEX;
  GfxDebug::draw_point(loc, color);
  GfxDebug::flush();
CubitStatus CurveFacetEvalTool::evaluate_bezier_edge ( CubitFacetEdge edge,
int  index0,
int  index1,
double  fraction,
CubitVector location_on_curve,
double *  tangent
) [private]
Definition at line 708 of file CurveFacetEvalTool.cpp.
CubitStatus status;
int numEdge, numVert, numLocs;
int edgeVert[2];
//int order;
double vert[6], edgeCtrlPts[9], location[3];
CubitVector *edge_ctrl_pts;
 double scaled_parameter;
  numEdge = 1;
  numVert = 2;
  numLocs = 1;
  edgeVert[0] = 0; edgeVert[1] = 1;
  vert[0] = edge->point(index0)->x();
  vert[1] = edge->point(index0)->y();
  vert[2] = edge->point(index0)->z();
  vert[3] = edge->point(index1)->x();
  vert[4] = edge->point(index1)->y();
  vert[5] = edge->point(index1)->z();
    edge_ctrl_pts = edge->control_points();
    edgeCtrlPts[0] = edge_ctrl_pts[0].x();
    edgeCtrlPts[1] = edge_ctrl_pts[0].y();
    edgeCtrlPts[2] = edge_ctrl_pts[0].z();
    edgeCtrlPts[3] = edge_ctrl_pts[1].x();
    edgeCtrlPts[4] = edge_ctrl_pts[1].y();
    edgeCtrlPts[5] = edge_ctrl_pts[1].z();
    edgeCtrlPts[6] = edge_ctrl_pts[2].x();
    edgeCtrlPts[7] = edge_ctrl_pts[2].y();
    edgeCtrlPts[8] = edge_ctrl_pts[2].z();
      //evalBezierEdge takes a parameter in the range of -1 to 1.
      // evalBezierEdge calls functions which  convert back to
      // a range of 0 to 1,
      // but we must convert to -1 to 1, before sending it.
    scaled_parameter = (2.0 * fraction) - 1.0;
  //  static function in Cholla.cpp
    evalBezierEdge(numEdge,numVert,edgeVert,vert,edgeCtrlPts,numLocs,
                   &scaled_parameter, location,tangent);
  location_on_curve.x(location[0]);
  location_on_curve.y(location[1]);
  location_on_curve.z(location[2]);
  status = CUBIT_SUCCESS;
  return status;
Definition at line 521 of file CurveFacetEvalTool.cpp.
  myEdgeList.reset();
  CubitFacetEdge *edge_ptr = myEdgeList.get();
  CubitPoint *pt0 = edge_ptr->point(0);
  CubitPoint *pt1 = edge_ptr->point(1);
  CubitSense sense;
  if (start_pt == pt0)
    sense = CUBIT_FORWARD;
  else if (start_pt == pt1)
    sense = CUBIT_REVERSED;
  else
    sense = CUBIT_UNKNOWN;
  return sense;
Definition at line 553 of file CurveFacetEvalTool.cpp.
  myEdgeList.reset();
  CubitFacetEdge* temp_edge = myEdgeList.get();
  CubitVector temp_vector = temp_edge->point(1)->coordinates() -
                            temp_edge->point(0)->coordinates();
  double tol = temp_vector.length() / 100.0;
  //if point(0) of first edge in list == start, it is CUBIT_FORWARD
  if(start.within_tolerance(temp_edge->point(0)->coordinates(), tol ) )
    return CUBIT_FORWARD;
  //if point(1) of first edge in list == start, it is CUBIT_REVERSED
  else if(start.within_tolerance(temp_edge->point(1)->coordinates(), tol ) )
    return CUBIT_REVERSED;
  else
    return CUBIT_UNKNOWN;
Definition at line 2051 of file CurveFacetEvalTool.cpp.
