cgma
cylinders.cpp
00001
00010 #undef NDEBUG
00011 #include <cassert>
00012 #include <string>
00013 #include <cctype>
00014 #include <iostream>
00015
00016 #include "GeometryModifyTool.hpp"
00017 #include "GeometryQueryTool.hpp"
00018 #include "CubitMessage.hpp"
00019 #include "Body.hpp"
00020 #include "RefVolume.hpp"
00021 #include "RefFace.hpp"
00022 #include "RefEdge.hpp"
00023 #include "RefVertex.hpp"
00024 #include "InitCGMA.hpp"
00025 #include "CubitCompat.hpp"
00026
00027 #include <algorithm>
00028
00029 #ifndef SRCDIR
00030 # define SRCDIR .
00031 #endif
00032
00033 #define STRINGIFY_(X) #X
00034 #define STRINGIFY(X) STRINGIFY_(X)
00035 #define SRCPATH STRINGIFY(SRCDIR) "/"
00036
00037 #ifdef HAVE_OCC
00038 #define FILENAME "s5.stp"
00039 #endif
00040 // forward declare some functions used and defined later
00041 CubitStatus read_geometry(int, char **, bool local = false);
00042 CubitStatus make_Point();
00043 // macro for printing a separator line
00044 #define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
00045
00046 int findString(const char *filename, std::string search)
00047 {
00048   std::ifstream Myfile;
00049   Myfile.open (filename);
00050   int found = 0;
00051   std::string line;
00052   size_t offset;
00053   if(Myfile.is_open())
00054   {
00055     while(!Myfile.eof())
00056     {
00057       getline(Myfile,line);
00058       if ((offset = line.find(search, 0)) != std::string::npos)
00059         found ++;
00060     }
00061     Myfile.close();
00062   }
00063   return found;
00064 }
00065 // main program - initialize, then send to proper function
00066 int main (int argc, char **argv)
00067 {
00068   CubitStatus status = InitCGMA::initialize_cgma();
00069   if (CUBIT_SUCCESS != status) return 1;
00070
00071   //Do make point.
00072   status = make_Point();
00073   if (status == CUBIT_FAILURE)
00074      PRINT_INFO("Operation Failed");
00075
00076   int ret_val = ( CubitMessage::instance()->error_count() );
00077   if ( ret_val > 0 )
00078   {
00079     PRINT_ERROR("Errors found during Mergechk session.\n");
00080   }
00081   return ret_val;
00082
00083 }
00084
00085 std::string type_from_file_name( const std::string& filename )
00086 {
00087   size_t dot_pos = filename.find_last_of( '.' );
00088   if (dot_pos == std::string::npos)
00089     return std::string();
00090
00091   std::string extension = filename.substr( dot_pos + 1 );
00092   std::transform( extension.begin(), extension.end(), extension.begin(), ::tolower );
00093   if (extension == "occ" || extension == "brep")
00094     return "OCC";
00095   else if (extension == "step" || extension == "stp")
00096     return "STEP";
00097   else if (extension == "iges" || extension == "igs")
00098     return "IGES";
00099   else
00100     return std::string();
00101 }
00102
00107 CubitStatus read_geometry(int num_files, const char **argv, bool local)
00108 {
00109   CubitStatus status = CUBIT_SUCCESS;
00110   GeometryQueryTool *gti = GeometryQueryTool::instance();
00111   assert(gti);
00112   int i;
00113
00114   PRINT_SEPARATOR;
00115
00116   for (i = 0; i < num_files; i++) {
00117     std::string type = type_from_file_name( argv[i] );
00118     if (type.empty()) // just guess OCC
00119       type = "OCC";
00120     std::string filename( local ? "./" : SRCPATH );
00121     char const* local_name = argv[i];
00122     filename += local_name;
00123     status = CubitCompat_import_solid_model(filename.c_str(), type.c_str());
00124     if (status != CUBIT_SUCCESS) {
00125       PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str());
00126       abort();
00127     }
00128   }
00129   PRINT_SEPARATOR;
00130
00131   return CUBIT_SUCCESS;
00132 }
00133
00134 CubitStatus make_Point()
00135 {
00136   GeometryQueryTool *gti = GeometryQueryTool::instance();
00137   GeometryModifyTool *gmti = GeometryModifyTool::instance();
00138
00139   DLIList<Body*> bodies, single_body, all_bodies, neighbor_list, new_bodies;
00140   DLIList<RefEntity*>  free_entities;
00141
00142   const char *argstep = FILENAME;
00143   CubitStatus stat = read_geometry(1, &argstep, false);
00144   //Constructed 12 Volumes: 8 to 19
00145   if (stat == CUBIT_FAILURE) exit(1);
00146
00147   //get all the bodies, use bodies 1-6 to unite and use united body to
00148   //subtract from body 7.
00149   gti->bodies(bodies);
00150   Body* brick = bodies.pop();
00151   all_bodies.append(brick);
00152
00153   stat = gmti->unite(bodies, single_body, CUBIT_FALSE);
00154   assert(CUBIT_SUCCESS == stat && single_body.size() == 1);
00155
00156   stat = gmti->subtract(single_body.get(), all_bodies, new_bodies, CUBIT_FALSE,CUBIT_FALSE);
00157   assert(CUBIT_SUCCESS == stat);
00158
00159   std::cout << "Number of resulting bodies = " << new_bodies.size() << std::endl;
00160   assert(new_bodies.size() == 1);
00161   //delete all entities
00162   bodies.clean_out();
00163   gti->bodies(bodies);
00164   gti->delete_Body(bodies);
00165
00166   free_entities.clean_out();
00167   gti->get_free_ref_entities(free_entities);
00168   assert(free_entities.size() ==0);
00169   return CUBIT_SUCCESS;
00170 }
