cgma
PST_Edge Class Reference
#include <PST_Data.hpp>
Inheritance diagram for PST_Edge:
PST_Entity
List of all members.
Public Member Functions
 PST_Edge (PST_Point *start_pt, PST_Point *end_pt)
PST_Edgesplit (PST_Point *point)
 ~PST_Edge ()
PST_Pointstart_point ()
PST_Pointend_point ()
const CubitVectorstart_coord ()
const CubitVectorend_coord ()
CubitVector direction ()
CubitVector position (double t)
double closest_on_line (const CubitVector &pos)
double closest_on_edge (const CubitVector &pos)
double closest_on_line (const CubitVector &base, const CubitVector &direction)
PST_Pointother (PST_Point *pt)
PST_Pointcommon_point (PST_Edge *edge)
PST_CoEdgeforward ()
PST_CoEdgereverse ()
PST_CoEdgeother (PST_CoEdge *coedge)
PST_CoEdgecoedge (PST_Face *face)
PST_Faceother (PST_Face *face)
PST_Facecommon_face (PST_Edge *edge)
CubitSense sense (PST_Face *face)
CubitSense sense (PST_CoEdge *coedge)
PST_Edgeother (PST_Point *point, PST_Face *face)
PST_Edgenext (PST_Point *pt)
void debug_draw (int color=1, bool flush=true)
int validate (CubitBoolean print=CUBIT_FALSE)
void print ()
Static Public Member Functions
static void make_gmem (GMem &gmem, DLIList< PST_Face * > &facets)
static void make_gmem (GMem &gmem, DLIList< PST_Edge * > &edges)
static void make_facets (GMem &gmem, double tolerance, DLIList< PST_Edge * > &edges)
static void make_facets (const std::vector< double > &coordinates, const std::vector< int > &connections, double tolerance, DLIList< PST_Edge * > &edge_list)
static PST_Facecreate_face (PST_Point *p1, PST_Point *p2, PST_Point *p3)
static PST_Edgesplit_face (PST_Point *start, PST_Point *end, PST_Face *hint=0)
static PST_Edgesplit_face (PST_CoEdge *after_coedge_1, PST_CoEdge *after_coedge_2)
static PST_Edgeinsert_in_face (PST_Point *end, PST_CoEdge *after_this)
static void faces (DLIList< PST_Edge * > &edges, DLIList< PST_Face * > &faces)
static void edges (DLIList< PST_Face * > &faces, DLIList< PST_Edge * > &edges)
static void edges (DLIList< PST_Point * > &pts, DLIList< PST_Edge * > &edges)
static void points (DLIList< PST_Edge * > &edges, DLIList< PST_Point * > &pts)
static void debug_draw_points (DLIList< PST_Edge * > &list, int color, int bcolor=0, bool flush=true)
static void debug_draw_edges (DLIList< PST_Edge * > &list, int color, int bcolor=0, bool flush=true)
static void debug_draw_faces (DLIList< PST_Edge * > &list, int color, bool flush=true)
static int validate (DLIList< PST_Edge * > &edges, CubitBoolean print=CUBIT_FALSE)
Public Attributes
int mark
Private Member Functions
void remove_point (PST_Point *&ptr, PST_Edge *&next)
void remove_start_point ()
void remove_end_point ()
void set_point (PST_Point *pt, PST_Point *&ptr, PST_Edge *&next)
void set_start_point (PST_Point *pt)
void set_end_point (PST_Point *pt)
Private Attributes
cBit private_mark_: 1
PST_Pointstart_
PST_Pointend_
PST_Edgestart_next_
PST_Edgeend_next_
PST_CoEdge forward_
PST_CoEdge reverse_
Detailed Description
Definition at line 181 of file PST_Data.hpp.
PST_Edge::PST_Edge ( PST_Point start_pt,
PST_Point end_pt
) [inline]
Definition at line 195 of file PST_Data.hpp.
      : mark(0), private_mark_(false),
        start_(0), end_(0)
        assert( start_pt != end_pt );
        set_start_point( start_pt );
        set_end_point( end_pt );
        forward_ = PST_CoEdge(this);
        reverse_ = PST_CoEdge(this);
Definition at line 249 of file PST_Data.cpp.
