cgma
CurveOverlapFacet Class Reference
#include <CurveOverlapFacet.hpp>
List of all members.
Public Member Functions
 CurveOverlapFacet (GPoint pnt[2])
 ~CurveOverlapFacet ()
double distance_overlapping (CurveOverlapFacet *other_facet)
double angle (CurveOverlapFacet *other_facet)
double length ()
bool bbox_overlap (double tol, CurveOverlapFacet *other_facet)
double facet_to_facet_distance (CurveOverlapFacet *other_facet)
void draw (int color)
CubitVector start_point ()
CubitVector end_point ()
Private Attributes
CubitVector p0
CubitVector p1
CubitBox boundingBox
double facetLength
Friends
class SurfaceOverlapTool
Detailed Description
Definition at line 16 of file CurveOverlapFacet.hpp.
Definition at line 14 of file CurveOverlapFacet.cpp.
  p0.set( p[0].x, p[0].y, p[0].z);
  p1.set( p[1].x, p[1].y, p[1].z);
  CubitVector min;
  min.set( CUBIT_MIN( p[0].x, p[1].x ),
           CUBIT_MIN( p[0].y, p[1].y ),
           CUBIT_MIN( p[0].z, p[1].z ) );
  CubitVector max;
  max.set( CUBIT_MAX( p[0].x, p[1].x ),
           CUBIT_MAX( p[0].y, p[1].y ),
           CUBIT_MAX( p[0].z, p[1].z ) );
  boundingBox.reset( min, max );
  facetLength = 0.0;
Definition at line 35 of file CurveOverlapFacet.cpp.
Member Function Documentation
double CurveOverlapFacet::angle ( CurveOverlapFacet other_facet)
Definition at line 177 of file CurveOverlapFacet.cpp.
  CubitVector vec1 = p1 - p0;
  CubitVector vec2 = other_facet->p1 - other_facet->p0;
  double angle = vec1.interior_angle( vec2 );
  return angle;
bool CurveOverlapFacet::bbox_overlap ( double  tol,
) [inline]
Definition at line 30 of file CurveOverlapFacet.hpp.
  { return boundingBox.overlap( tol, other_facet->boundingBox ); }
Definition at line 39 of file CurveOverlapFacet.cpp.
  //determine which is the smaller facet
  CurveOverlapFacet *short_facet, *long_facet;
  if( this->length() < other_facet->length() )
    short_facet = this;
    long_facet = other_facet;
  else
    short_facet = other_facet;
    long_facet = this;
  CubitVector long_facet_vector(long_facet->p1 - long_facet->p0);
  double long_facet_length = long_facet_vector.length();
  long_facet_vector.normalize();
  CubitVector l_p0_to_s_p0( short_facet->p0 - long_facet->p0 );
  CubitVector l_p0_to_s_p1( short_facet->p1 - long_facet->p0 );
  double dot_to_s_p0 = l_p0_to_s_p0 % long_facet_vector;
  double dot_to_s_p1 = l_p0_to_s_p1 % long_facet_vector;
  //no overlap
  if( ( dot_to_s_p0 <= 0.0 && dot_to_s_p1 <= 0.0) ||
      ( dot_to_s_p0 >= long_facet_length  &&
        dot_to_s_p1 >= long_facet_length ) )
    return 0.0;
  //overlap like this:
  // o-----------o
  //        o---------------------o
  if(  dot_to_s_p0 > 0.0 && dot_to_s_p1 < 0.0 )
    return dot_to_s_p0;
  if( dot_to_s_p1 > 0.0 && dot_to_s_p0 < 0.0 )
    return dot_to_s_p1;
  if( dot_to_s_p0 > long_facet_length &&
      dot_to_s_p1 < long_facet_length )
    return long_facet_length - dot_to_s_p1;
  if( dot_to_s_p1 > long_facet_length &&
      dot_to_s_p0 < long_facet_length )
    return long_facet_length - dot_to_s_p0;
  //overlap like this
  // o-----------o
  // or this:
  //    o-----------o
  // or this:
  if( (dot_to_s_p0 <= long_facet_length &&
       dot_to_s_p1 < long_facet_length ) ||
      (dot_to_s_p1 <= long_facet_length &&
       dot_to_s_p0 < long_facet_length ) )
    return fabs( dot_to_s_p0 - dot_to_s_p1 );
  return 0.0;
  //create vectors
  CubitVector v0( long_facet->p1 - long_facet->p0 );
  CubitVector v1( short_facet->p0 - long_facet->p0 );
  CubitVector v2( short_facet->p1 - long_facet->p0 );
  CubitVector normalized_v0 = v0;
  normalized_v0.normalize();
  //project v1 and v2 onto v0
  double dot1 = normalized_v0 % v1;
  double dot2 = normalized_v0 % v2;
  v1 = normalized_v0 * dot1;
  v2 = normalized_v0 * dot2;
  double length0 = v0.length();
  double length1 = v1.length();
  double length2 = v2.length();
  //no overlap at all
