cgma
OCCShapeAttributeSet Class Reference
#include <OCCShapeAttributeSet.hpp>
List of all members.
Public Member Functions
void * operator new (size_t, void *anAddress)
void * operator new (size_t size)
void operator delete (void *anAddress)
 OCCShapeAttributeSet ()
 Builds an empty ShapeAttributeSet.
 OCCShapeAttributeSet (const BRep_Builder &B)
 ~OCCShapeAttributeSet ()
void AddGeometry (const TopoDS_Shape &S)
 Stores the goemetry of <S>.
void WriteAttribute (const TopoDS_Shape &S, Standard_OStream &OS, TDF_Label &l_attr)
void ReadAttribute (TopoDS_Shape &S, Standard_IStream &IS, TDF_Label &l_attr)
Standard_Integer Add (const TopoDS_Shape &S)
void Write (Standard_OStream &OS)
void Read (Standard_IStream &IS, bool print)
void Read (TopoDS_Shape &S, Standard_IStream &IS, const int nbshapes, TDF_Label *l_attr=NULL)
void WriteGeometry (Standard_OStream &OS)
void ReadGeometry (Standard_IStream &IS)
void WriteGeometry (const TopoDS_Shape &S, Standard_OStream &OS)
void ReadGeometry (const TopAbs_ShapeEnum T, Standard_IStream &IS, TopoDS_Shape &S)
void Write (const TopoDS_Shape &S, Standard_OStream &OS, TDF_Label *l_attr=NULL)
Standard_EXPORT void WritePolygon3D (Standard_OStream &OS, const Standard_Boolean Compact=Standard_True)
void ReadPolygon3D (Standard_IStream &IS)
Standard_EXPORT void WritePolygonOnTriangulation (Standard_OStream &OS, const Standard_Boolean Compact=Standard_True)
void ReadPolygonOnTriangulation (Standard_IStream &IS)
Standard_EXPORT void WriteTriangulation (Standard_OStream &OS, const Standard_Boolean Compact=Standard_True)
void ReadTriangulation (Standard_IStream &IS)
void Clear ()
 Clears the content of the set.
void Check (const TopAbs_ShapeEnum T, TopoDS_Shape &S)
int NbShapes ()
Private Attributes
BRep_Builder myBuilder
TopTools_IndexedMapOfShape myShapes
std::map< int, int > my_ShapeNum_Location
TopTools_LocationSet myLocations
Standard_Integer myFormatNb
GeomTools_SurfaceSet mySurfaces
GeomTools_CurveSet myCurves
GeomTools_Curve2dSet myCurves2d
TColStd_IndexedMapOfTransient myPolygons2D
TColStd_IndexedMapOfTransient myPolygons3D
TColStd_IndexedMapOfTransient myTriangulations
TColStd_IndexedMapOfTransient myNodes
Detailed Description
Contains a Shape and all its subshapes, locations
and geometries, and attributes.
Definition at line 48 of file OCCShapeAttributeSet.hpp.
Definition at line 308 of file OCCShapeAttributeSet.cpp.
  :myFormatNb(1)
OCCShapeAttributeSet::OCCShapeAttributeSet ( const BRep_Builder &  B)
Definition at line 318 of file OCCShapeAttributeSet.cpp.
  :myBuilder(B)
Definition at line 72 of file OCCShapeAttributeSet.hpp.
{Clear();} ;
Member Function Documentation
Standard_Integer OCCShapeAttributeSet::Add ( const TopoDS_Shape &  S)
Stores <S> and its sub-shape. Returns the index of <S>.
The method AddGeometry is called on each sub-shape.
Definition at line 327 of file OCCShapeAttributeSet.cpp.
  if (S.IsNull()) return 0;
  myLocations.Add(S.Location());
  TopoDS_Shape S2 = S;
  S2.Location(TopLoc_Location());
  Standard_Integer index = myShapes.FindIndex(S2);
  if (index == 0) {
    AddGeometry(S2);
    for (TopoDS_Iterator its(S2,Standard_False,Standard_False);
         its.More(); its.Next())
      Add(its.Value());
    index = myShapes.Add(S2);
  return index;
void OCCShapeAttributeSet::AddGeometry ( const TopoDS_Shape &  S)
Definition at line 351 of file OCCShapeAttributeSet.cpp.