    // Update list "head" pointers on points, if necessary.
  if( start_point() )
    remove_start_point();
  if( end_point() )
    remove_end_point();
    // Destroy parent facets
  for ( int i = 0; i < 2; i++ )
    PST_CoEdge* coedge = i ? reverse() : forward();
    if ( coedge->face() )
      PST_Face* face = coedge->face();
      face->coedge_ = 0;
      PST_CoEdge* first = coedge;
      do {
        assert(coedge->face() == face);
        coedge->face_ = 0;
        PST_CoEdge* next = coedge->next();
        coedge->next_ = 0;
        coedge = next;
      } while( first != coedge );
      delete face ;
Member Function Documentation
double PST_Edge::closest_on_edge ( const CubitVector pos)
Definition at line 288 of file PST_Data.cpp.
  double t = closest_on_line( p );
  if( t < 0.0 )
    t = 0.0;
  else if( t > 1.0 )
    t = 1.0;
  return t;
double PST_Edge::closest_on_line ( const CubitVector pos)
Definition at line 279 of file PST_Data.cpp.
  CubitVector B = start_coord();
  CubitVector M   = end_coord() - B;
  if( M.length_squared() < RESABS_SQR )
    return 0.0;
  return ( M % ( P - B ) ) / ( M % M );
double PST_Edge::closest_on_line ( const CubitVector base,
const CubitVector direction
Definition at line 298 of file PST_Data.cpp.
  CubitVector B1 = start_coord();
  CubitVector M1 = direction();
  if( M1.length_squared() < RESABS_SQR )
    return 0.0;
  if( M2.length_squared() < RESABS_SQR )
    return closest_on_line( B2 );
  CubitVector cross = M2 * M1;
  if( cross.length_squared() < CUBIT_RESABS ) //parallel
    return 0.0;
  CubitVector N = M2 * cross;
  double      D = -( N % B2 );
  return -( N % B1 + D ) / ( N % M1 );
PST_CoEdge * PST_Edge::coedge ( PST_Face face) [inline]
Definition at line 534 of file PST_Data.hpp.
  PST_CoEdge* result = 0;
  if( forward_.face_ == face )
    result = &forward_;
  if( reverse_.face_ == face )
    result = result ? 0 : &reverse_;
  return result;
PST_Face* PST_Edge::common_face ( PST_Edge edge) [inline]
PST_Point * PST_Edge::common_point ( PST_Edge edge) [inline]
Definition at line 519 of file PST_Data.hpp.
  PST_Point* result = 0;
  if( (edge->start_ == start_) ||
      (edge->end_   == start_)  )
    result = start_;
  if( (edge->start_ == end_) ||
      (edge->end_   == end_)  )
    result = result ? 0 : end_;
  return result;
PST_Face * PST_Edge::create_face ( PST_Point p1,
PST_Point p2,
PST_Point p3
) [static]
Definition at line 339 of file PST_Data.cpp.
    // It is trivial to generalize this function for creating
    // faces with an arbitrary number of sides, but I just
    // want triangles.
  const int size = 3;
  PST_Point* p[size] = { pt1, pt2, pt3 };
  int i;
  PST_Edge* e[size];
  PST_CoEdge* c[size];
    // Initialize edge and coedge arrays, creating
    // edges if necessary.
  for( i = 0; i < size; i++ )
    e[i] = p[i]->common( p[(i+1)%size] );
    if( !e[i] )
      e[i] = new PST_Edge( p[i], p[(i+1)%size] );
      c[i] = e[i]->forward();
    else
      c[i] = e[i]->start_point() == p[i] ? e[i]->forward() : e[i]->reverse();
        // If the co-edge in the appropriate direction is already
        // part of a face (other than the boundary face), then we
        // can't proceed.
//      if( !c[i]->face()->boundary() )
      if( c[i]->face() )
        while( --i >= 0 )
          if( ! c[i]->face() )
            delete e[i];
        return 0;
  PST_Face* result = new PST_Face( c[0] );
  for ( i = 0; i < size; i++ )
    int next = (i + 1) % size;
    c[i]->face_ = result;
    c[i]->next_ = c[next];
  return result;
void PST_Edge::debug_draw ( int  color = 1,
bool  flush = true
Definition at line 620 of file PST_Data.cpp.
