cgma
VirtualImprintTool Class Reference
#include <VirtualImprintTool.hpp>
List of all members.
Static Public Member Functions
static CubitStatus virtual_imprint (RefFace *ref_face1, RefFace *ref_face2, DLIList< RefFace * > &results, double feature_size, CubitBoolean &curves_modified)
static CubitStatus virtual_imprint (DLIList< RefFace * > &input_faces, DLIList< RefFace * > &surf_results, double feature_size, CubitBoolean &curves_modified)
static CubitStatus virtual_imprint (RefVolume *ref_volume1, RefVolume *ref_volume2, DLIList< RefVolume * > &vol_results, double feature_size, CubitBoolean &others_modified)
static CubitStatus virtual_imprint (DLIList< RefVolume * > &imprint_volumes, DLIList< RefVolume * > &vol_results, double feature_size, CubitBoolean &others_modified)
Protected Member Functions
 VirtualImprintTool ()
 ~VirtualImprintTool ()
Static Private Attributes
static CubitBoolean useRealIntersection = CUBIT_FALSE
Detailed Description
Definition at line 24 of file VirtualImprintTool.hpp.
Definition at line 23 of file VirtualImprintTool.cpp.
Constructor. This shouldn't get called since all of the functions are static.
Definition at line 29 of file VirtualImprintTool.cpp.
Member Function Documentation
CubitStatus VirtualImprintTool::virtual_imprint ( RefFace ref_face1,
RefFace ref_face2,
DLIList< RefFace * > &  results,
CubitBoolean curves_modified
) [static]
Destructor shouldn't do anything because it never allocates its own members
Definition at line 36 of file VirtualImprintTool.cpp.
  if ( useRealIntersection )
/*    SurfaceImprintTool imp_tool(feature_size);
    CubitStatus stat = imp_tool.imprint_surface(ref_face1, ref_face2, results);
    if (stat != CUBIT_SUCCESS )
      return stat;
    curves_modified = imp_tool.curves_modified();
    return CUBIT_SUCCESS;
    return CUBIT_FAILURE;
  else
    ImprintBoundaryTool ib_tool(ref_face1, ref_face2, feature_size);
    CubitStatus stat=ib_tool.imprint(results, CUBIT_FALSE);
      return stat;
    if ( ib_tool.modified_bound_1() || ib_tool.modified_bound_2() )
      curves_modified = CUBIT_TRUE;
CubitStatus VirtualImprintTool::virtual_imprint ( DLIList< RefFace * > &  input_faces,
DLIList< RefFace * > &  surf_results,
) [static]
Uses virtual geometry to imprint the two surfaces.
Definition at line 68 of file VirtualImprintTool.cpp.
  int ii, jj;
    //Do the n^2 thing, imprint every volume against every other volume...
  DLIList <RefFace*> faces_stack = input_faces, ref_faces_close, tmp_results;
  RefFace *curr_face, *canidate_face;
  while ( faces_stack.size() > 0 )
    curr_face = faces_stack.pop();
    curr_face->marked(1);
    ref_faces_close.clean_out();
    CubitBox curr_box = curr_face->bounding_box();
    for ( jj = input_faces.size(); jj > 0; jj-- )
      canidate_face = input_faces.get_and_step();
      if ( canidate_face == curr_face || canidate_face->marked() )
        continue;
      CubitBox canidate_box = canidate_face->bounding_box();
      if ( curr_box.overlap(feature_size, canidate_box) )
        ref_faces_close.append(canidate_face);
    for ( jj = ref_faces_close.size(); jj > 0; jj-- )
        //check for interrupt.
      if ( AppUtil::instance()->interrupt() )
        break;
      tmp_results.clean_out();
      canidate_face = ref_faces_close.get_and_step();
      PRINT_INFO("Imprint Surfaces: %d %d\n", curr_face->id(), canidate_face->id() );
      CubitStatus stat = virtual_imprint(curr_face, canidate_face,
                                         tmp_results, feature_size,
                                         curves_modified);
      if ( stat != CUBIT_SUCCESS )
        PRINT_ERROR("Problems imprinting Surface %d and %d\n",
                    curr_face->id(), canidate_face->id());
        return stat;
      if ( tmp_results.size() )
        faces_stack.remove(canidate_face);
        input_faces.remove(curr_face);
        input_faces.remove(canidate_face);
        int ll;
        for ( ll = tmp_results.size(); ll > 0; ll-- )
          canidate_face = tmp_results.get_and_step();
          canidate_face->marked(0);
          faces_stack.append(canidate_face);
          input_faces.append(canidate_face);
        surf_results += tmp_results;
        break;
        //just break out and still clean up marks and stuff...
      break;
  for ( ii = 0; ii < surf_results.size(); ii++ )
    surf_results.get_and_step()->marked(0);
  DLIList <RefFace*> tmp_list;
    curr_face = surf_results.get_and_step();
    if ( curr_face->marked() )
      continue;
    else
      tmp_list.append(curr_face);
  surf_results.clean_out();
  for ( ii = 0; ii < tmp_list.size(); ii++ )
    curr_face = tmp_list.get_and_step();
    curr_face->marked(0);
    surf_results.append(curr_face);
CubitStatus VirtualImprintTool::virtual_imprint ( RefVolume ref_volume1,
RefVolume ref_volume2,
DLIList< RefVolume * > &  vol_results,
CubitBoolean others_modified
) [static]
imprint multiple surfaces.
