cgma
geo_from_stl.cpp
00001 #undef NDEBUG
00002
00003 #include <vector>
00004
00005 #include "InitCGMA.hpp"
00006 #include "CGMApp.hpp"
00007 #include "CubitCompat.hpp"
00008 #include "FacetQueryEngine.hpp"
00009
00010 #include "BodySM.hpp"
00011 #include "Body.hpp"
00012 #include "GeometryQueryTool.hpp"
00013
00014 #include <iostream>
00015
00016 static void print_usage( const char* name, std::ostream& stream )
00017 {
00018   stream << "Usage: " << name << " <input stl file name> [ <angle (degrees)> <tolerance> <output geometry file name> ] " << std::endl;
00019   stream << "     default arguments: angle: 135. tolerance: 1.e-6 output file: out.facet \n";
00020 }
00021
00022 int main( int argc, char** argv ) {
00023
00024   std::vector<CubitString> args;
00025   CGMApp::instance()->startup(args);
00026
00027   if (argc<2)
00028   {
00029     print_usage(argv[0], std::cout);
00030     return 0;
00031   }
00032
00033   const char* filename = argv[1];
00034   const char *out_file = "out.facet";
00035
00036   double angle = 135.;
00037   if (argc>2)
00038     angle = atof(argv[2]);
00039
00040   double tolerance = 1.e-6;
00041   if (argc>3)
00042     tolerance = atof(argv[3]);
00043
00044   if (argc>4)
00045     out_file = argv[4];
00046
00047   CubitStatus status = InitCGMA::initialize_cgma();
00048   if (CUBIT_SUCCESS != status) return 1;
00049
00050   DLIList<CubitQuadFacet*> quad_facet_list;
00051   DLIList<CubitFacet*> tri_facet_list;
00052   DLIList<Surface*> surface_list;
00053   FacetQueryEngine* fqe = FacetQueryEngine::instance();
00054   status = fqe->import_facets(filename, CUBIT_TRUE, angle, tolerance, 4, CUBIT_TRUE,
00055     CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE, quad_facet_list, tri_facet_list,
00056     surface_list, STL_FILE);
00057
00058   // get bodies, then export to a facet file
00059   DLIList<Body*> bodies;
00060   GeometryQueryTool::instance()->bodies(bodies);
00061   PRINT_INFO(" num bodies: %d\n", bodies.size());
00062   //BodySM* bodysm_ptr = body_ptr->get_body_sm_ptr();
00063   DLIList<TopologyBridge*> model;
00064   for (int j=0; j<bodies.size(); j++)
00065   {
00066     BodySM* bodysm_ptr = bodies[j]->get_body_sm_ptr();
00067     model.append( (TopologyBridge*)bodysm_ptr);
00068   }
00069   ModelExportOptions opts;
00070
00071   fqe->export_solid_model(
00072         model, out_file, FACET_TYPE,
00073         CubitString(), opts);
00074   PRINT_INFO( "converted stl %s to %s \n", filename,  out_file);
00075   if (CUBIT_SUCCESS != status) return 1;
00076
00077   return 0;
00078 }
