cgma
PeriodicParamTool Class Reference
#include <PeriodicParamTool.hpp>
Inheritance diagram for PeriodicParamTool:
ParamTool
List of all members.
Public Member Functions
 PeriodicParamTool (Surface *surf)
 ~PeriodicParamTool ()
CubitStatus set_up_space (double u_period, double v_period, double u_offset, double v_offset)
CubitStatus transform_to_uv (const CubitVector &xyz_location, CubitVector &uv_location)
CubitStatus transform_to_xyz (CubitVector &xyz_location, const CubitVector &uv_location)
void mirror_surface (bool true_false)
CubitStatus uv_derivitives (double u_param, double v_param, CubitVector &du, CubitVector &dv)
Private Attributes
SurfacerefSurf
double uPeriod
double vPeriod
double uOffset
double vOffset
bool mirrorSurface
Detailed Description
Definition at line 26 of file PeriodicParamTool.hpp.
Definition at line 28 of file PeriodicParamTool.cpp.
    //- update private variables
    refSurf = surf;
    uOffset = 0.0;
    vOffset = 0.0;
  uPeriod = 0.0;
  vPeriod = 0.0;
  mirrorSurface = false;
Member Function Documentation
void PeriodicParamTool::mirror_surface ( bool  true_false)
Definition at line 134 of file PeriodicParamTool.cpp.
  mirrorSurface = true_false;
  if (mirrorSurface)
    PRINT_INFO("Loops appear backwards, mirroring surface...\n");
CubitStatus PeriodicParamTool::set_up_space ( double  u_period,
double  v_period,
double  u_offset,
double  v_offset
Definition at line 54 of file PeriodicParamTool.cpp.
    // store the u and periods
    uPeriod = u_period;
    vPeriod = v_period;
    uOffset = u_offset;
    vOffset = v_offset;
    CubitStatus rv = CUBIT_SUCCESS;
    return rv;
CubitStatus PeriodicParamTool::transform_to_uv ( const CubitVector xyz_location,
CubitVector uv_location
) [virtual]
Implements ParamTool.
Definition at line 75 of file PeriodicParamTool.cpp.
    double u,v;
    CubitStatus rv = refSurf->u_v_from_position(xyz_location, u, v);
    // offset values to avoid parameter discontinuity
    if (uPeriod && u < uOffset)
        u += uPeriod;
  // mirror surface if required to get correct loop orientation
  if (mirrorSurface)
    u = -u;
    if (vPeriod && v < vOffset)
        v += vPeriod;
    uv_location.set(u,v,1.0);
    return rv;
CubitStatus PeriodicParamTool::transform_to_xyz ( CubitVector xyz_location,
const CubitVector uv_location
) [virtual]
Definition at line 112 of file PeriodicParamTool.cpp.
    double u = uv_location.x();
  if (mirrorSurface)
    u = -u;
    if (u > uPeriod)
        u = u - uPeriod;
    double v = uv_location.y();
    if (v > vPeriod)
        v = v - vPeriod;
    xyz_location = refSurf->position_from_u_v(u,v);
    return CUBIT_SUCCESS;
CubitStatus PeriodicParamTool::uv_derivitives ( double  u_param,
double  v_param,
CubitVector du,
CubitVector dv
) [virtual]
Reimplemented from ParamTool.
Definition at line 142 of file PeriodicParamTool.cpp.
  if (mirrorSurface)
    u_param = -u_param;
  if (u_param > uPeriod)
    u_param = u_param-uPeriod;
  if (v_param > vPeriod)
    v_param = v_param-vPeriod;
  refSurf->uv_derivitives(u_param, v_param, du, dv);
Member Data Documentation
Definition at line 54 of file PeriodicParamTool.hpp.
Definition at line 49 of file PeriodicParamTool.hpp.
double PeriodicParamTool::uOffset [private]
Definition at line 52 of file PeriodicParamTool.hpp.
double PeriodicParamTool::uPeriod [private]
Definition at line 50 of file PeriodicParamTool.hpp.
double PeriodicParamTool::vOffset [private]
Definition at line 53 of file PeriodicParamTool.hpp.
double PeriodicParamTool::vPeriod [private]
Definition at line 51 of file PeriodicParamTool.hpp.