  GfxDebug::draw_line(
    float(start_coord().x()), float(start_coord().y()), float(start_coord().z()),
    float(  end_coord().x()), float(  end_coord().y()), float(  end_coord().z()),
    color );
  if( flush ) GfxDebug::flush();
void PST_Edge::debug_draw_edges ( DLIList< PST_Edge * > &  list,
int  color,
int  bcolor = 0,
bool  flush = true
) [static]
Definition at line 755 of file PST_Data.cpp.
  if( !boundary_color ) boundary_color = color;
  for( int e = edge_list.size(); e--; )
    PST_Edge* edge_ptr = edge_list.get_and_step();
    int c = !edge_ptr->forward()->face() || !edge_ptr->reverse()->face()
       ? boundary_color : color;
    edge_ptr->debug_draw( c, false );
void PST_Edge::debug_draw_faces ( DLIList< PST_Edge * > &  list,
int  color,
bool  flush = true
) [static]
Definition at line 771 of file PST_Data.cpp.
  DLIList<PST_Face*> face_list;
  PST_Edge::faces( edge_list, face_list );
  PST_Face::debug_draw_faces( face_list, color, flush );
void PST_Edge::debug_draw_points ( DLIList< PST_Edge * > &  list,
int  color,
int  bcolor = 0,
bool  flush = true
) [static]
Definition at line 725 of file PST_Data.cpp.
  if( ! boundary_color ) boundary_color = color;
  DLIList<PST_Point*> point_list;
  DLIList<PST_Point*> boundary_list;
  PST_Edge::points( edge_list, point_list );
  for( int i = point_list.size(); i--; )
     PST_Point* pt = point_list.step_and_get();
     PST_Edge* e = pt->edge();
     do
       if( !e->forward()->face() || !e->reverse()->face() )
         break;
       e = e->next(pt);
     } while( e != pt->edge() );
       point_list.change_to( 0 );
       boundary_list.append( pt );
  point_list.remove_all_with_value(0);
  PST_Point::debug_draw_points( point_list, color, false );
  PST_Point::debug_draw_points( boundary_list, boundary_color, flush );
Definition at line 259 of file PST_Data.hpp.
      { return end_coord() - start_coord(); }
void PST_Edge::edges ( DLIList< PST_Face * > &  faces,
DLIList< PST_Edge * > &  edges
) [static]
Definition at line 807 of file PST_Data.cpp.
  int f;
  for( f = faces.size(); f--; )
    PST_CoEdge* first = faces.get_and_step()->first_coedge();
    PST_CoEdge* coedge = first;
    do
      coedge->edge()->private_mark_ = 1;
      coedge = coedge->next();
    } while( coedge != first );
    do
      if( coedge->edge()->private_mark_ )
        coedge->edge()->private_mark_ = 0;
        edges.append( coedge->edge() );
void PST_Edge::edges ( DLIList< PST_Point * > &  pts,
) [static]
Definition at line 837 of file PST_Data.cpp.
  int p;
  for( p = pts.size(); p--; )
    PST_Point* pt = pts.get_and_step();
    PST_Edge* edge = pt->edge();
    if( edge ) do
      edge->private_mark_ = 1;
      edge = edge->next( pt );
    } while( edge != pt->edge() );
    if( edge ) do
      if( edge->private_mark_ )
        edge->private_mark_ = 0;
        edges.append( edge );
const CubitVector& PST_Edge::end_coord ( ) [inline]
Definition at line 256 of file PST_Data.hpp.
      { return *end_; }
Definition at line 250 of file PST_Data.hpp.
      { return end_; }
void PST_Edge::faces ( DLIList< PST_Edge * > &  edges,
) [static]
Definition at line 778 of file PST_Data.cpp.
  int e;
  for( e = edges.size(); e--; )
    PST_Edge* edge_ptr = edges.get_and_step();
    if( edge_ptr->forward()->face() )
      edge_ptr->forward()->face()->private_mark_ = 1;
    if( edge_ptr->reverse()->face() )
      edge_ptr->reverse()->face()->private_mark_ = 1;
    PST_Face* fface_ptr = edge_ptr->forward()->face();
    PST_Face* rface_ptr = edge_ptr->reverse()->face();
    if( fface_ptr && fface_ptr->private_mark_ )
      fface_ptr->private_mark_ = 0;
      faces.append( fface_ptr );
    if( rface_ptr && rface_ptr->private_mark_ )
      rface_ptr->private_mark_ = 0;
      faces.append( rface_ptr );
Definition at line 283 of file PST_Data.hpp.