  // Add the geometry
  if (S.ShapeType() == TopAbs_VERTEX) {
    Handle(BRep_TVertex) TV = Handle(BRep_TVertex)::DownCast(S.TShape());
    BRep_ListIteratorOfListOfPointRepresentation itrp(TV->Points());
    while (itrp.More()) {
      const Handle(BRep_PointRepresentation)& PR = itrp.Value();
      if (PR->IsPointOnCurve()) {
        myCurves.Add(PR->Curve());
      else if (PR->IsPointOnCurveOnSurface()) {
        myCurves2d.Add(PR->PCurve());
        mySurfaces.Add(PR->Surface());
      else if (PR->IsPointOnSurface()) {
      myLocations.Add(PR->Location());
      itrp.Next();
  else if (S.ShapeType() == TopAbs_EDGE) {
    // Add the curve geometry
    Handle(BRep_TEdge) TE = Handle(BRep_TEdge)::DownCast(S.TShape());
    BRep_ListIteratorOfListOfCurveRepresentation itrc(TE->Curves());
    while (itrc.More()) {
      const Handle(BRep_CurveRepresentation)& CR = itrc.Value();
      if (CR->IsCurve3D()) {
        if (!CR->Curve3D().IsNull()) {
          myCurves.Add(CR->Curve3D());
          myLocations.Add(CR->Location());
      else if (CR->IsCurveOnSurface()) {
        mySurfaces.Add(CR->Surface());
        myCurves2d.Add(CR->PCurve());
        if (CR->IsCurveOnClosedSurface())
          myCurves2d.Add(CR->PCurve2());
      else if (CR->IsRegularity()) {
        mySurfaces.Add(CR->Surface2());
        myLocations.Add(CR->Location2());
      itrc.Next();
  else if (S.ShapeType() == TopAbs_FACE) {
    // Add the surface geometry
    Handle(BRep_TFace) TF = Handle(BRep_TFace)::DownCast(S.TShape());
    if (!TF->Surface().IsNull())  mySurfaces.Add(TF->Surface());
    myLocations.Add(TF->Location());
void OCCShapeAttributeSet::Check ( const TopAbs_ShapeEnum  T,
TopoDS_Shape &  S
Definition at line 1809 of file OCCShapeAttributeSet.cpp.
  if (T == TopAbs_FACE) {
    const TopoDS_Face& F = TopoDS::Face(S);
    BRepTools::Update(F);
Definition at line 1717 of file OCCShapeAttributeSet.cpp.
  mySurfaces.Clear();
  myCurves.Clear();
  myCurves2d.Clear();
  myPolygons3D.Clear();
  myPolygons2D.Clear();
  myNodes.Clear();
  myTriangulations.Clear();
  myShapes.Clear();
  my_ShapeNum_Location.clear();
  myLocations.Clear();
Definition at line 1823 of file OCCShapeAttributeSet.cpp.
  return myShapes.Extent();
void OCCShapeAttributeSet::operator delete ( void *  anAddress) [inline]
Definition at line 60 of file OCCShapeAttributeSet.hpp.
        if (anAddress) Standard::Free((Standard_Address&)anAddress);
void* OCCShapeAttributeSet::operator new ( size_t  ,
void *  anAddress
) [inline]
Definition at line 52 of file OCCShapeAttributeSet.hpp.
        return anAddress;
void* OCCShapeAttributeSet::operator new ( size_t  size) [inline]
Definition at line 56 of file OCCShapeAttributeSet.hpp.
        return Standard::Allocate(size);
void OCCShapeAttributeSet::Read ( Standard_IStream &  IS,
bool  print
Definition at line 712 of file OCCShapeAttributeSet.cpp.
 // on sauvegarde l'ancien LC_NUMERIC
  char *oldnum,*plocal ;
  plocal =   setlocale(LC_NUMERIC, NULL) ;
  oldnum = new char[strlen(plocal)+1] ;
  strcpy(oldnum,plocal);
  Clear();
  // Check the version
  char vers[101];
  do {
    IS.getline(vers,100,'\n');
    // BUC60769 PTV 18.10.2000: remove possible '\r' at the end of the line
    //Standard_Integer lv = strlen(vers);
    //char *pm;
    //if(pm = strchr(vers,'\r'))
    //  *pm ='\0';
    for (Standard_Integer lv = (strlen(vers)- 1); lv > 1 && (vers[lv] == '\r' || vers[lv] == '\n') ;lv--)
      vers[lv] = '\0';
  } while ( ! IS.fail() && strcmp(vers,dVersion) && strcmp(vers,dVersion2) );
  if (IS.fail()) {
    if (print_results)
      cout << "File was not written with this version of the topology"<<endl;
    setlocale(LC_NUMERIC, oldnum) ;
    delete[] oldnum;
    return;
  if (strcmp(vers,dVersion2) == 0) myFormatNb = 2;
  else myFormatNb = 1;
  // read the locations
  myLocations.Read(IS);
  // read the geometry
  ReadGeometry(IS);
  // read the shapes
  std::string buffer;
  IS >> buffer;
  if (buffer != "TShapes") {
    if (print_results)
      cout << "Not a TShape table"<<endl;
    delete[] oldnum;
    return;
  Standard_Integer i, nbShapes;
  IS >> nbShapes;
  for (i = 1; i <= nbShapes; i++) {
    TopoDS_Shape S;
    //Read type and create empty shape.
    TopAbs_ShapeEnum T = ReadShapeEnum(IS);
    ReadGeometry(T,IS,S);
    // Set the flags
    IS >> buffer;
    // sub-shapes
    TopoDS_Shape SS;
    do {
      Read(SS,IS,nbShapes);
      if (!SS.IsNull())
        myBuilder.Add(S,SS);
    } while(!SS.IsNull());
    S.Free      (buffer[0] == '1');
    S.Modified  (buffer[1] == '1');
    if (myFormatNb == 2)
      S.Checked   (buffer[2] == '1');
    else
      S.Checked   (Standard_False);     // force check at reading..
