cgma
facets.cpp
00001
00008 #ifdef NT
00009 //#include "stdafx.h"
00010 #endif
00011
00012 #include <math.h>
00013 #include "AppUtil.hpp"
00014 #include "CGMApp.hpp"
00015 #include "GeometryQueryTool.hpp"
00016 #include "FacetModifyEngine.hpp"
00017 #include "FacetQueryEngine.hpp"
00018 #include "CubitObserver.hpp"
00019 #include "CubitPointData.hpp"
00020 #include "CubitFacetData.hpp"
00021
00022 #include "TopologyBridge.hpp"
00023 #include "DLIList.hpp"
00024 #include "Surface.hpp"
00025 #include "ShellSM.hpp"
00026 #include "Lump.hpp"
00027 #include "Body.hpp"
00028 #include "RefFace.hpp"
00029 #include "RefVertex.hpp"
00030
00031 extern "C" void gl_cleanup()
00032 {}
00033
00035 int main (int argc, char **argv)
00036 {
00037
00038   if (argc == 1) {
00039     PRINT_INFO("Usage: facets <angle_val>\n"
00040                "  where <angle_val> is the facet dihedral angle below which a\n"
00041                "  model edge will be constructed.\n");
00042     return 0;
00043   }
00044
00045     // first argument should be an angle
00046   double angle = atof(argv[1]);
00047
00048     // Initialize the GeometryTool
00049   GeometryQueryTool *gqt = GeometryQueryTool::instance();
00050   FacetModifyEngine *fme = FacetModifyEngine::instance();
00051
00052   DLIList<CubitFacet*> f_list;
00053   DLIList <CubitPoint*> p_list;
00054
00055     // define some really simple facets, corresponding to the
00056     // facets for a brick
00057   typedef CubitPointData CPD; typedef CubitFacetData CFD;
00058   CPD *p1 = new CPD(0, 0, 0); CPD *p2 = new CPD(1, 0, 0);
00059   CPD *p3 = new CPD(1, 1, 0); CPD *p4 = new CPD(0, 1, 0);
00060   CPD *p5 = new CPD(0, 0, 1); CPD *p6 = new CPD(1, 0, 1);
00061   CPD *p7 = new CPD(1, 1, 1); CPD *p8 = new CPD(0, 1, 1);
00062   p_list.append(p1); p_list.append(p2);
00063   p_list.append(p3); p_list.append(p4);
00064   p_list.append(p5); p_list.append(p6);
00065   p_list.append(p7); p_list.append(p8);
00066   CFD *f1 = new CFD(p1,p3,p2); CFD *f2 = new CFD(p1,p4,p3); // xy-
00067   CFD *f3 = new CFD(p5,p6,p8); CFD *f4 = new CFD(p6,p7,p8); // xy+
00068   CFD *f5 = new CFD(p1,p8,p4); CFD *f6 = new CFD(p1,p5,p8); // yz-
00069   CFD *f7 = new CFD(p3,p7,p6); CFD *f8 = new CFD(p3,p6,p2); // yz+
00070   CFD *f9 = new CFD(p1,p6,p5); CFD *f10 = new CFD(p1,p2,p6); // xz-
00071   CFD *f11 = new CFD(p3,p4,p8); CFD *f12 = new CFD(p3,p8,p7); // xz+
00072   f_list.append(f1); f_list.append(f2); f_list.append(f3);
00073   f_list.append(f4); f_list.append(f5); f_list.append(f6);
00074   f_list.append(f7); f_list.append(f8); f_list.append(f9);
00075   f_list.append(f10); f_list.append(f11); f_list.append(f12);
00076   DLIList<LoopSM*> my_loops;
00077
00078   DLIList<Surface*> surf_list;
00079   CubitStatus result;
00080   result = fme->build_facet_surface(NULL, f_list, p_list, angle, 4,
00081                                     false, false, surf_list);
00082
00083   if ( surf_list.size() == 0 || result != CUBIT_SUCCESS )
00084   {
00085     PRINT_ERROR("Problems building mesh based surfaces.\n");
00086     return result;
00087   }
00088   else
00089     PRINT_INFO("Constructed %d surfaces.\n", surf_list.size());
00090
00091     //Now build the shell.  If we had it set up right this would be
00092     //in a loop.  We need to store list of DLBlockSurfaceLists on each
00093     //blockvolumemesh to store the shell information.  But that will
00094     //be saved for later.
