cgma
TDOctreeRefEdge Class Reference
#include <TDOctreeRefEdge.hpp>
Inheritance diagram for TDOctreeRefEdge:
ToolData
List of all members.
Public Member Functions
 TDOctreeRefEdge ()
 ~TDOctreeRefEdge ()
CubitBoolean get_visit (void)
void set_visit (CubitBoolean type)
void clean_gpoint_list (void)
void set_mref_edge (RefEdge *ptr_mref_edge)
GPointget_head_gpoint ()
int get_gpoint_list_length (void)
CubitBoolean generate_gpoint_list (double decimation_ang)
Static Public Member Functions
static int is_td_skl_mref_edge (const ToolData *td)
static CubitStatus add_td (RefEdge *mref_edge)
static TDOctreeRefEdgeget_td (RefEdge *mref_edge)
static void decimate_curve_points_for_source_entity (GMem &point_data, double angle_tolerance, GMem &result_point_data)
static CubitBoolean find_curve_curvature_using_three_points (CubitVector point_a, CubitVector point_b, CubitVector point_c, CubitVector &curvature)
Private Attributes
GMemresultPointData
RefEdgerefEdge
CubitBoolean visit
Detailed Description
Definition at line 21 of file TDOctreeRefEdge.hpp.
Definition at line 25 of file TDOctreeRefEdge.cpp.
  clean_gpoint_list();
    //PRINT_INFO("Inside ~TDOctreeRefEdge\n");
Member Function Documentation
CubitStatus TDOctreeRefEdge::add_td ( RefEdge mref_edge) [static]
Definition at line 43 of file TDOctreeRefEdge.cpp.
  ToolData *td;
  td = mref_edge->get_TD(&TDOctreeRefEdge::is_td_skl_mref_edge);
  if ( td == NULL )
    TDOctreeRefEdge *td_gm = new TDOctreeRefEdge;
    mref_edge->add_TD( td_gm);
    td_gm->set_mref_edge( mref_edge );
  else
    TDOctreeRefEdge *td_gm = CAST_TO(td, TDOctreeRefEdge);
  return CUBIT_SUCCESS;
Definition at line 30 of file TDOctreeRefEdge.cpp.
  delete resultPointData;
void TDOctreeRefEdge::decimate_curve_points_for_source_entity ( GMem point_data,
GMem result_point_data
) [static]
Definition at line 85 of file TDOctreeRefEdge.cpp.
    // pointListCount instead of point_data.point_list_size()  (they are different)
  int num_pre_points = point_data.pointListCount;
    // only decimate if we have more than 2 points
  if(num_pre_points <= 2)
    result_point_data = point_data;
    return;
    // get threshold value
  const double threshold = cos( DEGREES_TO_RADIANS(angle_tolerance) );
    // mark array for what to keep and throw
  char* mark_array = new char[num_pre_points];
    // zero means keep the point, non-zero means remove the point
  memset(mark_array, 0, num_pre_points);
  int num_points_to_keep = 2;   // initialize to keep start and end points
  int i;
  GPoint* point_data_array = point_data.point_list();
    // initialize first point
  GPoint* pre_point = &(point_data_array[0]);
    // traverse all but start and end points
  for(i=1; i<(num_pre_points-1); i++)
      // create two vectors
      // one from i-1 to i and another from i to i+1
    GPoint* point = &(point_data_array[i]);
    GPoint* next_point = &(point_data_array[i+1]);
    CubitVector v1(CubitVector(pre_point->x, pre_point->y, pre_point->z),
                   CubitVector(point->x, point->y, point->z));
    v1.normalize();
    CubitVector v2(CubitVector(point->x, point->y, point->z),
                   CubitVector(next_point->x, next_point->y, next_point->z));
    v2.normalize();
      // compute whether to keep the point
    double dot_product = v1 % v2;
    bool keep = dot_product > threshold ? false : true;
      // if keep
    if(keep)
      num_points_to_keep++;
      pre_point = point;
      // if not keep
    else
      mark_array[i] = 1;
    // make a new GPoint array
  GPoint* new_point_list = new GPoint[num_points_to_keep];
  int new_point_list_count = 0;
    // copy points to keep into the new array
  for(i=0; i<num_pre_points; i++)
    if(mark_array[i] == 0)
      new_point_list[new_point_list_count] = point_data_array[i];
      new_point_list_count++;
  delete [] mark_array;
  assert(new_point_list_count == num_points_to_keep);
    //printf("reduced points from %i to %i\n", num_pre_points, num_points_to_keep);
    // put data into the result gmem
  result_point_data.replace_point_list(new_point_list, new_point_list_count, new_point_list_count);
  result_point_data.points_consolidated(CUBIT_TRUE);
Definition at line 189 of file TDOctreeRefEdge.cpp.
  CubitVector vec_ba, vec_bc;
  vec_ba = point_a - point_b;
  vec_bc = point_c - point_b;
    // Squares of lengths of the edges incident to `a'.
  double ba_length = vec_ba.length_squared();
  double bc_length = vec_bc.length_squared();
    // Cross product of these edges.
    // (Take your chances with floating-point roundoff.)
  CubitVector cross = vec_ba * vec_bc;
    // Calculate the denominator of the formulae.
  double denominator = 0.5 / (cross % cross);
  assert(denominator != 0.0);
    // Calculate offset (from `a') of circumcenter.
  CubitVector circle_center  = (ba_length * vec_bc - bc_length * vec_ba) * cross;
  circle_center *= denominator;
    //store radius
  double radius = circle_center.length();
  circle_center.normalize();
  circle_center /= radius;
  curvature = circle_center;
  return CUBIT_TRUE;
Definition at line 169 of file TDOctreeRefEdge.cpp.
    // get facets from cgm
  GMem point_data;
  refEdge->get_graphics( point_data );
    // decimate the facets to the resolution we want
  TDOctreeRefEdge::decimate_curve_points_for_source_entity( point_data, decimation_ang, *resultPointData);
  return CUBIT_TRUE;
int TDOctreeRefEdge::get_gpoint_list_length ( void  ) [inline]
Definition at line 51 of file TDOctreeRefEdge.hpp.
Definition at line 49 of file TDOctreeRefEdge.hpp.
{ return resultPointData->point_list(); }
TDOctreeRefEdge * TDOctreeRefEdge::get_td ( RefEdge mref_edge) [static]
Definition at line 70 of file TDOctreeRefEdge.cpp.
  ToolData *td;
  if ( td != NULL )
    return td_gm;
  return (TDOctreeRefEdge*) NULL;
Definition at line 39 of file TDOctreeRefEdge.hpp.
{ return visit; }
static int TDOctreeRefEdge::is_td_skl_mref_edge ( const ToolData td) [inline, static]
Definition at line 47 of file TDOctreeRefEdge.hpp.
{return (CAST_TO(const_cast<ToolData*>(td), TDOctreeRefEdge) != NULL);}
void TDOctreeRefEdge::set_mref_edge ( RefEdge ptr_mref_edge) [inline]
Definition at line 45 of file TDOctreeRefEdge.hpp.
{ refEdge = ptr_mref_edge; }
void TDOctreeRefEdge::set_visit ( CubitBoolean  type) [inline]
Definition at line 40 of file TDOctreeRefEdge.hpp.
{ visit = type; }
Member Data Documentation
Definition at line 28 of file TDOctreeRefEdge.hpp.
Definition at line 27 of file TDOctreeRefEdge.hpp.
Definition at line 29 of file TDOctreeRefEdge.hpp.