    S.Orientable(buffer[3] == '1');
    S.Closed    (buffer[4] == '1');
    S.Infinite  (buffer[5] == '1');
    S.Convex    (buffer[6] == '1');
    // check
    if (myFormatNb == 1)
      Check(T,S);
    myShapes.Add(S);
  delete[] oldnum;
void OCCShapeAttributeSet::Read ( TopoDS_Shape &  S,
const int  nbshapes,
TDF_Label *  l_attr = NULL
Definition at line 1736 of file OCCShapeAttributeSet.cpp.
  std::string buffer, buffer_attr;
  IS >> buffer;
  std::map<int,int>::iterator it;
  if (buffer[0] == '*')
    S = TopoDS_Shape();
  else {
    char type;
    int num;
    std::istringstream buffstr(buffer);
    buffstr >> type >> num;
    S = myShapes(nbshapes - num + 1);
    switch (type) {
    case '+' :
      S.Orientation(TopAbs_FORWARD);
      break;
    case '-' :
      S.Orientation(TopAbs_REVERSED);
      break;
    case 'i' :
      S.Orientation(TopAbs_INTERNAL);
      break;
    case 'e' :
      S.Orientation(TopAbs_EXTERNAL);
      break;
    Standard_Integer l;
    IS >> l;
    S.Location(myLocations.Location(l));
    int shape_num = nbshapes - num + 1;
    typedef std::pair <int,int> sh_loc_pair;
    it = my_ShapeNum_Location.find(shape_num);
    if(it == my_ShapeNum_Location.end())
      my_ShapeNum_Location.insert(sh_loc_pair(shape_num, l));
  if(label != NULL)
    Standard_Integer i, nbShapes = myShapes.Extent();
    for ( i = 1; i <= nbShapes; i++)
      TopoDS_Shape Sh = myShapes(i);
      IS >> buffer_attr;
      if(buffer_attr[0] != '*' && buffer_attr[0] != 'C')
        break;
      if(buffer_attr[0] == '*') //empty attributes for this shape
        continue;
      it = my_ShapeNum_Location.find(i);
      if(it != my_ShapeNum_Location.end())
        int loc_num = it->second;
        if (loc_num > 0)
          Sh.Location(myLocations.Location(loc_num));
      ReadAttribute(Sh, IS,*label);
void OCCShapeAttributeSet::ReadAttribute ( TopoDS_Shape &  S,
TDF_Label &  l_attr
Definition at line 427 of file OCCShapeAttributeSet.cpp.
  std::string buffer, type, stringdata;
  std::vector<CubitString> strings;
  std::vector<double> doubles;
  std::vector<int> ints;
  int c_num, length;
  char s;
  do {
    IS >> c_num; //length of name string
    IS.get(); //' '
    type.clear();
    for(int j = 0; j < c_num; j ++)
      IS.get(s);
      type.push_back(s);
    strings.clear();
    strings.push_back(type.c_str());
    IS >> length; //number of strings
    for(int i =0; i < length; i++)
      IS >> c_num ; //length of each string
      IS.get(); //' '
      stringdata.clear();
        IS.get(s);
        stringdata.push_back(s);
      strings.push_back(stringdata.c_str());
    int tmp_int;
    double  tmp_dbl;
    IS >> length; //number of ints
    ints.clear();
    for (int i = 0; i < length ; i++)
      IS >> tmp_int;
      ints.push_back( tmp_int );
    IS >> length; //number of doubles
    doubles.clear();
      IS >> tmp_dbl;
      doubles.push_back( tmp_dbl );
    CubitSimpleAttrib tmp_attrib(&strings, &doubles, &ints);
    OCCAttribSet::append_attribute(tmp_attrib, S);
    IS >> buffer;
  }while(buffer[0] != '*');
void OCCShapeAttributeSet::ReadGeometry ( Standard_IStream &  IS)
Definition at line 839 of file OCCShapeAttributeSet.cpp.
void OCCShapeAttributeSet::ReadGeometry ( const TopAbs_ShapeEnum  T,
TopoDS_Shape &  S
Definition at line 1228 of file OCCShapeAttributeSet.cpp.
  // Read the geometry
  Standard_Integer val,c,pc,pc2,s,s2,l,l2,t, pt, pt2;
  Standard_Real tol,X,Y,Z,first,last,p1,p2;
  Standard_Real PfX,PfY,PlX,PlY;
  gp_Pnt2d aPf, aPl;
  Standard_Boolean closed;
#ifndef DEB
  GeomAbs_Shape reg = GeomAbs_C0;
#else
  GeomAbs_Shape reg;
#endif
  switch (T) {
    // vertex
  case TopAbs_VERTEX :
      TopoDS_Vertex& V = TopoDS::Vertex(S);
      // Read the point geometry
      IS >> tol;
      IS >> X >> Y >> Z;
      myBuilder.MakeVertex(V,gp_Pnt(X,Y,Z),tol);
      Handle(BRep_TVertex) TV = Handle(BRep_TVertex)::DownCast(V.TShape());
      BRep_ListOfPointRepresentation& lpr = TV->ChangePoints();
      TopLoc_Location L;
      do {
        IS >> p1 >> val;
        Handle(BRep_PointRepresentation) PR;
        switch (val) {
        case 1 :
            IS >> c;
            if (myCurves.Curve(c).IsNull())
              break;
            Handle(BRep_PointOnCurve) POC =
              new BRep_PointOnCurve(p1,
                                    myCurves.Curve(c),
                                    L);
            PR = POC;
          break;
        case 2 :
            IS >> pc >> s;
            if (myCurves2d.Curve2d(pc).IsNull() ||
                mySurfaces.Surface(s).IsNull())
              break;
            Handle(BRep_PointOnCurveOnSurface) POC =
              new BRep_PointOnCurveOnSurface(p1,
                                             myCurves2d.Curve2d(pc),
                                             mySurfaces.Surface(s),
                                             L);
            PR = POC;
          break;
        case 3 :