      { return &forward_; }
PST_Edge * PST_Edge::insert_in_face ( PST_Point end,
PST_CoEdge after_this
) [static]
Definition at line 507 of file PST_Data.cpp.
  if( end->edge_ )
    return 0;
  PST_Point* start = after_this->end_point();
  PST_Edge* new_edge = new PST_Edge( start, end );
  new_edge->forward_.next_ = new_edge->reverse();
  new_edge->reverse_.next_ = after_this->next_;
  new_edge->forward_.face_ = new_edge->reverse_.face_ = after_this->face_;
  after_this->next_ = new_edge->forward();
  after_this->face_->modified(true);
  return new_edge;
void PST_Edge::make_facets ( GMem gmem,
double  tolerance,
) [static]
Definition at line 902 of file PST_Data.cpp.
  assert(gmem.fListCount % 4 == 0);
  std::vector<double> points(gmem.pointListCount*3);
  std::vector<int> facets(gmem.fListCount*3/4);
  int i;
  GPoint* pitor = gmem.point_list();
  std::vector<double>::iterator ditor = points.begin();
  for ( i = gmem.pointListCount; i--; )
    *ditor++ = pitor->x;
    *ditor++ = pitor->y;
    *ditor++ = pitor->z;
    pitor++;
  int* fitor = gmem.facet_list();
  std::vector<int>::iterator iitor = facets.begin();
  for ( i = 0; i < gmem.fListCount; i += 4 )
    assert( *fitor++ == 3 );
    *iitor++ = *fitor++;
  make_facets( points, facets, tolerance, edge_list );
void PST_Edge::make_facets ( const std::vector< double > &  coordinates,
const std::vector< int > &  connections,
double  tolerance,
DLIList< PST_Edge * > &  edge_list
) [static]
Definition at line 932 of file PST_Data.cpp.
  double tol_sqr = tolerance * tolerance;
  int i, j, k, numcoords, numtriangles;
  numcoords = coordinates.size()/3;
  numtriangles = connections.size()/3;
  //The list of points created.
  PST_Point** ptlist = new PST_Point*[numcoords];
  //The list of indices into ptlist, where the index into this
  //list is the same as the index into the point list, and
  //the value in this list is the index of the corresponding
  //point in ptlist.  This is used because some points will
  //be merged due to the tolerance.
  int* ptindex_list = new int[numcoords];
  //Create the points
  k = 0;
  for( i = 0; i < numcoords; i++ )
    CubitVector pos( coordinates[3*i], coordinates[3*i+1], coordinates[3*i+2] );
    //Check if we need to merge this point with a different point
    for( j = 0; j < k; j++ )
      if( (*(ptlist[j]) - pos).length_squared() <= tol_sqr )
        break;
    if( j == k )
      ptlist[k] = new PST_Point( pos );
      ptlist[k++]->sequence = i;
    ptindex_list[i] = j;
  int fail_count = 0;
  for ( i = 0; i < numtriangles; i++ )
    int i1 = ptindex_list[connections[3*i  ]];
    int i2 = ptindex_list[connections[3*i+1]];
    int i3 = ptindex_list[connections[3*i+2]];
    if ( i1 == i2 || i2 == i3 || i3 == i1 )
      PRINT_ERROR("Degenerate facet encountered in PST_Edge::make_facets()\n");
      fail_count++;
    else
      PST_Face* new_face
        = PST_Edge::create_face( ptlist[i1], ptlist[i2], ptlist[i3] );
      if( new_face ){
        face_list.append(new_face);
        new_face->sequence = i;
      else{
        fail_count++;
  if( fail_count > 0 )
    PRINT_ERROR("Failed to construct %d facets in PST_Data::make_facets(..)\n",
      fail_count);
  delete [] ptindex_list;
  delete [] ptlist;
  if(fail_count == 0)
    PST_Edge::edges( face_list, edge_list );
    validate( edge_list, true );
    bool debug1 = false;
    if (debug1)
      debug_draw_edges( edge_list, CUBIT_BLUE_INDEX, CUBIT_RED_INDEX, true );
void PST_Edge::make_gmem ( GMem gmem,
DLIList< PST_Face * > &  facets
) [static]
Definition at line 640 of file PST_Data.cpp.