00095   ShellSM *shell_ptr;
00096   result = fme->make_facet_shell(surf_list, shell_ptr);
00097
00098   if ( shell_ptr == NULL || result != CUBIT_SUCCESS )
00099   {
00100     PRINT_ERROR("Problems building mesh based shell entity.\n");
00101     return result;
00102   }
00103   DLIList<ShellSM*> shell_list;
00104   shell_list.append(shell_ptr);
00105   Lump *lump_ptr;
00106   result = fme->make_facet_lump(shell_list, lump_ptr);
00107
00108   if ( lump_ptr == NULL || result != CUBIT_SUCCESS )
00109   {
00110     PRINT_ERROR("Problems building mesh based lump entity.\n");
00111     return result;
00112   }
00113   DLIList<Lump*> lump_list;
00114   lump_list.append(lump_ptr);
00115
00116   BodySM *bodysm_ptr;
00117   Body *body_ptr;
00118   result = fme->make_facet_body(lump_list, bodysm_ptr);
00119
00120   body_ptr = GeometryQueryTool::instance()->make_Body(bodysm_ptr);
00121
00122   if ( body_ptr == NULL || result != CUBIT_SUCCESS )
00123   {
00124     PRINT_ERROR("Problems building mesh based body entity.\n");
00125     return result;
00126   }
00127
00128   if (!body_ptr) {
00129     exit(1);
00130   }
00131
00132   PRINT_INFO("Body successfully created.\n");
00133
00134   PRINT_INFO("Number of vertices = %d\n", gqt->num_ref_vertices());
00135   PRINT_INFO("Number of edges = %d\n", gqt->num_ref_edges());
00136   PRINT_INFO("Number of faces = %d\n", gqt->num_ref_faces());
00137   PRINT_INFO("Number of volumes = %d\n", gqt->num_ref_volumes());
00138   PRINT_INFO("Number of bodies = %d\n", gqt->num_bodies());
00139
00140     // print vertex positions
00141   DLIList<RefVertex*> verts;
00142   gqt->ref_vertices(verts);
00143   int i;
00144   for (i = verts.size(); i > 0; i--) {
00145     CubitVector coords = verts.get_and_step()->coordinates();
00146     PRINT_INFO("Vertex %d: %4.2f, %4.2f, %4.2f.\n",
00147                8-i, coords.x(), coords.y(), coords.z());
00148   }
00149
00150   RefFace *face = gqt->get_first_ref_face();
00151
00152     // find closest point on each coordinate plane face center
00153   CubitVector test_position, result_position, normal;
00154
00155   test_position.set(.5, .5, 0);
00156   face->find_closest_point_trimmed(test_position, result_position);
00157   normal = face->normal_at(result_position);
00158   PRINT_INFO("Point (%4.2f, %4.2f, %4.2f):\n  "
00159              "closest=(%4.2f, %4.2f, %4.2f), normal=(%4.2f, %4.2f, %4.2f).\n",
00160              test_position.x(), test_position.y(), test_position.z(),
00161              result_position.x(), result_position.y(), result_position.z(),
00162              normal.x(), normal.y(), normal.z());
00163
00164   test_position.set(.5, .5, 1);
00165   face->find_closest_point_trimmed(test_position, result_position);
00166   normal = face->normal_at(result_position);
00167   PRINT_INFO("Point (%4.2f, %4.2f, %4.2f):\n  "
00168              "closest=(%4.2f, %4.2f, %4.2f), normal=(%4.2f, %4.2f, %4.2f).\n",
00169              test_position.x(), test_position.y(), test_position.z(),
00170              result_position.x(), result_position.y(), result_position.z(),
00171              normal.x(), normal.y(), normal.z());
00172
00173   test_position.set(.5, 0, .5);
00174   face->find_closest_point_trimmed(test_position, result_position);
00175   normal = face->normal_at(result_position);
00176   PRINT_INFO("Point (%4.2f, %4.2f, %4.2f):\n  "
00177              "closest=(%4.2f, %4.2f, %4.2f), normal=(%4.2f, %4.2f, %4.2f).\n",
00178              test_position.x(), test_position.y(), test_position.z(),