            IS >> p2 >> s;
            if (mySurfaces.Surface(s).IsNull())
              break;
            Handle(BRep_PointOnSurface) POC =
              new BRep_PointOnSurface(p1,p2,
                                      L);
            PR = POC;
          break;
        if (val > 0) {
          IS >> l;
          if (!PR.IsNull()) {
            PR->Location(myLocations.Location(l));
            lpr.Append(PR);
      } while (val > 0);
    break;
    // edge
    case TopAbs_EDGE :
      // Create an edge
        TopoDS_Edge& E = TopoDS::Edge(S);
        myBuilder.MakeEdge(E);
        // Read the curve geometry
        IS >> tol;
        IS >> val;
        myBuilder.SameParameter(E,(val == 1));
        IS >> val;
        myBuilder.SameRange(E,(val == 1));
        IS >> val;
        myBuilder.Degenerated(E,(val == 1));
        do {
          IS >> val;
          switch (val) {
          case 1 :                               // -1- Curve 3D
            IS >> c >> l;
            if (!myCurves.Curve(c).IsNull()) {
              myBuilder.UpdateEdge(E,myCurves.Curve(c),
                                   myLocations.Location(l),tol);
            IS >> first >> last;
              Standard_Boolean Only3d = Standard_True;
              myBuilder.Range(E,first,last,Only3d);
            break;
          case 2 :                               // -2- Curve on surf
          case 3 :                               // -3- Curve on closed surf
            closed = (val == 3);
            IS >> pc;
            if (closed) {
              IS >> pc2;
              reg = ReadRegularity(IS);
            // surface, location
            IS >> s >> l;
            // range
            // read UV Points // for XML Persistence higher performance
              IS >> PfX >> PfY >> PlX >> PlY;
              aPf = gp_Pnt2d(PfX,PfY);
              aPl = gp_Pnt2d(PlX,PlY);
                (closed && myCurves2d.Curve2d(pc2).IsNull()) ||
              break;
            if (closed) {
                myBuilder.UpdateEdge(E,myCurves2d.Curve2d(pc),
                                     myCurves2d.Curve2d(pc2),
                                     myLocations.Location(l),tol,
                                     aPf, aPl);
              else
              myBuilder.Continuity(E,
                                   reg);
            else
                                     aPf, aPl);
              else
            myBuilder.Range(E,
                            first,last);
            break;
          case 4 :                               // -4- Regularity
            IS >> s >> l >> s2 >> l2;
            if (mySurfaces.Surface(s).IsNull() ||
                mySurfaces.Surface(s2).IsNull())
              break;
                                 mySurfaces.Surface(s2),
                                 myLocations.Location(l2),
                                 reg);
            break;
          case 5 :   // -5- Polygon3D
            IS >> c >> l;
            myBuilder.UpdateEdge(E,Handle(Poly_Polygon3D)::DownCast(myPolygons3D(c)), myLocations.Location(l));
            break;
          case 6 :
          case 7 :
            closed = (val == 7);
            IS >> pt;
            if (closed) {
              IS >> pt2;
            IS >> t >> l;
            if (closed) {
                (E, Handle(Poly_PolygonOnTriangulation)::DownCast(myNodes(pt)),
                 Handle(Poly_PolygonOnTriangulation)::DownCast(myNodes(pt2)),
                 Handle(Poly_Triangulation)::DownCast(myTriangulations(t)),
            else {
                (E,Handle(Poly_PolygonOnTriangulation)::DownCast(myNodes(pt)),
            // range
            break;
        } while (val > 0);
    break;
    // wire
  case TopAbs_WIRE :
    myBuilder.MakeWire(TopoDS::Wire(S));
    break;
    // face
  case TopAbs_FACE :
    // create a face :
    myBuilder.MakeFace(F);
    IS >> val; // natural restriction
    if (val == 0 || val == 1) {
      IS >> tol >> s >> l;
      if (!mySurfaces.Surface(s).IsNull()) {
        myBuilder.UpdateFace(TopoDS::Face(S),
        myBuilder.NaturalRestriction(TopoDS::Face(S),(val == 1));
    // BUC60769
    std::string line;
    std::getline( IS, line );
    std::istringstream str( line );
    if (str.get() == '2') {
      // cas triangulation
      str >> s;
                           Handle(Poly_Triangulation)::DownCast(myTriangulations(s)));
//    else IS.seekg(pos);
    break;
    // shell
  case TopAbs_SHELL :
    myBuilder.MakeShell(TopoDS::Shell(S));
    break;
    // solid
  case TopAbs_SOLID :
    myBuilder.MakeSolid(TopoDS::Solid(S));
    break;
    // compsolid
  case TopAbs_COMPSOLID :
    myBuilder.MakeCompSolid(TopoDS::CompSolid(S));
    break;
    // compound
  case TopAbs_COMPOUND :
    myBuilder.MakeCompound(TopoDS::Compound(S));
    break;
  default:
    break;
void OCCShapeAttributeSet::ReadPolygon3D ( Standard_IStream &  IS)
Definition at line 1621 of file OCCShapeAttributeSet.cpp.