  DLIList<PST_Point*> point_list, temp_list;
  int i, j, pcount, fcount;
  for( i = facets.size(); i--; )
    PST_Face* facet = facets.get_and_step();
//    if( facet->boundary() )
//      continue;
    temp_list.clean_out();
    facet->append_points( temp_list );
    for( j = temp_list.size(); j--; )
      temp_list.get_and_step()->mark = -1;
  pcount = 0;
  fcount = 0;
//      continue;
    fcount += temp_list.size() + 1;
      PST_Point* pt_ptr = temp_list.get_and_step();
      if( pt_ptr->mark == -1 )
        pt_ptr->mark = pcount++;
        point_list.append( pt_ptr );
  gmem.allocate_tri( facets.size() );
  gmem.pointListCount = point_list.size();
  GPoint* pt_array = gmem.point_list();
  point_list.reset();
  for( i = 0; i < point_list.size(); i++ )
    PST_Point* pt_ptr = point_list.get_and_step();
    pt_array[i].x = float(pt_ptr->x());
    pt_array[i].y = float(pt_ptr->y());
    pt_array[i].z = float(pt_ptr->z());
  gmem.fListCount = facets.size() * 4;
  int* offset = gmem.facet_list();
//    if( facets.get()->boundary() )
//      continue;
    facets.get_and_step()->append_points( temp_list );
    *(offset++) = temp_list.size();
      *(offset++) = temp_list.get_and_step()->mark;
) [static]
Definition at line 711 of file PST_Data.cpp.
  PST_Edge::faces( edges, face_list );
  make_gmem( gmem, face_list );
PST_Edge* PST_Edge::next ( PST_Point pt) [inline]
Definition at line 312 of file PST_Data.hpp.
      { return pt == start_ ? start_next_ :
               pt == end_   ? end_next_ : 0; }
PST_Point* PST_Edge::other ( PST_Point pt) [inline]
Definition at line 278 of file PST_Data.hpp.
      { return PST_OTHER(pt,start_,end_); }
PST_CoEdge* PST_Edge::other ( PST_CoEdge coedge) [inline]
Definition at line 289 of file PST_Data.hpp.
      { return PST_OTHER(coedge,&forward_,&reverse_); }
PST_Face* PST_Edge::other ( PST_Face face) [inline]
Definition at line 295 of file PST_Data.hpp.
      { return PST_OTHER(face,forward_.face(),reverse_.face()); }
PST_Edge * PST_Edge::other ( PST_Point point,
PST_Face face
Definition at line 320 of file PST_Data.cpp.
  PST_Edge *result = 0;
  for( PST_Edge* e = point->next(this); e != this; e = point->next(e) )
    if( e->forward()->face() == face || e->reverse()->face() == face )
      if( result && result != e )
        return 0;
      result = e;
  return result;
void PST_Edge::points ( DLIList< PST_Edge * > &  edges,
) [static]
Definition at line 868 of file PST_Data.cpp.
  int e;
    edge_ptr->start_point()->private_mark_ = 1;
    edge_ptr->end_point()->private_mark_ = 1;
    PST_Point* sp = edge_ptr->start_point();
    PST_Point* ep = edge_ptr->end_point();
    if( sp->private_mark_ )
      sp->private_mark_ = 0;
      points.append( sp );
    if( ep->private_mark_ )
      ep->private_mark_ = 0;
      points.append( ep );
CubitVector PST_Edge::position ( double  t) [inline]
Definition at line 263 of file PST_Data.hpp.
      { return start_coord() + t * direction(); }
void PST_Edge::print ( )
Definition at line 1233 of file PST_Data.cpp.
  PRINT_INFO("Edge %p:  Points:  Start: %p  End: %p   Faces:  Forward: %p  Reverse: %p\n",
    (void*)this, (void*)start_, (void*)end_, (void*)forward_.face_, (void*)reverse_.face_ );
void PST_Edge::remove_end_point ( ) [inline, private]
Definition at line 343 of file PST_Data.hpp.
void PST_Edge::remove_point ( PST_Point *&  ptr,
PST_Edge *&  next
) [private]
Definition at line 581 of file PST_Data.cpp.
  if( next == this )
    ptr->edge_ = 0;
    next= 0;
    ptr = 0;
    return;
  PST_Edge* prev = next;
  while( prev->next(ptr) != this )
    prev = prev->next(ptr);
    assert( prev != next );
  if( prev->start_next_ == this )
    prev->start_next_ = next;
  else
    assert(prev->end_next_ == this);
    prev->end_next_ = next;
  if( ptr->edge_ == this )
    ptr->edge_ = next;
void PST_Edge::remove_start_point ( ) [inline, private]
Definition at line 342 of file PST_Data.hpp.