  CubitFacetEdge* this_edge;
  CubitFacetEdge* next_edge;
  CubitPoint *this_pt1;
  CubitPoint *next_pt0, *next_pt1;
  if( myEdgeList.size() == 0 )
  this_edge = myEdgeList.get_and_step();
  int ii;
  for( ii = myEdgeList.size() - 1; ii > 0; ii-- )
    if( 0 != this_edge->num_adj_facets() )
       continue;
    next_edge = myEdgeList.get_and_step();
    this_pt1 = this_edge->point( 1 );
    next_pt0 = next_edge->point( 0 );
    next_pt1 = next_edge->point( 1 );
    if( this_pt1 != next_pt0 &&
        this_pt1 != next_pt1 )
        //Swap direction of edge.  (mod. 3-7-06)  Now calling flip instead
        // of doing the flip manually.  The flip function also tracks
        // the orientation so that we can remember the original orientation
        // of the edge.
      this_edge->flip();
    this_edge = next_edge;
    //Handle last edge
  next_edge = myEdgeList.prev(2);
  if( 0 == this_edge->num_adj_facets() )
    CubitPoint* this_pt0 = this_edge->point( 0 );
    if( this_pt0 != next_pt0 &&
        this_pt0 != next_pt1 )
        //Swap direction of edge.(mod. 3-7-06)  Now calling flip instead
        // of the edge.
      this_edge->flip();
  return CUBIT_SUCCESS;
void CurveFacetEvalTool::get_facets ( DLIList< CubitFacetEdge * > &  facet_list) [inline]
Definition at line 190 of file CurveFacetEvalTool.hpp.
    { facet_list +=  myEdgeList; }
Definition at line 152 of file CurveFacetEvalTool.hpp.
{ return output_id; }
void CurveFacetEvalTool::get_points ( DLIList< CubitPoint * > &  point_list) [inline]
Definition at line 193 of file CurveFacetEvalTool.hpp.
    { point_list +=  myPointList; }
CubitStatus CurveFacetEvalTool::get_segments_from_loops ( DLIList< DLIList< CubitFacetEdge * > * > *  facet_loop_list,
CubitVector start,
CubitVector end,
DLIList< CubitFacetEdge * > &  edge_list,
DLIList< CubitPoint * > &  point_list,
CubitSense  owrts
) [private]
Definition at line 181 of file CurveFacetEvalTool.cpp.
  int ii, jj;
  int mydebug = 0;
  CubitBoolean done = CUBIT_FALSE;
  DLIList<CubitFacetEdge*> *facet_loop;
  CubitFacetEdge *edge, *startedge = NULL;
  CubitPoint *pt0, *pt1;
  CubitVector loc_pt0, loc_pt1;
  double edge_length;
  facetLength = 0.0e0;
  int tool_id = surfFacetEvalTool->tool_id();
    //loop over the "loops"
  for (ii=0; ii<facet_loop_list->size() && !done && stat == CUBIT_SUCCESS; ii++) {
      //get the next facet loop
    facet_loop = facet_loop_list->get_and_step();
      // now loop over the edges in that loop
    for (jj=0; jj<facet_loop->size() && !done; jj++) {
        //get the start edge... we will
        //traverse the list forwards, if the surface is oriented forward
        //otherwise, traverse it backwards
      startedge =
        (orientation_wrt_surf == CUBIT_FORWARD) ? facet_loop->get_and_step() :
        facet_loop->get_and_back();
      if (startedge->get_flag() == 0) {
        if (orientation_wrt_surf == CUBIT_FORWARD) {
          startedge->boundary_edge_points( pt0, pt1, tool_id );
        else {
          startedge->boundary_edge_points( pt1, pt0, tool_id );
        loc_pt0 = pt0->coordinates();
        loc_pt1 = pt1->coordinates();
        if (loc_pt0.within_tolerance( start, GEOMETRY_RESABS )) {
          startedge->set_flag( 1 );
          edge = startedge;
          if (mydebug) draw_edge( edge, CUBIT_GREEN_INDEX );
          while (!done) {
            edge_list.append( edge );
            point_list.append( pt0 );
            edge_length = loc_pt0.distance_between( loc_pt1 );
            facetLength += edge_length;
              //if the other end of the edge is at the begginning of the
              //loop, then we're done.