    std::string buffer;
    //  Standard_Integer i, j, p, val, nbpol, nbnodes, hasparameters;
    Standard_Integer i, j, p, nbpol=0, nbnodes =0, hasparameters = Standard_False;  Standard_Real d, x, y, z;
    IS >> buffer;
    if (buffer.find("Polygon3D") == std::string::npos)
      return;
    Handle(Poly_Polygon3D) P;
    IS >> nbpol;
    for (i=1; i<=nbpol; i++) {
      IS >> nbnodes;
      IS >> hasparameters;
      TColgp_Array1OfPnt Nodes(1, nbnodes);
      IS >> d;
      for (j = 1; j <= nbnodes; j++) {
        IS >> x >> y >> z;
        Nodes(j).SetCoord(x,y,z);
      if (hasparameters) {
        TColStd_Array1OfReal Param(1,nbnodes);
        for (p = 1; p <= nbnodes; p++) {
          IS >> Param(p);
        P = new Poly_Polygon3D(Nodes, Param);
      else P = new Poly_Polygon3D(Nodes);
      P->Deflection(d);
      myPolygons3D.Add(P);
void OCCShapeAttributeSet::ReadPolygonOnTriangulation ( Standard_IStream &  IS)
Definition at line 1578 of file OCCShapeAttributeSet.cpp.
    std::string buffer;
    IS >> buffer;
    if (buffer.find("PolygonOnTriangulations") == std::string::npos)
      return;
    Standard_Integer i, j, val, nbpol = 0, nbnodes =0;
    Standard_Integer hasparameters;
    Standard_Real par;
    Handle(TColStd_HArray1OfReal) Param;
    Handle(Poly_PolygonOnTriangulation) Poly;
    IS >> nbpol;
      IS >> nbnodes;
      TColStd_Array1OfInteger Nodes(1, nbnodes);
        IS >> val;
        Nodes(j) = val;
      IS >> buffer;
      Standard_Real def;
      IS >> def;
        TColStd_Array1OfReal Param1(1, nbnodes);
          IS >> par;
          Param1(j) = par;
        Poly = new Poly_PolygonOnTriangulation(Nodes, Param1);
      else Poly = new Poly_PolygonOnTriangulation(Nodes);
      Poly->Deflection(def);
      myNodes.Add(Poly);
void OCCShapeAttributeSet::ReadTriangulation ( Standard_IStream &  IS)
Definition at line 1660 of file OCCShapeAttributeSet.cpp.
  std::string buffer;
  //  Standard_Integer i, j, val, nbtri;
  Standard_Integer i, j, nbtri =0;
  Standard_Integer nbNodes =0, nbTriangles=0;
  Standard_Boolean hasUV= Standard_False;
  Handle(Poly_Triangulation) T;
  IS >> buffer;
  if (buffer.find("Triangulations") != std::string::npos) {
    IS >> nbtri;
    for (i=1; i<=nbtri; i++) {
      IS >> nbNodes >> nbTriangles >> hasUV;
      IS >> d;
      TColgp_Array1OfPnt Nodes(1, nbNodes);
      TColgp_Array1OfPnt2d UVNodes(1, nbNodes);
      for (j = 1; j <= nbNodes; j++) {
        IS >> x >> y >> z;
      if (hasUV) {
          IS >> x >> y;
          UVNodes(j).SetCoord(x,y);
      // read the triangles
      Standard_Integer n1,n2,n3;
      Poly_Array1OfTriangle Triangles(1, nbTriangles);
      for (j = 1; j <= nbTriangles; j++) {
        IS >> n1 >> n2 >> n3;
        Triangles(j).Set(n1,n2,n3);
      if (hasUV) T =  new Poly_Triangulation(Nodes,UVNodes,Triangles);
      else T = new Poly_Triangulation(Nodes,Triangles);
      T->Deflection(d);
      myTriangulations.Add(T);
void OCCShapeAttributeSet::Write ( Standard_OStream &  OS)
Definition at line 620 of file OCCShapeAttributeSet.cpp.
  //on sauvegarde l'ancien LC_NUMERIC
  // on positionne LC_NUMERIC a "C" (point decimal)
  setlocale(LC_NUMERIC, "C") ;
  int  prec = OS.precision(15);
  // write the copyright
    OS << "\n" << dVersion2 << endl;
  else
    OS << "\n" << dVersion << endl;
  // write the locations
  myLocations.Write(OS);
  // write the geometry
  WriteGeometry(OS);
  // write the shapes
  OS << "\nTShapes " << nbShapes << "\n";
  // subshapes are written first
    const TopoDS_Shape& S = myShapes(i);
    // Type
    PrintShapeEnum(S.ShapeType(),OS,Standard_True);
    OS << "\n";
    // Geometry
    WriteGeometry(S,OS);
    // Flags
    OS << "\n";
    OS << (S.Free()       ? 1 : 0);
    OS << (S.Modified()   ? 1 : 0);
    OS << (S.Checked()    ? 1 : 0);
    OS << (S.Orientable() ? 1 : 0);
    OS << (S.Closed()     ? 1 : 0);
    OS << (S.Infinite()   ? 1 : 0);
    OS << (S.Convex()     ? 1 : 0);
    OS << "\n";
    // sub-shapes
    Standard_Integer l = 0;
    TopoDS_Iterator its(S,Standard_False,Standard_False);
    while (its.More()) {
      Write(its.Value(),OS);
      l++;
      if (l == 10) {
        OS << "\n";
        l = 0;
      its.Next();
    Write(TopoDS_Shape(),OS); // Null shape to end the list
    OS << "\n";
  OS << endl;
  OS.precision(prec);
  // on remet le LC_NUMERIC a la precedente valeur
  delete[] oldnum;
void OCCShapeAttributeSet::Write ( const TopoDS_Shape &  S,
Standard_OStream &  OS,
Writes on <OS> the shape <S>. Writes the
orientation, the index of the TShape and the index
of the Location.