00179              result_position.x(), result_position.y(), result_position.z(),
00180              normal.x(), normal.y(), normal.z());
00181
00182   test_position.set(.5, 1, .5);
00183   face->find_closest_point_trimmed(test_position, result_position);
00184   normal = face->normal_at(result_position);
00185   PRINT_INFO("Point (%4.2f, %4.2f, %4.2f):\n  "
00186              "closest=(%4.2f, %4.2f, %4.2f), normal=(%4.2f, %4.2f, %4.2f).\n",
00187              test_position.x(), test_position.y(), test_position.z(),
00188              result_position.x(), result_position.y(), result_position.z(),
00189              normal.x(), normal.y(), normal.z());
00190
00191   test_position.set(0, .5, .5);
00192   face->find_closest_point_trimmed(test_position, result_position);
00193   normal = face->normal_at(result_position);
00194   PRINT_INFO("Point (%4.2f, %4.2f, %4.2f):\n  "
00195              "closest=(%4.2f, %4.2f, %4.2f), normal=(%4.2f, %4.2f, %4.2f).\n",
00196              test_position.x(), test_position.y(), test_position.z(),
00197              result_position.x(), result_position.y(), result_position.z(),
00198              normal.x(), normal.y(), normal.z());
00199
00200   test_position.set(1, .5, .5);
00201   face->find_closest_point_trimmed(test_position, result_position);
00202   normal = face->normal_at(result_position);
00203   PRINT_INFO("Point (%4.2f, %4.2f, %4.2f):\n  "
00204              "closest=(%4.2f, %4.2f, %4.2f), normal=(%4.2f, %4.2f, %4.2f).\n",
00205              test_position.x(), test_position.y(), test_position.z(),
00206              result_position.x(), result_position.y(), result_position.z(),
00207              normal.x(), normal.y(), normal.z());
00208
00209   double a = 1.0/3.0;
00210   double b = 1.0/3.0;
00211   double c = 1.0/3.0;
00212   CubitVector temp_point(a,b,c);
00213   CubitVector eval_point;
00214
00215   f1->evaluate( temp_point, &eval_point );
00216   PRINT_INFO("Evaluation of facet 1 at (%4.2f, %4.2f, %4.2f) is "
00217              "(%4.2f, %4.2f, %4.2f).\n",
00218               a, b, c, eval_point.x(), eval_point.y(), eval_point.z() );
00219
00220   a = 0.0; b = 1.0; c = 0.0;
00221   temp_point.set(a,b,c);
00222   f2->evaluate( temp_point, &eval_point );
00223   PRINT_INFO("Evaluation of facet 2 at (%4.2f, %4.2f, %4.2f) is (%4.2f, %4.2f, %4.2f).\n",
00224               a, b, c, eval_point.x(), eval_point.y(), eval_point.z() );
00225   a = 0.5; b = 0.5; c = 0.0;
00226   temp_point.set(a,b,c);
00227   f3->evaluate( temp_point, &eval_point );
00228   PRINT_INFO("Evaluation of facet 3 at (%4.2f, %4.2f, %4.2f) is (%4.2f, %4.2f, %4.2f).\n",
00229               a, b, c, eval_point.x(), eval_point.y(), eval_point.z() );
00230   a = 0.0; b = 0.5; c = 0.5;
00231   temp_point.set(a,b,c);
00232   f4->evaluate( temp_point, &eval_point );
00233   PRINT_INFO("Evaluation of facet 4 at (%4.2f, %4.2f, %4.2f) is (%4.2f, %4.2f, %4.2f).\n",
00234               a, b, c, eval_point.x(), eval_point.y(), eval_point.z() );
00235
00236   int ret_val = ( CubitMessage::instance()->error_count() );
00237
00238   FacetQueryEngine * fqe = FacetQueryEngine::instance();
00239   DLIList<TopologyBridge*> model;
00240   model.append( (TopologyBridge*)bodysm_ptr);
00241   ModelExportOptions opts;
00242   const char *arg = "brick.facet";
00243   fqe->export_solid_model(
00244         model, arg, FACET_TYPE,
00245         CubitString(), opts);
00246   PRINT_INFO( "Wrote %s \n", arg);
00247   return ret_val;
00248 }