            if (loc_pt1.within_tolerance( end, GEOMETRY_RESABS )) {
              done = CUBIT_TRUE;
              point_list.append( pt1 );
            else {//otherwise...
                edge = facet_loop->get_and_step();
              else {
                edge = facet_loop->get_and_back();
              if (mydebug) draw_edge( edge, CUBIT_BLUE_INDEX );
                //if we got back to the startedge without the
                // other end of an edge getting to the start vertex,
                // we have a problem....
              if (edge == startedge)
                stat = CUBIT_FAILURE;  // this shouldn't happen
                done = CUBIT_TRUE;
              }//end edge == startedge
            }//end else not within tolerance
          }//end while not done
        }//end if within tolerance
      }//end if not marked
    }//end loop over edges in facet loop
  }//end loop over facet loops
  if(done!=CUBIT_TRUE)
    PRINT_ERROR("Can't define curve representation in mesh-based geometry\n");
  return stat;
CubitPoint start_pt,
CubitPoint end_pt,
CubitSense  owrts
) [private]
Definition at line 285 of file CurveFacetEvalTool.cpp.
  int ii, jj;
  int mydebug = DEBUG_FLAG(181);
  double edge_length;
  DLIList<CubitFacetEdge*> temp_edge_list;
  DLIList<CubitPoint*> temp_point_list;
  if (mydebug)
    GfxDebug::draw_point( start_pt->x(),
                          start_pt->y(),
                          start_pt->z(),
                          CUBIT_RED_INDEX );
    GfxDebug::draw_point( end_pt->x(),
                          end_pt->y(),
                          end_pt->z(),
    GfxDebug::flush();
    //loop over the list of facet loops
      //now loop over the edges in that facet loop
      startedge =
        //if startedge isn't marked
          //get the points from the start edge in the appropriate order
        else {
          //convert to CubitVector
          //if the first point on the edge is the start_pt... otherwise step
        if (pt0 == start_pt) {
            //mark the startedge
          CubitFacetEdge* marked_edge = NULL;
          edge = startedge;
          if (mydebug) draw_edge( edge, CUBIT_GREEN_INDEX );//draw the start edge
            //loop until we have reached an end or no more choices
          while (!done) {
              //if the first point is at the start, we are either
              // just starting, or we have looped back onto the
              // start point.  The latter _may_ be ok.  In case
              // the latter is the case, clean out the temporary
              // lists and (re)initialize the length.  Also, unmark
              // the edge that we marked the last time we started,
              // if we previously marked an edge.
            if (pt0 == start_pt){
              temp_point_list.clean_out();
              temp_edge_list.clean_out();
              facetLength = 0.0;
              if(marked_edge)
                marked_edge->set_flag(0);
              marked_edge=edge;
              edge->set_flag(1);
              //add the current edge to the edge list
            temp_edge_list.append( edge );
              //add the current start point to the point list
            temp_point_list.append( pt0 );
              //measure the edge... essentially
              //keep a running tally of the curve length
              //if the second point is at the end, we're done
            if (pt1 == end_pt ) {
              done = CUBIT_TRUE;
              temp_point_list.append( pt1 );
              //otherwise, we need to step forward
            else {
              else {
                //convert point to CubitVector, as above
                done = CUBIT_TRUE;
            }//end else (ie, if not pt1==end_pt)
          }//end while !done
        }//end if pt0 == start_pt
      }//end if start edge isn't marked
    }//end loop over edges in the loop
    //now put the temporary list entries onto the end of the list we return.