Definition at line 1200 of file OCCShapeAttributeSet.cpp.
  if (S.IsNull()) OS << "*";
  else {
    PrintOrientation(S.Orientation(),OS,Standard_True);
    OS << myShapes.Extent() - myShapes.FindIndex(S.Located(TopLoc_Location())) + 1;
    OS << " " << myLocations.Index(S.Location()) << " ";
  //Write Attributes
  if(l_attr != NULL)
      const TopoDS_Shape& Sh = myShapes(i);
      WriteAttribute(Sh, OS, *l_attr);
void OCCShapeAttributeSet::WriteAttribute ( const TopoDS_Shape &  S,
TDF_Label &  l_attr
Writes the attributs of <S> on the stream <OS> in a
format that can be read back by Read.
Definition at line 495 of file OCCShapeAttributeSet.cpp.
  if(l_attr.IsNull())
    return;
  Standard_Boolean found = Standard_False;
  TDF_Label myLabel;
  for (TDF_ChildIterator it1(l_attr,Standard_False); it1.More(); it1.Next())
    //find the same shape attribute first
    myLabel = it1.Value();
    Handle_TDataXtd_Shape attr_shape;
    TopoDS_Shape exsiting_shape;
    if(TDataXtd_Shape::Find(myLabel, attr_shape))
      exsiting_shape = attr_shape->Get(myLabel);
    if(!exsiting_shape.IsNull())
      if(exsiting_shape.IsPartner(S))
        //It's possible that the myLabel found in this way wasn't the bounded
        //lable with the shape. Find the bounded one now.
        if(!OCCQueryEngine::instance()->OCCMap->IsBound(exsiting_shape))
          continue;
        int k = OCCQueryEngine::instance()->OCCMap->Find(exsiting_shape);
        std::map<int, TDF_Label>::iterator it =
           OCCQueryEngine::instance()->Shape_Label_Map->find(k);
        if(it != OCCQueryEngine::instance()->Shape_Label_Map->end())
          found = Standard_True;
          myLabel = (*it).second;
          break;
  if(!found)
    OS << "\n*";
    return;
  if(!myLabel.HasChild())
    OS << "\n*";
    return;
  for (TDF_ChildIterator it2(myLabel,Standard_False); it2.More(); it2.Next())
    TDF_Label child = it2.Value();
    //Write out all attributes
    Handle_TDataStd_Name attr_name;
    TCollection_ExtendedString name_string;
    if(child.FindAttribute(TDataStd_Name::GetID(), attr_name))
      OS << "\n";
      OS << "CGM_ATTRIB ";
      name_string = attr_name->Get();
      int length = name_string.Length();
      OS << length << ' ';
      name_string.Print(OS);
      OS << ' ' ;
    else
      continue;
    Handle_TDataStd_ExtStringArray attr_strings;
    if(child.FindAttribute(TDataStd_ExtStringArray::GetID(), attr_strings))
      Standard_Integer i = attr_strings->Lower();
      TCollection_ExtendedString string;
      int size = attr_strings->Upper();
      OS << size -i + 1 << " ";
      for(; i <= size; i++)
         string = attr_strings->Value(i);
         int length = string.Length();
         string.Print(OS);
         OS << ' ';
    else
      OS << "0 " ;
    Handle_TDataStd_IntegerArray attr_ints;
    if(child.FindAttribute(TDataStd_IntegerArray::GetID(), attr_ints))
      Standard_Integer i = attr_ints->Lower();
      int size = attr_ints->Upper();
        OS << attr_ints->Value(i) << ' ';
    else
      OS << "0 " ;
    Handle_TDataStd_RealArray attr_doubles;
    if(child.FindAttribute(TDataStd_RealArray::GetID(), attr_doubles))
      Standard_Integer i = attr_doubles->Lower();
      Standard_Integer size = attr_doubles->Upper();
      for(;i <= size; i++)
        OS << attr_doubles->Value(i) << ' ';
    else
      OS << "0 " ;
  OS << "\n*";
void OCCShapeAttributeSet::WriteGeometry ( Standard_OStream &  OS)
Writes the geometry of me on the stream <OS> in a
Definition at line 824 of file OCCShapeAttributeSet.cpp.
  myCurves2d.Write(OS);
  myCurves.Write(OS);
  WritePolygon3D(OS);
  WritePolygonOnTriangulation(OS);
  mySurfaces.Write(OS);
  WriteTriangulation(OS);
void OCCShapeAttributeSet::WriteGeometry ( const TopoDS_Shape &  S,
Writes the geometry of <S> on the stream <OS> in a
Definition at line 1059 of file OCCShapeAttributeSet.cpp.