Definition at line 286 of file PST_Data.hpp.
      { return &reverse_; }
CubitSense PST_Edge::sense ( PST_Face face) [inline]
Definition at line 547 of file PST_Data.hpp.
  CubitSense result = CUBIT_UNKNOWN;
    result = CUBIT_FORWARD;
    result = (result != CUBIT_UNKNOWN) ? CUBIT_UNKNOWN : CUBIT_REVERSED;
  return result;
CubitSense PST_Edge::sense ( PST_CoEdge coedge) [inline]
Definition at line 303 of file PST_Data.hpp.
      { return coedge == forward() ? CUBIT_FORWARD  :
               coedge == reverse() ? CUBIT_REVERSED : CUBIT_UNKNOWN; }
void PST_Edge::set_end_point ( PST_Point pt) [inline, private]
Definition at line 348 of file PST_Data.hpp.
      { set_point( pt, end_, end_next_ ); }
void PST_Edge::set_point ( PST_Point pt,
PST_Point *&  ptr,
PST_Edge *&  next
) [private]
Definition at line 550 of file PST_Data.cpp.
  if( ptr )
    remove_point( ptr, next );
  if( pt->edge_ )
    if( pt->edge()->start_point() == pt )
      next = pt->edge()->start_next_;
      pt->edge()->start_next_ = this;
    else
      assert( pt->edge()->end_point() == pt );
      next = pt->edge()->end_next_;
      pt->edge()->end_next_ = this;
  else
    next = this;
    pt->edge_ = this;
  ptr = pt;
void PST_Edge::set_start_point ( PST_Point pt) [inline, private]
Definition at line 346 of file PST_Data.hpp.
Definition at line 524 of file PST_Data.cpp.
  if( point->edge_ )
    return 0;
  PST_Edge* new_edge = new PST_Edge( point, end_ );
  if (forward()->face()) {
    new_edge->forward_.face_ = forward_.face_;
    new_edge->forward_.next_ = forward_.next_;
    forward_.next_ = new_edge->forward();
    forward_.face_->modified(true);
  if (reverse()->face()) {
    new_edge->reverse_.face_ = reverse_.face_;
    new_edge->reverse_.next_ = reverse();
    reverse_.previous()->next_ = new_edge->reverse();
    reverse_.face_->modified(true);
  set_end_point(point);
  return new_edge;
PST_Edge * PST_Edge::split_face ( PST_Point start,
PST_Point end,
PST_Face hint = 0
) [static]
Definition at line 391 of file PST_Data.cpp.
  if( !start->edge_ || !end->edge_ )
    return 0;
  if( ! face )
    PST_Edge* start_edge = start->edge();
    do
      PST_Face* curr_face = start_edge->forward()->face();
      PST_Face* rev_face = start_edge->reverse()->face();
      while( true )
        PST_CoEdge* coe = curr_face->coedge_;
        do
          if( coe->other( end ) )
            if( face ) return 0;
            face = curr_face;
            curr_face = rev_face;
            break;
          coe = coe->next();
        } while( coe != curr_face->coedge_ );
        if( curr_face == rev_face )
          break;
        else
      start_edge = start_edge->next(start);
    } while( start_edge != start->edge() );
    if( !face ) return 0;
  PST_CoEdge* start_coedge = 0;
  PST_CoEdge*   end_coedge = 0;
  PST_CoEdge* coedge = face->coedge_;
  do
    if( coedge->end_point() == start )
      start_coedge = coedge;
      break;
  } while( coedge != face->coedge_ );
  if( ! start_coedge )
    return 0;
  coedge = start_coedge->next();
  PST_CoEdge* stop = start_coedge;
  do
    if( coedge->end_point() == end )
      end_coedge = coedge;
      break;
  } while( coedge != stop );
  if( ! end_coedge )
    return 0;
  return split_face( start_coedge, end_coedge );
PST_Edge * PST_Edge::split_face ( PST_CoEdge after_coedge_1,
PST_CoEdge after_coedge_2
) [static]
Definition at line 473 of file PST_Data.cpp.