  point_list += temp_point_list;
  edge_list += temp_edge_list;
  if(done!=CUBIT_TRUE || stat == CUBIT_FAILURE)
    PRINT_WARNING("Can't define curve representation in mesh-based geometry\n");
    PRINT_INFO("  Hint: Try importing as a free mesh and examining nodes and attached\n");
    PRINT_INFO("        elements near the following locations:\n");
    PRINT_INFO("        Start curve = %f %f %f\n", start_pt->x(), start_pt->y(), start_pt->z());
    PRINT_INFO("        End curve = %f %f %f\n", end_pt->x(), end_pt->y(), end_pt->z());
    if (mydebug)
      surfFacetEvalTool->debug_draw_facets( CUBIT_YELLOW_INDEX );
      int i, j;
      for (i=0; i<facet_loop_list->size(); i++)
        DLIList<CubitFacetEdge*> *my_facet_loop = facet_loop_list->get_and_step();
        for (j=0; j<my_facet_loop->size(); j++)
          draw_edge( my_facet_loop->get_and_step(), CUBIT_RED_INDEX );
      GfxDebug::mouse_xforms();
  return stat;
CubitStatus CurveFacetEvalTool::get_segments_from_positions ( std::vector< CubitVector > &  positions,
CubitVector start_pt,
) [private]
Definition at line 443 of file CurveFacetEvalTool.cpp.
  DLIList<CubitPoint*> surface_pts;
  surfFacetEvalTool->get_points( surface_pts );
  facetLength = 0;
  double smallest_dist = CUBIT_DBL_MAX;
  CubitPoint *start_pt = NULL;
  //find the closest point to 'start'
  for( int k=surface_pts.size(); k--; )
    double tmp_dist = surface_pts.get()->coordinates().distance_between_squared( start );
    if( tmp_dist < smallest_dist )
      smallest_dist = tmp_dist;
      start_pt = surface_pts.get();
    surface_pts.get_and_step();
  myPointList.append( start_pt );
  CubitPoint *current_pt = start_pt;
  CubitPoint *next_pt = NULL;
  for (size_t k = 1; k < positions.size(); k++ )
    CubitVector current_pos = positions[k];
    //find the CubitPoint attached to this point via an edge
    CubitFacetEdge *next_edge;
    DLIList<CubitFacetEdge*> adj_edges;
    current_pt->edges( adj_edges );
    for( int m=adj_edges.size(); m--; )
      CubitFacetEdge *tmp_edge = adj_edges.get_and_step();
      CubitPoint *other_pt = tmp_edge->other_point( current_pt );
      double tmp_dist = current_pos.distance_between_squared(  other_pt->coordinates() );
        next_pt = other_pt;
        next_edge = tmp_edge;
    current_pt = next_pt;
    facetLength += next_edge->length();
    myEdgeList.append( next_edge );
    myPointList.append( current_pt );
  if ((size_t)myPointList.size() != positions.size() ||
      (size_t)myEdgeList.size() != positions.size() - 1 )
CubitStatus CurveFacetEvalTool::initialize ( DLIList< CubitFacetEdge * > &  edge_list,
FacetEvalTool surf_eval = NULL
Definition at line 124 of file CurveFacetEvalTool.cpp.
//   static int counter = 0;
  output_id = -1;
  myBBox = NULL;
  curvSense = CUBIT_FORWARD;
  surfFacetEvalTool = surf_eval;
  myEdgeList = edge_list;
  myPointList = point_list;
  set_length();
  CubitStatus status = fix_point_edge_order();
  if( CUBIT_SUCCESS != status )
    return status;
  interpOrder = 0;
  if(surf_eval)
    interpOrder = surf_eval->interp_order();
  bounding_box();
CubitStatus CurveFacetEvalTool::initialize ( FacetEvalTool surf_eval_tool,
CubitPoint start_point,
CubitPoint end_point,
Definition at line 91 of file CurveFacetEvalTool.cpp.
  output_id = -1;
  myBBox = NULL;
  surfFacetEvalTool = surf_eval_tool;
  CubitStatus stat = get_segments_from_loops( surfFacetEvalTool->loops(),
                                              start_pt, end_pt,
                                              myEdgeList, myPointList,
                                              orientation_wrt_surf );
  goodCurveData = (stat == CUBIT_SUCCESS) ? CUBIT_TRUE : CUBIT_FALSE;
  if( !goodCurveData )
    PRINT_ERROR( "Unable to initialize Curve Evaluation Tool for Faceted Geometry.\n" );
  interpOrder = surfFacetEvalTool->interp_order();
  curvSense = find_curv_sense( start_pt );
  bounding_box();
CubitVector start,
CubitVector end,
Definition at line 32 of file CurveFacetEvalTool.cpp.