  // Write the geometry
    // Write the point geometry
    TopoDS_Vertex V = TopoDS::Vertex(S);
    OS << BRep_Tool::Tolerance(V) << "\n";
    gp_Pnt p = BRep_Tool::Pnt(V);
    OS<<p.X()<<" "<<p.Y()<<" "<<p.Z()<<"\n";
      OS << PR->Parameter();
        OS << " 1 " << myCurves.Index(PR->Curve());
        OS << " 2 " <<  myCurves2d.Index(PR->PCurve());
        OS << " " << mySurfaces.Index(PR->Surface());
        OS << " 3 " << PR->Parameter2() << " ";
        OS << mySurfaces.Index(PR->Surface());
      OS << " " << myLocations.Index(PR->Location());
      OS << "\n";
      itrp.Next();
    OS << "0 0\n"; // end representations
    // Write the curve geometry
    OS << " " << TE->Tolerance() << " ";
    OS << ((TE->SameParameter()) ? 1 : 0) << " ";
    OS << ((TE->SameRange())     ? 1 : 0) << " ";
    OS << ((TE->Degenerated())   ? 1 : 0) << "\n";
    Standard_Real first, last;
    BRep_ListIteratorOfListOfCurveRepresentation itrc = TE->Curves();
          Handle(BRep_GCurve) GC = Handle(BRep_GCurve)::DownCast(itrc.Value());
          GC->Range(first, last);
          OS << "1 ";                               // -1- Curve 3D
          OS << " "<<myCurves.Index(CR->Curve3D());
          OS << " "<<myLocations.Index(CR->Location());
          OS << " "<<first<<" "<<last;
          OS << "\n";
        if (!CR->IsCurveOnClosedSurface())
          OS << "2 ";                             // -2- Curve on surf
        else
          OS << "3 ";                             // -3- Curve on closed surf
        OS <<" "<<myCurves2d.Index(CR->PCurve());
        if (CR->IsCurveOnClosedSurface()) {
          OS <<" " << myCurves2d.Index(CR->PCurve2());
          PrintRegularity(CR->Continuity(),OS);
        OS << " " << mySurfaces.Index(CR->Surface());
        OS << " " << myLocations.Index(CR->Location());
        OS << "\n";
        // Write UV Points // for XML Persistence higher performance
          gp_Pnt2d Pf,Pl;
            Handle(BRep_CurveOnClosedSurface) COCS =
              Handle(BRep_CurveOnClosedSurface)::DownCast(CR);
            COCS->UVPoints2(Pf,Pl);
          else {
            Handle(BRep_CurveOnSurface) COS =
              Handle(BRep_CurveOnSurface)::DownCast(CR);
            COS->UVPoints(Pf,Pl);
          OS << Pf.X() << " " << Pf.Y() << " " << Pl.X() << " " << Pl.Y() << "\n";
        OS << "4 ";                              // -4- Regularity
        OS << " "<<mySurfaces.Index(CR->Surface());
        OS << " "<<mySurfaces.Index(CR->Surface2());
        OS << " "<<myLocations.Index(CR->Location2());
        OS << "\n";
      itrc.Next();
    OS << "0\n"; // end of the list of representations
    if (!(TF->Surface()).IsNull()) {
      OS << ((BRep_Tool::NaturalRestriction(F)) ? 1 : 0);
      OS << " ";
      // Write the surface geometry
      OS << " " <<TF->Tolerance();
      OS << " " <<mySurfaces.Index(TF->Surface());
      OS << " " <<myLocations.Index(TF->Location());
      OS << "\n";
void OCCShapeAttributeSet::WritePolygon3D ( Standard_OStream &  OS,
const Standard_Boolean  Compact = Standard_True
Writes the 3d polygons
on the stream <OS> in a format that can
Definition at line 854 of file OCCShapeAttributeSet.cpp.
  Standard_Integer i, j, nbpol = myPolygons3D.Extent();
  if (Compact)
    OS << "Polygon3D " << nbpol << endl;
  else {
    OS << " -------\n";
    OS <<"Dump of " << nbpol << " Polygon3Ds\n";
    OS << " -------\n";
  for (i = 1; i <= nbpol; i++) {
    P = Handle(Poly_Polygon3D)::DownCast(myPolygons3D(i));
    if (Compact) {
      OS << P->NbNodes() << " ";
      OS << ((P->HasParameters()) ? "1" : "0") << "\n";
    else {
      OS << "  "<< i << " : Polygon3D with " << P->NbNodes() << " Nodes\n";
      OS << ((P->HasParameters()) ? "with" : "without") << " parameters\n";
    // write the deflection
    if (!Compact) OS << "Deflection : ";
    OS << P->Deflection() << "\n";
    // write the nodes
    if (!Compact) OS << "\nNodes :\n";
    Standard_Integer i1, nbNodes = P->NbNodes();
    const TColgp_Array1OfPnt& Nodes = P->Nodes();
      if (!Compact) OS << setw(10) << j << " : ";
      if (!Compact) OS << setw(17);
      OS << Nodes(j).X() << " ";
      OS << Nodes(j).Y() << " ";
      OS << Nodes(j).Z();
      if (!Compact) OS << "\n";
      else OS << " ";
    OS <<"\n";
    if (P->HasParameters()) {
      if (!Compact) OS << "\nParameters :\n";
      const TColStd_Array1OfReal& Param = P->Parameters();
      for ( i1 = 1; i1 <= nbNodes; i1++ ) {
        OS << Param(i1) << " ";
      OS <<"\n";
void OCCShapeAttributeSet::WritePolygonOnTriangulation ( Standard_OStream &  OS,
Writes the polygons on triangulation
Definition at line 917 of file OCCShapeAttributeSet.cpp.