  if( (length1 > long_facet->length() && length2 > long_facet->length() ) ||
      (dot1 <= 0 && dot2 <= 0 ) )
    return 0.0;
  else if( dot1 <= 0 && dot2 > 0 )
    return length2;
  else if( length2 <= 0 && length1 > 0 )
    return length1;
  else if( length1 > length0 )
    return length0 - length2;
  else if( length2 > length0 )
    return length0 - length1;
  //else
    return fabs( length2 - length1 );
  CubitVector tmp_vec1( p0.x, p0.y, p0.z);
  CubitVector tmp_vec2( p1.x, p1.y, p1.z);
  CubitVector tmp_vec3( other_facet->p0.x, other_facet->p0.y, other_facet->p0.z);
  CubitVector tmp_vec4( other_facet->p1.x, other_facet->p1.y, other_facet->p1.z);
  IntersectionTool int_tool( GEOMETRY_RESABS );
  CubitVector closest_point_seg_1;
  CubitVector closest_point_seg_2;
  double sc, tc;
  CubitStatus stat = int_tool.closest_points_on_segments( p0, p1,
                            other_facet->p0, other_facet->p1,
                            closest_point_seg_1, closest_point_seg_2,
                            sc, tc );
  //Make sure the closest points aren't the end points.  If they are
  //and we are within tolerance, it may be that the tolerance is too big
  //cause we shouldn't be at a cross if the closest point is an end point...
  if ( sc > 0. && sc < 1. && tc > 0. && tc < 1. &&
       closest_point_seg_1.within_tolerance(closest_point_seg_2, 0.001) )
  return 0.0;
void CurveOverlapFacet::draw ( int  color)
Definition at line 275 of file CurveOverlapFacet.cpp.
  GfxPreview::draw_line( p0, p1, color );
  return;
Definition at line 286 of file CurveOverlapFacet.cpp.
  return p1;
the lines are almost parallel
Definition at line 196 of file CurveOverlapFacet.cpp.
  CubitVector u = p1 - p0;
  CubitVector v = other_facet->p1 - other_facet->p0;
  CubitVector w = p0 - other_facet->p0;
  double a = u%u;
  double b = u%v;
  double c = v%v;
  double d = u%w;
  double e = v%w;
  double D = a*c - b*b;
  double sc, sN, sD = D;
  double tc, tN, tD = D;
  // compute the line parameters of the two closest points
  if( D < GEOMETRY_RESABS )
    sN = 0.0;        // force using point P0 on segment S1
    sD = 1.0;        // to prevent possible division by 0.0 later
    tN = e;
    tD = c;
  else // get the closest points on the infinite lines
    sN = (b*e - c*d);
    tN = (a*e - b*d);
    if (sN < 0.0)
    {       // sc < 0 => the s=0 edge is visible
      sN = 0.0;
      tN = e;
      tD = c;
    else if (sN > sD)
    {  // sc > 1 => the s=1 edge is visible
      sN = sD;
      tN = e + b;
      tD = c;
  if (tN < 0.0)
  {           // tc < 0 => the t=0 edge is visible
    tN = 0.0;
    // recompute sc for this edge
    if (-d < 0.0)
      sN = 0.0;
    else if (-d > a)
      sN = sD;
    else
      sN = -d;
      sD = a;
  else if (tN > tD)
  {      // tc > 1 => the t=1 edge is visible
    tN = tD;
    if ((-d + b) < 0.0)
      sN = 0;
    else if ((-d + b) > a)
      sN = sD;
    else
      sN = (-d + b);
      sD = a;
  // finally do the division to get sc and tc
  sc = (fabs(sN) < GEOMETRY_RESABS ? 0.0 : sN / sD);
  tc = (fabs(tN) < GEOMETRY_RESABS ? 0.0 : tN / tD);
  // get the difference of the two closest points
  CubitVector   dP = w + (sc * u) - (tc * v);  // = S1(sc) - S2(tc)
  return dP.length();   // return the closest distance
Definition at line 186 of file CurveOverlapFacet.cpp.
  if( facetLength == 0.0 )
    CubitVector tmp_vec = p1 - p0;
    facetLength = tmp_vec.length();
  return facetLength;
Definition at line 281 of file CurveOverlapFacet.cpp.
  return p0;
Friends And Related Function Documentation
friend class SurfaceOverlapTool [friend]
Definition at line 21 of file CurveOverlapFacet.hpp.
Member Data Documentation
Definition at line 46 of file CurveOverlapFacet.hpp.
Definition at line 47 of file CurveOverlapFacet.hpp.
Definition at line 44 of file CurveOverlapFacet.hpp.
Definition at line 45 of file CurveOverlapFacet.hpp.