  PST_Point* point1 = coedge1->end_point();
  PST_Point* point2 = coedge2->end_point();
  if( (coedge1->edge()      == coedge2->edge() ) ||
      (coedge1->face()      != coedge2->face() ) ||
      (point1               == point2          ) ||
      ( point1->common( point2 )               ) )
    return 0;
  PST_Edge* new_edge = new PST_Edge( point1, point2 );
  new_edge->forward_.next_ = coedge2->next_;
  new_edge->reverse_.next_ = coedge1->next_;
  coedge1->next_ = new_edge->forward();
  coedge2->next_ = new_edge->reverse();
  PST_Face* old_face = coedge1->face();
  PST_Face* new_face = new PST_Face( new_edge->forward(), old_face );
  //new_face->boundary(0);
  old_face->coedge_ = new_edge->reverse();
  new_edge->reverse_.face_ = old_face;
  coedge1 = new_edge->forward();
  do
    coedge1->face_ = new_face;
    coedge1 = coedge1->next();
  } while( coedge1 != new_edge->forward() );
  return new_edge;
const CubitVector& PST_Edge::start_coord ( ) [inline]
Definition at line 253 of file PST_Data.hpp.
      { return *start_; }
Definition at line 247 of file PST_Data.hpp.
      { return start_; }
int PST_Edge::validate ( DLIList< PST_Edge * > &  edges,
CubitBoolean  print = CUBIT_FALSE
) [static]
Definition at line 1200 of file PST_Data.cpp.
  DLIList<PST_Face*> faces;
  PST_Edge::faces( edges, faces );
  int result = 0;
  for( int f = faces.size(); f--; )
    result += faces.get_and_step()->validate(print);
  return result;
Definition at line 1029 of file PST_Data.cpp.
  int result = 0;
  int count = 0;
  PST_Edge* edge = 0;
  if( !start_ )
    if( print ) PRINT_ERROR("Edge %p has null start point.\n", (void*)this);
    result++;
  else
    result += start_->validate(print);
    edge = this;
    count = 0;
    do
      if( count++ > PST_MAX_LIST_LEN )
        if( print )
          PRINT_ERROR("Bad edge list around Point %p.\n", (void*)start_);
        result++;
        break;
      edge = edge->next( start_ );
    } while( edge != this );
  if( !end_ )
    if( print ) PRINT_ERROR("Edge %p has null end point.\n", (void*)this);
    result++;
  else
    result += end_->validate(print);
    count = 0;
    edge = this;
    do
        if( print )
          PRINT_ERROR("Bad edge list around Point %p.\n", (void*)end_);
        result++;
        break;
      edge = edge->next( end_ );
  if (forward_.face_ && !forward_.next_)
    if( print )
      PRINT_ERROR("Forward CoEdge on Edge %p as Face %p but no next().\n",
        (void*)this, (void*)forward_.face_);
    count++;
  if (reverse_.face_ && !reverse_.next_)
    if( print )
      PRINT_ERROR("Reverse CoEdge on Edge %p as Face %p but no next().\n",
        (void*)this, (void*)reverse_.face_);
    count++;
  if (!forward_.face_ && forward_.next_)
    if( print )
      PRINT_ERROR("Forward CoEdge on Edge %p as %p as next CoEdge but no Face.\n",
        (void*)this, (void*)forward_.next_);
    count++;
  if (!reverse_.face_ && reverse_.next_)
    if( print )
      PRINT_ERROR("Reverse CoEdge on Edge %p as %p as next CoEdge but no Face.\n",
        (void*)this, (void*)reverse_.next_);
    count++;
  return result;
Member Data Documentation
Definition at line 352 of file PST_Data.hpp.
Definition at line 354 of file PST_Data.hpp.
Definition at line 356 of file PST_Data.hpp.
Definition at line 336 of file PST_Data.hpp.
Definition at line 339 of file PST_Data.hpp.
Definition at line 357 of file PST_Data.hpp.
Definition at line 351 of file PST_Data.hpp.
Definition at line 353 of file PST_Data.hpp.