Definition at line 161 of file VirtualImprintTool.cpp.
  CubitBoolean ref_1_mod=CUBIT_FALSE, ref_2_mod = CUBIT_FALSE;
  curves_modified = CUBIT_FALSE;
    //First make sure the bounding boxes are close...
  CubitBox ref_vol1_box = ref_volume1->bounding_box();
  CubitBox ref_vol2_box = ref_volume2->bounding_box();
  if ( !ref_vol1_box.overlap(feature_size, ref_vol2_box) )
    //Now get the list of surfaces for imprinting.
  DLIList <RefFace*> ref_faces1, ref_faces2, ref_faces_close;
  DLIList <RefFace*> faces1_stack, tmp_faces1,tmp_faces2, tmp_output;
  DLIList <RefVolume*> tmp_vols;
  RefFace *curr_ref_face, *canidate_ref_face;
  ref_volume1->ref_faces(ref_faces1);
  ref_volume2->ref_faces(ref_faces2);
  int ii, jj;
  CubitStatus stat;
    //loop over the the ref_faces from the first list.
    //Get all the reffaces that are within tolerance of its
    //bounding box.
  for ( ii = ref_faces1.size(); ii > 0; ii-- )
    curr_ref_face = ref_faces1.get_and_step();
    CubitBox curr_box = curr_ref_face->bounding_box();
    //do this everytime to get the most up-to-date ones...
    ref_faces2.clean_out();
    for ( jj = ref_faces2.size(); jj > 0; jj-- )
      canidate_ref_face = ref_faces2.get_and_step();
      CubitBox canidate_box = canidate_ref_face->bounding_box();
        ref_faces_close.append(canidate_ref_face);
      //Now imprint the faces that are close with the curr_ref_face.
    faces1_stack.clean_out();
    faces1_stack.append( curr_ref_face);
    while( faces1_stack.size() && (curr_ref_face = faces1_stack.pop()) != NULL &&
           ref_faces_close.size() > 0 )
        break;
      while (ref_faces_close.size() && (canidate_ref_face = ref_faces_close.pop()) != NULL )
        tmp_output.clean_out();
        stat = virtual_imprint(curr_ref_face,canidate_ref_face,
                               tmp_output, feature_size, curves_modified );
          return stat;
          break;
        //Now sort the faces in tmp_output into two lists associated
        //with the owning volumes...
        for ( jj = tmp_output.size(); jj > 0;jj-- )
          RefFace *ref_face = tmp_output.get_and_step();
          tmp_vols.clean_out();
          ref_face->ref_volumes(tmp_vols);
          if ( tmp_vols.move_to(ref_volume1) )
            ref_1_mod = CUBIT_TRUE;
            tmp_faces1.append(ref_face);
          else
            ref_2_mod = CUBIT_TRUE;
            tmp_faces2.append(ref_face);
        if ( tmp_faces1.size() > 0 )
          break;
      faces1_stack += tmp_faces1;
      ref_faces_close += tmp_faces2;
      tmp_faces1.clean_out();
      tmp_faces2.clean_out();
      break;
  if ( ref_1_mod )
    vol_results.append(ref_volume1);
  if ( ref_2_mod )
    vol_results.append(ref_volume2);
CubitStatus VirtualImprintTool::virtual_imprint ( DLIList< RefVolume * > &  imprint_volumes,
) [static]
Uses virtual geometry to imprint the two volumes.
Definition at line 265 of file VirtualImprintTool.cpp.
  int ii, jj;
  DLIList <RefVolume*> marked_vols;
  DLIList <RefVolume*> vols_stack = input_vols, ref_vols_close;
  RefVolume *curr_volume, *canidate_volume;
  while ( vols_stack.size() > 0 )
      break;
    curr_volume = vols_stack.pop();
    curr_volume->marked(1);
    marked_vols.append(curr_volume);
    ref_vols_close.clean_out();
    CubitBox curr_box = curr_volume->bounding_box();
    for ( jj = input_vols.size(); jj > 0; jj-- )
      canidate_volume = input_vols.get_and_step();
      if ( canidate_volume == curr_volume || canidate_volume->marked() )
        continue;
      CubitBox canidate_box = canidate_volume->bounding_box();
        ref_vols_close.append(canidate_volume);
    for ( jj = ref_vols_close.size(); jj > 0; jj-- )
        break;
      canidate_volume = ref_vols_close.get_and_step();
      PRINT_INFO("Imprint Volumes: %d %d\n", curr_volume->id(), canidate_volume->id() );
      CubitStatus stat = virtual_imprint(curr_volume, canidate_volume,
                                         vol_results, feature_size,
                                         curves_modified);
        PRINT_ERROR("Problems imprinting volume %d and %d\n",
                    curr_volume->id(), canidate_volume->id());
        return stat;
  DLIList <RefVolume*> tmp_list;
  for ( ii = 0; ii < vol_results.size(); ii++ )
    curr_volume = vol_results.get_and_step();
    if ( curr_volume->marked() )
      continue;
    else
      tmp_list.append(curr_volume);
  vol_results.clean_out();
    curr_volume = tmp_list.get_and_step();
    vol_results.append(curr_volume);
  for ( ii = 0; ii < marked_vols.size(); ii++ )
    marked_vols.get_and_step()->marked(0);
Member Data Documentation
Imprints the volumes in the list against each other.
Definition at line 78 of file VirtualImprintTool.hpp.