  Standard_Integer i, j, nbpOntri = myNodes.Extent();
  if (Compact)
    OS << "PolygonOnTriangulations " << nbpOntri << endl;
  else {
    OS << " -------\n";
    OS <<"Dump of " << nbpOntri << " PolygonOnTriangulations\n";
    OS << " -------\n";
  for (i=1; i<=nbpOntri; i++) {
    Poly = Handle(Poly_PolygonOnTriangulation)::DownCast(myNodes(i));
    const TColStd_Array1OfInteger& Nodes = Poly->Nodes();
    if (!Compact) {
      OS << "  "<< i << " : PolygonOnTriangulation with " << Nodes.Length() << " Nodes\n";
    else OS << Nodes.Length()<<" ";
    if (!Compact) OS <<"  ";
    for (j=1; j <= Nodes.Length(); j++) OS << Nodes.Value(j) << " ";
    OS << "\n";
    // writing parameters:
    Param = Poly->Parameters();
    if (Compact) OS <<"p ";
    if (!Compact) OS << "  Deflection : ";
    OS <<Poly->Deflection() << " ";
    if (!Param.IsNull()) {
      if (!Compact) {
        OS << "  "<< "Parameters :";
      else OS << "1 " ;
      for (j=1; j <= Param->Length(); j++) OS << Param->Value(j) << " ";
      OS << "\n";
    else OS <<"0 \n";
void OCCShapeAttributeSet::WriteTriangulation ( Standard_OStream &  OS,
Writes the triangulation
Definition at line 972 of file OCCShapeAttributeSet.cpp.
  Standard_Integer i, j, nbNodes, nbtri = myTriangulations.Extent();
  Standard_Integer nbTriangles = 0, n1, n2, n3;
  if (Compact)
    OS << "Triangulations " << nbtri << endl;
  else {
    OS << " -------\n";
    OS <<"Dump of " << nbtri << " Triangulations\n";
    OS << " -------\n";
  for (i = 1; i <= nbtri; i++) {
    T = Handle(Poly_Triangulation)::DownCast(myTriangulations(i));
    if (Compact) {
      OS << T->NbNodes() << " " << T->NbTriangles() << " ";
      OS << ((T->HasUVNodes()) ? "1" : "0") << " ";
    else {
      OS << "  "<< i << " : Triangulation with " << T->NbNodes() << " Nodes and "
         << T->NbTriangles() <<" Triangles\n";
      OS << "      "<<((T->HasUVNodes()) ? "with" : "without") << " UV nodes\n";
    OS <<T->Deflection() << "\n";
    // write the 3d nodes
    if (!Compact) OS << "\n3D Nodes :\n";
    nbNodes = T->NbNodes();
    const TColgp_Array1OfPnt& Nodes = T->Nodes();
      OS << Nodes(j).Z();
      else OS << " ";
    if (T->HasUVNodes()) {
      if (!Compact) OS << "\nUV Nodes :\n";
      const TColgp_Array1OfPnt2d& UVNodes = T->UVNodes();
        OS << UVNodes(j).X() << " ";
        OS << UVNodes(j).Y();
        else OS << " ";
    if (!Compact) OS << "\nTriangles :\n";
    nbTriangles = T->NbTriangles();
    const Poly_Array1OfTriangle& Triangles = T->Triangles();
      Triangles(j).Get(n1, n2, n3);
      if (!Compact) OS << setw(10);
      OS << n1 << " ";
      OS << n2 << " ";
      OS << n3;
      else OS << " ";
    OS << "\n";
Member Data Documentation
std::map<int,int> OCCShapeAttributeSet::my_ShapeNum_Location [private]
Definition at line 166 of file OCCShapeAttributeSet.hpp.
BRep_Builder OCCShapeAttributeSet::myBuilder [private]
Definition at line 164 of file OCCShapeAttributeSet.hpp.
GeomTools_CurveSet OCCShapeAttributeSet::myCurves [private]
Definition at line 170 of file OCCShapeAttributeSet.hpp.
GeomTools_Curve2dSet OCCShapeAttributeSet::myCurves2d [private]
Definition at line 171 of file OCCShapeAttributeSet.hpp.
Standard_Integer OCCShapeAttributeSet::myFormatNb [private]
Definition at line 168 of file OCCShapeAttributeSet.hpp.
TopTools_LocationSet OCCShapeAttributeSet::myLocations [private]
Definition at line 167 of file OCCShapeAttributeSet.hpp.
TColStd_IndexedMapOfTransient OCCShapeAttributeSet::myNodes [private]
Definition at line 175 of file OCCShapeAttributeSet.hpp.
TColStd_IndexedMapOfTransient OCCShapeAttributeSet::myPolygons2D [private]
Definition at line 172 of file OCCShapeAttributeSet.hpp.
TColStd_IndexedMapOfTransient OCCShapeAttributeSet::myPolygons3D [private]
Definition at line 173 of file OCCShapeAttributeSet.hpp.
TopTools_IndexedMapOfShape OCCShapeAttributeSet::myShapes [private]
Definition at line 165 of file OCCShapeAttributeSet.hpp.
GeomTools_SurfaceSet OCCShapeAttributeSet::mySurfaces [private]
Definition at line 169 of file OCCShapeAttributeSet.hpp.
TColStd_IndexedMapOfTransient OCCShapeAttributeSet::myTriangulations [private]
Definition at line 174 of file OCCShapeAttributeSet.hpp.