  output_id = -1;
  myBBox = NULL;
  CubitStatus stat = get_segments_from_loops( surfFacetEvalTool->loops(), start, end,
                           myEdgeList, myPointList, orientation_wrt_surface );
  curvSense = find_curv_sense( start );
  bounding_box();
CubitVector start,
Definition at line 58 of file CurveFacetEvalTool.cpp.
  output_id = -1;
  myBBox = NULL;
  CubitStatus stat = get_segments_from_positions( positions, start,
                           myEdgeList, myPointList );
  bounding_box();
double CurveFacetEvalTool::length ( ) [inline]
Definition at line 184 of file CurveFacetEvalTool.hpp.
{ return facetLength; };
double CurveFacetEvalTool::length_from_u ( double  root_param,
double  end_param
Definition at line 788 of file CurveFacetEvalTool.cpp.
  double length = (end_param - root_param) * facetLength;
  return length;
CubitStatus CurveFacetEvalTool::position_from_fraction ( double  fraction,
Definition at line 621 of file CurveFacetEvalTool.cpp.
  CubitStatus status = CUBIT_SUCCESS;
  double length, curlength, targetlength, lastlength;
  CubitFacetEdge *edge = NULL;
  CubitPoint *pt0=NULL, *pt1=NULL;
  CubitVector eval_location;
  myEdgeList.reset();
  myPointList.reset();
  pt0 = myPointList.get();
  if (fraction <= 0.0) {
    location_on_curve = pt0->coordinates();
    return status;
  curlength = lastlength = 0.0e0;
  targetlength = fraction * facetLength;
  assert(myEdgeList.size() > 0);
  int ii = 0;
  for ( ; ii<myEdgeList.size() && !done; ii++) {
    loc_pt0 = edge->point( 0 )->coordinates();
    loc_pt1 = edge->point( 1 )->coordinates();
    curlength += length;
    if ( edge->point(0) == pt0 ){
      pt1 = edge->point(1);
    else{
      pt1 = edge->point(0);
    if (targetlength <= curlength) {
      done = CUBIT_TRUE;
      double local_fraction = (targetlength - lastlength) / length;
      eval_location = loc_pt0 + local_fraction * (loc_pt1 - loc_pt0);
      if (interpOrder == 0 || !surfFacetEvalTool) {
        location_on_curve = eval_location;
      else {
      //  evaluate Bezier edge
        int index0 = 0;
        int index1 = 1;
        if ( pt1 == edge->point(0) ) {
            //switching the indices causes evaluate_bezier_edge to compute the
            //wrong location, so I'm removing the switch (mbrewer)
          //index0 = 1;
          //index1 = 0;
          local_fraction = 1. - local_fraction;
        status = evaluate_bezier_edge(edge,index0,index1,local_fraction,
                                        location_on_curve,0);
    else {
      lastlength = curlength;
        pt0 = edge->point(1);
    else
        pt0 = edge->point(0);
  if (!done) {
    if(pt1 == NULL){
      PRINT_ERROR("Opposite point not found while evaluating a curve.\n");
      location_on_curve.set(0.0,0.0,0.0);
    location_on_curve = pt1->coordinates();
  return status;
CubitStatus CurveFacetEvalTool::project_to_bezier_edge ( CubitFacetEdge edge,
CubitVector point,
CubitVector projected_point,
double *  tangent,
double *  tval
) [private]
Definition at line 1025 of file CurveFacetEvalTool.cpp.
CubitStatus stat;
int numEdge, numVert, edgeVert[2], numLocs;
double vert[6], edgeCtrlPts[9], xyz[3], xyzOnEdge[3];
  numEdge = 1;
  numVert = 2;
  numLocs = 1;
  vert[0] = edge->point(0)->x();
  vert[1] = edge->point(0)->y();
  vert[2] = edge->point(0)->z();
  vert[3] = edge->point(1)->x();
  vert[4] = edge->point(1)->y();
  vert[5] = edge->point(1)->z();
  xyz[0] = point.x();
  xyz[1] = point.y();
  xyz[2] = point.z();
  projToBezierEdge( numEdge,numVert,edgeVert,vert,edgeCtrlPts,
                       numLocs,xyz,xyzOnEdge,tangent,tval );
  projected_point.x(xyzOnEdge[0]);
  projected_point.y(xyzOnEdge[1]);
  projected_point.z(xyzOnEdge[2]);
  return stat;
Definition at line 2168 of file CurveFacetEvalTool.cpp.
Definition at line 2144 of file CurveFacetEvalTool.cpp.
  // replace edges
  this->myEdgeList = curv_edges;
  // replace points
  DLIList<CubitPoint *> point_list;
  int i;
  // insert start point of every facet_edge
  curv_edges.reset();
  for( i = 0; i < curv_edges.size(); i++ )
    point_list.append( CAST_TO( curv_edges.get_and_step(), CubitFacetEdge )->point(0) );
  // insert end point of last facet_edge
  curv_edges.step( curv_edges.size() - 1 );
  point_list.append( CAST_TO( curv_edges.get(), CubitFacetEdge )->point(1) );
  this->myPointList = point_list;
  return CUBIT_TRUE;
Definition at line 2120 of file CurveFacetEvalTool.cpp.
  int npoints = myPointList.size();
  CubitBoolean istat = CUBIT_FALSE;
  int i;
  for ( i = 0; i < npoints; i++ )
    point_ptr = myPointList.get();
    if( point_ptr == del_pnt )
      myPointList.remove();
      myPointList.insert( keep_pnt );
      istat = CUBIT_TRUE;
    myPointList.step();
  return istat;
CubitStatus CurveFacetEvalTool::restore ( FILE *  fp,
int  num_edges,
int  num_points,
CubitFacetEdge **  edges,
CubitPoint **  points,
int  num_fets,
FacetEvalTool **  fet_list
Definition at line 1968 of file CurveFacetEvalTool.cpp.
  NCubitFile::CIOWrapper cio(endian, fp);
  typedef NCubitFile::UnsignedInt32 int32;
    // read stuff about this eval tool
  int ii;
  int int_data[4];
  cio.Read(reinterpret_cast<int32*>(int_data), 4);
  interpOrder = int_data[0];
  int surf_tool_id = int_data[1];
  if (int_data[2] == -1 )
    curvSense = CUBIT_UNKNOWN;
  else
    curvSense= int_data[2] ? CUBIT_REVERSED : CUBIT_FORWARD;
  goodCurveData = (int_data[3]==0) ? CUBIT_FALSE : CUBIT_TRUE;
  if( surf_tool_id != -1 )
    surfFacetEvalTool = fet_array[ surf_tool_id ];
  else
    surfFacetEvalTool = NULL;
  cio.Read(&facetLength, 1);
    // read the edges
  int nedges;
  cio.Read(reinterpret_cast<int32*>(&nedges), 1);
  if (nedges > 0)
    int32* edge_id = new int32 [nedges];
    cio.Read(edge_id, nedges);
    int id;
    for (ii=0; ii<nedges; ii++)
      id = edge_id[ii];
      if (id <0 || id >= num_edges)
        delete [] edge_id;
      myEdgeList.append(edges[id]);
    delete [] edge_id;
    // read the points
  int npoints;
  cio.Read(reinterpret_cast<int32*>(&npoints), 1);
  int id;
  if (npoints > 0)
    int32* point_id = new int32 [npoints];
    cio.Read(point_id, npoints);
    for (ii=0; ii<npoints; ii++)
      id = point_id[ii];
      if (id <0 || id >= num_points)
        delete [] point_id;
      myPointList.append(points[id]);
    delete [] point_id;
  bounding_box();
Definition at line 1893 of file CurveFacetEvalTool.cpp.
  NCubitFile::CIOWrapper cio(fp);
    // write out "interpOrder"
  cio.Write(reinterpret_cast<int32*>(&interpOrder), 1);
   // write the associated facet eval tool id.  If there is none then write -1
  int surf_tool_id = -1;
  if (surfFacetEvalTool != NULL)
    surf_tool_id = surfFacetEvalTool->get_output_id();
  cio.Write(reinterpret_cast<int32*>(&surf_tool_id), 1);
    // convert "curvSense" in an int
  int sense;
  if( curvSense == CUBIT_UNKNOWN )
    sense = -1;
  else
    sense = (curvSense == CUBIT_REVERSED) ? 1 : 0;
    // write "curveSense" and "goodCurveData"
  cio.Write(reinterpret_cast<int32*>(&sense), 1);
  int32 is_good = goodCurveData ? 1 : 0;
  cio.Write(&is_good, 1);
    // write "facetLength"
  cio.Write( &facetLength, 1 );
    // write ids of facet edges in "myEdgeList"
  int ii;
  CubitFacetEdge *edge_ptr;
  int nedges = myEdgeList.size();
  myEdgeList.reset();
    edge_ptr = myEdgeList.get_and_step();
    edge_id[ii] = edge_ptr->id();
  cio.Write(reinterpret_cast<int32*>(&nedges), 1);
  if (nedges > 0)
    cio.Write(edge_id, nedges);
  delete [] edge_id;
    // write ids of points in "myPointList"
    point_id[ii] = point_ptr->id();
  cio.Write(reinterpret_cast<int32*>(&npoints), 1);
  if (npoints > 0)
    cio.Write(point_id, npoints);
  delete [] point_id;
Definition at line 187 of file CurveFacetEvalTool.hpp.
{ return curvSense; };
void CurveFacetEvalTool::set_facet_eval_tool ( FacetEvalTool surf_eval_tool_ptr) [inline]
Definition at line 198 of file CurveFacetEvalTool.hpp.
   { surfFacetEvalTool = surf_eval_tool_ptr;}
Definition at line 1870 of file CurveFacetEvalTool.cpp.
  int ii;
  CubitFacetEdge *cf_edge;
  for (ii=0; ii<myEdgeList.size(); ii++)
    cf_edge = myEdgeList.get_and_step();
    facetLength += cf_edge->length();
void CurveFacetEvalTool::set_output_id ( int  id) [inline]
Definition at line 153 of file CurveFacetEvalTool.hpp.
{ output_id = id; }
double CurveFacetEvalTool::u_from_arc_length ( double  root_param,
double  arc_length
Definition at line 770 of file CurveFacetEvalTool.cpp.
  if( facetLength == 0 )
    return 0;
  double u = root_param + arc_length / facetLength;
  return u;
double CurveFacetEvalTool::u_on_facet_edge ( CubitFacetEdge edge_at_pt,
CubitVector  pt
) [private]
Definition at line 1741 of file CurveFacetEvalTool.cpp.
  int ii;
  double cum_len = 0.0;
  myEdgeList.reset();
  for (ii=0; ii<myEdgeList.size() && !done; ii++) {
    if (edge != edge_at_pt)
      cum_len += edge->length();
    else
      CubitVector pt0;
        pt0 = edge->point( 1 )->coordinates();
      else
      cum_len += pt.distance_between( pt0 );
      done  = CUBIT_TRUE;
  if (!done)
    PRINT_DEBUG_122( "Error in CurveFacetEvalTool::u_on_facet_edge" );
  double u = cum_len / facetLength;
  return u;
Member Data Documentation
Definition at line 38 of file CurveFacetEvalTool.hpp.
Definition at line 37 of file CurveFacetEvalTool.hpp.
Definition at line 30 of file CurveFacetEvalTool.hpp.
Definition at line 35 of file CurveFacetEvalTool.hpp.
Definition at line 40 of file CurveFacetEvalTool.hpp.
Definition at line 29 of file CurveFacetEvalTool.hpp.
